View Full Version : Honda Accord (1990 - 2002)
- Need help w/ Optima Battery
- Convert to 5spd and Cat Converter questions
- Alternator Belt -- tighting how much is too much
- h22 with f22 tranny MPG average
- 94 EX Brake Noise....HELP
- power door locks 91 honda accord
- Stock cam gear pic request f22a6
- Reeally sorry to have to do this again
- wheres the oil from?
- Adjustable ball joints vs. Camber Kit..
- integra headrest question,
- lower ball joint removal in 1989 Accord LX
- Oil !!
- h22 mounts
- can you adjust camber on a 94 accord LX?
- fog lights
- WTF is wrong with my engine, vid inside
- 2002 Accord SE accelerator pedal stiffness
- tire size?
- Buzzing/Clicking noise when in motion and shifting manually out of gear into neutral
- Accord Carpool Lane Question
- BIG QUESTION
- ride height sportlines 96 accord
- For those who did rear brake disc conversion
- Auto Tranny Delayed Shifting...
- Parts Cross Reference
- stock muffler...mod?
- Stock Muffler Mod's (kinda big pic)
- Thermal exhaust on 98 V6 accord what u guys think of yours?
- Help finding wires RPM, A/F 93 accord?
- H22 Tranny Questions
- KYB gr2 with sportlines
- Water pump swap....HELP!!
- *** replaced IGNITOR now car won't start!!!! ... help
- Accord Seats Fit Guide
- if i go turbo would i need a whole new front bumper
- JDM f23's? myth?
- 03 coupe sub install
- Loose door panel? Also brake noise.
- Intstalling Coilovers on 2000 4door
- My remote starter story
- H22 swaps
- Warrenty
- cooling fan problem.
- 93 Accord wont start
- radiator fan problem
- 2 O2 sensors before the cat?
- Brakes
- Honda Accord 2000 - Audio Installation
- Need help with information on the wiring for H22a into a 5 gen accord (lx model)
- Muffler
- What year did the V6 accord come standard in??
- Accord roof rack (Yakima)
- front end damage please help
- tuning your 6th gen AUTO accord right...
- 5th Gear grindage problems?
- anybody know if a 2000 h22 will go in a 96 accord ex? HELP
- Seized bolt! need help QUICK!
- Anyone Know Who Makes Small 4psi Turbo's?
- how many miles do you get on your original clutch?
- what can fix squeeky doors?
- how many miles does your accord have on it?
- Air Pressure
- Used Accord
- Picture write up on auto->manual conversion?
- high mileage boosting? Few other questions
- jdm h22 problem?
- h22 5th Gen. Coupe 1/4 times?
- euro light for honda LX??
- tune up question. 97 Accord 4cycl
- Triple whammy...non-mechanical, a newbie and have a question
- 2000 accord stock front bumper
- what are specs aliments for the 97 accord lx
- Springs???
- Anybody have trouble aiming aftermarket clear headlights?
- 98' accord
- new to the accord
- h22 swap questins?
- clutch will hold crankshaft pulley from rotating?
- 91 Accord Ignition Switch
- OEM 6 disk changer
- stereo harness : pic....please
- Car Accident
- Is it possible to swap in a h22 into an accord with euro R mounts
- how to fix gas guage?
- How to remove alternator from 98 Accord Coupe V6 LX?
- 90-93 engines
- NEED HELP LOCATING THE FLYWHEEL AND TIMING CONNECTOR
- Q: How do I get that passenegrs kick panel off (for the OBD I) .... ???
- Body Difference From 94-97 Accords
- 2k3 Accord Valentine 1 Radar install tips
- HELP! Does anyone have pics of what a 1.5" drop will do to my 98 Accord sedan?
- MORENO VALLEY/RIVERSIDE MEET!
- Pricing H22's!? Need Some info
- ?????Changing The Tachometer Face?????
- Wheel well lining
- anyone selling ex stocks for a 94 accord??
- side skirt removal?
- pistons... pistons... pistons
- I just lowered the front only and.....
- thermal wrapped headers?
- Springs chopped
- Any tips for installing an AEM CAS on a 93 Accord?
- Installed Prothane Mount, but did I do it right?
- ECU options?
- aftermarket springs on stock shocks
- Exhaust... What brand is good?
- Can someone please help me with a Carfax lookup?!!
- TURBO MANIFOLD FOR A 1994 ACCORD LX AUTO?
- Starts fine....then doesn't start at all....
- Rattling steering wheel.....
- which one?
- Fuel Injection Failing??
- GETTIN MY CAR DROPPED YO!!
- 98 Accord Suspension problem
- 2000 accord V6, throwing miss fire codes comptech supercharger!
- Got some stuff for sale in the classified's, FYI for 94-97 Accord owners
- OT: bumpstops
- heated seats
- inspection on a 90 accord ex
- Putting on a interior door handle.....Need help!
- HELP!! crank shaft blown???? 99 accord
- Accord Manifold ?
- junkyard rack and pinion
- REPLACEMENT RECOMENDATIONS
- obd2 - obd1
- Any Know Conflicts with swap? where does H22A Redline??
