View Full Version : Honda Accord (1990 - 2002)
- F22 and H22 header ??? anyone ever deals with an ebay header ?
- Vtec
- 2001 4-Cyl. coupe LX distributor cap & wires
- 96 LX 5sp F22B2 clutch problem, wearing out too fast?!
- Accord De-cat
- limited slip tranny for h22a
- Chance to buy 99 coupe
- ACT clutch & flywheel for Accord
- Are the I4 5th gen accords really faster than the V6's?
- Brake light is on all the time
- Thermostat or what
- Cat back exhaust options
- inlet/outlet sizes
- AUTO TO MANUAL CONVERSION???????????????
- Coolant Disappearing
- New to Hondas few q's to ax
- Speed Sensor Installing help
- charging problems
- h22a wire harness for accord
- First Car 96accord, $5k to spend... suggestions??
- '97 accord front bumper/bumper cover removal?
- Transmission noise - Help wanted
- head bolts
- Spoiler for Sale.
- How to post pics?
- Transfer case output shaft?
- does my moms car have a fitv?
- Spring Rates
- Compression Check
- accord mirrors on a prelude
- 2dr too 4dr lip
- Anyone have Electrical manual for 98-02 Accord?
- G-Series Plugs or Dowel???
- question about clutch wiring for a 1994 accord auto to manual swap
- starting problem when hot
- lowering my Accord
- Nitrous purge kit
- h23 vs jdm f22
- Poor Gas consumption on 90 Accord after engine swap
- Srt-4 inj
- Aux. input on Factory Radio (2005 Coupe)
- Just Got a Another Accord...here come the kinks...
- hid or projectors
- 96 2.7 V6 questions
- Puzzling Light
- H22 head swap
- Dual Tip exhuast DONE.... but now its whistlin
- DSM 450's on 91 turbo accord
- 03 V6 6sp coupe going back to stock
- SELLING ROTA TRACK R
- Dash light
- engine mounts
- 94 Accord- starting problem
- Engine mounts - Accord 2000 - 4cyl
- Does a 1992 Honda Accord EX-R requires a engine Heat-up time?
- 90-93 Clear Honda Accord Corners
- Power Locks broken...clicking noise
- When does the service manual call for valve adjustment on accord?
- Fuel Pressure test port
- '02 V6 EX - sporadic srs/side-srs light, maint req'd light until fastening seatbelt -help
- intake for 04 accord v6
- 1986-1989 Transmission for sale???
- cel codes
- 1992-93 Accord vibration in D4 and Reverse
- rear suspension clunk
- Differences In Suspension Set-up
- 92 accord cruise control and power door locks
- accord 91 shift grinding but doesnt do it when car just starts up?fluid?
- replacing front cross member
- CEL help
- fuel injector ?
- few ?'s
- Side Mirror Options
- Signal lights not working...
- head swap
- atf- what to use?
- Homelink
- Fuel pump not getting power..help
- OIL Pan Install: Tips?
- Non Intercool'd
- Need Help !
- Brake conversion
- Clutch Master Cylinder Leaks?
- ABS SIGNAL
- computer problems?
- Engines sounds like it's full of marbles
- 5gen SPARK PLUG GAP ?? WHAT IS IT ?
- Noise after lowering
- what tranny is this?
- Bumper lights on 4th gen, just for show?
- HELP 92 Accord Ex throwing code 12
- Really quick easy question...
- Cruise Control Issues...
- exhaust system 96 honda accord and v-tec controller
- location of intermittent wiper relay
- Replacing AC and PS Belts...
- oem wagon grille
- 1989 Lx Auto -> Serious Idle issues Explained IN DETAIL
- 93 accord auto to 5 speed swap
- Need info fast please
- Alternator Terminals
- Rear Control Arm Bushing Help Needed (w/ Pics)
- Is the f22b DOHC worth it?
- 88 lx fuel cut-off relay
- 96' 5speed beeps 3 times at keyturn, battery seemingly dead
- Bleeder Screw Broke
- valve lash for a 92 accord ex?
- Springs Question
- Need Help on my 04 coupe
- what other wheels fit a 92 accord?
- Outside Window clip/thing
- Does anyone know how to remove the gauge cluster
- 96 accord power window sticking
- CAI for 97 Ack CL
- accord h22
- Acura TL 98 Seats Question.,
- Need help fixing alignment after accident
- Accord 98 V6 Coupe - RIMS 19 - Rubbing
- Honda 2004 Stereo Problem
- 95 Accord annoying rumbling and vibration
- which is my vss?
- Replacing AC and Power steering belts, need a little advice...
