View Full Version : Honda Accord (1990 - 2002)
- Redlines H22A
- Noise and Vibration
- Transmission Fluid
- 98-2002 accord 4-cyl. question
- Looking for an engine for my 90 accord, not JDM, US spec
- changing antifreeze
- Question about tire and rims??
- d-4 tranny light?
- 2003 honda accord navi, can it watch dvds?
- What should I do!?
- auto to manuel swap around mid-west area
- valve cover spark plug oil seals
- Euro R?
- Start then immediate stop.
- Wheres my oil going??
- Was there any Accords with 15" 4x100 wheels?
- 94 center consol on 97?
- Turbo or All Motor
- Accord 98 v6
- Cooling Fan wont turn on...
- obd2 p13 ecu for sale
- Vibration at idle
- New member here just saying whats up didnt know where else to post it.......
- whats the timing setting for a 98 accord 2.3
- master cylinder n break booster upgrade
- '91 accord
- is this possible?
- Throttle Cable to use for H22 in 99 Accord LX?
- h22
- Help please!
- Looking at 90' Accord, but no AC.
- any auto accords that are turboed?
- Civic Owner needs help with ACCORD swap....
- WELD HEADER FLANGES???
- 6thgen Intake Air Temp Code 10
- H23A1 with F22 Auto tranny in a fourth gen accord
- Rough Idle
- 6th gen Accord 4drs suspension : What Other car would it fit ????
- VTEC Controller for 7th Generation Accord
- Thickness specs for vavle adjustment on f22b1
- How many quarts for 97' V6 oilchange? and what grade oil?
- Clutch problem....
- Anybody making a true short shifter for 6th gen?
- B18 c5 (Type R)
- best quality oil filter?
- Az peeps***STOLEN ACCORD***
- time for new radiator?
- Transmission Problem?
- best turbo for 96 lx accord
- PLEASE HELP!
- h22 into a 92 accord
- NOob question about suspension
- Axles for h22a/Accord ?
- trouble
- Will a 2001 auto tranny bolt up to my 99 accord V6
- abs light
- Is this idle normal for a 98 4cyl ?
- lx or ex?
- Any one have the answer to this ?
- Reset Switch for the 7th Gen Accord
- camber kits interchangeable?
- lucas products?
- tranny code 14?
- ** What is the widest I can go on Accord 6th gen (1999 4drs)
- 2000 accord horsepower
- short shifter
- REMOVE RADIO COnSOLE
- Need Help, where can i purchase an SRS Unit and ABS Unit for 94 accord EX
- oil in spark plug chamber
- Tranny question
- h22 mounting question........
- ** HELP F23 NO Power over 3500 in 3rd and 4th **
- i installed my new intake, thanks everyone who replied me.but a q. come out
- h23a non-vtec running h22a vtec ecu...possible??
- 97+ Prelude Springs/Shocks on 99 Accord LX?
- 1992 Honda Accord EX (H22a) for sale
- helping a friend on accord swap info
- DOES TRANS FROM MY 91 ACCORD 2.2 FIT AN H-22 90/93 PRELUDE
- Problem With CCT axles (NAPA)
- Euro Accord Type R engine
- Vtec Head
- **ANYONE W/ A STOCK 98-02 ACCORD?**
- Back to the drawing boards
- 3rd gen motors
- ACCORD ENGINE AND TRANNY SWAP HELP
- ATTENTION: Anyone with a 98+ HELMS manual
- Alternator - WEAK
- Limited Slip for 03 Accord EXV6 AT
- antifreeze leak... HELP
- ATTN: has anyone ran into a SuperCharged H22 powered Accord?
- Installer ELectronic climate control from a V6 into a I4 (1999 Accord 4dr)
- Accord Clock Bulb
- Fastest Accord
- which exhaust?
- Valentie 1 Headliner Removal/Hardwire Install
- Odd starting problems. Sometimes resolves itself
- help me out here guys. need info
- No pressure in clutch pedal
- BAD gas mileage?
- FS:Turbo H22 Accord stuff, everything must go~~~ Thanks NICK
- 93 prelude auto tranny into 90 accord
- H22 on a 6th Gen and JR Supercharger-- will it work?
- timing jumped a tooth
- removing oil pan
- H22A Automatic Transmission
- Flywheel / Clutch
- Swap info requested: '94 EX into '91 DX
- Any suggestions??thanks
- Will Integra seats from 94-00 fit in a 5th gen Accord?
- VAFC 2 Installation instruction Accord with H22A OBD1
- F23 IAC plug doesn't fit the H22
- prelude passenger motor mount in 93 accord
- has anyone's 98-02 accord been stripped recently??
- Accord v6 ex
- Question
- clang clang
- 1999 Canada LX-G Accord 4drs : Does it have rear disc or Drums ?
- F22 motor H22 tranny
- anyone have pullies on their 95-96 accord lx??