- Crazy Auto Question
- Redline For H22A? Any Conflicts Putting an H22 in an accord?
- Gas Tank Seems funny
- 00 V6 acccord 6spd supercharged.
- 89 accord engine swaps
- BG44K.......DIY ???
- Braking Problem coming down from high speeds
- 96 Accord ABS Advice
- Suspension Techniques anti-sway bars 5th to 4th
- Car cover says not to use it on any newly repainted surfaces for 6 mos????
- no movement!?
- 4TH Gen help
- Seek Accord seat mounting specs
- need help understanding ems/ecu
- 94 Honda Accord Lx Need Help!!!!
- 00 Accord v6 chip or ecu???
- Pic Request: Neuspeed Front STB on a 4th Gen.
- I need your help again everyone!
- Master Brake Cylinder question...
- distributor-90 accord ex
- tire lump
- will my f series clutch work on my h22?
- Hayame coilover
- Help - Rear Lower Strut Bar Installation
- tranny
- where to BUY 93 distributor IGNITOR... dealership doesn't sell it seperatly
- Down Pipe
- DIY Question?!?!
- Blue dash and gauge lights?
- OT: The console on my 95 accord and the temp knob
- 94 lx coupe weight
- how to remove/install front rotors on 97 accord?
- h23 swap in 94 accord : power steering
- are 90-91 distributors and 92-93 interchangeable?
- looking for 90-95 obd1 accord shell!
- Newbie Accord Owner
- 98 singlecam vtec injectors flow rate
- May drop car, and put rims: question regarding brand and size
- Accord Gauge Cluster Removal
- Ignition Question
- Just got a 1994 LX Coupe and want to update my ECU what should I do?
- diagram for 91 accord
- Going to test drive once more before I buy.. things I should look out for?
- 94 accord rear bushing question
- 90 Accord Chime location...
- 03 accord v6 high rpm noise
- Everyday Driving Turbo Accord LX 94
- HELP! Tranny fluid change!
- boost or all motor?
- how do you know your DISTRIBUTOR is going out or is it my MSD 6al?
- What's a good amount of turbo boost for everyday driving?
- h22 1/4 mile times????
- OBD1 MAP sensor pin?
- jdm headlights.....???
- Need Help Finding Aftermarket Parts for my 2004 Sedan!
- have you had head work done on your F?
- Helix Power Tower...
- Looking to get blue prints of my car
- P1164 Error Code PCM/O2 Sensor problem
- Accord Idle Surging
- Thermostat question
- First step modding my accord
- Is It Possible To Take Off the Turbo Charger??? And Still Drive The Car???
- some thoughts on oil and tranny oil...
- coilovers?
- why cant i post in classifieds?
- HELP ME !! lost all pick up
- Oil Pressure Sender/Switch leak?
- question
- Strut bars or sway bars?
- 93 Accord radiator replacemant tips
- 95 Accord Distributor Problem....HELP!!!
- Emmisions recall on my '99, should I do it or not?
- how do I adjust my headlights?
- Temperature Sensor not working right
- intake exhaust
- "S" light keeps blinking?
- JDM headlights for 01 accord
- Brake Swap
- please help, cv joint 90 lx
- ecu pinout
- 98 Accord Ex V6 - I need a transmission!!!!!!!! a few questions for you guys
- 97 Accord Ex with 97 Prelude Sh ECU and a h22 motor? HELP
- fuse panel diagram
- PRICE ON H22 SWAP?????
- '96 accord-misfire cylinder #2?
- Installing muffler
- Want turbo or supercharger for 94 Accord Ex
- Need 1996 Accord right lower control arm
- Can a 5th gen use a s2000 oil filter?
- is 18's too big or will it cause any damage overtime for my 99 accord
- brakes upgrade for 92 accord
- H22 accord swap shop in san diego/LA area?
- Just purchased a 96 Honda Accord EX 5spd
- 94 Accord EX -- ignition issues
- engine swaps
- 94 honda accord idles
- installing fog lights for 98 accord.
- A couple questions on my 93 Accord?
- torque converters 97 accords
- 90 Accord LX Questions on self fixing.........
- Security system swap - 97 SE to 97 EX?
- f22a tranny gearing
- Tighten Throtal Cable?
- Headlights are uneven
- 90 accord short shifter.
- Street Tire?
- ODBII Codes P0420 and P1457 What's Up ?
- throttle body problem
- 94 ex accord Hesitation in first gear
- 1994 honda accord LX cooling capacitiy? how many gallons of anti freeze?
- Skunkworks Coiloversleeve help please
- F**kin' Tranny Problem. Help Please!!!!!!
- Strange Noise while letting off throttle
- Turbo Kits or V6 for an Accord?
- 1990 Accord Coolant leak
- Would like information on the 2003 Accord
- i want to buy a exhaust for my car..
- wiring speakers
- stumped!! no spark
- Help with A/C please
- 1994 EX Oil Drip--> Oil Gasket? Pan?
- New honda emblem won't fit the back of 97 Accord LX
