View Full Version : Honda Accord (1990 - 2002)
- Majestic Honda Question
- Where do i start?
- g series plan of attack
- cooling system?
- I searched and I STILL need HELP!!
- Engine Rev up and down after 2 min
- more power????????
- Original ride height front strut replacement
- 93' idle flux after braking??
- starts and dies immediatly
- f20b question?!?!
- Help! GF ran gas empty on the 93 accord last night & won't start now!
- wheel hub
- steering wheel shimmy at about 60 mph
- Eibach Pro-kit vs Sportline Springs
- automatic shift cable help!!
- Short ram intake to cold air intake?
- Boiling,gurgling noise in oil?
- '99 vs '01 Accord dark green the same green?
- Quick ? about H22 swap in Accord
- changed spark plugs and engine light came on??
- obd2 wiring
- Suspension Question
- need help with IM problem
- tranny going out?
- clutch
- 97 accord wagon- help with hood and bumper comparability.
- All you street nachines help me find awesome brakes pleas
- Fuel Filter8(
- vibration, binding???
- which rims would go best on my 97 burgundy accord?
- pics
- h22 head conversion info
- h22?????!!!! need help asap plz
- 93 Accord A/C system diagram?
- Fel-pro valve gaskets, spark plug tube seals, any good?
- Light smoke coming from the engine
- accord engine light turns on while driving
- 1990 tranny into 1997
- Lower Control Arms
- 01 accord srs light stays on
- 94-97 seats in a 90-93?
- '94 Honda Accord LX MT Ignition wont turn to off.
- 94 honda accord e-brake light Q?
- Need Help with Accord
- steering wheel ?
- ABS light stays on
- will 93 civic shocks and strut fit on 91 accord
- Blinker stops when brakes applied.
- Quick Sway bar question
- spark plug tubes full of oil.
- 92 honda accord no start
- f20c3
- exhaust leak?
- foglight install?
- Stop Light doesn't work Honda Accord 2000 EX 4 cyl.
- Butterflies vs no Butterflies?
- 95 accord making really weird noise
- driver window wont go up need help ??
- WHAT SIZE SOCKET
- where to get a camber kit?
- Honda parts or secondary market parts
- 6th gen auto to manual What ECU??
- 1994 Accord F22b (non vtec) wont stay running?
- Timing Belt Cover Gaskets
- 97 Auto to Manual Swap HELP
- PROBLEMS with F20B swap
- 96 Honda Accord VSS replacement
- where the rubber meets the steel (fuel line)
- Thinking about buying 94 Accord
- Harmonic Balancer Off?
- Cost to replace/fix 2000 accord lx sedan front bumper & right headlight?
- Steering Wheel Symptom While Turning Left
- Good headers for my 4 cyl accord f23?
- will 1991 accord 2.2L swap into 2001 accord?
- 98 Accord vapor lock
- Ball Joint R&R
- Honda Accord 97, Took Out Battery Temporarily now it wont Crank/Start!
- 1999 accord help!!!
- 01 accord cheap but useful engine upgrades??
- v6 parts on a 4cyl?
- Honda Accord for a daily driver?
- wheel stud in the REAR broke .. drum-brake setup .. how to replace stud ?
- Steering Wheel fitment?
- Intake Question?
- Dash Fitment
- thinking about buying a 98 or 99 accord
- Weak spark
- Oil in spark plug tube,
- New to the forum "CD5"
- Hey guys
- dipstick tube loose
- 94 Accord Engine Vibration/Rough Idle
- Auto to manual tranny swap...4th in a 5th?
- 1991 accord running problems...??
- 98 accord brake light switch
- 2001 accord F23A4 will not rev
- 99-00 Accord V6 alternator bracket
- Replacing VSS on a 1990 Accord LX
- a/c problem on 94 accord EX 2.2
- taillight question.......
- Power Window will go down and sometimes not up
- surging/bucking when letting off gas, deceleration only???
- HELP NO START
- Front end "squeaks"
- 98 accord service manual?
- 94 Accord EX surges
- Honda Shop in Birmingham,AL
- Installing Oil Pan, do I need anything else?
- 98 Ex accord w/ usdm h22a4 install
- Speedo not working after windshield change
- 1992 accord wont start
- Blinking D4 ... Are the TCU Codes saved/retrievable after the blinking goes away?
- coilovers vs struts and springs
- Double stack! Double what?
- Cam gears or no?
- f20B DOHC SIR-T swap in 97 accord
- 94-97 jdm accord black housing headlight bulbs?
- is it bad to shift with out the clutch?
- My 94 accord ex and it's stunning past 8? months
- Code Intrepertation
- No Chance For Good Will Warranty On Transmission?
- best cams choice for f22
- dc headers
- Hazards blink when car starts
- Disable SRS for 96 Honda Accord EX
- Is this an A/C Blower Motor problem?
- 93 Accord EX No Start
- 02 Accord HID Headlight Problem - HELP!
- 91 accord AT problem
- 93 accord clutch issues
- Caliper slide problem
- Weird squeak!?
