View Full Version : Honda Accord (1990 - 2002)
- broken headlight switch
- New Accord owner and site member
- f22 to build or NOT!
- weird squeak at driver side wheel when turning right, opinions please
- Planning to buy an accord and need advice...
- How bad is "limp mode"
- Sports Light Flashing... trans runs fine...
- semi-urgent: h22 questions
- 5th gen ex wheels on 4th gen accord
- OBD 2-1 engine/chasis harness compatibility question
- Brake lamp light
- Installed a new contol and cv questions
- reving idle at start up
- Need help with buying springs...
- front lip?
- how much power will a header give over stock exhaust manifold?
- Brake Pads
- RESTORE engine additive
- Anyone Interested in B20A motor for 86-89 accord
- crank pulley torquing
- Msg for im_the_teacher (falfj@jlfa.com)
- HELP- What if speedometer and transmission stop working correctly at the same time? (95ex)
- Torque spec on strut lower mounting bolt
- Heat Shield Removal Question.
- Anyone here with 14" wheels?
- RSX Seats in 93 Accord Coupe
- hey, wat would u guys do if you in my position?
- CarFax please on this accord.
- Suspenion Package - Good or Bad?
- 90-93 Accord: Best Products
- need right corner blinker part # on '94 coupe
- Need intructions installing coilovers/springs..
- How do u know your header crack
- Where to get a spoiler for my 98 accord ex v6 any suggestions?
- just changed fast idle thermo valve on a '90 accord ex, still having the erratic idle problem
- struts
- 95 LX V6 rare?
- Looking for front hubs for a 91 accord
- Whistling when i start (5th gen)
- Just intall AEM CAI V2, Is this normal ?
- just got a front lip
- Exhaust ??? for a 97 Accord LX
- intake question
- How do i remove my Rear lip (5th gen)
- mounting a low rear tie bar?
- Trouble with balljoint boots?
- Is it true....
- any sites where to buy accord parts?
- Help with honda running badly....ideas please!
- HELP with lowering an accord
- Cruise control connected to ignition coil????
- Accord manual in pdf file?
- swapping transmissions...
- Nitrous
- Paranoid?
- rims for accord
- Parts Interchange / Engine Swap for 2nd Gen
- 2004 Accord V6 sedan coming in six-speed? Anyone know?
- H23
- really need help asap....
- world sport/ accord fitting
- car pulls to the left
- Lucas cylinder?
- FAN is on while ....
- need help on 4th gen vtec
- How much for main seal repair ?
- Engine Parts
- A'PEXi Piping
- NEED HELP...
- Possible to get exhuast system as stock looking as poss.?
- does the brand matter...?
- Greddy Evo or not?
- crv swap
- Undercarriage vibration
- Help for headlights..
- Best suspension setup for a 99 Accord EX V6 Coupe?
- diff between headers??
- Where is my ECU?
- good exhaust system.......
- Where to find the motor for power antenna?
- Replacing OEM light bulbs?
- Possible Ball Joint Troubles Changing Axles(1994)
- Help- will all sorts of issues
- Door Panel 2000 Accord problem
- Accord intake manifold swap
- flushing radiator?
- where online would you guys...
- resetting SRS light turned bad!!! please help
- Valve Cover removal?
- 2nd dumb question of the day... i/h/e??? eh?
- damn you all for making me want to turbo my car!!!
- timing belt tensioner?
- 5th Gen 95 accord EX exhaust
- AEM cai vs AEM cai V2
- brakes in the rain
- Alternator/Charging System: what's the purpose of the green 4-wire harness that plugs into the alt.
- is this mod worth it..?
- someone with a vafc.....
- where to get a run channel for 91 accord driver side?
- Please help me find internals for my 94 accord ex.
- vtec controller on a f22 accord
- 1989 Honda Accord
- Tryin to help sister
- 4th gen: EX header vs. all others??
- where to get a turbo kit for a 4th gen
- Turbo from junkyard?
- Turbo F23A motor
- 01' v6 coilovers
- ACCORD 5 LUG CONVERTION?
- 4dr accord 2001 front skirt
- which accord best for IHE?
- 97 Accord EX H22A swap
- warranty??
- STOLEN 93 red hatch stolen from my Apt. LOUISIANA
- installed driver side driveshaft, now there's noise when i accelerate out of a right turn..
- Back Seat
- Radiator cap
- Is chipping a waste?
- 90-91 accord rear brake lines(drum)
- Alternator & crank belt size
- fmax turbo on 97 accord
- Anyone know OEM oil filter bypass pressure?
- How Do u reset Maintanance light on 99 Accord ?
