View Full Version : Honda Accord (1990 - 2002)
- Can slightly wrapped rotor cause vibrations?
- buying tires tommorow, any flaw in my desicion?
- A Place to buy 98-02 OEM Accord Under Spoiler Kit?
- Whats the 0-60 time on a (stock) 1991 Accord 4 door 4 cyl automatic?
- Technical Question: Can anyone Please help out a fellow H-T member?
- Uh Oh
- radio security
- 97 Accord SE, radio interference with defroster button ?!?!?!
- Spring install gone wrong?
- Little bit of a different motor swap
- question on how to read codes
- momo steering wheel installation
- f22 + h23 tranny
- why is my gas needle jumping all over the place?
- Need Help Installing a new Intake
- FINALLY pics of my engine almost complete
- DIY fuel injector cleaning??
- Question for 98-01 guys??
- about the mid-to late 80's accord hb......
- guage sensor reading hookup
- need your opinion on tires
- turbo manifold for 99-01 accord coupe
- heater/defrost buttons/lights not working
- Older Accord Intake In My 6th Gen
- Rear Motor Mount
- Should my cousin Trade his 1988 CRX SI for a 1991 Accord EX coupe
- Glove Box Light
- broken camshaft at gear area due to oil deprivation
- planning to install new flywheel. reuse flywheel bolts or buy new oem ones?
- How can I tell if my shocks are going bad or have gone bad?
- 94 Accord non V-TEC switch to ACCORD 97 v-tec
- Will 93 Prelude 15" alloy wheels fit well on 91 Accord?
- Difference between OBD's
- 90 accord ex, spark plug and wires covered in oil
- Need the name of this part where the axle goes into the tranny
- rear low arm
- broken brakes???
- 97 Accord SE
- accord turbo question
- where to buy hoses
- HELP : Lo Beams Not Working!!!
- how to wire an F20B in a 2002 accord
- quickk...... are 93 ex and lx thermostate the same???
- 02 ACCORD struts...
- good shops in Minneapolis?
- 91 Accord Auto EX, won't run
- Steering wheel shakes above 60!!!
- how can i get the ball joint off a 92 lx?
- Favorite Year for the Accord???
- Sparkplug for F22B1
- I want to buy Honda. Plz Help me guys.
- How do you guys clean your engine bays?
- my cf hood
- soulracing.com? ever buy from them?
- door light on 94 accord keep comming on
- how to kill an engine????
- Car Keeps Dying: Need come ideasa or suggestions
- 92 LX Problems... TPS? Tranny?
- Lowering
- 94 Accord non-vtec to vtec changeover
- How to take gas out of an 5 gen accord LX
- 1990 Accord w/ h22a swap...
- stereo security code
- greddy sp cat back 3 weeks old. cheap will fit 98-02
- Bright headlights for better night driving
- Turbo Timer Help
- Blown Fuse
- My Suspension: A month of driving now...here's my thoughts
- 1986 LX-i parts
- I need to talk to everyone with a 4th gen 5spd that's running an h22 or h23.
- Twin Turbo 4cyl??
- PROBLEM: 2001 ACCORD EX-V6 w/ Check Engine and TCS lights on
- Tranny Rebuilt
- 94 Accord (red face gauges) ferrari style...
- H22A dyno
- is there diff. between 94 OEM & GREDDY Lip?
- A/F guage in 5th gens
- Engine swap & gauges question
- gas pedal is sticking. what do i do???
- my 89 accord lx 5spd has major issues
- My $200 accord
- needing some installation help here please
- Boosted accord from Austin in Odessa.. you on here?
- '96 EX exhaust manifold on a '96 LX
- Lights
- Replacement Seats
- Front bumper
- figured out my lag... still need help
- ABS Fluid
- Brake light comes on when cold
- 96 clutch?
- H&R Springs....
- European Accord
- 90-93 injectors put out how many cc's??
- Why is my "Brake Light" on (the one on the pic of the car that lights up when your bulb is out.)
- brake rotor torgue specs
- Just Purchased Neuspeed Konis For $460...couple questions...
- how to: amber gauges in 4th gen accord (90-93)
- ABS light on while driving
- mods for autoX
- Good Place To Buy Online?
- will a 96 civic power window regulator work in a 4th gen accord?
- 87 Accord, Dr. Headlight doesn't work.... need help fast!
- Where did you get the best price on your clutch?
- 99 accord swap??
- help with speed sensor
- newbie here_____PLEASE HELP.
- H22a/accord turbo kit
- L.A. Please Read and Help Me!!!!
- bad main bearing
- turbo f22
- shifting problem in 2000 accord
- AEM intakes for cheap!
- Lowered 4th Gen Accord Extreme Camber Problem???
- intake, gas saver?
- F22 heads
- Time frame for changing waterpump
- sluggish lag STILL!!
- found out why i blew up my engine
- OEM brake pads, where to put the lube?
- Problem after installing intake
- resurfaced flywheel
- D4 light problem..need serious help fast!!!!
