View Full Version : Honda Accord (1990 - 2002)
- if i have eibach springs and tokico shocks.. is a camber kit really needed???
- whats the usual cost to install a strut, springs , and shocks??
- I wrecked my '94 Accord
- Idling problems
- What Stage level clutch to get for 5th gen Accord?
- 1988 Accord Idle Problem
- How do you know if car is going to look like a boat with lowering springs ex. eibach prokit... *sear
- strange coolant leak '87
- tailights interchanable?
- Do I have to use honda brake fluid for 94 accord brakes?
- Door Locks
- 88 accord sunroof problem
- how to test the speedometer working correctly? wiring schematics?
- Looking for some nice 97 accord rims
- unhook IAT and car runs, dies when connected
- idie poblem
- Caster problem
- Possible Tranny lockups 02 limited ed?
- how do u test to make sure your v-tec is working
- Power steering issue...
- 98+ Coupe and Sedan Chasis Code?
- Common Breakages?
- White smoke
- vibrations on the highway
- Is it a deal or a buyers beware at 200K?
- Please end JDM Headlight Argument!
- Car stolen last night. - may know who did it.
- I Need your feedback
- Wheel Size
- Ive got an Intake question
- manual breaking
- Drivehafts on a '90 Accord manual transmission
- axles........
- 1995 Accord keeps over heating
- anyone know the radio wiring diagram for a 92 accord?
- Can I put 20" rims on my 2004 accord V6 sedan
- 03 nav in 01EX?
- brake upgrade?
- accord replacment speakers
- 97 accord F22 question
- Stock or aftermarket ? HELP
- Comments on the later model 3rd gens?
- What Kind Of Struts to buy ....and or Springs
- EVAP Purge Valve
- 1990 EX-R Swap...?
- 93' Accord not starting sometimes
- problems at 100k?
- Whisling sound on 01 accord 4cyl engine vtec
- Steering makes noises
- nopi nationals
- Head swap for f23a4
- sorry dumb question: where is the o2 sensor on 1994 accord?
- Cam for a F23A4
- Build quality question...
- K24
- 96-97 power problem can any one help ????
- 1986 Accord LX Timing Belt/ Ignition Timing Question
- tire size question
- new accord owner, 98 coupe v6. motor and tranny oil change infor need.
- Typical post-warranty repair patterns on an Accord
- 91 accord problem
- car wont turn on
- Installing This fuel filter
- EX? LX? Help!
- accord 97 ecu trouble codes anybody?
- How do i remove .... a number of things
- 5 gen radiator question
- +20hp chip?
- Best place for body parts?
- rear strut tower brace
- problem with my 91 honda accord
- knowledge about v-tech...
- Bad Bearing in 2001 Auto Tranny
- H23A1 vs. H22A ?
- EGR pipe under fuel rail.......
- Would a f22b DOHC accept a f22a SOHC transmission?
- i don't want my speedo to work!!! how? (milage wise)
- 97 accord taking out cluster
- what kind of air intake...PLEASE HELP
- Can't find source of oil leak.....
- should i take out my motor?
- zex or nos?
- Cooling Fan Issue
- strait 6 cilinder smokes after 15 mins of idle why?
- 97 honda accord engine light pls help
- need to know if the h23 iab solenoid valve will work on an h22...i need this part bad
- hard clutch
- 95 EX V-Tech sedan vs 95 Ex V6 Sedan
- 99 Accord dies after 30 sec. consistently
- Need an Expert! CSI-Type question
- Need a side view mirror
- squeaking
- Gas mileage?
- 2003 Accord Ventilation problems
- Minimum rotor thickness question
- sensor problems
- XM Radio for Accord V6 question
- Xenon
- what should i consider or look for when purchasing a h23a for my 96 accord?
- Richmond VA - Nov 13th Meet and Super Tuner Show event
- Speaker sizes
- Strut and Shock for 88 Honda Accord LX
- Mods for the interior...
- usa spec exhaust system on uk car???
- Wheres the A/C Filter on a 98 accord
- wat eats gas?
- Accord CEL light
- Worth the money?
- Accord rear camber
- door won't open.
- Recommend non-HID for '00 Accord Projectors?
- 88 accord instructions
- 2003 Accord Headlight Inquiry
- 1990 honda accord ex problem plz respond
- 88 accord parts
- 92 squeeks around turns
- Grill
- Auto seatbelt noise, loud. Easy fix?
- Diagnostic error code P1167
- oil consumption 91 accord
- tire size on 4th gen accord
- 98 accord projector headlights
- bogging problem.
- Car Bra
- ACCORD Panther "Flood" Rims CHROME 18's in Classifieds
- 87 Accord DX headlight problem
- 1990 ACCORD SHUTS OFF
- 50 too thin?
