PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 [331] 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. high output alternators? where can i get these? for a 90 EX?
  2. h22a in a 6th gen
  3. Pics of the Prospeed Headers you guys been waiting for!
  4. Hi, I am a new kid here, need some help...
  5. 2003 front bumper
  6. 90 Accord Side Skirt Removal
  7. FYI - Wrecked 93 Prelude w/ 67k in TN - hit him up?
  8. need some info on a upgraded ecu for my 5th gen accord
  9. Desperate, need hood and fender!!
  10. I have question for grounding my 02 4cyl(F23A1)
  11. 93 LX hesitates under light load
  12. adj cam gear installation Q
  13. How 2 find positive brake lead???
  14. Does anyone have PIAA lights for their 2003 accord?
  15. Where can I buy the 03 Accord rims???
  16. Head Gasket needed!
  17. Quesiton about my AEM intake....Bypass Valve?
  18. accord 96-97 ecu question.......
  19. oem kit for 01 accord..
  20. My 90LX Accord
  21. Accord Air conditioner Problem
  22. my new pics
  23. 90 honda accord / idle revs up and down
  24. Code 6, on a 90 LX
  25. How big are the H22 and F22 in cubic inches?
  26. Has anyone ever driven/races a 03' coupe (V6) ...240hp?
  27. Cleaning Motor?
  28. Cheap Horse power improvements?
  29. Suspension techniques pricing???
  30. please will anone show me their tranny mounts
  31. Door Panel
  32. '87 Accord climate control module...
  33. brake problems
  34. Anyone has the Helms in pdf for 94 Accord?
  35. Accordexchange, Neidjdbdkbd, Drag4ACCORD, BOOSTED ACCORDS HELP ME PLEASE! I need Intercooler routing
  36. 94 Accord EX Auto to 5-Speed conv.
  37. DC Header
  38. Valve Adjustments
  39. direct replace low profile fans?
  40. Odd Engine Problem
  41. APEXi World Sport Exhaust
  42. trans. question
  43. question re: 5th gen JDM Accord SiR headlamps
  44. Where can I find one of these???
  45. what does this ecu go to?
  46. 5speed ecu on an automatic car?
  47. Trans dying?
  48. 95 Accord tech issues...
  49. Need pic of 90 accord 2dr front rotor
  50. Brake pads with little to no dust
  51. changing the problem soon as far as idleing, (warning)
  52. K20A Engine
  53. OBX Strut bars
  54. exhaust help
  55. Aftermarket hood for V6?
  56. 3.2CL Engine Swap
  57. wat size sway bar for 94-97 accord?
  58. f22b dohc complete swap, any takers?
  59. Accord/TSX Engines?
  60. Yet another H22 in Accord swap question...
  61. Camshaft ??
  62. 92 accord front bumper lenses
  63. 96 EX Head on a 94 LX Block
  64. Interesting sounds from the rear of my car (not music that's for sure)
  65. A/C problem please help
  66. camber kit for 4th gen
  67. v6 manual?
  68. K24 with an RSX-S head on it
  69. Check connector on a 96??
  70. Has anyone purchased these seperately (5th gen)
  71. peeps w/ JDM H22 in 94-95 Accord - HELP please!
  72. Short shifter
  73. Need Help..changing ATF fluid
  74. ACCORD DIAGNOSTIC CODE # 7!!! Please help!!
  75. honda shifter
  76. A20A Camshaft
  77. Suggestions on new Tires for Accord
  78. 2003 Accord V6 starting problems and others...
  79. reset maintnance light?
  80. h22a help please!!!
  81. right hand drive conversion
  82. OEM vs Genuine O2 sensors
  83. H22 in a 5th gen, wiring problems
  84. Another Accord off the streets
  85. Idle problem .... 4th gen
  86. R12 V R134 Air Condintioning
  87. When AC is on, brake pedal loses pressure?
  88. ABS Light stays on, 93 Accord
  89. Radiator hose
  90. Brake Pads
  91. Buying 88 LXI, is the roof leaking?
  92. Keep blowing fuse.
  93. Automatic to 5spd Conversion 94 Accord
  94. stripped threads
  95. h22 manifold on a f22??
  96. tensioner(sp) nut?!?!?!?
  97. to all heads with 5th gen accords with coilovers on
  98. Tein Basic or SS on a 02 Accord
  99. 5th gen rotor over hub brake swap
  100. how do you know when the oxygen sensors are shot?
  101. Computer Chip?
  102. preformance timing adjustment for accord
  103. Intermittent engine problem on Accord '99 4 cyl. 65000 miles
  104. Antenna
  105. Oil Pressure Question??
  106. Seats
  107. Valve Nut Size
  108. 4th gen automatic , when the sports light on the cluster is blinking...........
  109. ABS light is on??????????
  110. suspension
  111. SHOCKS anybody?
  112. Code 63 for 5th gen. Accord
  113. any luck with performance on a f22a6
  114. Window fog ?????
  115. *****once again! i need everyones attention!!*****
  116. quick question------will a F23 auto tranny work on a H23?
  117. Need Help with Oil Pressure Gauge
  118. aem lude rail design for accords?
  119. vafc on 6th gen F23 vtec?
  120. prices prices prices?
  121. Motor Mounts?!
  122. Any of you guys have a OEM '03 accord wing?
  123. Will it Fit?!
  124. Engine Making Noise -- PLEASE HELP?
  125. oil pan for 96 Accord
  126. 2003 Accord
  127. 94 timing belt
  128. Door Handle and Window Control Panel Trouble Getting Off
  129. What are the specs of a 94 Accord Ex auto
  130. Installed new window, now need help with regulator
  131. Power steering fluid
  132. Car shuts off while driving. Very unusual????
  133. axle nut size??