- i need grey cloth interior specifically door panels
- 90-93 Accord Ex (sohc) header ..cheap
- 95Ex newww manual dRiVEr!!
- Compression Ratio?
- Two things for free...
- Replacing driver side window regulator and motor on 93 accord EX. Buying parts on ebay?
- How much is my HP
- swapping valve springs
- dash and tail lights out - help
- any one have this problem or have advice?????
- Air conditioning fan not running.
- bypass o2 sensor
- AEM V2
- Major Accord Issues
- 96 MISSFIRE ,EX VTEC.
- Car cranks by itself!!!!!!!
- dumb idea to mod 4 bangers?
- Side Marker Location...
- Help with CEL on '98 Accord (low catalyst???)
- scary driving my car....
- Weird (to me) problem starting the car
- Charging A/C??
- ..Help, Smoke from gear box.......
- upgrade performance of 97 accord special edition
- carbon fiber hood
- TIRE SIZE?
- how many quarts of oil for an accord v6?
- Accord auto trans codes
- 97 accord bumper lights...
- HID bulbs
- 94 ex cold air intake
- f22b cam kit
- Trunk strut question
- tranny fluid
- how does this sound ?
- n e 1 use f22b1 crank in there h23?
- 01 Honda Accord Brake Light
- 1992 Honda Accord DX
- help= auto tranny fluid filler hole
- 90 accord engine swap
- CODE 41 on a 2000 2dr Accord
- does the 6th gen V6 have transmission problems like the Acura TL V6?
- good coilovers??? what your pick?
- motor mounts
- Special Lug Nuts
- what is that little box...
- Replacing Brake Fluid, 2001 Accord EX 4 cyl. - How do I do it myself?
- Front Speaker size for 98 Honda Accord EX Sedan
- lowering the ride
- cryo2
- upper control arm problem *pics*
- abs light came on for a few & car started losing power...
- Good Deal?????
- Mugen 95 EX ECU chip??
- h22 dist
- HELP, Code 71 Cylinder Misfire
- Steering wheel....
- Which part on this pic is the main fuel relay?
- Putting an intake need help...
- Putting in an intake need help...
- Hidden exhaust?
- went over a bump and now me seat belt light is on
- ony one have the exaust from a 90 accord Ex for sale (stock)
- stock muffler replacement
- Injector sizes
- 94 accord major ac problems!!
- JDM Accord Sir dash
- computer
- 94 speedometer
- Actual header HP gain...?
- Mounting Hitch to 1999 Accord. Help
- 2002 Coupe Spoiler
- 94 accord auto to manual swap question
- Newb question...
- Noise coming from front wheel well
- Anyone have a 96 accord ex stock cd player and stereo
- 1997 LX exhaust help
- comptech supercharger?
- H22a automatic or manual
- brake pedal doesnt feel right
- Do any of you have the Fastbrakes kit?
- Wiring For H22A
- All Season tires?
- Sylvania Silverstar Bulbs
- Suspension Knuckle ??
- JDM H22A Distributor
- 95 Accord Losing Radiator Fluid
- Accord Tranny Swap
- 91 accord compatability
- would these tires fit on my stock accord?
- cat back exhuast
- any good places to get a cyl head and intake for my 98 sedan? stock is a good start
- V6 in a 94 Accord EX???
- Brake me. Your set-up?
- Rear Suspension Spings to Short!!!!
- hey does any one else have this problem
- 5th gen cruise control.. parts
- f22a6 valves
- 94-97 accord ex rims?
- intake, computer, and head swap will it work?
- which cold air intake do i use for 93 jdm h22a in 94 accord ex?
- blown headgasket
- Turbo Manifold
- N/A 4th Gen Accord
- Gas Gauge Question???
- umm..what happened to my post asking about Accord navigation?
- brake lines for 03 accord
- what does maintance required light mean.
- coolant drain bolt behind engine block
- what header for dohc F22b
- Chip in car keys
- 86 legend puffing white smoke @ stoplights.
- Maintenance Required Light
- when does vtec engage on a 94 accord ex?
- anyone looking for slicks
- ...6th Gen Model Differences...
- 1988 accord idle problem
- hmm noise in clutch area a little squeeky got release bearing just fixed how do i make it go away
- TEIN Springs.. oppinions?
- gains from taking a/c compressor...
- '93 Accord getting hot -- additional strange symptoms !
- which wiring harness to use for H23 swapped 90 accord??
- Any know the part# for the fast idle valve for a 90 accord ex
- AEM EMS or Hondata?
- A/C PROBLEM!!!!!!!!
- swapping h22 need some ?s answered please
- Supercharged.
