View Full Version : Honda Accord (1990 - 2002)
- h22 tranny hitting subframe
- Injectors
- Upgraded my brakes today (AV6 rotors & Legend Calipers)
- 94-97 Accord Headlights
- 98-02 4cyl Stick Needed. Free Intake
- cam compatability
- Question about CV Boot
- no boost... turbo help please...
- 4 door '03 Accord needed! Free intake!!
- tires and shocks
- Emissions Test Failed.
- HELP car won't move. Tranny or clutch prob??
- 5-6th Gen Cats
- turbo accord Headgasket problem
- Accord shutting off ? Early Redline ? Help*******
- Where is the scan tool diag conn.
- P0B EcU
- what is the best swap for an accord?
- 95 Accord won't come out of drive. HELP!
- 6th gen suspension (tried search)
- 2002 Taillights?
- Air Condition Problem...
- Leaking coolant HELP
- 1997 Accord needs new timing belt--where to get tool?
- 90-93 interior problem
- Fog Light Bulb?
- Its about TIME! many pics
- Replacing stud on rotor?
- crashed my 98 accord V6, need front end parts...
- Removing the brake pedal spring?
- Pedals for a 2003 Accord
- No Reading from tach, speedo, digital mileage and temp*
- oil change.....
- obd conversion
- Hard cold starting, please help!
- Rims on an Accord
- weird clunking noise
- 4th gen accord, 5th gen engine swap.
- how to repair the board for the Electronic transmission control unit
- 94 accord lx wheel bearing HELP NOW
- will a prelude clutch/flywheel combo work on a 99accord?
- ECU "upgrades"
- Taking the car to trak tomorrow need some advice please??
- 1996 igniter replacement help
- please help... erratic idle- rpms constantly goes from 1000 to 1500 updown up down
- how do you remove the black bracket that holds the alt?
- what can you do with this?
- 4th gen short shifter
- HELP!
- a/c condenser r and r
- Help Please! Accord ECU wiring harness
- 1996 accord lx, h22 swap.. .??
- '03 V6 6-Speed needed! Free Intake!!!
- H22 accord vs turbo D16 civic
- Temp Gauge
- No Power when ac is turned on
- Check Engine Code 1146
- JDM h22a Thermostat different then USDM?
- lighting problems
- 90 Accord auto transmission hard to get in and out of park
- prestone coolant is good with honda accords?
- coolant capacity
- ok if coolant gets on crank sproket?
- water seal question
- need help ASAP...
- Sorry if dead horse....but did honda make '01 accord in LXi????
- want a new turbo kit for a accord??
- accurate curb weight
- crack on timing belt cover
- H22a accord question
- Armrest/Console question for 92/93 Accord
- hey wu warrior
- What is part number for 98 coupe front lip ?
- Milling the cylinder head
- How to remove 95's bumper?
- Camber kit installation
- aftermarket parts for 2003 accord?
- how can I customize my interior?
- How do I take my dash off?
- Burning Oil Like Crazy
- lighter light, ash tray light
- do they make an ecu up grade for my CD7 lx?
- replace boot or axle?
- 1989 Accord Lug Pattern?
- Inconsistent idle, starting and speedometer operation on '90 Honda Accord
- Good online place for discount dealership parts?
- engine serial?
- is that O2 sensor ?
- help with valve train assembly
- where can I find abs codes?
- Speed Sensor
- weight of COMPLETE F22 head -minus valve cover and distributor
- 2003 LX radio removal
- minimal torque
- use threadlock on crank pulley bolt?
- Wierd clicking sound from driver side
- How much should I pay to do resurface rotors and change pads for the front and rear?
- please help me serious car proplems
- 2003 4-door Accord OEM fog on with parking lights only
- problem with jack stands
- 98 Accord Ex's clock wont light up. help me fix this. please.
- C E L code 12 in a 92 EX 5spd, what is wrong?
- stuff to put on crank bolt to help loosing
- 99 honda accord
- my clutch is sticking half way up on my 94 accord.
- h22 w/ f22 tranny and ecu......easier and worth it??
- EX head on LX block?
- Where can i buy rear disc coversion kit for 4th gen accord?
- Eibach sportline springs
- Car is squeaking when I turn left or right .....?
- rear big brakes for the 94 coupe LX
- abs problems on my 96 Accord EX
- What engine do I have?
- The wheel cylinder came off of my rear brake assemble? Help!
- Wiring Harness f20B
- DEL sol seats in to 90 accord. Stuck with these seats.
- abs problem by honda accord aerodeck 2.0i SE (94)
- New H22 Running, But Won't Give Me Any Grunt
- Accord idles at 2 grand
- Secondary O2 sensor removal
- where can i get intercooler pipings made for 92 accord with h22?