  134. 96 accord dx +1k for a 94 si vtec prelude is it worth it??!@?!??!@?!?@?!?@?!?
  135. top of breather leaking above tryanny
  136. 1999 trouble code
  137. Accord Timeslips
  138. What's a '93 LX worth....wrecked?
  139. weird sound at 1500 rpm from under the car
  140. 98 Accord check engine light
  141. Timing Advancement
  142. CAR STALLS ------- help!!!
  143. Got a cel code 41 - need advice !!
  144. New gen Accord tranny question. Read damnit! It's not like y'all are working :)
  145. h22a With NOS
  146. Strange missing
  147. Beeping Seat Belt Light...but that's not it
  148. 2002 front bumper
  149. bilstein shocks
  150. windsheld wiper nozzles.
  151. Exhaust for an Accord V6
  152. Pics of f22a piston, rod, sleeve???
  153. got some questions about my 94 accord lx
  154. 6th gen h22a swap need nelp fast
  155. difference between b-series and h/f-series clutches...
  156. Poor gas mileage after AEM AR install on 99 v6
  157. engine code question.... f22b????
  158. 98 Accord LX won't start
  159. Automatic transmission problems...
  160. Accord wagon??? (online commercial inside)
  161. h22 in a 5th gen (I made a mistake on a previous post)
  162. i need a nitrous guru to hook it up!!!!!!
  163. special tool to remove stock motorized antenna on 5th gen? Anyone got pics?
  164. 2000 Accord EX-V6 Coupe Clock Bulb?
  165. ABS Ghost!
  166. Sell or fix up? Gimme a hand, y'all!
  167. KYB AGX for 5th gen
  168. Flashing oil light... HELP!!!
  169. installing 5th gen EX head to LX...
  170. OEM Catback Exhaust will it fit a different year model?
  171. 94-97 ex vtec crossover point?
  172. H22A Accord Compression Numbers....
  173. best state to find a 5 speed
  174. Where is the fuel pump??? 5th gen
  175. Brakes Change
  176. Grills
  177. starting problem, any ideas?
  178. 5th gen with WW Type-W
  179. prelude spring into accord, will it fit?
  180. I searched but couldnt find any help (antenna problem on 5th gen accord)
  181. Don't buy anything from GUDE.
  182. *ABS Problems*
  183. JDM Retailer in Atlanta, Georgia
  184. Front bumper damage
  185. running lean what should i do
  186. okay on the map sensor question
  187. will please someone take a picture of how the internal distributor looks like
  188. HELP!!! Erratic tach on 1992 Accord
  189. Help! '95 Accord stalls out when put into drive
  190. Turbo vs. H22
  191. Advance Timing
  192. 3 used Konis Yellows and 1 new one... ???
  193. Mounting a Prelude AEM CAI in a 4th Gen Accord (H22)
  194. Why does the O2 / oxygen sensor cost so much for a honda?
  195. electrical problems + ticking sound at ignition
  196. Changing the shift knob on my 02 accord
  197. accord V6 or 4 cyl?
  198. I need some help with window replacement
  199. Need ideas for my 94 accord
  200. need help on adjusting a camber kit
  201. H22 swap in 4th gen
  202. Any tuners
  203. my windshield fluid won't dispense!
  204. Got oil in my spark plug and ignition wires
  205. Accord owners with a nice Spring Set up.. keyword spring setup, im looking for a nice ride
  206. Funny story about me and my accord
  207. 94-95 accord injector flowrate
  208. just installed H22 in4th gen for a friend, need help finding a map sensor
  209. got a question about a 94-95 accord
  210. Turbo accord with larger intercooler
  211. !!!H&R----KYB AGX----DC Sports???
  212. Koni Yellow
  213. Timing Belt How To
  214. Does the 5th gen accord LX/DX/EX all comes with disc brake front/back???
  215. Need help with spring install
  216. which one is lighter
  217. Just did a compression test, is 200 too high??
  218. What can I do with an '86 Accord???
  219. 94 Accord axle nut
  220. Free AEM Intake
  221. How much would you pay for this accord??
  222. Idle speed questions
  223. crankshaft pulley price
  224. how can you tell if your ecu is srewed?
  225. a bit of internal viuals of an inside distributor
  226. 80k miles 98 accord tuneup tips
  227. burnt valves
  228. Error Code 12 and 15
  229. Air Bag Light
  230. suggestion on new tires for my accord
  231. hey help me with my problem
  232. N E one with a 3rd gen honda accord
  233. touching up my rear-bumper and limiting rust
  234. How do I detatch my oem grill
  235. h22 ecu in 4th gen
  236. f22b1 header interchangable with the f23a1?
  237. Accord 6th and 7th Gen Engine Codes
  238. 90 teg gs, or 94 accord exr???
  239. Soldering Hairline crack in Radiator
  240. New Pics Of My Coupe...Heres A Link To App\Cosmetic
  241. looking for an oem part
  242. Rough idle
  243. Tein ss system for 90 accord, Is it worth the money?????
  244. APEXi dunk cat-back exhaust for sale.
  245. My rpm revs up and down while in nuetral or park
  246. Fog Lights on 92-93
  247. Power Steering Fluid....
  248. Need help quick!!!! Please!!!!!
  249. Hey all, some info on my Accord
  250. 5th gen accord, where is the vin on the engine?
