View Full Version : Honda Accord (1990 - 2002)
- Inncorrect valve cover gasket?
- Stock d15 swap?
- 2000 Accord IACV Repin
- low idle at cold start 90 accord
- SPUDDEER somtimes
- 2000 Accord 4cyl VTEC Immobilizer
- ECU swap / electrical issues
- Need suggestions for my '90 ACCORD LX
- Please help me
- 1997 accord SE p0135 location?
- 2002 Accord LX 2.3 vtec sedan
- Can cleaning the carbon resolve the knock sound problem while acceleration?
- 98 Accord Transmission Swap
- Quicker ratio steering rack - Where do I get one?
- 98 Accord Instrument Lights "shorted out"
- 99 Accord V6 E-Brake light comes on and off
- Need help; completely lost.
- Auto to 5spd swap questions
- 6th Gen Accord Fuel Pipe Leak - Need repair advice
- Question???????
- Engine ran 'rough' once... problem?
- Brakes
- 2001 Accord Heater/AC damper door not working
- Knock Sensor Error
- Where to find 99 Accord replacement cyl. head?
- 1997 Honda Accord SE needs help
- DTC P1399 P0303 Problems
- Cleaned IACV and EGR on 6th gen Accord. Now idle is more sporadic.
- P0303
- 94 accord corner blinkers stopped working plzzz help!!!
- Horn Fuse Keeps Blowing
- help, leaking bolt, no clutch pressure
- F23 / G23 - Thick Headgasket??
- 01 Accord Overheating
- 1997 honda accord funky issues
- Loss of power
- 94 accord needs new water pump
- Left my head lights on.......
- 2000 ACCORD engine coff
- 2002 accord ex v-6 coupe: tcs light on
- accord 1991 F18A1
- 97 Accord exhaust leak?
- Clutch Slave Cylinder Alternatives?
- oil leak
- 2000 Accord lunges when shifted into park
- Note: Brand new expansion valve was bad
- window frustrations
- 1997 Accord cranks, doesn't start
- Projector HID retrofit in stock housing - Cheapest ?
- F22 VTEC conversion 5000 rev limit ???
- paint job cost?96 accord ex
- Heater not working - How to diagnose
- 92 Honda Accord EX engine revs down at 64-65 on highway.
- f22b2 cam removal
- A/C blowing 90 degree air
- ELECTRICAL BOX UNDER CAR SEATS
- DIY: 96 EX Accord: EGR
- N/A accord 1/4 mile times
- 93 Accord EX: Service port issues
- 95 Accord Brake Issue
- 1991 accord won't stay in lockup?
- Bitter Winter, which Oil??? 0W-30?
- 1994 Honda Accord Ex Temp Issue.
- wurring noise on releasing clutch
- Seems so common, but still can't figure it out. :(
- Voltage dropping
- Strange noise and vibration on clutch pedal
- Accord 93 CODE 43
- Radio memory
- 1996 honda accord power locks
- 97 honda accord with ABS problem
- Help Help With my 1999 Honda Accord IGNITON SWITCH OR NOT
- Door Panel
- various vibration
- Ignition switch replacement + wiring hackjob, wtf!?
- Big decision : repair oil leak in spark plug + brake line rust OR buy another car
- f23 vtech to h23 vtech
- 91 Accord problems.
- Automatic Transmission Problems
- 95 Accord Idle Issue
- 94 Accord starter
- 98 acura cl H22 and auto to manual project help
- 92 Accord Ex Code 43/Timing issues
- Engine loops when trying to start
- 1997 accord - P0401 code, how to clean EGR ports?
- window glue?
- How hot does your 5th gen accord run?
- Intake?
- Problem with starting 02 accord after it's been sitting for a year
- 97 accord a/t starting problems
- 96 Accord F22 Vtec - h23 fuel injectors make a difference?
- 2002 Accord V6 - CEL and TCS Troubleshooting Question
- 91 Accord wont run after distributor O-ring replacement.
- Accord 96, strange door power lock problem.
- Tie rod end play?
- 1994 Accord LX - Loud click when I let off the gas
- 97 Accord Transmission Issue
- 6th gen accord 4cyl automatic.
- 98 Honda Accord EX auto 2.3l ----ABS control module and VSS
- Vtec solenoid removal
- 2000 Accord V6 Fan A/C not Working-Blower Resister?
- 2002 - Rearender today
- Accord 2002 Window Stuck - No Power
- Wiring Help
- 1995 Accord EX issues NEED HELP!!
- 2000 Accord will not start
- what to look out for on a bottom end.2.2 h22a7
- 95 Accord swap f20b problem with wire harness
- Honda Oil Cooler
- 1997 accord leather interior options/questions
- Good body kit for 97 Accord?
- 94' Accord won't go past 20mph?
- Rear swap
- 1998 Accord EX 4 door :: front suspension suspension sits very high
- 91 Accord Front End Noise 50+ MPH
- Anyone know what this is?
- 1997 Special Edition exhaust - pre-cat parts?
- rev limiter changes from 4000 to 5000rpm
- 98 accord rear window regulator problems! i never seen b4
- Transmission or Sensor issue???
- H22a VS H23 Blue top Vtec
- Dead cylinder?? Possibly
- where's the fuel pump?
