PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 [274] 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. Accord 6 gen auto tranny question
  2. Jumping Engine
  3. Oil leak/burn(searched, not right answers)
  4. selling f22a1
  5. VACUMM LEAK 86 ACCORD & BEST CLUTCH KIT 4 RACING
  6. PRELUDE TO ACCORD CARB SWAP
  7. Type R injectors for H22A swap???
  8. What is the best oil filter?
  9. 2003 Coupe EX V6
  10. All the damn wires in the engine bay???
  11. Ignition relay same as main relay?
  12. Coilover Springs w/Shocks Vs. Full Coilover kit
  13. Question about were to hook up wire from AMP to Fuse.
  14. Pulsating Brakes
  15. My turn signal lights flsh quicker now that the lower ones are off. Can I make them flash slower?
  16. swap gsr or h22a in my 99 accord coupe
  17. blower motor
  18. Good places to look for short shifter?
  19. 2005 Accord: Installing After market rear deck 6x9 speakers???
  20. Need help with H22 head!?!?
  21. Help with 94 Accord........
  22. 04 accord v6 sedan premature rear brake wear
  23. Maintenance Light on 1999 Accord LX
  24. question
  25. F22B2 --> JDM H22A distributor wiring... HELP!
  26. role cages
  27. how big is a f22a1 TB
  28. Advice on manual tranny swap
  29. starting+radiator
  30. Your take on the new Accord ('03+)
  31. SRS light on...
  32. Eibach Springs??
  33. 97 Accord Interior
  34. No leak, No burn- still loose oil.
  35. engine check light codes
  36. '91 accord, weird noise, what could be the problem?
  37. '99 Accord, Check Engine Light....Code P1457....how to fix?
  38. need clutch help quick
  39. whoa need help asap
  40. idle problem
  41. CEL help needed - '91 Accord
  42. Maintance Required Light Flashes?
  43. interior lighting
  44. 93 Accord> D4 always on, wont shift, only stay in 3rd gear.
  45. Uncontrollable Engine stutter
  46. "cat back" ??? I have found "NOTHING BACK" is much better and CHEAPER
  47. quieting my exhaust
  48. h22
  49. Takes off strange
  50. tearing dash apart to replace wiring harness?!
  51. Stiff ride
  52. 04 Accord starts hard
  53. Starting problems
  54. Need help on how to replace the front wheel stud?
  55. k20 moter mounts for 4th gen??
  56. 1991 accord cooling fan problems.
  57. 99 accord, inline 4.. manual tensioner right?
  58. NGK Spark Plug Wires ... F22B2 --> H22A
  59. honda seat belt replacement for FREE
  60. motor
  61. Electrical design?
  62. 91 Accord Motor Mounts
  63. H22 Swap Sound off
  64. 90 accord lx thermostat location
  65. new air filter
  66. problems just before inspection due...
  67. 1999 accord
  68. b series 1999 honda accord?....
  69. Need a step by step on a removal of two axles on a 96 accord
  70. 91 accord, no spark
  71. Cpl questions on 94-97 Accords... may be buying
  72. Tranny Cooler Question
  73. How many O2 sensors on a 94-95 EX?
  74. h22 swap on a 92 accord ex???
  75. oil burning and gas burning rich
  76. 93 honda accord tranny?
  77. egr port cleaning
  78. STOLEN ACCORD IN NY (BROOKLYN)
  79. tokico adjustables
  80. f22 turbo???
  81. Clicking Noise - Pushing on brake in park
  82. 94 accord gas problem
  83. got a problem?
  84. 2000 Honda Accord What Generation is it
  85. 2000 Honda Accord Heating Q
  86. How to Remove Dashboard in 2000 Honda Accord coupe
  87. front bumper swap?
  88. 4th gen Accord RHD conversion?
  89. Problems
  90. Hid Wiring
  91. What engine in 93 accord SE?
  92. can any body tell me what kind of cars are these ??
  93. 92 Accord EX now has a "Vibration" after new timing belt installation!
  94. Car not running like usually does, what is up?
  95. Gas pedal hard to press?
  96. any good engine swap besides h22?
  97. does a honda run
  98. HOW TO INSTALL A OIL P.S.I GAUGE
  99. Both Radiator Hoses under pressure
  100. Dash Removal
  101. F22a1'a4'a6 piston/deck ?'s
  102. i have a question for the accord tuners and any other honda tuners
  103. bumper conversion help
  104. installing cat-back exhaust on a 92
  105. where to purchase jdm lsd
  106. Install Tach
  107. 17" tires on 94 accord cause poor gas mileage?
  108. ABS light on 95 accord
  109. high milage shift points
  110. steelie + tire weight
  111. what kind of light bulbs should i buy?
  112. what's the lug pattern on a 6th gen 4 lug accord?
  113. Brake Light Problem
  114. 91Accord - which remote/keyless lock system?
  115. Help Getting radio Error
  116. skunk 2 stage 2 cams
  117. how to get burned cds to work?
  118. DISTRIBUTOR HELP
  119. Reving when idleing?
  120. Opinion for sellng a car
  121. Covering O2 sensor hole
  122. Throttle bodies for F23?
  123. tranny swap on 96 accord
  124. 3rd Gen Accords (86-89)
  125. Question: "Whistling" when i start the engine.
  126. problems with the speedometer
  127. My accord
  128. 95 Accord Manual to Auto swap H22... engine not sitting level?
