View Full Version : Honda Accord (1990 - 2002)
- AC Clutch
- carbon fiber hoods
- Wierd engine noise
- Draining block on 92 Accord (2.2)
- help....
- Car turns off while driving and its not the battery.
- Which website for rims and tires are trustworthy? Give your opinion PLEASE!!
- New to Honda.
- oil royal purple constant use or honda oil
- why would you make a touring accord
- the lip instrcuctions
- where can I get the manual of 96 accord ex from?
- guys with pulleys need your help asap!!!!
- cv joint replaced, now grinding noise when turning?
- Cheap Ebay parts good or bad?
- exhast install tips
- Anybody got Tein H-Tech on your accord?
- wheel bearing confusion
- high idle
- Overheating/Coolant Problem...3 months and no one can help.
- Towing a camper
- will an f20b longblock drop into a 97 Acura 2.2 CL (f22b) and bolt up to the tranny?
- Question about accord/prelude transmissions
- idle speed drops on hot days
- Intake for a 97 accord ex f22b1
- Temp guage.
- 1991 Accord ABS Light ... engine stalls
- need opinions on a car I'm thinking about buying
- does anyone have the belt number for the AEM pullies?
- 98 accord wheel balancing issue
- 95 Accord LX Suspension help
- the question on everybody's mind.....
- which block will work
- Should I get a front sway for my CB7?
- Spoiler
- Vibrating Car?
- Need help ASAP!
- Fender Turn Signals
- Temperature Gauge question for Honda Accord 2007
- SiR Front Clip, RHD Conv.
- new honda owner and 07 intake question
- Good Exhaust for Turbo??
- igintion coil
- Help loud F22a1 listen to video please!
- accord dsm turbo 4th gen
- I Need Help On My H22 Swap
- 87 motor swap
- Master Cylinder?
- Starting issues-2000 accord coupe ex v6
- Help! Which one is my ATF?
- problem with the 5spd transmission on 96 acd Ex trim
- f23
- 98 Accord - Changing Timing Belt and Water Pump, should I change Oil pump etc.
- upgrading an 04 accord coupe ex to factory nav.
- JVC CD changer CH-X1500RF wiring
- AC PROBLEM
- 1990 accord door lock
- 90 accord steering wheel?
- how to get more MPG...?
- Oil Consumption
- Hub Assembly swap
- f20b head on f23a1
- obd1 codes for 92 accord
- Rear shock removal on 6th gen?
- idle repeadedly surging to 4500 rpms, then almost dies, any ideas?
- Upgrades to my 04 Accord
- 1998 Accord Ex Stock Radio
- 90 Accord EX stuck in high gear...need help ASAP!!
- cracked cylinder
- Check Engine Light. Help.
- VIN #
- 6th Gen. rear swaybar on a 5th Gen.
- 95 V6 A/C
- 98-02 suspension setups
- Too much boost on stock 4th gen internals
- F-series boost ???
- Tein s. tech...
- 2 simple question
- EX-R versus EX
- which muffler is better
- code 15 after changing ignition switch
- 3rd Gen. accord for sale
- Oil Pan / OP Gasket Question
- Clutch pedal return problem
- Engine question
- all motor question
- Where can i program key-lees controller for cheap?
- Wierd noise coming from rear
- Why are my wheels bouncing?
- erg valve help!
- rev limiter
- good on-line place to buy OEM parts 89 accord
- intake manifold leak
- What spark plugs are the best
- brakes
- Tein Lowering Springs
- Please help me
- function form type 2
- HID'S for my new honda accord 07?
- what sensor is this?
- Low idle problem!
- shaking and clicking steering wheel
- wierd noise, something is loose!!!!
- still getting lazy starts
- Droppin' in an h22....
- Will these 16" Borbet rims with 225x40x16 tires fit '95 accord LX?
- Is Something Missing? H22a
- euro accord type-r turbo(no power@ 3000 rpm)
- Best way to lighten my accord
- intake question?
- What Gen is my Accord? Cant find the answer
- After market Steering wheel...
- 6th gen Accord suspension geometry
- 04 accord sedan D4 light blinking
- Searched F22b1 Swap into Prelude
- Speedometer going cazy !!!
- Should a 95 Accord V6 be loud?
- Ethanol and Fuel Economy
- Auto trans compatiblility
- block
- need help on clicking noise on drivers side
- Accord Wont Start! Please help
- 7th gen 6MT - Turbo & injectors
- turbo charging an h22
- Is there a way to add miles to my odometer?
- help please, temperature way up
- fluid leaking out when CV joint (half axle) replaced??
