View Full Version : Honda Accord (1990 - 2002)
- Turbo fitting
- i just picked up an 87 accord is there a motor swap i can do?
- Euro headlights, can't take off bumper
- splicing
- "Max boost" with 11:1 cr with stock sleeves????
- Colorado Accord Meet
- catback exhaust
- obd2 h22 into obd1 accord ex
- '96 Accord OBD2 wiring diagram
- 93 Accord - Spindle Nut - Torque Spec?
- Attention any 4th/5th gens interested in the GREDDY Front Air Dam...
- 6gen f23a1 intake manifold question
- Timing belt broke, possible bent valve?
- brand of oil?
- No Power in first gear
- Car Door is Locked Shut
- 2000 accord, can't get rotor retaining screw out
- CV joints
- 1993 Accord overheating --- help !
- Lightest and cheapest 15inch rims for a 5th gen?
- Sixth gen sedan spring rate questions
- car starts but radomly dies?
- Anyone out their selling a 90-93 accord coupe 5 speed
- prelude suspension into accord???
- ECU issues
- need info help
- How do you check and possibly change the motor mounts??
- paint chips on hood
- Something you don't see everyday
- 1991 Accord EXR Wagon Cruise Control - intermitent problem.
- 1990 Accord EXR Speedo intermitant problem.
- 1990 Accord EXR fluctuating idle when cold.
- Major Problem Still Exists
- auto tranny q
- Gauge lights question (SRS & Maintance Req.)
- 94 front bumper
- 2000 Accord Coupe Ex
- Which camshaft is good for my 98 accord??
- air conditioning?
- Big Problem, Need Help
- Hyper Flex kit need help with Strut rod bushing 90-93
- 2003 rear bumper removal?
- Weird Smell
- Honda Accord '88 Dashboard light not working.
- 85 ACCORD CARBURATOR SWAP
- What kind of camber kit
- boosting an accord
- SAFC hack
- Intercooler is installed, help me find a good air filter solution!!
- I have a sinking/little resistance pedal after a new MC. Adjusting brake pedal pushrod? bad booster?
- engine turns off when i pull a wire
- tail lights on ?
- body kits
- noob-cv joint and axle
- Hey..U cant swap engines anymore!! NEW RULE..
- CAI install on 96 accord... HELP!
- ? for 5th gen accord LX MT owners
- any have a roll cage in there 4gen?
- New generation accord coupe suspension
- newbie question about air intake, sorry
- 7th wheel bearing at 230,000 kms.
- Missing piece in turbo project: HELP!!
- 92 Accord Cut Out
- problem with h22(posted in prelude forum too)
- i finally installed my SPC ball joint camber kit.
- Anyone running 4 piston caliper brake kits on their 90-3 Accords?
- HELP, stock 4th gen. exhaust needed in So. Cal.
- front upper control arm >> front upper ball joint
- Advancing Timing...?
- A/C PROBLEM
- accord shakes, what might be wrong?
- 1989 Honda Accord Engine swap
- Coolent
- Vortech FMU Ratio
- upper ball joint removal from the knuckle????
- New Buyer.......
- Brakes squeaking;Honda Mechanics dont know whats up.
- h22a turbo?????
- 89 accord bolt pattern?
- progress report
- Throttle butterfly sticks. Best way to clean/lubricate?
- Boosted F vs. N/A H...
- MY RADIO BROKE
- Weapon R throttle rotor.
- hybrid cooling question
- h22a1 with nos
- lucas upper cylinder cleaner
- coilover question
- another accord losing oil post
- What should be done?
- 92 Accord Exhaust Question...
- 96-97 bumper light...
- camshaft F22B
- Camshafts for the F23
- Question about Rear view camera and putting car in reverse
- ok ok ok so im getting a drop.....
- Hesitation on 95 Accord LX
- 5th gen bumper question?
- 94 Accord Power Steering?
- best exhaust combo ?
- Thinking of getting a 94-97 Accords, What should I look out for?
- Car falls flat on face
- Show me an Accord on 17s
- help Replacing rotors and pads help!!!!!
- took out waterpump now car wont start HELP
- HELP! Car won't start...starter works but won't turn over
- cruise control ?
- Floor Mats
- cai install 91 accord
- 94 Accord EX Crashed...Who Wants What???
- prelude guy needs tip for automatic accord tranny fluid replacement.
- car wont start in heat!?
- H22 Final Drive in a F22 Tranny
- clicking sound from around the steering gear area
- How to change axles?
- need info on a shock to compliment my h&r race springs
- kyb gr2 shocks-----any good on 5th gen with hr race springs
- specs on valve adj..for accord???
- Anyone has 18"s?
- pulley advice?
- at what milage do you adjust valves?
