View Full Version : Honda Accord (1990 - 2002)
- 89 Accord DX choppy/dies/then runs ok
- Engine swap info please
- Need new exhaust: CHEAP
- recalibrate the speedometer in an 87 accord
- Where to buy stock parts?
- SIZING FREEZE PLUG HELP!!!
- Need help installing a OBX Power Steering Pulley??
- Wheres my A/C !
- Wagons?
- new in this board..HELP MY CAR HESITATES--98 accord
- Finished h22 swap and got it dyno'd
- b16 and f22
- Turbo kit
- 97 accord lx 4cycl crank oil seal
- f22 question
- wiring diagram for 94 honda accord
- cooling fan short with a fuse that blew and reconnected
- 01 honda accord ULEV V-tec engines???How do i make them fast..?
- 5th Gen Owners...Need help fast!
- 5th gear, to be or not to be
- 2d/4d front lip?
- 93 Accord A/C R12 question
- Seat Brackets
- Cluster Question
- camber kit for accord
- distributor probs
- my rear lights are screwed
- 1998 Honda Accord LX
- Add on body kit???
- Hot Keys
- is 2" to 2.5" drop to low for 94 accord with 17's
- JDM Type S H22A swap into a 1996 Honda Accord EX-R
- H22 in a 91 accord question???
- Accord Type R engine
- 3 wire to 2 wire map sensor
- 97 Honda Accord Special Edition
- engine type.
- Car dies when a/c is on at dead stop
- Just purchaed 89 Accord, need help with tune up
- Please! short shifter help!
- JDM h22a(manual) into a a/t 1990 honda accord ex coupe. Is this hard?
- I need help with my brake lights
- help with p0401 EGR Flow Insufficient & MAP sensor
- timing and balancer belt installation order
- -----how to remove headlights---
- 98 v6 with 105k maintenance
- Accord 94-97 A/C fan .. push or pull type?
- 1991 Accord wagon speaker....what fits?
- why is there squeaking when car starts?
- F22 VETC swap comp.
- Honda Accord 92 Check engine light
- 93 Accord Ex with Oil pressure problem
- 95 accord auto... think tranny is slipping need help
- 1990 accord starting problem
- Bogging at around 4-5000 RPM already brought up but not the solution
- Searched with nothing....rpm's when hard braking
- A few ?'s about a caber kit... plz help if you can.
- Odometer pissin me the F off....
- Lowering Car Again
- Greddy Evo II exhaust
- help difference checking cel 0bd1-0bd2
- VTEC Malfunction
- Does anyone else have issues with theyre tranny snycros?
- I hate...
- Oil and filters-95 Accord EX Vtec
- What spark plug wires do i use for an f20 dohc non vtec
- odometer readings
- prelude struts fit accord?
- How big is the gas tank on the 1991 accord LX?
- Anyone else Have an F20B?
- Air filters
- Need Help Installing OBX Alt. & Pwr Steering Pulleys!!
- who makes a header for the v6 accord
- 92 main relay
- check engine light
- 94 accord lx ecu upgrades
- 99 Accord Belt?
- Jacking Points
- 91 Accord won't start
- How bad is it when oil goes where it shouldn't?
- 2005 Accord EX V-6 twin turbo
- 97 accord 4500 to 5000 rpm bogout ?
- 92 EXR transmission problems?
- 02 sensor replacement help
- bumper side marker 96 coupe
- tachometer 95 accord v6
- OEM Fog Lights wiring question, Did search, got nothing, its a tricky one
- Cooling System... giving trouble.....
- why nitrous?
- Indiglow Gauges on 96 Accord
- Stock shocks/springs ?
- does any body know about taking out a key cylinder for a 95 honda accord
- Need Help with Oil Leaking in the Front
- Need help with CEL codes......
- xenon lights
- Need p13 ECU ASAP
- ABS kickin in all the time in one wheel
- brakes
- When is the NOOB sign gonna go away???
- Headlgiht Installation Help
- The Juice Box
- best place to buy h22 for my 95 accord?
- Spark Plug ?'s
- Buzz sound
- wire order on distributor, accord 97 EX
- Unsure of what part belongs...
- will my 94 accord ex ever handle like my roommates 94 prelude si?
- Leaky Trunk
- f22b?
- 1996 accord lx automatic radiator
- Can Gen5 H22a accord have Supercharged?
- fuel injectors question
- under side of 5th gen
- Do 5th gen coupe interiors fit into a 4th gen ???
- 7thGen Accord
- timing check and adjustment 1997
- Where is the 02 sensor located on a F22A4?
- new picture thread
- Tranny Problem...
- Transmission problem??
