View Full Version : Honda Accord (1990 - 2002)
- Custom Pipe
- TSX K24 in 98-02 Accord
- another noob question
- Rev and RPM's
- looking for a 94-97 accord lx cluster
- Need to find a door latch assembly.
- accord chassis and prelude
- Help! 96 Accord CD Player dash wire harness replacement
- 99 Accord Rear Lower Tie Bar Placement
- A/C Compressor noise, '97 Accord EX
- auto cb7 and h22 .....I did a search already.
- oil change
- 5 spd pedal assembly
- WTB:Stock or aftermarket headers
- Brake Noise help -
- no spark during cranking?
- 99 door panel removal
- Clutch pedal problem.
- Emanage experts on OBDII
- manifold leak....
- IACv problem
- 96-97 rear bumper fit 95 accord
- PROJECT WAGON help??
- Turbos for H22 Question
- lx to ex.
- Surging idle and "wind" coming from oil cap?
- JDM F22B hesitation
- Experienced Air Conditioning Help please... did my searching
- after installing new front speakers windows wont go up, need help ASAP
- ECU code 43 - 92 accord ex - some help please before I throw money at dealer
- Looking for a car
- hesitation and backfiring
- Sway bar question
- ebay
- Lowering Springs?
- f22b1 block/h23a1 head?
- need some help....a/c
- 90 Accord rear motor mount
- 4th Gen Rear Sway Bar- Is Progress better than ST?
- Another "What Kind of Oil" Thread.....deal wit it
- whats wrong with my Wagon 97 accord help
- AV6 45K tuneup checklist?
- gauge cluster
- air intakes
- Timing Belt Change-Please help me
- Hi Flow cat, what to do with O2 sensor?
- 91 Automatic jumps out of gear
- Who makes a LONG SHiFTER for a 94-97 accord 5spd :/
- Aftermarket distributor sucks!
- Sqeaky front end noises ( 90 Accord )
- Fuel Problem.
- Rear Windshield Wiper WHAT!!????
- Low-side service valve location for A/C
- Overheating 91 accord lx
- Underdrive Pulleys
- Spark Plugs
- 93 rear speaker size
- honda swap ?
- now what do i do?
- 99 V6...trying to replace altenator belt
- 92 accord rough transmission
- Vehicle speed sensor 1995 accord
- question about city lights...
- 1998 Accord P0170/P0172 - Need hpelp troubleshooting
- 1997 Accord SE newbie upgrade question
- ? about '86 auto trany
- 2000 Accord
- H22 CB7 (90-93 Accords) Turbo Setup w/A/C for SC61 or GT35R turbo
- exterior parts.
- Quick 89 Accord question- LCA dangling
- HELP! Stripped Cat Bolt Question
- Grounding System
- Radio installation
- Lowest offset on a 5th gen ACCORD
- Engine Management Required light
- Does your 91' accord stall in the heat?
- 91' Accord EX short ram air intake... and computer reset?!
- BB4 (92-96 Prelude) front end conversion on a 94' 4 door accord LX with a H22 motor swap?
- Accord acting weird
- HELP!!! High Idle Smoking Header
- 98 LX Tranny Q
- Wheel Bearings on a 99 Accord *tips and tricks*
- 94-97 Accord shop/service manual
- Shift boot - aesthetics!
- something is wrong with my car?
- 95 accord w/stock h22, changing pistons but i must sleeve my block???
- 5sp shifter
- car shakes in reverse
- 9 second cb7
- bumper question
- no power at fuel pump question
- Motor mounts
- your help or thoughts welcome
- steering wheel shaking....did a search....
- 1990 honda accord ex fuel mangement, what is available? what is good? where do i get?
- Problem Installed AEM Short Ram Air Intake
- D4 Light blinks wont start.
- 1991 Accord drivers door wont open
- IF you have a 1996 Accord can you tell me somthing?
- NEED HELP with front prking light/blinker?
- 2005 Acura TL rims fit a 1999 accord ?
- Get a free exhaust from GReddy Performance Products
- That wild accord kit car?
- Anyone road racing their CB7's (suspension set-ups)
- Type-R engine swap
- headers - yay or nay?
- Water pouring out of floor vents
- F23/H22 boost questions
- Vtech system
- 03 Accord CEL Reset
- weird brake problem - need help please!
- Gas Gage
- New 05'Accord Parts Proble....
- swaps on a 83 accord?
- Civic OBD1 ECU vs H22 VTEC ECU ..
- 2004 Accord EX 4Cyl Problems. Please Help
- SONAR HEAD LIGHT HELP
- Random battery drain
- H22 Into 94 Accord Please help
- How/With What Should I Mod My 97 Accord LX? Please Help!
- Power Door Lock problem... can't figure it out
- Idiots in my town... kinda long(Accord related)
- F22 Rebuild?????????????
