View Full Version : Honda Accord (1990 - 2002)
- 96 Accord EX won't start
- Rear Drum Brakes???
- Idle adjusted, now what?
- 89 accord springs
- Problem: slight hesitation just off idle
- axle help
- i'm back and in the swing of things!!b
- Engine noise advice
- Need diagram to remove IAC valve on 93 DX
- 86 Accord LX Stalls in the rain .. HELP!!
- Lookin 4 94-95 Front bumper
- 86 accord JDM 5 speed-no reverse.
- f22b2 in 92 accord
- Smoking at high rpms ????
- 2000 LX 4cyl Check Engine Light
- Transmission Help?
- best springs for daily driver h22 4gen accord? goldlines?
- Reground camshaft/valvesprings
- SAFC for 4th gen
- Air Filter
- 6th gen offset
- EX muffler on a LX, is it a bolt on?
- accord chassis code
- 83 accord stalling...need help
- Crank Pully
- car lags under acceleration
- looking for an f22b1
- transmission
- Newbie questions regarding '86 Accord DX
- HELP! Engine Light & Burning Lean!!!!
- Timing Belt
- underdrive Pulley
- Accord 03 problems!!!!!!
- Remote door unlock for 1991 Accord ?
- I have oil all over my spark plugs... WHAT IS WRONG????
- turbo accord question
- 95 Accord--What pressure should be used in the 18inch tires?
- tranny shifter problems
- question about 5th gens
- auto trans failure to upshift under full throttle
- Newbie Question
- Should I change only my C-V joint or just change the whole drive shaft?
- what's the best spark plug for 94 Accord LX?
- Recipe for 13 sec h23 5th gen accord?
- transmission
- brembo calipers!!
- engine revving by itself
- Urgen, how to replace brake master cyclinder on 94 accord EX
- 5th gen lx block with.....
- bad starter relay?
- ABS???
- Impressions of new v6 accord coupe?
- Short Shifter??
- side marker power wire?
- anybody know the oil filter thread size of the f22b1?
- turbo power
- Lowering and Wheel Diameter
- hey 2point6
- ABS Light just came on......Have a ticking in motor?? Help
- Junkyard Experiences : Tips, Tricks and Advice for finding parts for your Accord
- h22a pinouts on 93 accord
- 3rd gen hatchback
- ATTN: *SRS* specialist -- Detailed pics of SRS issue inside.
- car totally loses power
- f22b2 or h22a
- rear bumper turn signals
- Suspension "crunch" on '93 Accord
- Tein's for 4th gens
- metallic rattling sound..HELP!
- OBDI conversion makes car run irregular??????
- In need of stock Accord engine
- 94 accord dx coupe tire sizes
- Blockguard for F22a???
- Aftermarket Questions.... HELP!!
- 96 V6 accord motor or acura legend V6 motor in a 91 accord....
- My Car's Specs??
- AEM Brake Pad install
- Battery Relocation
- Accord Intake problems.
- Compression results in a 4th gen F22a4 and a question
- HELP 4Th gen Temp guage going crazy!
- dsm turbo mani on accord
- LSD Options for f22?
- rear strut bar quality
- Rods and postons for my F22
- Car dies when in neutral
- AT trany clunks when it's cold?
- F20 replacement ffor the f22?????
- how hard is to change CV boot on 95 accord
- Car died on freeway last night...timing belt slip?
- TECH: 5th Gen OBDII ECM/PCM Terminal Arrangement
- will downsizing from 18 inch to 15 inch wheels improve ANYTHING?
- could someone with a 4th gen do me a favor?
- 93 Accord 4ws
- Gauge Cluster How To?
- Cannot get out of park! (Auto)
- bent rim & suspension damage?
- help......hard time starting up the car.
- Which tranny should I go with?
- skunk2 suspension
- Accord Tranny PLEASE HELP
- SRS Reset: MES connector Voltage = 0.00V
- Changing throttle cable??
- Lx and Ex distributor ??
- power antenna question any help?
- Odessy Brake Swap/Rear Conversion Question
- Hondata now has AUTOTUNE
- Automatic: should I bother?
- Parking brake light illuminating when accelerating
- 5th Gen Accord distributers interchangeable?
- Cutting Accord brake rotors
- who makes turbos for 4th gen accords
- Brake Lamp Troubleshooting
- abs brake system malfunction
- 2003 Accord TypeS, Huh?
- Coolant Question
- 1990 Accord axle and CV joints
- Rewiring the fans for switch?
- hit a curb! help me out
- i have 500 dollars and i need to know what i should do next?
- Spring
- transmission lag in 2nd gear??
- 86-89 Accord Shop Manual downable
- h22 a Accord Tachometer Problems...
- WTF-missing motor mount bolt.
- who has a'pexi vafc on their 4 cyl accord?
- FS: 17 x 7 Wheels
- Valve destruction theory... Intelligent people please!!!!!
- new tb and my cruise control doesnt work
- MSD in 94 LX
- 4th gen rad flush, bolt on engine problem
- Tired of car not starting!!!!!!!! HELP!!!
