View Full Version : Honda Accord (1990 - 2002)
- need a pic or some advice
- Stereo Anti theft Code
- OEM Fog Lights for 2000 Accord EX Sedan
- A/C EXPANSION VALVE
- 90K mile Service???
- Programing in-car remote garage opener
- Please help
- What is code
- 90 accord ex problems
- 03 on guam
- accord 1994 ex model gas question
- *www.jdmmotoring.com*
- **1994 Accord TRANY PROBLEMS...PLZ HELP ME!!!***
- test only smog.
- Lookin for an OBD1 H22A swap for my 91 LX coupe
- Exhaust Whistler that makes the sporty sound...
- Just bought '95 EX. ABS light won't go off.
- ABS Light on 1993 Accord (Front/Rear Disk)
- Alignment Result.. i have a few questions.
- Ignition Wires and Plugs
- **POST PICS 98-01 accord with rims...**
- 90 Accord LX F22 Swap
- where to find replacement bulbs?
- Are KN filters worth the money? Any mpg or HP increase?
- 1996 Accord - Replacing Auto Door Lock Control Unit
- Hybrid almost killed my family
- Help with broken trunk lid light
- 0xygen sensor replacement?
- whats wrong with my accord help!!!!!
- Car died while driving 45 mph down the street!!!
- Car won't start?????
- AC question
- speed sensor unit?
- 4x114.3 to a 5x114.3??????Help please
- Vacuum line plug
- Euro R Owners Manual
- Transmission won't shift, '91 LX.
- Selling h22 accord
- tranny problems
- 1994 Honda accord hard hot start
- 3rd generation h22 swap
- Chopped Tires
- Better for the environment...
- Honda Car Care Days, April 1 - April 30, 2006.
- NEED PART FOR MY 2000 HONDA ACCORD
- ecu location
- oily spark plugs
- Part name?
- Accord versus Prelude
- 03 Accord Coupe Suspension Problem...Caused by Lowering?
- 87 accord DX
- Trainhorns... hehehe
- F22A2 spec. anyone?
- installing an HID kit on a 03 Honda accord
- WTB: f22 tranny!
- New Clutch?
- timing belt @ 60k
- Purpose of trunk hook 2006 Accord Sedan?
- 95 accord lx non vtech/ help w/vacuum line layout fom air manifole
- Basic Taillight install/removal?
- parts for dropping my 1997 honda accord lx
- h22 tune now oil leak
- need help with a 90-92 accord tranny
- Parking/Tail/Interior Dash lights dont work.... fuses all good... why?!
- 01 Accord Sedan vibrating noise, not CV or tires!
- gotta ??? car wont start???
- What manual tranny will bolt up to 2001 Accord V6?
- Overheating Help
- question about hight clearence
- tranny from a 97 prelude
- bigger wheels for Accord
- Wheels
- 4000rpm limit?!?!
- Unknown issue. Cluster lights on 99 auto accord v6 coupe came up last night....Help please
- 94 Accord Ex tranny issue????
- 6th gen I-4 amp wiring......where to make holes?
- What drives the oil pump?
- engine swap but now wont start period
- 17x7.5 With 35 offset....
- horn relay
- Catalitic inefficeny giving off a check engine light?? does it really make a differ to my car??
- Problems with tuning :S
- Gas warning light doesn't turn on anymore even when empty
- 95 odyssey f22b6 into 96 lx accord?
- It Wont shift, unless manually shift
- Please help - 93 accord Ex, Automatic with 156K
- Do AEM Cold Air Intakes help your MPG?
- looking for used exhaust
- 06 Salavaged Accord
- f20b head swap
- 94 Accord Gauge Problems
- questions about cooling fan
- AC issues 97 ex
- 98 honda accord lx over heating
- lets see ur tint
- accord issues
- 1990 accord lx help
- I need to improve my MPG - Tips?
- f22b1 + nitrous = dyno results inside
- A/C Problem & Question
- 1994 Honda Accord EX Tranny
- 2000 Honda accord SOHC vtec issue
- honda accord lx issues
- Insurance Compaines over Charging
- How do i set the timing on my F22a1
- All motor SOHC F22A runs 9s, with over 333whp!
- 94 Accord EX: Auto to Manual
- ABS light - honda accord 93 EX automatic
- 93 honda accord
- LED's to replace dash lights?
- Resistor box for F20B
- Feel ripped off by honda dealer
- accord type r
- 1994 F20B into 1994 Accord LX
- free 93 accord... should i take it?
- brakes...getting sick of this
- AGAIN--ACCORD SPEAKERS!!! ANSWER!!
- Honda Accord Speaker
- Borla Exhaust?
- h22 problems...
