View Full Version : Honda Accord (1990 - 2002)
- Best turbo kit for a 97 honda accord? and a little help needed from all Please......
- Broken timming belt
- 1996 Accord Automatic Transmisson fluid lines to and from radiator
- *URGENT*
- 98-01 accord 4 cylinder head bolts torque specs?
- 94 ABS light
- question about spoon calipers
- Removing dome light on 97
- How change power steering fluid?
- HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!!
- 92 ACCORD AUTOMATIC GRINDS IN REVERSE
- Thinking of forged rods and pistons for your f22?
- big problem need help ASAP
- how to determine if your coolant temp sensor is bad?
- 90 Lx not starting
- H22 QUESTION!!!
- Emergency Brake Light
- which year has an 11" press on brake rotor?
- 91 accord radiator support~
- Front wheel bearings
- camber and caster help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Fan stays on after car is off.
- cooling fan- most common part that fails?
- Looking for injector o-rings
- replacing 92 Antenna Mast ??
- TYPE-S CAMS?
- My '99 Accord has a tempermental start. Please help.
- For anyone who is pissed about the downing of the accords the other day
- Radiator Q's for 6gen 4cyl auto
- Mufferl Problem.
- 96 Honda Accord sponsored by Quantum Tek Alloys FOR SALE
- Tires
- hi and muffler
- radiator removal/replacement
- Halogen Bulbs for 1994 Accord EX
- what type of clutch & flywheel
- hubcaps
- f23/22 question
- clicking sound from fan
- Question on Mufflers
- Accord 95 LX Power Window Question
- What Rotor brands to get?
- 2000 Accord HU Problems.
- Burning Oil!
- Accessory Pouch w/door under the radio
- Seattle-area Honda owners willing to help?
- i have a 93 accord but i need help
- WTB Accord 92-93 EX 5-speed Only look!!!
- Heater Problem w/2000 Accord
- I had some work on my car..
- wtb 96 accord lx man trans wiring harness!
- srs complete removal questions?
- Understeer
- How to check fuel pump circuit 1990 Accord ex
- misfiring..code71-76
- 94 Accord 8psi tunning question.
- Tranny Slipping . . . sort of
- remote start and lights....
- I NEED HELP? 1992 ACCORD
- Weird problems with 99 Accord
- Oil
- very bad sound from around front right wheel
- euro r redline?
- suggestions for exhaust?
- how easy is it to remove and get my throttle body bored out
- Accord hondata questions
- Tran fluid
- what would be some clean looking add-on kit for 4 dr. ?
- accord 2000 lx radio problems.
- 04 v6 accord exhaust
- Engine help-ROUGH IDLE!
- 91 EX Service Manual
- Rough Start
- ECU advice PLEASE HELP
- a/f gauge problems!
- front tires air loss
- car puts when idle in park
- can someone help me out pls, car dont start
- Help Removing Windshield Wipers 1991 Honda Accord
- bore out or buy headers?
- taking out ps
- "1987 accord"
- RPMS drop down to ~900-800 (from ~1500) when i start engine.. What is it?
- 1994 Accord ignition
- 1994 Accord suspension pop
- Another Hybrid Thread for you Accord guys... F23/H22...
- Rear Motor Mount
- heater probs
- Air cleaner element - '97 Honda Accord 4
- next engine mod
- Is this just a fuse?
- 2004 accord starting problem
- 98 Accord V6 Starting Problem
- Up and down idle...
- power window problem '96 accord lx
- jdm h22a died please help
- How to decarbonize Honda V6 engine ?
- Looking for tires. Need opinion
- Newbie - Help on Old Accord?
- Will this service manual work for my car?
- Turbo kit for 00 3.0 accord?
- Bosch Dud?
- 98 accord 4cyl tranny on 90 accord?
- Leak
- no spark on 94 dx
- Premium Gas VS Regular Unleaded 2004 Honda Accord LX - Does it Matter?
- Is the 2004 Honda Accord EX SIRIUS or XM ready?
- Alarms
- Headlights come on fine, parking lights don't stay on... help?
- curb weight?
- Links
- 96 accord can't shift into gear after engine startup
- Dash Trim
- Curious if this has happened to anyone?
- DISTRIBUTOR PROBLEMS?
- something's leaking pretty bad
- My dashboard looks like a Chirstmas tree
- wholesale offers on ebay fact or fiction
- Pulley Kits
- 94 accord
- 1987 Accord Not starting
- Can I expect more power by boreing out the carb then buying new headers?
- Any advice for a J30A engine swap?
- jdm f22b engine?
- Weird Idling when in park
- 6th gen h22 swap questions
- Some Jerk backed into my mom's car... Where is a good place to get dent removed?
- '95 accord 2.0i tdc sensor error 8
- 27MPG HWY on 87 EFI, normal????