  129. no spark from distributer
  130. Srs light ON, any ways to diagonose!?
  131. when do i need to replace spark plugs?
  132. how much to paint bumper cover
  133. gsr seats in accord?
  134. Where is my ignition?
  135. problem with factory alarm, 1999 Accord ex
  136. installing a Cold Air Intake
  137. Replacing ignition lock
  138. 1986 Honda Accord DX Engine ID
  139. 92 accord problem please help ASAP Please
  140. Window smashed...
  141. trouble getting into reverse...
  142. JDM H22A needs piston rings
  143. Programming 2000 Honda accord key
  144. Hondata Heatshield Gaskets for the H23 and F22
  145. 91Accord - lock relay?
  146. Need help on Shocks...Springs..for 6gen Accord
  147. Coolant Fan stays on for a long time after car is off
  148. car idles at 1000 rpms ? wtf
  149. Metallic "squeak" in left-front wheel driving me crazy. Brakes? Bearing? Thoughts?
  150. 02 Accord V6 - fuel economy strange behavior
  151. Drivers side door won't lock
  152. 2000 Accord LX fuse box
  153. Help Me with this problem
  154. 03 accord help
  155. PT3 chips??
  156. new swap
  157. ECU on 01 Accord
  158. 5gen camber correction
  159. window crack
  160. Mount problem for H22 swap in a 5th Gen.
  161. putting vtec head on lx??
  162. MyCar "locks up"
  163. 91 Accord Reverse Problem
  164. Header
  165. help D4 light blinks
  166. Speaker size?
  167. v2 aem
  168. Will a 96 manual tranny fit a 94 sohc engine? Both 5th gen right, but same tranny?
  169. LOOKING FOR THE FASTEST ACCORDS
  170. RSR Exhaust
  171. ABS light
  172. Trouble on cold start (99 Accord)
  173. JDM H22A Accord 5th gen
  174. Rear Brake Conversion on 4th Gen Accord????
  175. 1992 grill
  176. weird weird overheating problem:(???
  177. Tranny died at 106,349 miles old
  178. Help with sagging rearend
  179. A question for those people who lower Hondas
  180. axle nuts
  181. how can I modify...
  182. SoCal Meet
  183. Honest Opinion
  184. Need Help ASAP: Code 7 on 01 acccord LX
  185. 93 f22 convert to vtec.
  186. H22 swap for a 91
  187. 92 Accord LX
  188. MPG drop from 31 to 22 on 2004 Accord. Dealer says normal. Yes?
  189. MSD ignition coils for 93 accord F22A engine!?
  190. catback fixing B-pipe problem
  191. Attention 6th gen coupe owners!!!
  192. bolt that holds the rim in place
  193. 95 accord lx timing belt and belt balancer changing help>
  194. a/f gauge question???
  195. 92 honda accord front lip
  196. 92 ACCORD AUTOMATIC GRINDS IN REVERSE
  197. Newby needs some help
  198. Brake upgrade 5th gen ex
  199. Lug Patterns
  200. redline tranny fluid
  201. 93 Accord EX Igniter unit
  202. Will a main relay go out in the cold?
  203. Cold Air Intake
  204. Motor oil
  205. How can you tell if a strut or shock for a Accord is bad?
  206. car will not start, help
  207. Found leak in radiator yesturday!!##@$#$%
  208. 6th Gen Accord Turbo: Need to upgrade fuel management
  209. I have a tranny problem...
  210. Needles...
  211. 90 Accord problems, need assistance
  212. Is my 97 accord ex a dohc or sohc
  213. THERMAL Factory-Exit Classic Stainless Steel Cat-Back System
  214. gotta headlight question..???
  215. another headlight thread
  216. Rattling noise in 03 accord?
  217. Opinions on factory alarm.
  218. Stupid Question...
  219. Resetting cel? 98 4dr
  220. Slammed into a curb...... HELP!!!
  221. second intake runner in plenum open....BAD?
  222. '99 Accord V6 Coupe Tranny Swap
  223. H22 in 4th Gen Honda Accord
  224. Accord Vrs. Ford Van.. Who will win.. I know!!!
  225. 2001 Accord factory headunit problems.
  226. Engine swap for an 87 accord
  227. 92 accord EX interior door handle - is it a different part than the 4dr?
  228. How large of an intercooler will fit behind 93 bumper
  229. suspension change on 01 Coupe
  230. newbieee quick intake question???
  231. [update] 1991 Accord EX Won't start after sitting all day
  232. Best 6th gen brake pads with least dust and extended rotor life.
  233. Best turbo kit for a 97 honda accord? and a little help needed from all Please......
  234. Broken timming belt
  235. 1996 Accord Automatic Transmisson fluid lines to and from radiator
  236. *URGENT*
  237. 98-01 accord 4 cylinder head bolts torque specs?
  238. 94 ABS light
  239. question about spoon calipers
  240. Removing dome light on 97
  241. How change power steering fluid?
  242. HELP! 5th gen accord w/ 01' h22a4 swap NO VTEC!!!
  243. 92 ACCORD AUTOMATIC GRINDS IN REVERSE
  244. Thinking of forged rods and pistons for your f22?
  245. big problem need help ASAP
  246. how to determine if your coolant temp sensor is bad?
  247. 90 Lx not starting
  248. H22 QUESTION!!!
  249. Emergency Brake Light
  250. which year has an 11" press on brake rotor?
