View Full Version : Honda Accord (1990 - 2002)
- Fuel pump installed!
- 97 Accord LX- No spark, changed coil/control module. Help!
- power steering
- transmission swap 94 honda accord EX vtec
- wtf....brake question.
- 1999 CL Headbolt TQ Numbers
- Pic Request (Deciding on wheels) - 5th Gen Accords with Rota Grids! OR Volk TE-37's!
- replaced instrument lights, now srs and maint lights are on and D4 light doesnt work
- Bleeding Brakes On A 1996 Accord
- 90 honda interior part - needed bad
- New to Honda
- WHAT KIND OF SUSPENSION IS THIS?
- drop springs question 98-02 accord
- H23 in CB7 FAIL help
- Ignition or starter: Click, click, then starts right up
- bpi velocity stack on f22?
- 5th gen accord questions + more
- CLKUP ... question(s) ...
- how can i tell if the tcu is bad
- 95 Accord ex Problems
- aha! O2 Sensor Found
- H22A2 air trouble, please help!
- 1993 Accord - Brake Lamp Indicator on
- f23 vtec swap in 90-93
- MP1A swap for MPXA?
- Brake warning lamp
- 2.2 Vtec leaks coolant out of radiator and fills up overflow tank? backwards?
- My radiator is full of air.
- vtec sputtering deep intom 2nd gear
- h22a head on f23 help
- Odd Noise.....Leak?
- ELINALANE
- 96 Accord leaking oil, need help.
- anniversary edition?
- 2000 ACCORD 3.0L V6 MOTOR MOUNTS
- JDM black housing headlights
- Transmission fluid leak?
- Cluster and Power problems
- S light blink code please help
- shift lock key for 1996 Honda Accord 2.2 liter
- efficient hierarchy of upgrades? Opinions please.
- H22a swap fuel rail question
- Auto trans 1st gear slipping?
- Cant believe my eyes......crankshaft pulley fell off while driving on the freeway....
- (P1457) Estimate from mechanic. Fair?
- Quick question about my 97 CF5 Accord here in Misawa Japan
- I Need A Left Rear Caliper!!
- possible suspension trouble... need answers pls.
- Tranny wont shift!!!
- wow can my life get any worst?? :( plz help me!!!!
- Misfire Problems - 2001 Accord Coupé
- HELP catalytic converter problem?
- sh trans lsd
- '99 Accord vandalized, but alarm did not go off....
- 1994 honda accord problems
- NEED HELP
- New to honda's a few questions
- Unusual Rattle
- H E L P....engine sparks
- Synthetic Oil?
- H22 into 4th gen.. what PS?
- 99 accord tune up?
- 2005 Elec Problem
- '99 Honda Accord LX - Check Engine Light? Code PO135 ? PLEASE HELP!!!
- f22b2 crank and crank but no start!1 :( help me plz!
- GROSS POLLUTER
- speedo doesnt work
- Standalone TCU / TCM
- Transmission Problem, possibly
- headers f22b2
- new compressor, new drier, no leaks, charged up. still blowing hot air ????
- 94-95 Rear License Plate Cover
- NEED HELP car hesitating when accelerating and jerks
- A real basic question.
- Slow Oil Leak, not sure where it is leaking
- Possible Transmission Fluid In Radiator
- injectors help
- 90-02 Accord BS thread. Keep it clean.
- This Important? And What is it?
- 91 Accord gas gauge question
- CB7, Engine Cranking, not starting, Ticking Noise?
- "plaque" on top of the engine is... green?
- 91 Honda Accord Car Alarm won't de-activate
- 4th Gen Sleeper project
- Mysterious Oil Leak + Oil always on
- Thinking of Buying 95 Accord w/ 167k. Advice
- Synthetic Oil + 02 sensors
- How to I replace my ECM?
- windshield wiper switch/contacts
- Idle Issues & Oil Pressure Light?
- Remote key replacement
- Accord 2001 V6 Odometer number scrambling
- door sensor???
- F22B2 Oil Leak
- intake advice
- 1995 Accord EX Wagon - Trunk Lock Problem
- ECU Auto to Manual Question
- Honda Accord 1997 Automatic not starting
- paint job?
- clutch pump question
- Euro-R vs. Skunk2 Manifold
- A trick to help with timing belts or setting valves
- 1990 Honda Accord, another question
- 99 accord--->engine light problems<---
- code 43 and fumes in cabin '90 accord 200,000Mi
- Best Plugs for f22b2?
- Engine Coolant Sensor Replacement
- Prepping for eventual h22 swap.
- F22B1/97 EX Seafoaming?
- decode 2001 accord transmission vin numbers
- Brake light
- 1990 Honda Accord, Here's a good one for you!
- 92 radiator brackets
- Help 00 Accord EX w/ CEL But runs fine
- Youtube DIY Videos
- majorly overheating help!
- Difference between auto and manual in performance?
- accord 2000 its crank but no start
- 1992 accord help asap??!!!