- accord drag suspension
- 95 accord with h22 swap from f22
- 98 honda accord cannot start
- new distributor! but...
- Accord 97 ex stalls while driving
- code 43 emission failed.
- dome light
- obd2 h22 usdm p5m ecu use?
- 1995 Accord Electrical Issue
- 98 Accord EX Abs light / brake troubles
- Starter Issues on 1997 Accord I-4
- 1997 Honda Accord SE F22B2 Build or swap?
- widest 4x114.3 wheel BY honda
- 4 cyl has no balls
- '97 accord christmas tree lighting problems
- Accord transmission/clutch woes
- 96 Accord rotor problem?
- Radio Problem
- Engine removal guide???
- 94 Honda Accord Radio Code
- '92 Accord Starting Issues
- sputtering
- A/C expansion valve torque specs for 1998 Honda Accord LX 4 cylinder
- 91 Accord rev only in drive, reverse works.
- '02 Accord: Abnormal Series of Engine Issues - please help!
- Help! All spark plugs going Black.
- Reverse Noise
- 2000 Accord in dash CD changer Cover
- 96 honda accord v6 2.7 power steering problem
- Accord 92 oil in sparkplug well.
- code 43. need help!
- Strut replacement
- 96 honda accord egr problem
- '91 LX belts
- Accord bogging under normal acceleration - Problem AND Solution
- 94 honda accord ex - No crank no clicks...bad starter solenoid?
- Problems with my Accord
- clutch problems
- Low Power when AC is turned ON
- Accord 92 - Did this brake overhaul!
- 92 honda accord D4 light stays on??
- abs code 5-8
- Clutch poped then real light
- Codes...
- 92 Acc shifts late 1st->2nd. Possible causes?
- 1990 Accord Heater Core
- door indicator dont work!
- 98 accord transmission interchangeability
- check engine light problem
- surging idle issue
- measure radius rod accord 96 picture
- Need help! 94 accord struggles to go
- F20b motor M2B4 Tranny Clutch Set that will fit.
- which is PS return hose?
- 96 Accord LX cooling fan stays on after engine bay is detailed.
- clutch or master/slave cylinder?
- Automatic to Manual Transmission Swap
- 1995 Accord Transmission Issues
- vtec at all times
- 96 aftermarket audio issue
- 13" Rims??
- 1997 Honda Accord, P1361, P1381, P0301, P0302, P1300, P1399 & Engine stalling
- odd starting problem and out of ideas
- FelPro Oil Pan Gaskets...USE AT YOUR OWN RISK!!!
- Accord Intake Issues
- Rebuilding a Keyless FOB
- OEM Oil Cooler, yea or nay?
- Read Error code on Accord 94_F20B2-Engine
- ECU Testing
- 1994 honda accord trouble please help
- 99 accord temperture guage not working
- 96 transmission grenaded
- jdm f22 sohc non vtec into 96 accord(misfire)
- 1999 Honda Accord 4 cyl power steering fluid quantity
- Acceleration cutoff higher speeds, Need bigger injectors?
- 1991 Honda Accord
- HELP ME PLEASE
- RS*R Exhaust gasket
- 97 Accord - blower speed and temp knob not illuminating
- Oil pump balancer gear case
- Need help
- Random heat spike?
- Honda accord 2001 V6 I messed something up
- P1361, TDC intermittent signal fault
- Accord 92 intermidiate axle
- 2001 Accord 4 cyl - Help removing a spool valve assembly
- '91 Accord DX ignition problem
- pictures comparation brakes disc pad and hub vigor vs accord 94-97
- Engine bay dimensions
- 2000 Honda Accord - Maintenance Suggestions
- Excessive oil burning/coolant loss
- 1994 Accord seat-belts interchangeable with Integra/Civics?
- Swapping trunk lids on two 1991 Accords
- f22b2 to f22b1 vtec swap
- 95 accord h22 swap
- Need help 95 Accord!
- 94 accord lx, Wont start after sitting for a while
- Can excess pressure in the fuel tank cause a no start condition?
- 1990 Accord Service Manual- missing pages
- Dash light fuse
- Cb7 p/s delete
- 94 accord wire help
- 95 Accord Wiring Harness Question
- Mystery Connector on 94'
- 91 Honda Accord speed sensor??? Not sure if this is my problem
- 92 Accord Ex Maddening Bogging
- question about carbon tracking in distributor cap
- Brake Light fuse keeps blowing
- no vtec
- 1991 Accord revving wgile in park
- 1996 Accord lx stalls and sputters when coming to a stop?
- HELP HHHEELLLPPP, '97 accord
- Weird wire on 1992 Accord
- Lowering a 97 accord help
- Honda Accord Bulb change doesn't work on one side only
- Code 43 need help Urgent.
- 2001 Honda Accord Expansion Valve replacement
- Release fork vibration and release bearing noise
- Low Power after driving
- Accord SiR (h22a) Possible Problems
- electrical problem from hell need help asap!!
- clutch/pedal/bleeding advise
- What is it now? Knocking Noise...
- Front End Chatter/Rattle Type Noise
- 1994 Clutch Pedal Question ???
- Ugh! EVERYONE is out of Koni's for 90-97's!
