View Full Version : Honda Accord (1990 - 2002)
- power loss/ eletrical short?
- HELP ME OUT! plug gasket leak
- 1998 4CYL Transmission problems
- new spoiler for the04 accord coupe ???
- 5000rpm cut off problem
- newbi in turbos-"questions"
- Bulbs for 90 Accord EXR (canadian)
- Narrowed down my Lighting Troubles
- thought it was misfiring was wrong?!?!
- Clear Third Brake Light Kits & Under Seat Brackets
- Wheels for 01 accord v6
- Bra for 94 Accord
- squealing nosie when it rained today
- Is it worth it to put projectors on an accord?
- extended warranty 94-97 accord
- JDM ITR SRS Steering wheel, will it fit my 93 Accord SE?
- coil problem on a h22 swap in my 1994 accord lx
- Flexpipe leak...
- jdm headlights
- Honda Accord 4 door with H&R OE Spring
- Help me choose some Rims
- OT How many miles are on your accord
- What did you pay for your Honda EX V6 sedan (with Nav and leather seats)?
- Where can i find a h22 type s
- Newbie here could someone please help
- SF people and springs.
- Differences in models: 1995 EX, 1995 DX, 1995 LX....what are the differences
- diagram of rear suspension for cb7 (4th gen) accord
- Taking Out Stock Stereo
- 1994 Accord electrical problems? Head lights!
- eBay upper arms and motor mounts any good?
- Car still "clicking" when key is turned, new battery.
- Automatic OBD2 to OBD1
- It can be done.
- Am I driving Hard?
- manual transmission oil
- Exhaust light indicator
- Gen6 Headlight bulb number?
- Name That Part!
- euro-r
- Auto 2 Manual.......$$$
- OEM F22 Stroker kit
- Is a camber kit necesarry for a 1.5" drop on my 98 accord?
- reverse grind
- distributor swap
- help replacing timing belt and water pump
- what would i need 90 accord ex
- Automatic To Manual conversion with H23
- MOMO Steering Wheel Adapter Problem - CB7 (93 Accord)
- how to change brake pads on a 2002 accord coupe v6?
- Anyone got experience with H&R OE on their accord?
- lowered the ride and have a question
- Exhaust manifold question
- ROUGH idle
- loss of power
- Climate control lights don't work
- What tire size for 17 inch rims?>
- p13 chipping
- strange question
- I'm changing timing belt and have question
- Is this normal Honda transmission behavior?
- radiator pipe/hose leak
- what CAI is this?
- OT I need a A20A1 cylinder head 88' LX
- Shift Light
- climate control
- 2004 ACCORD 17" V6 SIX SPEED WHEELS FOR SALE
- 6th gen OEM window visors
- Struts and Shock ... ?
- CEL codes
- Help Me Convince My Dad About Lowering My Accord
- I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help
- drum to disk conversion
- accord rear bumper sag
- BAD GAS LEAK.... help me before the car explodes
- How much?
- JDM DISTRIBUTOR/ BATTERY QUESTION
- weird squeak from exhaust when idled...
- Help: where can i get a wiring harness for my 95lx?
- Need Help, Lot's of Problems (Wash. State)
- Can Anyone recomend a good Performance Distributor Cap and Rotor for a 1996 Honda Accord DX.
- ECU
- Throttle Body
- Remember Larry Settles
- 209thousand mi. on accord what can i do
- 89 Accord Headlight Question
- 90 accord project car help
- '93 accord h23a1 P13 or P14 ? which will work ?
- engine starting problem
- shiftin in an automatic
- this tranny?
- which accord ECU's are more valuable?
- how much could I get for this car or should ask for?
- question bout 94-97 accord models... and bout the v6 model
- Suspension drooping on one side - AGX's with Sportlines
- Strut bar inside trunk?
- tires...???
- FSM
- 98 accord clutch problem
- new car or weight reduction?
- f22 have frm sleeves?
- 91 accord being really gay
- Need help finding side skirts and rear lip...Plus need an opinion
- 6th gen DC SPorts Header, anyone with any experience ?
- cross drilled rotors > 94 accord wagon
- Curb Weight
- How do you remove the control lever from AT on an '89 Accord? HELP!!!
- accord chasis ??
- How many juice does it take to start
- Want to buy affordable PERFORMANCE Distributor cap and rotor no MSD for 19996 Accord Dx.
- ET
- how do lowering springs work?
- can i swap it???
- 4 wire o2 sensor help!!!!!!!!!!!!!!! please!!!!!!!!! H22A
- please help! motor ?'s
- why is it so hard changing the driverside headlight on my 96 accord?
