View Full Version : Honda Accord (1990 - 2002)
- Venom?
- 02 Accord - Dealer claims oilpump leak - needs timing belt replaced b/c oil on it
- What size exhaust pipe?
- PDF Workshop manual needed for a 1990 - 1996 Honda Accord
- Valve cover nut f22b2
- Service Manual questions for crank bearings
- I tried everything! helllppp...!!!
- Flat tyre noise / loose blet noise
- Free VIN Check
- swapping 95 f22b to 97 f22b???
- Lowered 1999 V6 Coupe Ride Quality
- turbo on a f22
- Lighting/combination switch HOT
- accord 1999 car radio code
- Anyone recommend a site for complete rebuild kits? (F23A1)
- Accord 1995 L2.2 Alternator Belt Change
- Knock Sensor HELP
- Never experienced this problem before. HELP
- 1991 honda accord
- Snow tire chains.
- timing belt
- 90-93 honda accords question
- 2001 accord engine misfire
- New to the forum
- 94 honda accord exhaust
- DIY for Coilover installation?
- Intake manifold questions
- 97 Accord v6 has spark and fuel but no turnover
- I have Honda Accord 2002 model SE 2 lt
- Headlight dimming.
- Denso or NS fuel gauge
- 5 speed swap questions
- Transmission help 93 honda accord
- 90 shaking something awful at idle
- 01 honda v6 at alot of questions
- Honda accord 1999 ex bad MPG
- F23A1 SOHC Im/tb/fuel inj work on a f22b1?
- Another P0780..... (Just rebuilt Tranny)
- Confused with 93 Honda Accord
- 1996 accord 5 speed turning over but wont start
- aftermarket trans fluid
- D4 LIGHT FLASHING AFTER CAR WARMS UP
- Oil Leaking
- Spark plugs distributor cap and coil question
- defroster wont work, intermittent wipers wont work
- help
- 205/55-16 fit a 2002 Accord cpe?
- 91 accord intermittently starts with starter fluid
- supertech valve springs for f22a6
- 1991 Honda Accord EX - Sticks in Park and Slow Acceleration
- Tire width question
- 96 Accord abs codes/reset
- OBX LSD
- Passenger headlight jus went out help
- Dizzy help
- Newish beginning.
- Power steering hose leaky problem
- 97 Ex: SMD dome light stays on, but very dim.
- '94 Accord cruise control does not engage
- Going from f22b2 to f22a6
- Wierd Starting Problem
- D4 light with ignition at II
- Immobilizer?
- 97 Honda Accord alarm question
- HELP ex. mani. studs broke in head
- 1995 Accord V6 Intermittent Stalling
- Replacing f22a4 DIY
- F23A1 Idle Problems
- 6th Gen lowering springs
- Need new transmission for '98 Accord. Can I trust this online dealer?
- New member
- 94 accord ex - surging issues
- 1993 accord low idle or stall
- 5th Gen market
- 94 accord dx help ?
- 6th Gen trbl codes
- Starting Issue
- 91 accord cold starts and misses but evens out when warm
- Need help!
- Weather stripping?? Can't find
- Will an obd1 f22 dizzy fit a f23 vtec head?
- HELP! SMOG issues
- Non welding muffler/exhaust
- 93 Accord Cold Start issue after new Water Pump (sorry for bringing it up again)
- Water inside tail light, pours into trunk upon opening trunk
- Read this.
- Catalytic converter
- f23 swap in my 94 accord. ran great for a day or two....
- Help with buying Accord
- Endless thermostat housing leak.
- On Cold Idle, Car Goes to 2k RPM, Drops, Repeats
- Exhaust opinions
- Stuck in 2nd gear,can't even get it out even the car is off, do i have a bad tranny?
- 95 accord speedometer lights randomy dont work?
- Dash lights flickering and going out
- Randomly flashing oil light
- 94 accord shaking problems
- 98 Honda Accord V6 accelerate when engine cold
- best value in stock replacement shocks?
- f22/f20 head
- turbo! help
- Need Help 95 Accord vtec
- 1995 Accord distributor swap out question
- Low idle 2002 Accord EX 4cyl
- Cut egr vacuum lines... why?
- Srs question
- 96 accord low fuel light
- plz help a girl out!!!!!
- Distributor replacement. Help please.
- Honda Accord rough idle, cuts off when u put it in gear slow down or stop. HELP!
- Accord flight problem
- Honda Accord P0700 problem.
- A ULEV CATI'ALYC CONVERTER FOR MY 01 ACCORD OR CAN I USE ANY.
- High flow cat test pipe
- '98 Accord EX -- No flow in rad, no pressure
- Check Engine Light P1167
- 91 accord lx f22b2 swap
- 97 accord brakes
- Key Wont Turn
- 91 Accord f22a1 warm start issue
- driver's side window install?
- arp main studs and arp head studs...2 different things?
