rear brake disk conversion
Old Jun 13, 2003 | 05:20 PM
HANABLE's Avatar
Default rear brake disk conversion
i want some info on how to go about putting rear disk brakes on my 91 accord
any input would be appreciated
thanks H.
Old Jun 13, 2003 | 06:37 PM
thenick's Avatar
Default Re: rear brake disk conversion (HANABLE)
should be just EX rear trailing arms and lines
Old Jun 14, 2003 | 01:01 AM
RotaryBzzzz's Avatar
Default Re: rear brake disk conversion (ixiblindixi)
almost not worth the trouble if you can't get the parts for free. Or you are replacing to an upgrade.
Old Jun 14, 2003 | 07:03 AM
thenick's Avatar
Default Re: rear brake disk conversion (RotaryBzzzz)
are you serious?? have you ever removed a trailing arm?its 5 bolts
Old Jun 14, 2003 | 07:30 AM
Saintor's Avatar
I had a lot more troubles with rear disks brakes than with drums! My advice; don't bother.
Old Jun 14, 2003 | 07:36 AM
carolinaACCORD's Avatar
Default Re: rear brake disk conversion (Saintor)
5th gen EX parts from the knuckle out.
Old Jun 14, 2003 | 08:37 AM
iam7head's Avatar
Default Re: rear brake disk conversion (carolinaACCORD)
well, the rear brake only supply 35-30% of the braking power...if you dont plant to autocross(which drum brake gets hot after couple hard braking) your car..dont brother.
Old Jun 14, 2003 | 10:05 AM
90AccordEX4Dr's Avatar
New User
Do it... it is very simple and looks a lot better if nothing else. I did this to mine and have had no problems whatsoever in the three years since... The brakes fade a little less, those drums were horrible.
Old Jun 14, 2003 | 10:58 AM
iam7head's Avatar
Default Re: rear brake disk conversion (90AccordEX4Dr)
for those we did the swap, how much it cost?
Old Jun 14, 2003 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixiblindixi &raquo;</TD></TR><TR><TD CLASS="quote">are you serious?? have you ever removed a trailing arm?its 5 bolts </TD></TR></TABLE>
What part of this didn't you get? :almost not worth the trouble if you can't get the parts for free
How does that relate to the actual job of doing it?
Old Jun 14, 2003 | 02:47 PM
thenick's Avatar
you make it come off like its some astronomical job...jesus christ sorry
Old Jun 14, 2003 | 02:57 PM
96Prelord's Avatar
I just completed my "fully built"...lol, rear disk conversion. I used Powerslot rotors, SS brake lines and some Axxis Ultimate pads. I got the WHOLE rear end off of a 93 accord in a junk yard and i compared EVERYTHING off of my 96accord rear disks, and all you need is
The rear disk knuckle and the rear disk assembly w/rotors, etc.
The long *** screw on the bottom from the disks, b/c its like 1 inch shorter than the one from your drums.
Other than that, the trailing arms are EXACT.
I road race my accord and i noticed a HUGE difference in braking w/o ABS. IMO its worth it for performance braking.
Old Jun 15, 2003 | 07:25 AM
New User
Default Re: rear brake disk conversion (iam7head)
Yeah all you need is this green circled part:
You could probably get those at a junkyard for a couple hundred $
Old Jun 17, 2003 | 11:58 AM
HANABLE's Avatar
thanks for all your help!
everybody. " burn rubber not you soul!" heres a round for all you all!
Old Jun 17, 2003 | 12:25 PM
2point6's Avatar
I did mine... It was a very easy job. No problems in 4 years. Looks cleaner and the disk brakes are easier to maintain than the drums. Not sure why someone would post it isn't worth it... I guess they haven't any clue.
Old Jun 17, 2003 | 01:46 PM
Default Re: rear brake disk conversion (2point6)
Ack.
Old Jun 17, 2003 | 01:53 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">Ack. </TD></TR></TABLE>
Just messin' with you man...
Old Jun 17, 2003 | 06:13 PM
f22a's Avatar
what do the blue and red arrows in that picture signify?
Old Jun 17, 2003 | 06:58 PM
New User
Default Re: (f22a)
The blue arrows point to the lower control arms, which are identical between 1990/1993 drum/disc. The red arrow is the upper control arm which is also identical, so I swapped this one over to the disc setup. Turns out I only needed the green circled hub
Old Jun 17, 2003 | 07:15 PM
f22a's Avatar
what about the lines? are they the same as well?
Old Jun 18, 2003 | 11:37 AM
rage237's Avatar
what about the e-brake cable?
so if i get the hubs off a 90-97 accord it will work or only 90-93?
Old Jun 18, 2003 | 12:54 PM
bacal36's Avatar
Default Re: (rage237)
I believe 90-97 is all the same.
Has anyone changed their proportioner valve? I think the 90 accord has 35/30 pressure, for stock front disc and rear drum. But I know of someone who changes it out to the 90-93 GSR proportioner valve that has 40/40 pressure for all disc brakes.
Old Jun 24, 2003 | 07:58 PM
94cd7's Avatar
Default Re: (bacal36)
are you able to use all the same brake lines will they just screw in the same as on the drums
Old Jun 24, 2003 | 08:47 PM
New User
Default Re: (94cd7)
Yes, brake lines are all the same.
E-brake cables are attached to the hub... need those with a swap.
I have not changed my porportioning valve, but probably shoud
Old Jun 24, 2003 | 10:48 PM
sloaccord's Avatar
New User
Default Re: (90AccordEX4Dr)
surprise! you'll need two Prop valves, not one. hondas come from the factory with a safety feature built in- that front left and rear right are connected, and front right and rear left are connected, so if there is a brake line failure you dont only have rear brakes (bad) or just front brakes (also bad). you will need to put a prop valve on both lines or convert your brakes to a single-valve front-rear design (expensive).