- Head gasket replacement
- Oil in Spark Plugs Please Help
- jdm f22b
- will i fail emissions?
- engine runs like hell at normal driving speeds, any one know why?
- About to Start on My Timing Belts...Last Minute Tips?
- Fans come on - power is affected
- ECU Codes
- battery keeps draining while driving! What is wrong?????
- 5 lug conversion
- Turbo as my first 03' coupe mod? or something else?
- What size tire will fit my rims?
- Old engine: will strengthening bottom or top cause other part to fail?
- Attn: Built "F series" people
- Honda Accord/Prelude question...
- Need opinion on Modesti's Independent Repair
- Apex'i or GReddy Exhaust Comparision
- Noise with camber kit??
- N2O and iginition setups
- SOHC VS. DOHC in NEW accords
- Signal Lights
- major squeakage in suspension..need some help
- Car overheating, help me please
- 7th gen clicking rattle noise while idling.
- Blocks?
- H22a head on f22 block?
- Leak on Floorboard...Help!
- Time for motor rebuild on F23A1 motor. Help looking for parts.
- how much does labor cost for an accord?
- trouble codes after a swap
- o2 sensor wire on ecu for 95 accord???
- Thinking about buying a used Accord, which years are better?
- Engine makes "knocking" sound at certain rpm
- clutch/transaxle
- idle problem
- Tires...
- Speedometer broken. Help!!
- Anyone consider rear brake upgrades? or have any ideas for possible swaps?
- cluster problem - help
- NEW to forumn, specs on cars plz
- tail lights
- AC Goes on when I put the defrost on!!!!
- 2003 aftermarket
- Can anyone tell me how to change the 2000 Accord ac air filters? How do I get to them?
- Do I need to use Honda brand products for brake fluid and antifreeze?
- What internal components can NOS damage and car still run?
- V6 Accord Stock-like Brake Pads for Cheap
- The not so cool F22a1......
- Need some advice on selling engine & tranny. Sell complete or part it out?
- Question regarding motors
- brake light coming on...
- Switching to OBDI, what else besides jumper and ECU do i need
- In-need of Info on the new Apex'I Rev/Speed Meter!
- DOHC F22 JDM Cylinder Head?
- Radiator Fan Electrical Diaganostic Problem
- H22 swap into 5g Automatic ?'s
- Noise ( to hard to discribe ) while driving or parked, does you honda do it ?
- Need transmission help: 92 auto 4cyl
- H22 Swap, Tranny Problem
- Will a Honda 98-00 Accord Oxygen Sensor fit a 1994 honda civic ex coupe?
- How would this turbo work on my setup
- Good camber kit for 2000 Accord EX I4 Sedan?
- question on power pulleys any help?
- 5g cluster in 4g?
- rear sway bar help....itr on 01 accord
- burning rubber smell...cause?
- 1986 Accord LX Weight
- 94 accord camshaft
- Steering wheel wiggle at low speeds in '95 accord- goes away when moving faster...
- 95 EX rebuild cost?? Auto to 5 speed?
- *upgrade* Accord wagon rotor's BRAKE SETUP
- need more POWER any help?
- Hey, I'm thinkin about buying the new Accord 03' Should i get the LX manual, or LX V6?
- ecu needed
- Has ANYONE built an F22a1 or F22a4, ever?
- top speed
- Aite before i say this,, im thinking the same thing,, WTF? b18 in a 5th gen Accord.
- H&R OE Sports on a 4th Gen?
- Noise when steering
- 4th gen accord 4x114 or 4x100?
- Idle is eratic during extreme cold weather
- How do you take out cluster in 94 accord ??
- Front Clips
- 6g accord dropping help for me
- wheel for 93' accord in cali
- Best nitrous to use---Post your nitrous setup
- turbo kits for 90-93 accords
- Gonna swap the LX exhaust manifold for an EX set....
- h series tranny mount question
- I Am Now Your Moderator
- Road noise (99 coupe)
- 2003 V6 Accord Air Intake & Chip????
- 96 H22 Swap questions............... again
- Need a diagram: Fan Control Unit
- computer chip and suspension
- Euro R Manifold pic
- WTB: Accord F-series manual transmission
- Question??
- ??Turbo F22??
- OT:01-02 accord coupe lip installation
- All Accord V6 Tranny problem people
- 5zigen axleback exhaust on 4th gen accord??
- ltr size
- to my dropped 5th gen Accords
- Turbo the F23A5 or H22
- How do you install a h22 in replace of f22 in 92 accord
- changing Auto tranny fluid-96 LX
- huge problem... please help me!!!!!!!!!!
- F23a1(2000 ex) going to my 93 ex......OBD1 or OBD2
- Slight Jerk From Clutch When Engaging In First From Standstill Any Ideas?
- 95 Accord Rear Window Defroster/Alternator problem?
- 98 Door lock problems
- Tranny fluid capacity chart.
- air ride for a 96 accord
- Is the tranny drain plug on 2000 Accord Vtec4 recessed, square entry, and blue?
- 91ex accord exhaust manifold..
- Whats the code # for 03 accord headlights?
- turbo f22 1/4 mile times
