View Full Version : Honda Accord (1990 - 2002)
- 2005 Accord owners get ready for the recall notices
- need help with fog light upgrade, please help
- ICM problem, PLEASE HELP
- Honda Accord 2002 EX Alarm
- Cone Air Filter Cleaning?!
- my first car 94 accord vtec
- H22 type SH motor question
- 90 Rear Drums Dilemma
- What OBD is 97 Accords?
- Rough Idle
- pcm problem with 98-99 accord v6
- Any1 here have an AEM pressure regulator?
- Acura 17" Wheels on 2004 Accord LX?
- H22 1999 CL Tuning question
- Tire or Wheel Bearing Roaring??
- HELP 1998 accord stuck in park
- right?
- What mods can I do?
- h23 intake mani on a f22b head?
- obd fault code p0137 for a 99 accord!!
- Car starter?
- f22b1 into 90-93 accord.... Anyone done this??
- 1998 Accord Type-S tiptronic
- ball joint replacement question
- Coilover question 99 accord EX
- Need help installing ignition lock assembly
- Radiator Hose
- buy in volume?
- Junkyard trip tomorrow... Opinions??
- Accord service manual
- rear windshield wiper
- Oil On Spark Plug Wires Changed The Rings WHAT NEXT
- manual swap
- h22 swap question
- Just bought a f22a1
- '92 Accord strange problem with brakes
- Are these interchangeable?
- Hey, totally anti-HOnda Question
- Where can I find some decently priced h22a with warrenty?
- 5TH GEN BREAKS
- 97 accord missfire problems
- about the "JDM " engines
- Windshield wiper
- H22a Type s
- Carbon deposits...
- is this natural??
- 1997 Accord EX 4-cyl timing belt woes
- My rotors are rusted!! Recommendations?
- rear brake caliper help
- Where can I get Apexi WS I
- Rims
- tuning options for turbo automatic accord?
- TCM code 2 help
- car doing something strange when accelerating
- GC Coilover and KYB AGX installation
- '99 Accord Fuel Tank Pressure CEL problem. Gas cap didn't fix it...
- Owned by a rock moving truck...looking for parts
- i got a turbo kit for my F22(now i need some help)))
- SRS LIGHT CAME ON AFTER TIMING BELT CHANGED
- eBay auction correct or not?
- 93 accord problem with tranny
- aftermarket intake ---> more gas usage?
- will civic radiator fit 93 accord?
- FREE 40 point inspection from Honda dealership
- Need help with my accord
- 92 accord tranny?
- Engine Issues
- Which Coilovers shall i get?
- short shifters?
- 92 honda accord has speedometer problem?
- f22 na
- Clutch chatters when cold
- por racing chip on ebay??
- H22 swap?
- seat swap?
- 12 second accord Video
- a mustang guy aggrivated at his 96 ex...gas mileage,water leak,door continually locking
- 90 accord, feels like its missing @ 1500-2200 rpm, only after it warms up, new tune up did not fix.
- removing injectors? n00b
- 94 accord EX Speedometer will drop to zero while driving on the freeway.
- 92 accord wiring a accel super coil?
- quick question about clear cloat.
- 05 Accord Type S (2.4l)
- wth is this knock
- Parts Sites
- 2003 lx transmission and coolant fluid change
- Thinking about getting some skunk2 coilovers for my 92 EX... any known problems?
- Whistling Noise! Engine Bay area, not speakers
- O2 Sensor
- how to connect mp3 wire?
- 00 accord v6 electrical
- 88 LX-i Sedan -- wobbly crank pulley
- F23 head on F22 block
- JDM Side Markers
- Help Installing Apexi Controller
- Anyone experienced in hydrolocked cars?
- weird beeping sound
- Sometimes my brakes are great, other times eh
- swap help!
- Anyone used Nopi's brand
- Attention all 6th generation accords!
- 94 Accord Rear window install, NEED help, Please
- 94ex vtec ecu
- HELP! My engine is hydro-locked!!!
- Radiator Leak questions
- State Inspection w/o PS
- need info on headers
- jdm h22a into 94 accord problem/question
- 5-SPEED WAGON STOLEN
- HID Lights - Which ones and installation?
- turbo kit
- Check engine lite
- Car Willnt Start HELP
- 2002 honda accord V6 making me Stress out
- help...coolant temp is 140^c
- 1990 accord won't start, searched but they didn't answer, please help
- Accord Problem PLease Read!
- 2005 Accord LX Navigation Modding exist?
- Code 401 2000 Accord EX V6
- Check Engine light on my 6th gen
- my accords radiator blew up
- what IM do i have
- HID HEADLIGHT SYSTEM AND HEADLAMP Q & A?
