PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. 92 accord oil pan replacement?
  2. Please help: transmission related...
  3. wiring harness
  4. looking for number ecu
  5. Low Fuel Light Doesn't Work
  6. ignition switch wires
  7. 91 Accord Electrical acting up...
  8. Whitch Route Would You Go??????
  9. HELP!!! Problem with the Emissions and engine control system.
  10. Expect A Lot of New Members
  11. DIY 6th gen
  12. 91 Accord and its stalling!!
  13. 94 ex accord
  14. F22b2 turbo setup thoughts
  15. Ground Controls (searched)
  16. Euro tailight problem
  17. F22b2 question
  18. 1992 Accord LX AT hard starting cold... Runs great after start...
  19. Ive got the shakes!
  20. How about this one?
  21. turbo oil line on f22
  22. 98 Honda Accord Code P1382
  23. Whats the abbreviation/ chasis code for a 4th gen Accord?
  24. Will a F22B1 tranny fit in a F22B2 motor. Are the tranny bell housing bolt holes and mounts the sam
  25. Clutch pedal drops to floor
  26. TCS light and check engine light on
  27. Replace guage cluster?--tricky, on-going process
  28. 99 Accord Hesitation Problem
  29. any shops in centrel nj?
  30. White trash front rotor changer
  31. 1994-1995 accord red/clear tails
  32. Suspension adjustment ?
  33. A little clutch question..
  34. K20A???
  35. f22 bottom end
  36. syncros
  37. EGR Valve help.
  38. Need help to install security alarm
  39. 1997 Accord 2.2L Trans replacement with JDM Trans
  40. what you guys think of this clutch/flywheel?
  41. Rotor Thickness Question
  42. help needed w/ my '88 accord water pump!!!!
  43. JDM H22a Knocking??? Still???
  44. geting to the fuel pump
  45. Guides
  46. Anyone Know if 2001 accord coupe cront bumper will fit 4dr?
  47. Oil in coolant on 99 Accord, cracked head
  48. Whats the name of this sensor that would make my car idle bad... PIC
  49. Car sometimes wont go into 1st..
  50. real tech question...sort of
  51. accord climate control/radio lights not working
  52. F22 and H22 Starters the same?
  53. Tranny swap
  54. h22a 93 accord 5 speed
  55. Honda Accord 97 .. low pick up
  56. RICERS READ ASAP!!!
  57. Header(s)
  58. wrecked my honda
  59. Which Tie Rod Ends?
  60. Left front headlight
  61. Code P1456
  62. what the top speed if i had h22 with a f22 tranny
  63. 3rd brake light
  64. 96 Accord cluster question
  65. Help -- Is this a tranny problem or what?
  66. Please help with trouble codes
  67. Question about harness seatbelts.
  68. FS: Suspension OEM Honda Accord 2006 V6-6
  69. 05 Acord DL - Auto Door Locks
  70. Brakes
  71. Proud owner of 96 Accord EX
  72. Gauge Cluster not working HELP
  73. I'm really pissed... 16MPG and I cant find the problem.
  74. Stock Stereo Question
  75. HELP ME START MY ACCORD!!!!!
  76. 89 accord swap?
  77. 5 speed 1993 honda accord ex setups
  78. Stainless Steel Brake Lines or OEM Rubber - 92 EX
  79. I have a few questions...
  80. my boys accord
  81. engine build up f22b1
  82. 01 Monte Carlo SS or 01 Accord EX V6 Coupe
  83. Climate Control
  84. oil message
  85. pass side cv joint 95 5spd help!
  86. CAI
  87. performance parts
  88. first generation accord
  89. What do you all think of the Venom 400 module for the EX 2.2??
  90. spare Block cracked question
  91. when do i have to change my rotors? they are 14/16 in
  92. mugen t - stat & mugen fan switch??
  93. exterior light bulbs
  94. question about blue ion tint accord headlamps!~!!
  95. Putting An Engine Together ...
  96. I bought a new clutch
  97. 95 EX clutch slave cylinder
  98. MISFIRE BELOW 10% THROTTLE
  99. Do you know of any quality/good mechanics in Albany, New York?
  100. Retracting antena
  101. Help!! SPEEDOMETER PROBLEM!!
  102. Parts wanted 4 94 Accord
  103. Speedometer problem?
  104. About Headers..NEED HELP..PLS
  105. Shifter Cable and Clutch Pedal Assembly needed for 94 EX Accord
  106. How many mounts on my 91 ex.
  107. Loud noise when im in gear.
  108. F22 oil leak.... rear main??
  109. Coolant hose?
  110. Dash and Park lights
  111. Will this wheel fit my Accord?
  112. bout the thermostat
  113. Will the bulbs work? Please Help
  114. SRS Light 2002 Accord
  115. Engine Difference Question
  116. keyless entry system
  117. RED GAUGES!
  118. Which lowering springs for 2000 Accord?
  119. 91 accord sohc swap?
  120. Help noob with 97
  121. 94 accord tranny problem
  122. A question about my accord and its engine.
  123. 94 Accord EX MISSFIRE after warms up????????
