View Full Version : Honda Accord (1990 - 2002)
- Cam gear adv./ret. reccommendations
- Warning about 99 Accord Crank Pulley coming loose
- Racing Clutch and Regular clutch
- Trunk Weatherstripping part number for 1992 Accord sedan
- Rumbling/Vibration sounds during braking...please help
- Door Help
- idling....
- Seatbelt question
- I need your info on your honda
- racing seats
- air temp sensor?
- 91 Honda Accord Stock Springs
- Good clutch kit?
- Headlight Question (97 Accord)
- :( sad day at the dyno (dyno pic)
- bumpers?
- maybe better luck here
- sprayin the f22b
- F22A ???
- Clicking noise when braking and accelerating..?
- lurkers first post...
- cams for a 95 accord lx
- Secondary O2 Sensor
- f22 Vtec?
- anyone have pics of nuespeed sport or race springs on a 5th gen accord
- weird pinging noise
- Small oil leak into distributor
- H22A O2 Sensor Help
- Major problems
- selling my car
- SRS Light is on, how to shut it off ?
- hello all..im new! help with overheating?
- Does anyone know if 6th gen 4-door rear door handles would fit a 6th gen coupe?
- ever tow an accord with 4 flat?
- weighed my 92 today.
- looking for accord ecu!!!
- name some good internals for my nitrous
- Nology Wires BLOW
- POA1? accord engine
- Hondata intake manifold gasket $35
- Spoon Sports Thermostat & Cooling Fan Switch
- S-AFC install, pressure signal wire help?
- h22a iab
- Car dies immedately after starting
- a/c wiring diagrahm
- Anybody have H&R Race on a 98-01 Honda Accord + Pics?
- Shocks
- f20 in 5th gen
- taking off front bumper.
- ***Price check on a 99' honda accord lx***
- Axel Back Exhaust
- Need help temp. problem 95 accord
- Accord bolt pattern
- Symtoms of a ROLLED BACK Speedonmeter?
- Legend brake swap
- Question re: engine fans
- anyone have spare 4th gen lights?
- oem front and rear bumpers
- vacuum diagram
- just got cel with 2 days after greddy evo catback
- I screwed up the motor in my Car!!! :(
- Need Help! Accord check eng. codes
- who drives AV6's on this board?
- need H22 YESTERDAY!!!!!
- help on fuel rail?
- transmission question..... need advice/help
- Just bought 2003 Accord V6 EX with Navi 6-speed
- werid engine knock
- info
- Request for Advice
- Silverstars
- WTB H22a Rocker arms.
- best engine swap?
- need some help on engine specs
- can't find this engine code/ need help
- european accord motor swap/head swap?
- Upgrade order
- pic of rear bumper signal light
- just picked up my $75 accord today. shes a beaut!!
- anyone in san jose want to race?
- Just Bought a 95 accord crashed and need help
- Greddy vs Mugen
- 13 Gallon Gas Tank?
- 90-97 Accord kyb gas shocks agx
- After market steering wheel with cruse control?
- Posting for a friend: Car overheats
- diameter of 4th gen accord exhaust piping.
- Good Price on RC injectors???
- How do you adjust/aim headlights on 92 Accord?
- where is the CENTER crossmember on our accords? *90-93
- HELP my h22a is broke
- Adjusting a cam gear
- Timing belt question,
- Check engine light is on.
- Underdrive pulley and fuel regulator
- 90 Accord tranny problem.
- Who makes a short shifter or adapter for a 1990 Accord?
- 98 JDM Accord steering wheel to a 97?
- Accord V6 injector size/ Having problems with stalling after installing Comptech SC
- Clutch will not dissengage.
- Replacing rotors - what to do?
- need real help on installing obx water temp sending unit
- Key get stuck
- F22b DOHC?
- Who was buying my drivers side window?
- Need specs on the flywheel.
- options for F22
- 90 ex accord prob
- what is this??
- 5th gen accord steering wheel question
- need OEM corners.
- Film of OIL on Spark PLUGS HELP!!!
- notchy shifter??
- Hesitation at take off
- Upgrading clutch and flywheel (maybe even crank pulley)
- cheap stock parts?
- Climate Control fan
- 87 Honda Accord LX - Emissions
- Anybody using stock airbox on h22 accord?
- Got in an accident with a drunk driver
- I need help asap. accord timing belt shot.
- AEM dyno gains
- any cheap ways to improve handling?
- Fuel Gauge
- Ebay prices!!!
- ATTN: iam7head
- 2000 Honda Accord SS Chrome Headers
- car stops at random times
- vtec wiring
- Fuel Gauge not working
- Moving off in 1st gear
- not your typical problem-power window
- wtb* (1) 94-95 accord 7spoke rim
- what motors can i use
- 5th Gen accord owners, I need some help or soemthign
- h22 tranny w/ sequential sportshift in 4th accord???