- fried ecu?
- front bumper lights
- paint question
- best street shocks
- F22 engine specs needed asap
- just not my day, got sent the wrong cam gear I think
- anyone interested in holding a ny/tri state area meet?
- Help W/ My 94 EX Coupe, TPS Problems
- dallas meet tonight
- the IAC valve; how does it work?
- the search for the accord cage?
- '00 accord v6, stalling after start - any ideas?
- need help with '88 Accord...not getting any gas to carb.
- Cooling fans
- Where Can i Find?
- FYI: Classified forum split.....
- F22 rod big end diameter?
- 1997 accord ex smell
- 1991 Accord heater ?????
- resonator question?
- motor swap q's on a 92-93 accord, SUGGESTIONS!
- anyone doing your brake swap get your rotors here.
- VAFC fuel cor input ?
- I have a possible trick lock, can you confirmed
- SOHC F23a1 Tech Info Help
- Sunroof on 97 EX
- An awesome supsension
- fuel efficiency at idle?
- 97 lx motor in a 95 lx oossible?
- Balancer shaft oil seal product update
- you'll like this one.....
- 2000 Accord Auto Trans Problem
- installing alarm in 4th gen.
- Is it still rice if I'm just trying to be cheap?
- Was there a recent recal incl. 95 accords?
- Where can i get a new gauge cluster?
- Squeaky Suspension!! Cambers??
- 94 ex 5spd starter
- Best N/A engine swap?
- tail light removal question
- Tire Size Question.
- Help on Swap guide for 6th gen Accord
- fuel injector plug removal
- ATTN: everyone with AEM Cold air intake
- headlight assyembly
- Odometer Broken, help???
- '91 Accord Question Regarding Trunk
- head swap question for and 92 accord....PLEEZ HELP
- How should I set this up
- Clutch pedal no pressure
- 98+ Rear Upper Strut Bar: Do they exist???
- How do I start my Honda with my Carburator flooded ??
- 1/4 Mile Times????
- How Do You Recognize Wear And Tear On A Timing Belt?
- Accord motor, 16 valve SOHC???
- shaking leads to stalling......causes?
- new engine worth it?
- what local tire store could i goto to order kumho's?
- Maybe a we should have a price list?
- 4th gen starting problems
- Put my wheels on now?
- When you go to a dealer for parts.
- f-series engine conversion swaps
- dsm 440 injector fitment
- Windshield Wiper Problem on an '91 Accord EX
- How do i take off ball joint and tie rod end boots?
- Helm manual specifics
- vtec crossover
- newbie question about cd error code
- my new MPG record. 471 miles.
- CEL Code on 98 v-6 .. 17 or an 80??
- Intermittent stall issue with my 88 Accord DX coupe
- Car Computer
- Attn: All turbo Accord guys....
- A faster accord?
- 94 accord ex intake question...what the hell is that thing under it???
- ground wire kit in 94 accord
- Service bulletins (TSB)
- Smelling exhust or gas in the blowe vents???
- Anywhere to put gauges in a sleeper/functional manner?
- Compatibility: CL/TL Type S parts with 98-02 Accord V6
- tweeter question for 6th gen...
- p14 ecu
- Any other 7th Gen Accord sites
- Help w/headlight resisters
- postin in killed section?
- Just got an accord!
- 5 Lug w/ Type S wheels on accord?
- possible 6th gen accord theft in progress...need info
- Struts? 95 2dr
- What OBD is a 94 Accord ex?
- h22 swap question
- FYI - used 94-97 Accord Auto tranny in los angeles
- Installing H22a in 93 Accord, AC and PWsteering problems
- 1996 Accord EX; Parking Brake then ABS Warning light?
- KYB vs. Koni
- Oil Gaskets?(Labor)
- 2003 Accord EX
- 90-93 accord short shifter??
- Install Radiator Fan?(how to)
- A few questions about my new car...
- Intake Question
- Just got my 94 Accord Lx with 45k miles (big plans no money)
- because is it a big swap from 96 accord to h22
- Cheap $15 ebay front/rear strut bars
- Anyone ever ran a GSR ECU on a H22a4?
- Title Transfer
- What is the meaning of each number in the VIN#?
- anyone have a diagram for the clutch master/slave cylinder?
- HELP ! I made a burn mark on my passenger cloth seat
- 97 Acura 3.0 CL
- not getting 1st,3rd or 5th in h22 90 accord
- Locating Rear Strut Towers On 6th Gen Coupe?
- Hesiation
- my bad experience
- h22 question for a accord swap
- code 43 need help to fix fuel system
- Car Dies Out
- shifting the auto
- How many 5th gen av6???
- anyone have an extra carboard thing that goes under the carpettin in your trunk? sits about your spa
- Compression test out come???
- Anyone make an Intake mainifold for f22's
- How long do I need to wait for the prices of the 2003 accord to go down ?
- vtec head?
- Winter clean up
- F22 dohc head