- something wrong with my engine???
- New to the Honda World
- Tire Size Question.
- jacking my car up need help
- window problems?!
- A/C R-12 or R134a
- Are there Gabs for the 5th gen?
- Magnaflow 14814 muffler
- 90-93 accord short shifter?
- 96 accord LX back brake disc conversion
- 96 Accord LX
- Sixth gen V6 suspension in 4cyl?????
- Front Axles...
- h22a vss problems(searched)
- Radio/CD Player Help
- Transmission problem?
- Help! Pressure build-up in f22 head??
- 90-93 accord tranny vs. h23 tranny?
- Need a 94 LX 5 speed Tranny
- Tein coilovers.
- best how to......
- gas tank on a 93 accord
- Accord H22A Auto to Manual Transmission
- Any bulbs instead of HID kit?
- 5th Gen Accord on 6th Gen wheels
- Camber Kit
- 2003 Accord Lug Pattern
- please tell me... (pics)
- Canadian Emblems
- Cam Regrinds... Specs, Opinions, etc...
- Clutch Noise
- How many miles does your honda have?
- Just an FYI for Vexamus and others who question the k24 in the new Accord...
- Dumb question...work w/ me
- Replacing Driver's Rear Window motor in 91 Accord?? Suggestions?
- Buying a 2003 Coupe...
- nissin or akebono for 92ex?
- Re-doing interior!
- engine swap...
- prelude auto trans in a accord?
- Picked up a 96 accord V6 did i pay to much?
- Air conditioner problem
- max shot of NO2 for my 94 accord???
- air conditioning
- strange ticking from 2002 V6 Accord.. need help/suggestions please!
- Overheating Accord >>>>>>>>>>>>>
- Accord LX drums
- 94 LX Auto Tranny min-dillema
- any 03 accord websites
- Noise when applying brakes
- tail lights filling with water
- cooling fan problem
- plug gapping
- civic w/ f22???
- where's the water pump?
- Reseting SAFE MODE
- Valve Adjusment Specs - need ASAP
- Overheating Problems
- problem with my air conditoin
- electrical problems
- Custom Painting, i.e Side Skirts and such
- Gas Mileage 1991 Accord LX
- 93 Accord - Instrument Cluster
- seat belts....
- OBX headers
- best place to mount oil pressure guage
- how to jump the check engine light on a 96 ex
- 16's on a 5th gen?
- new tires
- Tranny problem
- Problem with my right fan not turning off
- I need a pic of clean radiator insides plz!
- accord air filter
- motor swap
- newbie trying to replace brakes.
- DIY adjustable speed flasher link?
- plugs for boost
- Prelude seats in accord
- MF2 Wiring question
- No headers for the 03 Accord V6...
- asdf
- Removing chrome strip around windows on 96 EX
- Good performing NOT LOUD exhaust...
- Subtle lowering of '99 LX sedan....
- 94 accord, 98 Acura Cl seats are direct bolt in??
- Check Engine Light
- AC Needs charged in 96 Accord...HELP!
- accord dx
- where to buy h22
- oil on spark plugs.....help!!!
- 90 Accord door glass coming out of run channel
- OT:Anyone have dyno'ed VAFC on 6th gen f23a1/4
- Can you even feel a difference when modding a auto 92 accord lx (4dr)?
- Gauge Trim
- Any 5th gens here with a Tanabe Racing Medalion?
- Are sunroofs worth it?
- h23vtec in a 90 accord
- h22a
- Bought a 99 Accord, give me some motor basics:::
- whats a good exhaust pipe size?
- ... what year/model accord did this console pocket come from?...
- Getting The Best Fuel Economy Out Of Your Car: Tips & Tricks
- JDM accord with the B18A was carb'd??????
- Daytime Running light in 94 Accord
- to shave or not to shave?
- 5Gen Accord V6 HP
- 2k Four Cylinder Specs?
- rear clanking noise
- Which models/years come with V6??
- Recomendations for a clutch kit
- Wheel rim rusted to rotor?! Help!
- 2001 V6EX COUPE WINDOWS
- Crank Pully
- Suspension
- Wheels...
- Stock parts for 97 accord
- not goin into gear easily
- Accord Coupe 2001 v6 muffler and intake
- Automatic seat belts 91 Accord
- I dont know how to take the rotor off Please help.........
- Need some info on a clutch asap please.
- Tan Cloth seats for a 95 accord?
- 6th gen trunk light
- FYI - 92 Prelude w/ H22a1 <$3.5k relatively clean - Los Angeles/ OC area
- Where to install Fuel Pressure Gauge on H22?
- Changing a head gasket, some questions...?
- Boosted SOHC Accord Owners
- 5th gen tune up questions
- Need help smogging my 91 Accord