- wiring harness for h22? install?
- Navigation system for accord
- 96 accord maintenance.
- (pic request) painted 94 ex Rims
- 88 Accord
- 1990 EX 2dr 5spd, turbo, camshaft, headers, what should i do?
- anbody have times for one of these
- Flywheels
- F1 racing clutches
- Best intake
- what size bolts for dc sports header
- Gas Smell inside car... think I figured it out...
- coilover help
- EGR repair on 6th gen accord
- aftermarket gauges w/ power inverter, what voltage/wires to hook up to?
- JDM Accord ?Wagon? Front bumper
- Exhaust Options?
- H22 Swap Problems IN 93 Accord
- what is the best aftermarket headlight for my 95 accord?
- Accord Fuel Pump
- D4 light flashing
- Need axle removal help ASAP!!
- 94 Accord LX, just recharged AC, fluctuating idle in park
- o2 sensor question
- 97 Accord SE Power Lock problems
- would this work
- obd2b swap into obd2a car w/ auto tranny
- how many watts is my stock system?
- Got a Turbo for free, need some help figuring out what it is and if it works.
- 88 lxi ????
- I want some wheels But.....
- 6th gen Fluidyne Radiator Installation
- 2000 Accord LX Vtec not reving past 5krpm in neutral
- Gutted Trunk
- Catalytic and exhaust advice for a n00bie ('98 Coupe LX V6)...
- 2002 Honda Accord Clear Coat Problem
- Hood Dent Removal 2000 4 dr
- check out this accord
- d4 flashes on dash
- 90’ accord with tcm problem
- What kind of bulb for the high beam does the JDM depo lights use?
- Drifts to the right...
- Problems with my 92 Honda Accord LX
- what kind of oil in a 1998 v6 accord?
- when does new models get released?
- 99 accord suspension
- 98' Accord Honda Floor mats
- Maintenance Light - How do I turn it off
- Camber Kit???
- Gauge needles not lighting up
- '95 LX exhaust estimate - is it legit?
- Honda Accord 1994 Starter Removal
- Springs or Coilovers?
- Rims
- Accord meets in the 801 area??????
- gotta question
- Head Light Bulb Replacement for a 05 Accord
- Interior on the doors...
- Heater Knob problem...
- ebay TSUDP exhaust systems any good?
- transmission fluid
- Looking for better than OEM brakes/pads
- Power Supply Locations??
- spark plug gap size?
- Crappy Manuals Suck! Where is Ground G301?
- 94 accord flooding inside
- 1988 Accord can it be swaped?
- code p1381 help!
- 99 Accord V6, where is the fuel line at?
- Tac issue
- I need some clarification please...
- '94 Accord B-pillar question
- 86 ACCORD TRANSMISSION
- 91 Honda Accord EX hesitates....fixed twice cert mech... still occurs egr or ??
- steering wheel stereo controls???
- Horsepower
- 1990 accord ex shakes under acceleration
- Clutch in the rain...
- Car makes clunking sound when accelerating, maybe transmission; help!
- Need help with exhaust setup
- Engines
- Horsepower?
- Auto to Manual?
- f22 head/f23 block
- SRS CODE
- Koni Yellows...
- Strange Idling 91 Accord EX
- INSPECTION
- mes connector for srs reset??
- Swaybar and Strut Tower bar suggestions?
- H22a in accord build
- Help!! Must find factory service manual for 97 Accord Sedan...
- Friend's car got jacked!!!!!!thread link inside
- Help with a relay issue after battery install
- Just bought An 89 4dr LXi What to tune first.
- anybody got a helms handy? torque specs for water and oil pump bolts? timing belt replacement...
- 95 accord ex speedo wiring question
- 97 accordse running hot while driving
- H22 Head Swap Questions
- Lowering my Accord
- Turbo Charger vs Super Charger
- suspension
- new gauges
- Gude/Bullfrog Head package
- 6th Gen Accord Spark Plugs
- Recommended tire presure for Accord 2002
- 1800 RPM buzz - 95 Accord
- HELP!!! Headers stuck
- Can a civic/integra turbo manifold bolt to an accord f22 head and will it work?
- 02 Accord v6 Vacuum gauge HELP!
- 90 Honda Accord LX has developed a miss
- 95 v6 using oil advice please
- EGR kit
- is an H22 the only motor that can be swapped in a 94-97 accord?
- Idleing Problems
- speaker grills
- Help with wipers
- 89 Exi Cruise control dosnt work???
- Engine idles too low. Car shakes.
- stupid question, but I really dont know.
- short shifter
- My passenger-side fan rattles and screeches!!!
- Annoying seat-belt-reminder beep
- need help people
- h22 swap for a '93 accord
- distributor cap
- coil springs or racing springs