- 1>2
- 96 accord smog - check engine light fail light
- 92 accord safety indicator lights dont alway go off
- broke throttle body hose connector
- stock radio code
- too much engie oil?
- brake problem - pulling to the right.
- Recommend a Body Shop in Central New Jersey
- Possible Bearing Problems!!! need help determining...6 gen accord 3.0
- MPG
- fuel filter seized on 94 Accord
- Springs
- My heater knob wont turn
- cel light ?
- 95 accord auto randomly shifts down?
- 95 accord overheating think its water pump need help
- how to check a/c?
- help
- 1998 Accord Check Engine Light "Catalyst not efficient" Fixable??
- engine cuts off at high rpm..
- Newcomer
- 95 accord vtec how much transmission oil/fluid?
- tranny making car shake?
- Tire Help, need to locate 16 inch rims (stocks)
- new accord rear lights
- H22 tranny w/ a F23 motor, what needs to be done to correct the speedo?
- Speedometer and Odometer aren't working
- Brembo, Get the Blanks, or get the cross drilled????
- 6th Gen Accord
- 92 accord dash
- New clutch
- balancer
- SRS Light
- Summer Problems
- Wierd idleing
- Any 90/93 Accords w/ H22/H23 Automatic Swaps?
- E-BRAKE CRAP
- Clutch Master Cylinder replacement question - 94 accord
- the temps outside are going up, now the car won't start???
- 92 accord rear motor mount.
- Noise at hwy speeds, either spoiler or???
- DIY taillight amber removal?
- Im new!!
- abs light
- PLEASE HELP: Accord ECU, what does it control?
- Clicking noise...not CV axles...
- banlancer oil seal retaining plate
- Vtec quit workin what's the problem
- Honda Accord A/C Problem Diagnosis
- Rotors/pads 98 Accord LX 4cyl: slot/drilled or none?
- Any neat features I dont know about that you do?
- rear cambers for '99 4 door accord
- 93 accord sedan swap?
- Temp Gauge normal reading
- Difficulty getting into gear.
- 96 ACCORD wont start???? no fuel pressure
- What offsets are you guys running? 91 accord
- link to DIY honda accord timing belt site?
- Camshaft and crankshaft seal installation
- how swaps Power steering pressure switch on my 1988 accord
- 1991 Accord Ex with spongy brakes!
- A word of advice
- B18 Swap into a 1992 Accord
- F20B and H22A
- vavle clearence adjustment specs
- 00 accord v6 dash light problem
- What is this, link with pic
- 99 Honda Accord Coupe
- 1991 accord (check engine light) code? i have searched and notting
- Car hesitates...
- Four jack stands?
- Brake problem/issue/question
- Speed Chip??
- Where did these rims come from?
- Air conditioning help!!!
- Went to get tranny drain/fill
- H22 Accord Swap
- Oil burning problem
- Wheels/tires This time
- Need diagnostic help with 98 Accord
- Spark plug/ignition wire question
- Outstanding main relay question from 6/5
- NOOB alert: Do I need a camber kit?
- Need some CV joint help
- a/c
- 1991 Accord Problem Starting, please help.
- 5 speed transmission help plz
- Power Steering oil cooler ..
- Gas door
- fuel filter
- DOHC Cam gear tuning ..
- Infamous Third Gear Grind
- 6gen aftermarket radiator?
- Heat and idle.... what could be wrong?
- timming belt question
- Condensor fan
- Tranny problem
- fuel filter
- Gunmetal accord wheels
- 1994 4dr sohc vss location?
- no air from blower
- HONDA ACCORD 2.7L V6
- i have a 90 honda accord. need advice
- Brake Fade...???
- turbo or all motor
- rear brake disc conversion
- GReddy Oil Cooler - Accord EX 94-97 (JDM only?)
- accord owners HELP me out.....
- suspension prob..bad spring? bad shock? out of alignment?? pics.
- 94-95 wings west rear lip
- Battery relocation kit ..
- What is wrong with my Accord now?
- Some problems on my 91 accord
- 7gen Accord pre-muffler & muffler backpressure
- 98 Accord V6 / no fuel pump priming / replaced main relay / confused...
- Quick Question
- thnking about the 05 accord
- '93 accord dashboard.
- New to board
- Recaro SRD in 96 Accord
- weird A/C problem
- srs light help please
- shaking
- clutch for turbo accord
- different automatic antenna replacement problem
- 2001 EX Accord Helms Scans
- A/C problem with my accord...anyone came across this one
- Cam Gear Question,just isntalled Dumbd question
- which line at radiator is tranny fluid RETURN line? passenger or driver side? 2001 ATX
- more info on egr port please