- Heater and AC problems!!!
- Car is posessed!!! Wiring problem? *help*
- 1990 Accord shakes at Idle
- 90 Accord with a H22 swap getting CEL. Help
- 6th gen amber light - how do I get rid of that amber strip?
- JDM Accord - J25?
- what's this?
- 90-93 accord parts car owners....
- Problem with my H22 Swap
- 2003 Accord radio removal
- I need help with a problem with the light on the AUTO shifter
- MSD BTM from FMAX on 6th. . . and strut bar ?
- what models can I use as a replacement IACV for my 95 accord EX
- tranny swap
- 92 EX Auto The shift gets stuck when put in park. I have to use my key to shift gears!
- How to jump ecu for codes on 1992 accord?
- HELP WITH 2003 ACCORD COUPE!!!!!!!!!!!
- Wiring F23 to 92 Accord
- About Honda Coolant....
- anyone riding on HP or GR-2 ?
- H22 Shift RPM
- Tie rod end
- ***** Are Accord injectors same as Prelude 290cc ?
- irratic idle and bogs down on accelleration, seems to have amiss in it.
- Cold morning start + shift into gear = car chokes and dies... help?
- control arm/camber question
- Heating system isn't heating up that good
- the guy at honda said this...
- 97 four door honda need help
- Euro-Type R Accord Engine Swap
- exedy cluth difference
- 94 ex door lock motor
- HELP! losing brake pressure in 94 ex with abs!
- front bumper fitment
- Stock Accord 1/4 mile times?
- Cruise Control light is out (button) 6th Gen.
- D4 Light :(
- 91 accord
- starter bolt Q
- f22b auto tranny swap?
- Prelude brake/suspension swap
- hey does any one know if this is true?
- 96 accord heater problem
- Fmax turbo for 6th gen...is it good?
- can anyone give me some advices??
- safc 2 setting first?
- to turbo an f22b2???
- bosch platinum (not the +4)
- srs air bag light
- tail light sensor comes on!
- Drum to Disc
- AEM pulley belts
- rough idle
- got my new manifold w/ pix.. also a fan question
- 2001 Accord pulse speed sensor pin??
- J30 manuel trans possibilities
- H22 w/ manual conversion on a 6th gen auto--
- trunk leakes water....help!
- what would you do? OEM or buy new on internet?
- NEED HELP Adjusting Depo Headlights
- rich, lean ?
- IACV for 95 accord EX
- turbo for accord 1990 with engine f22a1
- how to get euro r conversion?
- Tires for Stock 15" Wheel ...
- 5gen starter
- 94 ex tranny
- Accord tire suggestions
- 96 Honda Accord ABS Light Question
- vtec oil pressure switch on 95 f22b1
- anti-freeze question?
- grinding noise, perhaps starter issues?
- Info on 2000 vs 2002 ECM's
- 90' Honda Accord | Transmission Code | Engine Code
- JDM Euro-R Recaro Seats
- Valve Adj. Specs 96 Accord LX
- Exhast
- Leaking timeing belt cover
- Short, long block
- Torque..
- Getting and find Transmission codes
- 90' Accord EX | Automatic | Shifting in reverse
- Cleaning The Engine
- Repetitious Clicking Noise When Rolling
- speed sensor question for 90 Accord LX
- TL Sway Bars on an 02 Accord
- auto accord to h23a 5speed
- new f22a1 valve cover?
- 91 Accord Transmission Problem
- ATX to MTX swap in a 6th Gen Accord
- 95 Acord lips selection
- Sluggish Auto tranny
- Accord Relay problems?
- Jacked up exhaust story
- Strange noise when I let out the clutch on my 92 Accord
- question about replacing head.
- 97 accord 52k automatic pinging noise when accelerating HELP
- 1993 Accord EX Vacuum question...
- How Big A Tire?
- Emissions ~ Need help!
- Ultimate Accord Sleeper
- suspension question
- VAFC Removal question
- F22a1 performance mods....
- H22 over heating!!
- replacing timing belt.. A DIY job
- best headers
- 96 accord headlights
- gas milage
- Turbo on non-vtec
- 91' Accord 4 point seatbelts install?
- Need tires for the new Accord...
- bouncing tach
- Accord Transponder Keys
- Problem with idle speed???.....really wierd problem
- SCC swap article
- Check Engine Light For 01 Accord V6
- Brakes on 94 accord EX
- Fuel Pump
- Spoiler Question?
- Apex'i WS w/ Straight Testpipe vs. Resonated Testpipe
- 1986 ACCORD LXI MAIN RELAY LOCATION?
- springs for 94' accord
- will 98-01 leather fit in a 96?
- Lightweight 15" rims
- Online website for timing belt change?
- How much you think I can get for stock a/c parts?
- 97 accord susp question..
- No VTEC
- compression testing?
- F20b in a 6th gen Acc