- Q: Transmision markings
- 03 steering wheel removal
- Need Help
- JDM 4th Gen Cluster Question
- polishing wheels
- body kit
- a clunk when going from park to drive or when accel from a stop.
- plz answer this
- v-tec engines
- radio just shut off... anti theft light is blinking
- How to reset maintenance required light?
- Will Accord IACV fit on an H22A1?
- sparkplug gap
- B16 into 90-93 Accord chassis
- Perma-Plate
- Spray paint question!!!!!! :|
- Car not doing so good
- Tires
- Quick question.
- Removing lower ball joint
- Correct Torque setting for installing Spark Plugs in my 1994 H Accord ex
- Lost RPM gauge now tranny doesn't shift right.
- engine oil problem....need help
- Vehicle Speed Pulse (VSP) in a new Accord 2.2 iCDTI
- AEM Intake for 2004 Accord V6
- Headlight Adjustment
- oem 8 spoke 4 lug accord wheels.
- 94 accord 4 sale
- 6th gen accord h22 swap
- sway bars with stock suspension??
- 2000 Accord Carbon Fiber Parts
- say night night srt-4
- Need help with some engine mods.
- anyone with pics? (dark green accord w/ black or dark rims)
- BIG PROB. engine dies on accelleration
- Air temperature switch/dial replacement?
- 1 inch throttle body
- side effects of CAI installation?
- Shifting
- Car wont start, oil in plugs (Searched)
- Hayden transmission cooler application Q'
- Neuspeed lowering Springs??
- TIME ADJUSTING ON '96 ACCORD LX {NON-VTEC}
- Door buzzes when unlocked with remote.
- Correct Gap for 1994 Honda accord EX Spark Plug?
- TDC/CKP sensors really bad?
- Life after Timing belt change
- 99 Accord manual conversion w/H23 Tranny which speed sensor?
- Is Nanking just another brand of cheap knock off tires?
- 91 Accord EX - Transmission
- Starting Problems
- 92 Accord speedo inaccurate. Anyone experienced this?
- flywheel torque specs
- 95 accord, jdm h22 swap, need help
- where is the fuel pressure regulator on a 99?
- Hydro lock with short ram intake??
- maintenance required light reset.
- busted upper ball joint.
- how do the pro wash cv joint?
- How would you clean this engine?
- '94 Accord ABS Question
- (Automatic) If you're going 70 mph, can you shift into reverse ??
- Borla Mufflers
- New Accord Owner
- extra boost from comptech supercharger
- A couple of small problems, Radio + Door
- Stripped screw in door taking door panel off
- tranny... throte cable!!!!!
- Planning ahead, Winter tires for 92 Accord EX-R?
- 95 to 98 accord head light conversion
- stupid friends
- 1993 Accord Ex help!!!!
- sdf
- 89 Accord Lxi, coupe, manual, EFI: Bad gas in tank. ...Where is the frippin' drain plug???
- Supercharger system for F22A
- Engine Problems
- 205/55/R16 wheels on 03 accord?
- Best Plugs, etc?
- what do i need to do to my accrod for nos?
- V6 w/ automatic
- Accord Radio Question
- Whats going on??????
- 95 Accord keeps locking the doors on its own
- does 96 accord lx have a knock sensor
- What technical manual do you use for reference when performing repair work on your Accord?
- F22B6?
- OBDI ECU for F20B
- Fuel Pump Replacement
- Help. What model engine do I have?
- Lambo Doors for the Accord
- Honda Accord Alarm Question
- Soundproofing
- need h22 iab valve for swap
- Accord Side Mirror Compatibility
- FS: 90-93 Honda accord throttle body's for overbore!
- idiots lights coming on
- Help Need Mods C27!
- Looking for soft ride...
- check engine throwing a code 45?
- Where is this oil leak coming from, and also my spark plugs are submerged in oil... (pics)
- F22 clutch on H23 tranny?
- Replacing rusted quarter panels
- 99 EX Auto axle oil seals
- bad squeaking noise
- 91 Accord Coolant leak from Transmisssion Cover plate
- Newbie info... All encompassing "How To Drop" ... suspension that is
- how much oil for my manul tranny?
- swapping f22a1 with f22a6
- Greddy Lip on 4th gen
- F23A
- do u have accoed helm book? help for torque#
- 92 accord ex
- Time for new clutch?
- Very greesy engine
- silverstars
- STOPS RUST FOREVER. Can this be true?
- Driver's side window stopping *crunching noise*
- 99 V6 accord
- Wheel locks
- 90 Accord-no start
- left front wheel noise
- CAI for 04 accord 2.4L auto