- A Request for New Arrivals (Noobs, ect)
- 94 LX exhaust
- More problems on the '82 accord. :-/
- Any way to check codes other than dealer?
- 99 Accord Brakes
- PROBLEM WITH ACCORD.. *with audio*
- Glasspack Mufflers?
- stupid/annoying engine noise.... potential bigger probem?
- light not working
- 96 Accord Conversions?...
- Prestone flush n fill kit on a 5th gen?
- Grillz
- 98 rotor removal help !!!!
- 6th gen accord dash lights
- WTB: 94-95 OEM Black front grille...
- question about air intake for a 1993 accord lx. i know this ? gets asked a lot but i cant find it i
- Eibach sportlines?????
- 99 accord throwing cel code 9
- 1995 Accord Audio Head Unit issues
- people that did auto to manual swap
- 94 lx questions
- EGR valve issue fixed
- electical problem please help!
- Window not going up in problem zone
- CB7...more letters?
- idle issue
- FS: 98 and up coupe head & tail lights $200
- '92 Front Suspension
- LED lights
- f22 rod bearings size
- driving the streets w/o your front bumper, getting repainted
- Ground Controls *SALE* 1998-02
- Timing belt chaged now running diffferent!! Need help
- 1984 Honda Accord Hatchback
- installed clutch kit and new fluid now grinds and wont take gears in high rpms
- Just finished a retrofit for a 94 Accord
- Need help with 1992 Honda Accord
- Slow Window Operation
- cb7tuner.com for CD's.............. :[
- 01 accord airbag
- EX header
- is it worth it
- honda-tech decals?
- Boosted H22A
- '82 Accord Pictures.....
- My car is running rough after installing my camber kits PLEASE HELP
- Swapping prelude rotors
- North Dallas Mechanic
- Throttle Cable
- 91 EX w/Manual Brake Lights
- 91 accord tech
- 94 Accord, 232,000 miles--vibrations when accelerating only
- air/fuel ratio gauge help
- 95 Accord starting ignition problem
- 98 accord wiring
- Rear speakers for 92 LX
- Intake resonator
- 91 Accord annoying problem
- 92 Accord Front Bumper Removal
- Front Bumper (1990 accord)
- 86-89 Accord owners/parts holders
- 90-93 accord 5 speed?
- Transmission fluid add in 91 accord dx m/t how to
- COMPLETE NOOB with suspension
- Headlight question
- Need Advice on Suspension set-up ( 96 acc 4dr ex )
- Things to look out for
- lowering springs
- how much are tail and head lights worth?
- Is this harness from an Accord of any year?
- 92 LX w/auto transmission problems
- p12?
- h22 swap from hell almost done, now no vtec
- quick ways to gain hp cheap
- Factory CD player issue
- 94 accord h22 swap, atuo to stick swap as well
- $2 dollar chip for 20 hps!!!!!!
- rare problem i wish i was making this up...
- 94 accord rear struts
- How do you tighten the alternator belt?
- any useless parts
- passenger door panel
- '82 Accord the saga continues. :P - Some questions also....
- picture posting
- Wheel Offset?
- 5 lug (in process of)
- Rota Wheels!!!!
- Any 5th gen on H&R's??
- 05 accord tranny problem
- Brake Lamp Light
- How wide can I go?
- differences between 4th gen and 5th gen
- 1994 honda accord remote start installation
- How much to Turbo a F22
- i cant start a new topic
- oil leak, more serious than suspected...
- dual tip muffler on a 4cyl
- Question on a 94 accord
- f22 swap
- H&R sport and kyb gr-2
- problems after installed camber kit
- Honda Accord Factory Alarm Help!!!- I need to uninstall it
- Resistor Box Question?..
- headlight seal?
- Aftermarket intake manifold...
- Check Engine light
- WTB Accord '05 OEM Driver's Side Fender.
- Make a show car?
- Request for before-drop with new rims pictures
- sicccc
- Sqeeking front suspension 97 LX Accord
- jdm, usdm, type-s: how and what to build fun!!!!
- Dash and taillights not working
- installing electrical chairs..
- special k
- V6 Peak Torque
- Problem with speedo>??
- For the NOOBIES
- SiR Question
- suspension tech.
- Will they fit?
- 03 Accord Coupe-Stupid Headlight Bulb!!!
- Underdriving?
- 7th Gen Guys! 06 Interior Shot w/ Trim Kit and Hybrid Mirror Question
- How to prove legality of engine?
- 1997 Accord EX Tranny Trouble/Question
- Key question??
- which muffler and manifold to choose