  124. Oil weight
  125. 91 accord fuel injected engine upgrade
  126. Delay when i start my car
  127. jdm head function with a usdm block?
  128. 1998 honda accord V6 problem!!! please help!!!!
  129. window problems - 97 accord ex 4dr
  130. turbo front motor mount
  131. Air Induction Intake Cleaning?
  132. Engine Code
  133. help please, getting door panel off
  134. 97 accord SE motor mount
  135. 2002 Accord EX brakes
  136. Please Help with my 2004 Accord
  137. brake pedal sinks slowly
  138. Pro and Con on an Accord
  139. Why does this happen?
  140. Getting desperate for Acura/Honda electrical help!
  141. 94 Accord LX engine swap cost
  142. KONI/GC coilover adjustment
  143. Car throwing code 67?
  144. O2 Sensor?
  145. 98-02 I4 accord eibach springs in 98 accord v6?
  146. o2 sensor
  147. 1988 Accord LXI Tranny issues
  148. does anyone know what the valve adjustment spec's are for 95accord ex?
  149. Change transmission fluid or not?
  150. Replace leather seat upholstery
  151. S2000 motor in a 5th gen accord
  152. steering wheel wobble on accel after lowering
  153. valve adjustment
  154. WTB: coolant fan motor
  155. HID Help
  156. bolt pattern
  157. 98 Accord Problem Codes
  158. cyp sensor
  159. Idle so bumpy, car almost turns off - What could it be?
  160. 94 accord lx, no left highbeam
  161. Is it normal for the lights to dim when...
  162. BIG PROBLEM IN NEED OF SOME SERIOUS CAR HELP
  163. Jack Hammer noise is back!!
  164. idle adjust-88 accord carb.
  165. springs sag over the years..?
  166. come on the someone has to know this!
  167. Horrible Gas Mileage
  168. battery light on when braking
  169. damn...this sucks!
  170. OBD1 Ecu....
  171. Changing O2 sensor....how hard?
  172. CL compatible w/ Accord?
  173. 98 Accord Issues
  174. brake pad help!
  175. Best suspension setup for 97 AV6
  176. 91 Accord died
  177. my gas pedal gets stuck
  178. Selling 1990 Accord
  179. 6th gen TCM HELP!!!!
  180. Harsh shifting Transmission 92 Accord, Same old question.
  181. 5th Gen stock header..Searched
  182. 1998 Accord crankshaft hamper HELP!
  183. Need Gauge Cluster HELP!!!! ASAP!!!
  184. 96 v6 accord question regarding tannabe suspension
  185. Radio Code
  186. Took my steering wheel off and now have a quick release, need help with the horn.
  187. Gauge and Odometer not working
  188. distributor
  189. cv joint replacment
  190. 95 tranny oil
  191. Do plugs for EGR system push through?
  192. When doing engine swaps...
  193. 92 Honda Accord ex...Solid CEL plus Blinking "D" on the cluster....Need Help...
  194. splicing wires .. need help
  195. Fuel pressure
  196. Vtec solenoid
  197. looking for 2000 accord parts.
  198. 5th Gen Accord- Headlamp Replacement.
  199. 6th gen accord key reprogram question
  200. I finaly ran at the track...not drag
  201. whats the best ecu?
  202. CAI... I think I might have outdone AEM
  203. 6th/7th gen Accord (4 cylinder and V6) chassis/engine mount/engine mount-bracket questions
  204. supercharger/turbo................. 4spd to a 5 speed/
  205. Question about '04 Accord Sedan Suspension
  206. not an accord question, but maybe
  207. baffled by gauge
  208. Lug Nut Size?
  209. What kind of bulbs?
  210. projector headlights for HID
  211. 1990 Accord EX Firing order?
  212. Can't remove distributor rotor on accord
  213. Short shifter
  214. Accord Bulb problem
  215. Smoke coming out from the engine bay!!! help
  216. rear disc conversion
  217. Rattle in front right wheel when turning?
  218. maintance on... 106k
  219. difference between cold air and short ram?
  220. screeching noise??
  221. H22A OBD1 and OBD2 ecu swap??? Is it Possible???
  222. 3rd pressure switch on 1998 Accord
  223. Oil leak
  224. Changing front brake rotors
  225. need help on the ignition wires
  226. Torx bolt under oil filter
  227. Alarm for no reason?
  228. f22 trubo ?
  229. gas pedal sticking
  230. I NEED HELP WITH A HEAD SWAP
  231. steering column lock
  232. Help: Mount issue.
  233. gauge Q
  234. Anyone Read, About my fuel pump problem
  235. Metal Radiator
  236. Fuel pump
  237. P_Adams Read this
  238. Someone help!!
  239. ID a part
  240. 86 to 89 Accord LXI motor swap?
  241. rear bumper problem
  242. 91 F20B swap?
  243. help removing the throttle body on a 2001 L4
  244. Steering Knuckle/Brake Caliper Question
  245. 1991 Honda Accord - "S" Light flickering like crazy / TCU is clicking loudly
  246. 1990 Accord - Engine Temperature Fluctuating
  247. 5th gen top speed
  248. Electrical Prob
  249. Battery Problem
  250. Repair cracked visor?