- High Nox Level & Failed Inspection for 95' Accord
- 97 Accord Dash lights, parking lights, tail lights not working
- ABS Light
- 90 accord engine help
- wheel hub question
- Removing Alternator, out the front?
- What Does This Do???
- 2000 V6 Radio Wiring Diagram
- 98 Honda accord brakes
- 95 accord coupe brake trouble
- looking for p19 tcu
- cb7 h22 auto swap problems..
- AC On and Off Auto?
- 99 Accord 4 cyl. Tranny Sensors?
- f23a1 timing belt replacement
- P1456 DTC is sure difficult to solve!
- The Accord is number 1 again!!!
- Timing Belt valve adjustment + brake question
- AEM EMS Pin-out for Nitrous help!
- HIGH RPM on my 94 Honda Accord swap a 94 H22.
- rebuild or swap
- 1991 accord ex questions
- Q about secondary o2
- 96 accord ex headers question
- f22b1 dist question...
- 1990 Accord LX idles at 0 RPM
- 98 Accord no dash lights
- Issue with a dealer, Crown Honda Southpoint in Durham, NC
- Rotor + pad installation cost?
- Cyl 1 and 2 not working when engine warm
- 91 Accord Problems
- New member needs help! 91 no start! please!
- h22a head on f22a1 block
- 91 accord no start/no spark?
- P0135 Error Code for '96 Accord (help please)
- 1993 accord SW ex CODE 12 WTF!
- 92 trunk light ?
- accord ps woes
- 1997 Accord LX 2.2 Oil Pressure Problem!
- GOT PROBLEMS
- 91 clutch questions
- h22 swap in my aaccord
- Acura CL ?
- 95 accord exhaust
- HELP ON INSTALLING RADIO
- Rod Knock Fail?
- Helms, Haynes, or Chilton
- Random Power Loss in 6th Gen
- F22a1/f22a4 easy HP under $250
- Eibach sportline springs + ??? what shocks
- p1295 FINALLY SOLVED 01 F23A1
- Headers question?
- brakes not catching please help!
- 91 accord eengine swap
- H22 exhaust options on 97 SE
- F22B DOHC swap
- Parking Brake Adjustment (Rear Drums)
- speedometer problem, shows 10 Mph always
- accord brake lamps
- where can i get an H22a engine around orlando Florida?
- 94 accord ECU question
- black tail pipe smoke when idle 98 ex v6
- h22 swap or turbo f22b2?
- 97 accord Engine Cleaning?
- Advice please?
- Cost of auto to manual swap? # of labor hours?
- b20b knock sensor/p28-p72??
- Fuel Injector Tip/End (pics)
- Spongy breaks....
- jdm/mugen/spoon accord help
- DC5 pistons in F22a question
- 97 accord dx will not start
- 92 Accord front subframe replacement ?'s
- Properly Bleeding Coolant System?
- F22 VTEC into 96 LX
- 02 Accord Suspension
- 95 accord wagon
- Keyless entry module schematic
- 2000 Honda Accord V6 engine problem
- 97 Accord EX HELP (Steering/Suspension)
- electrical problem; 94 EX-R
- F22b1 1997 Accord EX ECU/O2 Sensor
- 1997 Accord UNUSUAL PROBLEM (Front End) Please Help.
- 99 v6 accord steering wheel spline/hub size???
- 97 Accord Door Ripped OFF. Need help Fixing.
- Cleaning IACV, FITV and TB
- Hello everyone; new around here.
- accord meet colorado springs co
- 94 Accord Fuse Box Diagram
- Where can i get a launch control for my 92 accord F22a1 NON VTEC
- F20b/h22 swap question?
- Car died and won't start
- 2000 Accord P1457 Code. Diagrams?
- changed my coolant....
- F20B engines, variations?
- H22 type R euro engine to a 97 SE
- accord 1999
- 90-93 Cylinder heads the same?
- vtec head swap???
- intake manifold gasket
- how to convert 92 accord OBD0 to OBD1??
- Radio code ErrE ?
- 2000 Accord Capiler Bolts???
- A/C Pressure Testing
- Replacing an alternator belt on 94 Accord
- resist box, injectors
- 93 Accord SE stuck in a gear?
- Power STeering line.
- seat swap?
- starting issue... HELP
- 94 Accord Questions
- 91 accord distributor vs. 92 accord distributor
- Balancer shaft question
- What factory 98 CL Option went here?
- f22b2 intake?
- cel light.
- 1997 Accord. Just replaced my condenser...need help!
- 95 ex wgn transmission issue
- Camber, caster, toe & a dropped 1997 acura CL
- Strange hestitation on warm-up
- 94 honda accord lx electrical problems. help!!
- 92 Accord LX - D4 No More Codes But Flashes
- Anyone have any luck finding an internal distributor seal
- Newbie help...
- Post up your coupes!!!!
- fuel pressure return line
- where to buy Gold Trunk trim for '97 EX
- recall on drivers inflator airbag on 2001-2002
- Squealing noise in a 1994 Accord LX
- Help???
- 1999 Accord power locks - need help