- where can i get the dohc f22b head that comes on the exr accord
- Turning a rotor?????
- Replacing A pillar
- Replacing Drum Brakes
- rims
- '94 Accord EX Question
- f22b1 swap into 94 accord dx problem
- I Need an ACCEL Distributor Cap and rotor Kit for a 1996 Accord Dx.
- Transmission Code P0740 TCC
- 91 accord a/t transmission code 8 ??
- Any help with this would be great
- springs
- Stock 6th gen Spring rates
- Question about shocks
- h22 in 91 accord
- new bottom end question ??
- H22a swap
- Passing smog - NOS problem
- anybody have a sticky door problem?
- downpipe
- 93 EX error code 43
- 94 Accord - Replaced Axles, Now Have a "Shimmy"??
- Aftermarket fogs on 7th GEN coupes?
- homemade solid polyurthane motor mounts
- Ecu codes-check engine light
- how to replace a 93 2dr window
- Do a civic 4 lug rim fit on a 4 lug Accord?
- Suspension/rims/seats and steering wheel
- bodykits
- F23 swap into 95 Accord
- 1991 Accord
- Wat should I do first?
- honda no spark condition
- TPS sensor gone bad, does it affect me?
- what does dx lx ex mean
- F22b1 blow by/beat engine
- red lining
- Clutch life
- Which would be better in an accord?H22 or F20?
- Removing Center Console? - 99 Accord LX 4DR
- f22b1 vtec wiring help
- Intake Heat Shield
- Can I drop a f22b1 into my 92 ex accord?
- NEED FUEL FILTER HELP ASAP!!!
- Noob on the loose
- Camber kit ???
- 92 acoord problems please help
- Who can figure this out!
- I need a tach signal
- Converting ABS to Non?
- Shock install problem?
- 99 Accord Alarm Wiring
- ne one know where i can get amber corners for a 90 accord????
- Timing belt replacement
- Front motor mount removal? (PITA)
- Power Window, Power Door Lock, Trunk release kits.
- ignition upgrade
- H22 or F20B
- What they call a 6th Gen Accord?
- AEM Intakes
- OBD2 and OBD1 ecu pinouts
- HELP!!!!
- johnnyracecar/tyrus ic ?!
- Which springs?
- speaker wire diagram
- Heating?
- Exhaust Hangers??
- wierd sound need help
- H22A Headers
- NGK copper or NGK iridium?
- 92 accord cuts off every now and then
- people with 16s... are you running 50 or 55 tires?
- Steering Wheel shakes when I brake??
- Exhaust manifold gasket question
- Coilovers? NEX..TEIN..etc
- 98 accord. how to change the headlamp bulb
- SPRINGS
- H23 throttle body
- Bolt patten?
- Brake bleeding process question
- might need a new engine...
- turbo question?
- Radiator cooling fan problem Need Help!!!
- I NEED HELP NOW!!!
- Engine dilemma
- Uberdata Accord?
- hit a bump and now its squeaking coming from the front..
- lowering 90 accord ex (help)
- TW Sensor? Help!
- Intake for 03 v6 Accord
- Door locks
- "98 ign swx recall question
- CEL Code 70
- 99 HOnda accord V6 Valve cover
- having problems with 99 accord v6
- Who rebuilt f22?
- f22 parts
- SRS stays on
- Intake system = More gas usage?
- help a noob fix up his accord
- wtb: h22 motor
- h22 accord problems
- Unreliable..HELP!!
- Brake fluid flush question
- tags on rear ? de badge
- Parting out 95 Honda Accord 4 door 5 speed
- Cam gears question
- A few Newbie Question
- Got my PT Header installed
- Possibly Dumb Question
- tie rod end, squeaking
- I NEED HELP FAST!!!
- IndyFAQ: Ignition Wires Spark Plugs
- I need some help
- 4th gen engine mod question....
- Whats covered in my warranty
- Loud Engine Noise
- Moter Mount?
- General Maintenance Questions
- Window not rolling up straight
- 99 accord with Ro_ja formula 5
- TV Shoppin - HELP!
- racing hart C2 18"
- New radaitor aftermakarket
- 98 Accord COntinues to keep Stalling
- does a 97 accord cat-back exhaust system fit a 98 accord?
- HELP! LOWERING 98 ACCORD w/ 18" chrome rims....
- question.. does anyone have the 5zigen fireball exhaust??
- Would It Fit?
- Swap out Factory Foglights
- 03-04 Sedan Stock Fog Light Removal
- Question about 4th gen Accord model
- Compression cut-off