- Transmission control solenoid
- Won't start... nothing working
- light vs. oem flywheel
- Accord exhaust question
- Brake lamp warning light
- Fixing clutch safety switch? ('93 Civic)
- Bisimoto F22 H beam rod and 9.1:1 piston combo..thoughts? pros/cons?
- Oil Pump Issue
- What trunk lid do you guys think looks better on a 95 accord. 94/95 or 96/97
- Best F22 setup non Vtec, Which head, and intake?
- pic request: 5g accord english fuse box stickers
- 93 Honda accord Code 14
- 1994 Accord non-start, no sound
- Electric Water Pump
- Ignition
- Intermittent heavy vibration when excellerating
- Heater blews cold air
- Tie Rod End
- f22 build.
- 97 Accord F22b1 to H22A OBD1 swap
- Distributor help for H23a vtec
- 1992 Accord Cruise Control
- 2002 Accord SE Trans. Slipping. Take to dealer?
- F22 hybrid build, input is great
- 1999 Accord EX Transmission leak
- 6th gen engine knocking noise? video included
- Car died while driving then got a P0335 code
- ok guys i need help!!!!
- Gas smell coming from vents
- Heater control panel and rear defroster no power.
- Car turns off after 15 minutes
- CA failed smog check
- Blinker Issue
- How do you remove the whole Air condition system on a 95 accord?
- Pic Request
- F22A6 Balancer Shaft Problem. Not the timing.
- Standard Distributor on VTEC engine
- 96 accord misfiring help
- balance shaft elimiantor
- h22 with h23 crank
- 94accrd 2.2nonvtech
- In DESPERATE need of help
- 1992 Honda Accord LX
- Where to buy 94-97 jdm accord sedan rear window with wiper?
- need advice before buying
- Interior swapping 97 into a 96
- 1990 honda accord dx KA4AT bleeding after half shaft replacement
- 92 civic new head gasket with cel codes
- 99 Trans Question
- 01 accord swap questions
- Valve Cover Gasket Change now its Smoking
- 98 Accord EX - Brakes feel like they are pumping
- ecu is chipped but no vtec?
- cb7 accord h22a1 issues
- help guys! 95 Accord wont start!!!
- I see pictureCIVIC SI2000 wheel ENKEI NT03 16"
- 1st time 95 accord coupe owner need some tips
- Experts and Techs Advise Needed for 1994 Accord-Overheating Problem
- Is this a good $ for a 5speed conversion
- Cam gears
- 96 Accord LX Wiring Harness Options
- Intermitten ABS light
- projector headlights and LED tail lights
- Do I Need A Transmission
- Engine Swap
- 1995 Accord EX Manual Trans Speedometer not always working
- f23, is it a great vtec motor for swap
- Updated parts list for 5 lug conversion---11.8 inch rotors
- Just a Tad Bit of Fun....
- 1995 honda accord ex 2.2 vtec
- Closed Deck H22
- H22A Turbo
- Oil in Spark Plug Wells, symptoms?
- coolant question
- NEED HELP FAST
- 3 PIN VSS PLUG.
- 94 accord cut off won't start
- 1993 EX Honda engine Swap to 1994 V-Tech
- 94 honda accord rear speaker removel
- control arm link ?
- Opinions please
- How much bigger can this problem get?
- 94 accord ct26 turbo
- Hi Revving to keep from bogging down
- 96 Honda Accord EX worries
- 1995 honda accord ex mod questions
- 1998 Accord Timing Belt 4cyl
- RTV sealant for VC
- Hesitation After New Ignition Switch
- 1997 Accord Won't Start After Installing New Stereo
- Need a parts list
- Somehow my tachometer is off....it's reading too low.
- stearing wheel
- Possible tansmission swap
- erratic idling between cold to warm
- Code 8 TDC Sensor on F22B1
- 1990 Accord CEL & Sport light Flashing
- Bad fuel pump??
- New User
- My 6thgen accord H22 swap thread and Info.
- F22B2 non Vtec Oil leak/burning
- 1994 Accord EX ABS DELETE Q's
- rebuilding a junkyard engine
- No start problem 93 Accord
- 91 Accord Head Gasket Oil leak
- Strange scraping, pulsating sound affecting handling.
- 1991 accord
- No spark, need help
- 1995 accord EX gauges dead
- motor swap help!!??!!
- Projector retrofit help please$$
- P1457 codes came up after rebuilding transmission
- 93 Honda Accord no start! Need Help!
- Accord 1997 vtec - high beam headlights question
- 90 accord engine rebuild or swap?
- clutch won't bleed
- Header question
- H&R Race 94-95 springs on cb7...how will it sit?
- 1990 accord obd port location???
- Need Help Starting 1992 Accord!
- Building the f22, got a question or two
- poor heat on highway 92 accord
- 97 factory security system has freaked out
- 97 SE speedometer/vents/lights issues plese help
- 90 accord smog fail
- Accord 1990
- 2000 Accord EX Coupe, 4 cyl, w/ 130k miles