- 97 accord se front brakes
- need help finding the door trim to a 94 accord coupe
- AC leaks on pass. side carpet..97 Accord
- rear engine mount for 96 accord 4 cyl
- shifting problem
- headers?
- Cracked starter???
- How's the quality of these splash guards from H and A?
- 1990-2002 Accord FS/WTT/WTB Jul - Sep 2009
- JDM F22A rod bearings help
- my Speedometer is stuck.how do i fix it?
- Remove instrument cluster for 1996 Honda Accord EX car
- rims and muffler
- 1999 Accord DX 2dr rear squeak suspension
- 98 auto accord shifting problem
- 2001 automatic tranny swap
- new to forums, and new driver.friendly advice would b nice
- Stock 97 Honda accord 2.2L 4 Cyl, Where should i start
- Is there a deodorizing powder I can put under my carpet?
- 97 acura cl h23 swap help!!!!!
- I need help with Mahle Pistons(H22A).
- MOMO horn wiring and getting rid of SRS
- Changing headlight of 1992 Honda Accord
- 98 turbo accord problems
- Steering whell vibration on my 1996 Honda Accord
- 1990 accord motor swap
- What years/models bumpers will fit a 2000 accord lx coupe?
- cb7 h22 powered accord review
- Help! Failed smog check, high NO
- What ecu should i run? and other technical ?'s
- Clutch not disengaging all the way
- 1990 Honda Accord - Battery Light Comes On - Can anyone help?
- Oil Pan Drain Plug Stripped!!!
- code 14
- 15a fuse in 7.5a fuse spot
- 30A fuse in 7.5A spot (turn signals) Now they don't work
- 93 Accord ex 2D
- wheels for a 95 accord wagon for autocrossing
- Help! dizzy shaft not lining up with housing
- Cost for fix 1996 Honda Accord EX Speed Meter
- Turning lights off
- help!!!!!!!!!!
- 99 Honda accord v6 automatic passenger side axle
- 1996 Honda Accord AC is leaking
- Can someone run me a carfax please!?
- addvize me please; whats a good harmonic balancer to use on a f22b1
- F22b2 to f22b1 conversion - ecu?
- 99 accord 4cyl and 94-97 4cyl a/c compressors the same?
- Problem with injectors not spitting fuel...
- 95 Accord Engine Swap Help!!!
- SRS light-93 Accord LX
- **Car shakes violently over 55mph**
- got a couple quick questions about F22s
- 1996 Honda Accord Speedmeter is Erratic
- Where can i buy an engine for my accord
- leaking oil presssure sending unit
- small rust spot repair on 94 accord
- 97 Accord Distributor cap
- CEL - P1457 (Could this damage PCM?)
- 98 Accord f23a1 shuts off out of nowhere
- tRYING TO PICK AN EXHAUST 02ACCORD SE 2.3L
- Cracked DC headers 02 Accord SE
- 2002 accord timing belt replace
- 5th gen license plate relocation
- Radiator fan problem. What's wrong here?
- problem at low rpms
- Annoying Engine Hesitation!!!
- [97 Accord] Dashboard Light flickering
- bpi
- 83 accord weird problem
- how to convert a dpfi harness to a mpfi harness
- 96 ACCORD OIL IN SPARK PLUGS
- proportioning valve + Master cyl.
- snapped my valve cover bolt
- I broke my headlight switch
- Radius rod nut torque spec?? (6th gen)
- 98 accord v6 rough idle, sometimes hard to start
- Help with tweeter install. 97 lx
- 96 coupe w? obd2 H22a swap ?????
- Wire tuck question (00 accord ex sedan)
- motor mount problem
- Honda accord 1999 wont start
- 99 accord fuse for running lights keep blowing
- hub conversion problem
- My door lock is tripping =) need help asap!
- 00 accord
- New member/honda owner
- TCS, Plus Check Engine light
- How-To: Replace Clutch Master Cylinder
- Question on AC line pressure readings
- 94 Accord brake problem
- Tranny swap for my 97 accord
- 1997 Accord Automatic Transmission Problems
- 1990 honda accord
- 220whp on h22a suggestions/setups
- Help with 2002 accord a/c problem
- 94 ex missfire
- once again poor gas mileage
- HELP PLZ im confused?????? help on my CD5 accord!
- flexplate failure
- Direct fit Driver side mount for H22 swaps
- CB7 Accord Odyssey 5-Lug Legend Caliper Questions
- srs module location
- Whats the diference?
- obd1 jdm SOHC f22b into obd2a '97 CL - what dizzy?
- 1992 Accord LX auto trans...again.
- 02 accord rear brakes
- 1992 honda accord LX electrical problems
- Inconsistent Idle - Stall on acceleration
- 2002 Honda Accord won't start
- 1996 honda accord beeping.
- f20c3
- are ebay fenders hit or miss....
- 1990 honda accord timing belt
- Still learning but currently LOST!!!
- 1990 accord ls
- 94 accord ex / h22 wiring