- Turbocharging the F22
- I can't find a camber kit anywhere, where can I get one?
- Problem with speedometer in 94 Accord LX
- Bolt on engine for 91 Accord 4dr?
- Header: DC or Kamikaze
- electric lock problems??? HELP
- steering wheel tilted question. . post *curb*
- my 88 accord lights are screwy
- Pics of Eibach pro-kit on 98-01 sedan anyone?
- valve sizes on f22a6/1
- 96-97 integra type R wheels on a CD7
- Rough idle....
- I'm gonna swap in an h23 and then turbo later, so...
- vibration in gas pedal
- 92 Accord EX lowering
- acura twin piston calipers on my honda accord
- Cam Gear F22 and F23
- eNeed Help With Head Swap
- '88 Accord--Battery, Alternator...?
- 92 Accord/Oil leak between distributor and engine/With pictures
- timing belt and harmonic balancer, how do you set them correctly
- Transmission Conversion??
- accord chek engine light which one
- Highway CEL
- AT 2 MT question
- H22a accord question
- Pulley and cam from 5th gen accord to h22a
- Crazy Jumping Speedometer/Blinking D4 Light
- How do I replace the air bags?
- Stock motor 1/4 build up times...
- H22a Swap
- 6th Gen Accord coupe front strut bar
- Lowering Help!!!!!!
- Help h22 install.....
- just bought greddy evo
- no spark, need help PLEASE.....
- buying a repair manual worth it??
- most quiet muffler?
- Valve Feeler Gauge
- Have a problem. Maybe the distributor?
- Will F22 vtec distrib work on h22 or h23?
- maintain' req' light came up after 6000 miles??
- Engine Cooling Fan Question....Both Needed???
- has anyone ever DIY lower ball joint?
- Engine is beginning to get really hot!
- Who has experience with making speedy F23's? Anyone?
- remove back seats? What is it like under there?
- 01-02 Accord Coupe questions....
- I have no pressure in my clutch pedel
- Horsepower
- FYI - Damaged 92 Accord w/ H23a & more $2.8k - Los Angeles Lowball Target $$$
- what tools do i need to replace my rotors?
- How to replace rotors?
- High comp w/low boost or Low compw/high boost
- just a question for accord owners
- questions: clutch install on `93 Accord
- what's the flow rate of the stock accord fans?
- 94 - 97 Accord Owners
- JDM H22A auto into 93 Accord EX auto???
- what is the redline on an h23?
- Anybody with an 03 4 cylinder in SoCal?
- Rough Idle when cold
- Valve adjustments
- Help 94-97 accord owners
- More Free AEM Intakes
- Transmission cooler for 94-97 Accord, anyone have one installed?
- 99 v6 honda accord owners manuals ** help
- F22b1 VTEC motor
- Auto tranny shifting at higher rpms than normal?
- where can i find the ECU?
- 94 - 97 engine ????
- Spark Plug Gap for 93 Acoord LX
- What oil do u use?
- Anyone try stronger window/sunroof motors? Also, stronger AC unit?
- paintin headlights
- 99 Accord - use injector cleaner in gas?
- air conditioning in '89 accord
- Got a used accord, having some problems.
- strange noise.
- 2002 V6 instrument cluster removal
- H22a, Vtec does not engage
- I need a VSS for my accord any help here guys?
- Sub:Throttle body wires + minor idle adjustments,,, Problem: need help
- 3rd gen. accords?
- Help!!! Question for h22 accords
- Oberheating, I should say fan turning on too late on the H22. What to do next?
- where to buy the greddy lip spoiler for 96-97 accord
- Car shuts off at operating temp, Auto trans prob?
- A/C Problems
- 1991 Accord Timing Belt Question 4 the Techs!
- *%#@ ABS light
- Another Free AEM Intake
- Help-Where to get one koni yellow?
- Convert Auto to Manual
- 93 Accord Auto EX ECU Code?
- for those with struts?
- Help on alignment, toe, camber after I installed Pro Kit's
- TECH: DX, LX 5th gen rear sway bar upgrade from EX
- Please Help Axle Problem Please Help
- Where can I find some nice front upper A arms for my 91 accord
- Bought a cold air intake.......How do you install it
- 94-95 Accord Int shaft on Lude SH block...?
- s2000 steering wheel in a 6 gen accord?
- strange noise
- 6th gen accord H22A swap info!
- Is the exhaust on a 96 Lx the same as an EX?
- 180 miles into break in and no 4th or reverse all of a sudden
- Skunk2 coilovers on 2000 Accord V6, install?
- 2000 accord cd player
- boggin, ruff idle , runnin too rich...
- SPEC Clutch and/or Flywheel Group Buy - The Clutch Depot
- question for tech
- 3 tech questions for a 94 accord, helpp!!!
- HELP my door will not open at all on my 91 accord sedan!!!