- 91 Accord overheating and thermostat question
- Radio got stoeln...now the dash lights won't work
- quater mile times with f22
- Fast-Idle speed on 95 Accord F22b2
- SF Honda Owners - Mechanic Suggestions?
- Knocking From Front End
- Custom exhaust
- Another New Member
- Code 15 Car dies, but it comes and goes!
- Removing 94 accord caliper!
- New member to honda-tech
- like it
- looking for a cheat f22 tranny
- 94 sedan... power locks stuck. help!
- horn doeasn't work on my 92 accord
- 03Accord oem lip kit
- For all you 5sp 94-97 cords, short shifter suggestions for you all!!
- Blinking sport light
- Towing with Honda Accord
- JDM F23A = USDM F23A1?
- H22 in 98, Can I stay OBD2?
- 5th Generation Transmission Swap
- 2002 Accord . . . battery went out . . so did the radio . . . ????
- need lil help.
- 99 accord window?
- dumb question, but can anyone describe where to look for the clutch slave cylinder?
- Air conditioning removal on CB7
- Koyo Radiator install NEED HELP!
- h22a
- Umm.. Timing..? HELP PLEASE
- gas mileage
- what size tires do i need for my new wheels? 94 accord
- Auto meter shift light
- Head Specs..?
- A'PEX V-AFCII Smoke???
- Trial Period Again
- Spark Plug heat?
- Help Headlight bulb 9006 keeps blowing
- P0141 code
- ECU pics
- can someone post me the thread on the 604hp 92 Accord?
- 92 accord ex leaking coolant & runny Hot, HELP!!!
- Is the K24A4 worth working on?
- rpm too high or a little erratic
- Question about my 99 Accord
- accord tire size - how important
- Polyurethane Xenon back bumper
- tranny mount (manual + auto)???
- Some USDM Accords made in Japan?
- Need help with 99 Accord Clickin'
- 92 honda accord missing while driving
- Is an F22 downpipe too small for an H22 swap?
- check engine code?
- Will it fit
- Black interior?
- rebuilding calipers
- 2 questions...
- 7th gen accord lx rear brake conversion
- Slight over heat 95 V6
- Where can I get this??
- check engine light
- auto to manual shifter assembly problem
- h22 in 1984 accord?
- Remanufactured Tranny from Autozone
- Idle goes up and down
- length of belt for f22b1
- Doesnt someone on honda-tech own this car?
- What Window Tint was used on the 96 year Accords?
- rear disks? 86 accord dx
- Any pic of 5th gen accords on Rota wheels?
- 94 Accord turn signal lamp housing
- 1999 LX Coupe stalling at idle
- Tranny drain vs. tranny flush at 130K
- Front bumper kit or lip for 5th gen V6?
- accord steering wheel ques.
- 2003 Accord Keyless Entry
- Apexi or Tein?
- Rear Upper Strut bar for 1999 EX Sedan, Where can I get one?
- 04 Check Engine Light/tranny slipping
- Intake Filter Question
- OEM Spoiler 93 Sedan
- brake light switch????
- EX downpipe diameter.
- odb question
- 99 LX AM radio reception
- FAQ: 7th Gen 2003 - 2006
- AWD Accord
- 89' Accord wont start
- acceleration stumble
- accord auto f22s. ?shift kit advice/ grounding system?
- 2.2 auto/ 95 accord needs more power/
- Trade or Possible Sale: Apex'I WS2 Muffler
- i got jdm h23a v-tec
- License plate
- Transmission fluid.
- For Sale or trade: Apex'I WS2 Muffler
- 94-95 Accord Stock Lip/Valance
- problems with 95 accord
- Window motor and regulator ?
- JDM: Accord Type-S F20b pistons
- Still V-tec ing
- SiR Accord?
- 91 EX Shifting Problems?
- 91 Accord LX Radio Removal.
- NEed wiring schematic or Diagram
- F22 stock p&h injectors with a p06 ecu
- JDM vs USDM
- How to remove the license plate holder off a 96 Honda Accord
- 94 accord issues
- 94 accord vibration
- (JDM) Accord Power Fold In Mirriors Install ?
- Engine fit question
- what a/c pump to use on h22 into 5th gen
- my heater gauge is whack....
- Used body parts Gen 7
- 3G SQUAD!
- 98 Accord - factory alarm problem
- Light bulbs
- Engine kill switch?
- tranny question!!!
- '96 Accord VTi Auto Transmission help
- my AC or Heater doesn't turn on
- THIS LIL LIGHT OF MINE
- Rare 86-89 Accord 4dr window visors, anyone know anything about these???
- Honda Accord EX 92 Brake Bulb
- quick info???
- 95 accord steering wheel
- head unit locked