- 96 ex wagon
- Trunk Remote Release Reciever
- k24 with k20a2/1 head?
- odometer
- Spun a bearing (need help)
- 3rd gen love?
- help with headlights!!!!!!??????
- drum brakes draging
- What 90-91 Accord lip is this?
- swaping lugs from an odyssey. Gotta questions.
- Im new to the honda world. but i have a ? about an h22a swap into a 91 accord?
- Door panel removal?
- Honda Accord 1998
- 1998 Honda Accord Ex Automatic Transmission Shifts Rough
- ABS Fix
- Trouble getting car out of Park!
- Idle to low at running temp!
- Honda Accord Rim Sizes
- ESPELIR Suspensions
- cig lighter circuit
- Need Help!! Is this a Good Buy or Not???
- Speedometer stopped working :(
- Mounts for H22
- Blinking S light (when it's hot)
- Honda Accord 03 Need help finding suspensions
- DOHC f22...?
- 05 Accord ECU change
- VAFC settings
- alarm start
- Accord Seat Brackets
- g23 help
- Gauge Cluster Problem
- 06-7 Rear End Conversion.
- accord head swap questions .....
- 1995 ex problems...
- Quick Fuel door cover Question..
- Wheel tire combo...fit on 2000 accord ex 4cyl
- (Pics)Auto H22 SWAPPED 6th gen Accord tranny help?
- h22a HEAD ON 4TH GEN
- 95 Honda accord EX handbook lost
- accord 2000
- Chepeast Place for a Tranny Flush??
- Oil Sensor
- tire wear 04 Accord
- clunk engaging drive 04 Accord
- Parts for turbo kit?
- Troubleshooting help
- Headlights in need
- cluster lights all came on
- 92 ACCORD engine code 12?
- If my Rear Main Seal or Oil Pan Gasket was bad.. Wouldnt I be leaking Oil? Or am I just crazy?
- Honda Accord 1992 (automatic) problems
- 92 honda accord charging prob.
- 98 Accord LX Consuming oil
- Honda Accord '92 with strong engine vibration, steering wheel shake
- hey thought i ask the pro's
- Just got an 04 Accord
- What is the positive and what is the negative of the Ignition Coil?????????????
- Best way to upgrade stereo 03 accord EX coupe
- car died for no reason. need help asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Will a 98 Accord body harness on the firewall work for a 98 prelude?
- F22B1, H22A, H23A head swap onto a F22A - questions
- Knock sensor in H22A Swapped Accord
- Change air filter tip on 7th G Accord
- Lugs Screws
- 94 accord ex coolant leak! Please help
- questions on auto to manual
- Fan Belt (Alternator on H22 using F22 Compressor)
- Can't get steering column cover off
- Anyone use the Tanabe Underbrace for their CD?
- just changed the clutch and no pedal!!!
- Honda dropping the Accord hybrid
- adjustable coilovers
- 5th gen accord exhaust question
- *Help Plz*
- Clutch or Tranny Problem
- Window - Master Switch wierd ! blergh! HELP!
- Programmable Garage door opener questions.
- would it be a problem to use a rear O2 sensor before the catalyst?
- new here...
- cv boot ripped. Which replacement is easier?
- engine light
- Radio display warranty extension 03-04 Accords
- unlocking a honda accord dirver side door
- tail light swap and engine swap questions (2000 Accord LX)
- Removing freeze plugs from intake manifold
- Help with spoiler install.
- Need help with my 00 Accord LX Radiator Hoses
- f22 to h22 or h23 swap info needed
- All gears lead to reverse =) 1990 accord, auto
- Possibly fried my ECU...
- How do you check ATF fluid level?
- Overheating!!!
- Fluttering noise o.O
- Worn engine?
- Tire Rec for 2004 Honda EX Accord 4 Dr V6?
- Timing belt replaced, clicking sound coming from under valve cover.
- Timing Belt Kits...
- Hard Acceleration!!!!!!
- new clutch yesterday and now no pressure in pedal
- 97 kickdown adjustment?
- IAR check valve- possible vacuum problem/leak?
- intake hose?
- f20A & f22A
- check engine code P0730
- o2 sensor problem
- trans
- Smog Gurus - Need Your Suggestion
- O2 Sensor Stuck Lean
- stupid question
- a couple of questions.....
- towing with an auto
- do you thnk it's worth
- 99 stock accord and VAFC II
- replacing rear main seal on 1994 accord auto trans help!
- oil light blinking
- Do I need a camber kit? (pics inside)
- Alt Belt
- 03 Accord wierd problems
- Startup Sometimes
- What's all needed for h22 swap?
- 91 accord auto to manual conversion??
- soft pedal