- 94 oem prelude springs to raise a 95 accord....and its still slammed
- sidemarker bulb - 95 LX
- Stone Chips - 2005 Accord
- Question about key and programming Accord '03
- Leaking Oil, Special Plug?
- 02 sensor - Universal or OEM?
- js racing carbon fiber intake h22 accord?!?!
- 4th gen heater control replacement
- box dimensions for 92'ish accord
- cv joints/ axles something wrong
- Can someone help me!
- 7th gen accord!?
- body repair and school project, help!!
- vent shade thingies?
- Might buy 95 Accord LX Coupe, Have Questions
- Sunroof?
- high beam socket lock
- vtec problem
- vtec problems
- Have a question about engine mounts
- Power Door locks noise
- h23 engine
- 6th Gen Accord ?
- high gas pressure?
- Reverse Lights
- installing front axles
- tailight problems...
- where can I get a F20b engine in so cal and would install it too?
- Will 92-96 Prelude radiator fit on 94-97 accord ? Also other simular question ?!?!
- f20b + tranny
- replacing ball joints
- which brake calipers fit? asap
- Cruice Control on New DX
- Newbie -Cold Air Intake?
- 6th gen 4cyl to V6
- Rough/Changing Idle
- deep water + low intake =heavy knocking
- Not Valve Noises?
- HELP ME PLEASE
- headers port smaller than stock and new head
- 2001 Accord Question
- 05 Accord alarm install - will it void electrical warranty?
- Valvoline Max Life - 5W30 or 3W30
- changing my timing belt..take out engine?
- 99 accord f23...should i go h22 or just turbo f23...looking for exp. input...
- High RPMs but not picking up very much speed???
- WTB f22a1 header
- Oil Question
- 90-93 Accord Cat Back FS
- tokico kit excludes vtec?
- Throttle body carbon buildup
- Had a dyno run today
- 88 accord dash lights
- 01 accord question
- Accord tranny/H22 engine (cons)?
- 91 Accord ran out of gas
- Accord revving problem
- Question about Accord aftermarket Headers
- 1998 4dr accord wheels
- 98-02 Accord J30A1 V6 Turbo Kit? Does it exist?
- Maintenance Required Light.
- Car struggles when starting.
- 5th gen: brakes: av6 rotors/brackets with 4cyl calipers?
- Stearling wheel volume and audio buttons
- Has anyone else put a f22b1 in a 4th gen accord(90-93)?
- f22b1 build up
- Parting out on a 90'Accord
- Diagnostic Jumper were it is?
- AEM SRI or Injen SRI?
- old question about egr
- rubbing/clicking sound when making right and left turns
- Replacement Radiator
- 02 honda accord (ex) looking for top hats for my full body coil overs.......
- V-AFC II Program and Setting SET_UP
- 97 accord trouble with o2 sensor
- suspension setup
- Rims\Sizes 1994 Accord EX\LX
- TSB's
- h22 rear mount
- mugen grill for the 5the gens
- Fxx
- 94-95 vs. 96-97 springs...
- Lifting car for bigger tires/rims? SRS light trouble?
- OWNED, Me, hit by a truck now tranny is FUBAR
- NEW member with 82 Accord 4dr
- egr insufficient lift
- 90 accord actting-up
- help me can't PASS Emission test
- Euro Intake Manifold....
- BAD BATTERY ?
- i have a q about the shift linkage on the accords
- 6th gen 15" OEM rim weight
- question on installing intake..
- My accord shuts off when I stop, need help!
- Questions for Steering wheel hub for 94 Honda Accord
- This is one for all the guys that have a accord and want to build F22B1 monster.
- I have a smashed 84 BMW 318i....can I switch out the seats into my 89 accord?
- 1st Gen Accord Parts and Literature
- Best rim color for 6th gen coupes?
- annual millage service question (7500 etc)
- 90 accord pulsing problem
- when i shift into R, my car rocks back as if it's ruff, got a Q bout seafoam
- Ignition wires,,,,what is the 5th one for???
- 99 ACCORD / CUTS OUT ? ? Garage says its the clutch??
- can 17x8 +35 offset wheels fit a 5th gen
- New Fuel Injectors/Pump
- battery light 88 accord
- Exhaust question!
- 1986 -1989 accord suspension help
- Need help parting off an 89 Accord
- ex to jdm
- engine swap
- Where is the oil pressure located
- how can i avoid increasing insurance rates from accidents
- Need Help Converting My auto tranny to Manual on a 1994 Accord Sedan,Please give me instructions tha
- new clutch...
- Changing oil pan gasket on 97 EX?
- is this a good deal
- 02 Engine code
- Cam tower seals?
- taillight question
- <<New battery, 90 accord wont start unless jumped???? Anymore ideas
- Help - Clutch Adjustment
- JDM Stanley Black Housing Head Lights
- 1990-93 single overhead cam turbo
- Help
- exhaust problem
