raise my compression
Old Jun 12, 2003 | 05:09 PM
veryslowaccord's Avatar
Default raise my compression
im looking to raise my compression, i have a f22b1, would the h22a pistons fit. I know the displacment is slightly different. If they did fit, would they raise the compression?
Old Jun 12, 2003 | 06:22 PM
RABBIT9's Avatar
Default Re: raise my compression (veryslowaccord)
http://www.raceeng.com
They can hook you up.
Old Jun 12, 2003 | 09:28 PM
399$? this is why i was wondering if i could just take some off of an h22. Would i wanna go up to 11:1 compression. How much will this take down gas milage and drivability, what kind of gains are to be seen?
Old Jun 12, 2003 | 09:37 PM
PUREVIL's Avatar
if you are looking at building something.. screw gas milage, and all that.
If you plan on building a NA f22.. Get ready to dish out some mad cash.
Your better off getting some n2o or turbo.. then figure out if you wanna build an na f22 or wanna do a h22 swap.. I went through the price of building a hi compression f22, the price wasnt worth the power.. Then on the other hand you can buy a turbo kit run it at a 7psi on a stock motor, see major gains, then build the f22 for more boost.. The f22 motor is a great motor for boost, starts with low compression. If you want more boost build it for the boost.
but then a high compression n2o fed motor isnt that slow either.
up to you man.. but a NA f22 is hard to do..
Old Jun 12, 2003 | 09:45 PM
f22a's Avatar
to answer your original question, i will sum it up by saying that h22 bores are 87mm and f22 bores are 85mm
it would be more feasible and economical to get forged pistons built for your f22 (if that is what you are going for)
Old Jun 12, 2003 | 09:54 PM
kentucky accord's Avatar
the bore is too big and the wrist pin location is different.
in short, no its not a viable option.
Old Jun 12, 2003 | 10:05 PM
PUREVIL's Avatar
Default Re: raise my compression (kentucky accord)
cough cough..............
ha ha whatever..
Old Jun 13, 2003 | 06:34 AM
if i went all motor what all would i need (im new and i have to learn sometime)
Forged pistons 399$
cam 200$? (gude)
springs ???
would i need a port and polish
clutch ???
flywheel
Plus boltons (don't have yet, just got the car) i/h/e, hiflow cat, throttle body, ignition,
I don't know, help me out here guys
thanks for all you help already
Old Jun 13, 2003 | 07:34 AM
Nick M's Avatar
Default Re: raise my compression (DRAG4ACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG4ACCORD &raquo;</TD></TR><TR><TD CLASS="quote">cough cough..............
ha ha whatever.. </TD></TR></TABLE>
what the hell kind of reply is that?
buy the race engineering pistons
Old Jun 13, 2003 | 07:51 AM
RABBIT9's Avatar
Before I bought ANYTHING from GUDE, I would highly advise doing a search.
I speak from personal experience.
Old Jun 13, 2003 | 07:52 AM
carolinaACCORD's Avatar
if you want a reliable and cheap way to raise your compression a little, find a GOOD machine shop and have them mill the head a little more than spec.
but be sure not to go too much or you'll have valve&gt;piston clearance problems, as well as other stuff.
you will need a different timing belt if you do this though.
Old Jun 13, 2003 | 12:22 PM
im using stock t-belt w/ gude/junk head.
Old Jun 13, 2003 | 12:29 PM
Default Re: (kentucky accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kentucky accord &raquo;</TD></TR><TR><TD CLASS="quote">im using stock t-belt w/ gude/junk head.</TD></TR></TABLE>
how much is it shaved?
Old Jun 13, 2003 | 12:35 PM
Default Re: (carolinaACCORD)
according to them, 40thousandths. im not saying it isnt a little loose, but i use it, lol.
Old Jun 13, 2003 | 12:38 PM
Default Re: raise my compression (Nick M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">
buy the race engineering pistons</TD></TR></TABLE>
exactly.
that dude is a dork.
Old Jun 16, 2003 | 11:17 PM
PUREVIL's Avatar
damn i wasnt serious.. But it takes a shitload of cash to build a NA f22..
I say more power to him if he has the cash to do so..
Im sorry bout that cough cough BS, it was a BS post... I had the same plans to builds a f22, but i got stupid and dished out the cash for the turbo.. But now im a superdumb *** im building the f22 for more boost,, so i guess im in the same boat..
Sorry.
yes im a dork, a big dork. ha ha..
racing engineering pistons.. They do good work.
Old Jun 17, 2003 | 05:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kentucky accord &raquo;</TD></TR><TR><TD CLASS="quote">according to them, 40thousandths. im not saying it isnt a little loose, but i use it, lol.</TD></TR></TABLE>
DAMN!!! That's one hell of a head cut! Hey, if it works, go with it.
BADxKARMAx
Oct 13, 2012 09:25 PM
icebergli
Jul 18, 2005 08:25 PM
TehMoonRulz
May 16, 2005 01:15 PM
jdmlude01
Jan 7, 2005 03:44 PM
s0liDyNe
Jul 19, 2003 10:24 PM
