will a prelude shifter work on an accord
Old Jun 7, 2003 | 09:29 AM
d98clturbo's Avatar
Default will a prelude shifter work on an accord
just like the topics says...i have noticed that the lude shifter is shorter than the accord's so i was considering...swapping it
does anyone have any knowledge on this?
Old Jun 7, 2003 | 12:56 PM
TypeSH's Avatar
Default Re: will a prelude shifter work on an accord (d98clturbo)
yea it works but all it is is a shorter stick, doesnt shorten, or wont significantly shorten the throw.
Old Jun 7, 2003 | 01:30 PM
SearchBeforeUPost!'s Avatar
Default Re: will a prelude shifter work on an accord (TypeSH)
it does work, you will need the prelude cables too.
You can't use a lude SS adapter on a lude shifter in an accord though, it hits the console.
Old Jun 7, 2003 | 04:25 PM
d98clturbo's Avatar
i went ahead and swaped the shifter it is awesome it is like 2 almost 3 inches shorter and the throw is also shorter... feels great! now i have a real short shifter in my cl...
the reason i asked about the accord is because everything in the cl is identical to the 94-97 accord
thanx everyone
Old Jun 7, 2003 | 05:57 PM
DC5_R's Avatar
Default Re: (d98clturbo)
How did you get the prelude shifter assembly? ordered?
Old Jun 7, 2003 | 06:31 PM
d98clturbo's Avatar
my friend has a 4th gen i took it out of that..the motor is blown in it so he is selling it to the junk yard...so i am taking all the parts i can
Old Jun 7, 2003 | 06:54 PM
fastaccord94lx's Avatar
Okay first, don't listen to these people that are just recycling what they've heard. I own a 5th gen, and I have put a 4th gen (95 lude si) shifter in my car without any major modification. It bolts right up, you DON'T need any cables. Just the lever, and part #26 and #27 from http://www.hondaautomotiveparts.com under the "SHIFT LEVER" section for a 95 Prelude. I don't think the trim level matters, I just chose Si. The only thing you have to do is take the Accord plate out and take a pair of vice grips and twist off these two little metal tabs that the shifter hits, you'll see them. I wiggled them both back and forth until they came off, took maybe 10 seconds each. And yes it is way shorter than stock, here's a picture:
So take it from me, it is a direct swap with little modification, very easy, maybe takes 20 minutes to exchange if you know what you're doing. About an hour if you have to experiment.
Peace
bigsnorlax
Dec 9, 2009 07:47 PM
preludepower
Aug 29, 2009 02:18 PM
808speedSyndicate
Apr 12, 2009 02:16 PM
i97supratti
Mar 3, 2006 03:30 PM
808BB6Turbo
Jul 20, 2005 10:40 AM