- 1992 Accord will not start
- Newbie? Stock Sedan vs Coupe Auto EXV6 Suspension, Is There a difference??
- 6gen accord 4cyl AT solenoidHelp
- how do i tell what year my block is?
- install gauges
- interested in getting '93 accord....
- 7th Gen. Accord Audio
- Booster air leak - Brake Gurus please help
- Newbie here... secondary o2 question.
- opinions on 95 fog lights
- What did they do wrong?
- need info on throttle bady spacer 4 95 f22b1
- Need Help with Automatic
- would this fit please help?
- Swapped Accord
- 1977 Honda Accord Heater Control Valve
- CAI 3" vs 2.5"
- side airbag light????
- Weird problem with the V-AFC II
- transmission parts
- newbie here...on exhaust
- 95 accord with H22, #3 code
- 6th gen rocker panels
- New With Accords Who Can Help?
- Write up - Dealer replaced catalytic converter 98 Accord OBD2 P0420...finally for free.
- Anti-Theft Bugs
- superficial scratches on alloy rims with a clearcoat finish
- help...frozen crank pulley bolt
- Just about to tear her apart
- Installing Mugen 4-2-1 headers in 98 accord
- 92 Accord Fuel Pump/Main Relay
- 92 Accord LX has a hole in the Exhaust Help?
- 94 h22 Baffle plate removal?
- H&R race vs. Eibach Sportlines
- 92 Accord Cooling Part Help - fitting rusted off
- 86 Accord won't start when temps are cold outside
- Can I use a 1998 GSr hydro tranny for my F23A1 engine
- manual H22 transmission + F23 engine???
- 5th Gen Temperature Knobs Loose/Broken?
- quick tire question
- Accord seat convert.....
- Greddy Emange on Boosted f23 Question
- 97 EX brakes
- why are accords slow
- will not start
- ARP headstud TQ specs?
- Is there much difference between dc header and dc style on ebay other than quality?
- smoked tailight
- 1978 Honda Accord LX CVCC vacuum routing
- Honda recalls 257,616 04/05 Accord sedans (airbag issue)
- eliminating balance shafts
- vtec headers vs normal headers
- I put a spyder kit on, where do I put my directionals.
- PLEASE i need all opinions on this
- question about AEM brake pads
- does the h22 fit directly into the 2002 accord?
- attempting to identify calipers
- Scratches
- Anyone have pictures of there car with Eibach pro-kit springs or H+R Sport on there accord?
- h23 head on f22 block
- Oil and filter change intervals on a 2004 Accord
- Will this magnaflow converter work well with my cat-back?
- projector headlights
- brakes not quite right.
- Rebuild power steering pump?
- Official Accord Turbo Thread?
- im needing someone to give ideas on what i should put on my car
- 92 Accord, High RPM's?
- 92 crunchy tranny...
- Need Help With Camber KIT
- Would you buy these?
- violent shakin
- Accidental SuperCharger Sound
- Stolen Honda Emblem
- Cold Air Intakes...
- white steam coming out from the hood?!
- 2001 EX rear spoiler
- 2004 Accord 5w20 or Mobile One 5w30
- Front motor mount accord h22a w/turbo
- 97 ex, removing door panel? tips?
- Unorthodox racing pulleys
- Confused.. installed catch can and vac. manifold and no boost!!
- removing AC unit from 95 accord??
- Key sometimes wont come out of ignition
- PROBLEMS WITH THE SRS
- vaccum advance ???????????
- ****ground wires****
- Newbe?Basic Improving handling without lowering,how??
- My Accord won't start right away
- part interchange
- arrggg, so many problems.
- DIY type-r grill
- ultimate swap guide
- airbags stolen
- Front brakes
- 4th gen prelude seat brackets and 94-97 accord brakets the same?
- 94 Accord, one side is lower than the other
- Accord Hesitation
- voltage blues
- 04 audio/hvac doesn't light up
- Tach jumps and engine sputters
- lowering my 99 accord
- 17x8 rims
- curious of what heads fit on the f22bs block ?
- 92-93 prelude rims 61/2 inches WIde fit 1996 accord?
- power steering pump the same 1990-1993?Pulley size is different?
- Check engine light
- Timing belt and water pump needs replacing.
- 94 accord need short shift kit
- GUDE services
- DOOR AND KEY LOCK FROZEN
- my car make tic tic and they don’t start
- code 22 but i dont have a vtec engine?.
- 6th Gen Accord (4cylinder) Cold Air Intake Installation Questions
- accordex-t turbo vs my nos b16a teg
- how come my acc. only brings one mirror.
- new turbo setup, questions and replies very much wanted.
- Hard Time Starting In Cold
- bleeding the brakes
- T25 DSM Turbo!! Civic or Accord?
- Curious to what you guys are shifting at?
