Metal sound at 2200 rpm
Old Jun 13, 2003 | 12:37 PM
PearlWhiteAccord's Avatar
Default Metal sound at 2200 rpm
Hi,
my 94 lx auto had the throttlebody cleaned and now it makes this sound at 2200 rpm that sounds like the heatshield from the cat. what can it be?? Cat was just replaced too, but it still makes that sound....
Old Jun 13, 2003 | 12:59 PM
urpapa's Avatar
Default Re: Metal sound at 2200 rpm (PearlWhiteAccord)
**** problem here... around 2000rpm... i have those rattling sound... i am sure its not heat shield,... coz my heat shileld rattles too, but a different kind of sound !!
Old Jun 13, 2003 | 05:34 PM
SOHCMAN's Avatar
Default Re: Metal sound at 2200 rpm (urpapa)
I just adjusted my valves to .010 (probably a bit loose) and I get valve noise at about 2200...
Its like a high frequency tapping of matel... it is possible thats what you are hearing? I think Im going to adjust them back to .009 to get rid of it, sort of annoying..
sohc
Old Jun 13, 2003 | 05:57 PM
StimpyBoy's Avatar
Default Re: Metal sound at 2200 rpm (SOHCMAN)
Just out of curiosity, how did you do your valve adjustment with respect to feeling the clearances? Specifically, did you go just by feel alone of the 0.010 (intake) and 0.012 (exhaust) gauges? Or did you try to insert the next larger size and adjust until the next larger size would not fit but the right size would fit (usually with a heavy drag?).
I just did one with the latter method, and I'm just curious as to what others do.
I'd think it may be the valves as well, because I can't picture anything else making that noise just based on a throttle body cleaning.
Old Jun 14, 2003 | 06:32 AM
Saintor's Avatar
There is an "exhaust buzz kit" that was installed on the 5th gen Accord. Mine got it under warranty when the car had 1 yr.
Old Jun 14, 2003 | 08:55 AM
Default Re: Metal sound at 2200 rpm (Saintor)
valves were adjusted 2 months ago, can this be anything else??
Old Jun 14, 2003 | 11:20 AM
raceACCORDingly's Avatar
the exhaust buzz recall, that saintor is talking about.
Old Jun 14, 2003 | 06:26 PM
SOHCMAN's Avatar
Default Re: (raceACCORDingly)
was that just fr 95 or 94 also?
Old Jun 15, 2003 | 09:12 PM
94AccordCoupe's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCMAN &raquo;</TD></TR><TR><TD CLASS="quote">was that just fr 95 or 94 also?
I get the exhaust buzz around 1800rpm. I havent bothered to fix it. That sounds like what your describing. Its a very common problem. Its just strange you noticed it only after you cleaned the TB. Are you sure you never heard it before. If its really a new noise, it might be something else
regnevazota
Dec 29, 2010 10:56 AM
EG-SIXV-TEC
13
Jun 15, 2009 12:49 PM
cabinhill
Jul 6, 2008 03:41 PM
strictly.business
May 25, 2006 03:15 PM
Ri5e
Sep 4, 2002 11:06 PM