- i cut down my shifter today
- Need new cat... maybe?
- accord 4dr and accord coupe weight
- need a front lip for a 92 accord
- Wanna set up 92 accord ex for road racing.
- Power Antenna Problems
- MPG for 92 EX Sedan Auto
- 1994 Accord engine repacement
- help, need advice keep accord or not?
- New timing belt vs. valve adjustment
- Air fliter for 98 accord CAI
- how much horsepower does my car have
- Apexi WS vs. RS?
- Pulled off a hose dunno what its for need help
- side effect of wrapping header
- ACCORD COUPE 2001 ENGINE MOUNT
- h22a in a 94 accord
- Need close up shots of the engine bay
- weird squeaking noise when turning
- need help on my friends car
- Changing Pistons
- H23 auto in 4th gen worth it?
- Noobs could benefit from this...
- 1G Odyssey with accord engine?
- size of the collector
- when i start my car for the first time everyday the rpms go up and down.. how come?
- What do you think about the Comptech supercharger for the accord v6 (6th gen).
- will 97-2001 prelude springs fit a 90-93 accord
- weight of car
- Problem with 98 accord
- DaM ECU!!!!
- h22 or h22?
- babysitting kids, tenzo seats, 500 bucks, shippping, no shipping, chicago, erased post?
- 1990 accord q??
- Turbo Kit for 01 Accord
- drl module?
- Please help diagnose starting problem on 00 Accord
- PART 3: TUNNING AN ACCORD INTO A RACE CAR ...
- What VTEC's will fit in 90-93 accords?
- accord sir intake
- O2 sensor universal
- Front Brake upgrade only
- 2003 Accord Headlights
- honda accord coupe sir(h22a) automatic to standard
- ok to pours engine coolant on the grass?
- Header Wraps..
- PART 2: Tuning An Accord into a Street Car ...
- front brake rotors
- check engine light after fuel ratio chip install
- Wiring Diagrams
- accord is smoking
- Prelude-->Accord gauge cluster swap question
- where to find a donut spare?
- HP and Torque ratings for 2002 4 cyl Accord Coupe?
- Anybody selling 90-93 Accord AC unit?
- specs on 93' disc brakes
- motor swap for 87 accord
- Test window motor
- 6th gen h22 accord fuel problems
- 4th gen A/C question
- Lowering accord w/ out body kit
- f22 internals building f22 with nos setup
- Stole my Stereo
- 03 Accord Coupe Recommended Maximum Rim WIDTH and Offset
- interior carpet?
- more temp gauge problems
- city lights went out?? help me cant find fuse
- Wheel offsets for 2001 V6, and 2003 V6?
- accord starting problem
- How do you know when your multiplexer control unit shorted or not?
- kamikaze header
- sooo i broke a studd and.............
- kinda confious
- tach doesnt work...
- front lower control arm... need info
- stereo code?
- stock header
- swapping in a F23 on Monday, do I need anything else?
- 6th gen CEL code P1259 VTEC System Malfunction
- Anyway to fix the accuracy of Gas Gauge?
- 3" exhaust
- Thank You.
- engine question
- Suspension stores
- F22 Turbo parts list
- LCA torque specs for shocks?
- H22a swap help PLEASE!!!!!
- Stain Problem
- Accord denso iridium
- power steering
- whole exhaust dropped out of the car?
- need opinions
- Greddy SP or DC Sports??? help me out
- 93 accord Transmission slipping
- 6 gen 4cyl injector question:
- Is there a difference between V6 and 4cyl springs(suspension)?
- alignment specs
- coolant
- sensors
- Tunning An Accord into a Race Car ...
- Fixed Power Loss Problem
- 95 ex engine problem!!
- 93 Accord...
- anyone have an accord o2?
- h22 question
- What ECU does a 93 Accord Auto have?
- driver side window and cruise control
- Whole car shakes when im braking from high speeds
- still have no spark, no start on accord 1990 LX.....
- bolt size
- Two H22's for sale...which one seems like the better idea for me?
- What wire harness for H22 Accord
- ecu reccomendations
- Alignment Issues
- Who has a 1990-91 accord with an H22 swap?
- My steering wheel is shaking when i get to a certain speed
- anyone experience rattling???
- Guide on how to install COILOVER anybody?
- Help - 96 Lx Alternator Problems - Dealer trying to screw me?
- Sporatic engine idle. Flooding after first attempted start.
- camshaft
- 97 Accord with OBDI H22 question
- Rear brake upgrade on 4th gen Accord
- When heat shields start buzzing, replace? or bend??
- head gasket leak
- F20b
- canadian accord ??? whats the difference. please help
- Ok guys, what YEAR prelude drivers side mount for H22 into 94-97 accord?
- 6th Gen Turbo install
