View Full Version : Honda Accord (1990 - 2002)
- need some quick help guys - msd cap install
- eibach prokit or H&R race springs?
- Ecu problem.
- SRS Light on
- VTEC in my 99 LX
- ???what 5 lug hub fits on the 94-97 accord???
- F22B1!
- prelude and accord interchangeable parts?!?!
- smoothest drop?
- Honda Warranty?
- does anybody know oem spring rates? 91 Accord specifically…
- DIY - rear brakes for 1990 Accord
- F22C in the S2000 same as the f22a1 in accords ??????
- 98 accord manual to 5spd swap...
- Service Manual for 2000 Honda Accord EX sedan V4
- Did the EX model for the CD5/CD7 only came with these rims?
- question for VTEC experts
- accord euro-r rims
- My friend's 90 Accord Swap
- auto transmission computer
- Will these wheels work on my 95 accord?
- 1994 Accord LX Tranny Messed up?
- Idle Air control valve
- F'ed up 1998 Accord
- Accord won't start some days.
- Finally Dyno'd - Lovely numbers for the haters
- 92 accord wire diagram
- What to use H23 intake manifold and throttle body, or F22A6?
- . VAFC Help with install
- 83 Honda Accord Cold Running Problem
- 97 accord with h22a swap
- Cleaning the Engine Bay?
- Head light problems + check engine light. Please help.
- My Instrument Cluster Suddenly Went Dead...
- Body piece removable?
- Help please - Help
- Accelerating issues for a 1990
- Ignition switch problem
- speed sensor 96 ex going bad?
- Brake fluid
- driveshaft
- problem with transmission?
- 6gen 2000 accord gasker and VTEC - Need Help badly
- weatherstripping leak!
- 1990 Clutch Prob
- Something we would all like to have... better steering feel
- WTF Why is My Carpet Wet?
- exhaust....again
- Where can I get shifter diagram?
- obd2 problems
- 2004 Accord CD Player Help!
- Non vtec head on vtec block
- need help: '91 2.2L lunges after changing hoses
- 87 fastback?
- Any word on the 2008 Accord?
- car won't start
- 04 accord forced induction
- accord coupe - redeeming qualities?
- help please. blew out my interior lighting
- 94-97 Honda Accord EX Wheels
- Carbon fiber questions
- japanese or euro license plate
- 89 Honda battery light and high idle
- spoon chip vs. skunk2 chip ecu
- How to program 03 Accord Keyless replacement.
- 4cyl exhaust on v6
- Struts and shocks which do es it come with?
- Wiper Problem
- rough ride on interstate
- ATF
- what other parts for my cb7(91 accord dx)
- Third Brake Light not working?
- Engine recommendations
- ***help suspension problem***
- Brake light is on
- 95lx automatic, sticky floor shifter
- 92 Honda Accord EX cruise control not working!
- 92 Honda Accord EX ABS pulsating when driving after changing CV axles
- searched:: trying to wire external coil on 95 ex f22b1
- STEERING WHEEL QUESTION
- hrater/ ac blower
- Question about 1995 accord v6 parts!!!!
- Is this wrecked 97 LX worth $900?
- Speakers
- Strut and Sway Bars
- WTB Short ram intake for 00 4cyl
- 94~97 Accord Carbon fiber front lip?
- Another Suspension Question please help
- wana turbo it with 13psi PLEAs eeeelp me comrades,,lol
- 1990 Accord Power Windows stopped working..
- 94 accord 5 lug conversion
- Enkei rpf1 advice!!!!
- is it possible to have this tranny...?
- exhaust port question
- What sized battry for 1992 4D Honda Accord?
- dashboard lights/cornerlights
- Tanabe a good choice?
- Cooling/Fuel?
- timing belt break
- another f22b dohc question????
- Where is 98 Accord trunk light activation switch located?
- accord motor swap
- help! check engine light on and rpm's wont go above 4k in any gear
- A/C question
- anybody done Auto Trans "flush" on 6th gen and is still working ?
- crx corner light swap
- help..1991 accord wagon. windshield wiper problems...please read
- Electrical Wiring Question
- Changeing the Interior Color
- Cool Idea
- '92 exhaust leak
- Where is my clock
- HELP!!!! F22 Non Vtec Help!!!! H22 head help or Swap Info!!!!!!!!!!!!!!
- Things to check before buying a used car?
- *ShowROOM* Interior and Motor!
- HELP here on accord probs~!!!
- a rhd to a 94 accord
- 1986 honda accord liquid leakage---urgent , waiting online!
- Weird Squeaking noise
- wiWindow regulator?
- How do I " CLEAR" the MALFUNCTION INDICATOR LAMP (Check Engine Light) ?
- Temp guage problem
- h22 gurus: PLEASE HELP
- Honda clutch or aftermarket clutch kit for same price?
- 2007 Accord 2-door owners, a couple of questions for you
- 2007 Accord infomation
- Any known issues with 2003 Accord EX 4cyl 5MT
- Interchangeable years for tow hitch: 90-93? or 90-97?
- quick question about AT to 5spd swap
- 3rd gear problem...
- Manual Climate Control Havok
- there is
- does a 7th gen coupe exhaust fit on a sedan?
- Honda Inspire
- Crush Washers, Dealer or Auto Store?
- k series into 94-97 accord
- 2 Cylinders misfire after jump starting another battery
- Seat Swap
- Manufacturers recommendations on Oil Chg intervals.
- spoon mirrors on a 90-93 accord? or any model accord
- Ideas???
- a lip kit....
- Accord Electrical radio/Cigarette lighter issue . Hellppp
- Automatic Seat Belt Stuck forward - won't move back
- no start
- 2000 accord egine lags around 40 mph, trans has been replaced
- Quick pic request
- transmission codes?
- gaskit or cracked head? f22b
- Acura RSX seats in a CD7?
- CV joints
- Painting Windshield Wipers!
- random switch
- Konig Monsoon wheels but no lug nuts?
- New Custom Parts.
- 4door 4cyl exhaust
- 97 accord wheel bearing help
- 99 Accord alarm issues
- What your settings on your AGX's?
- shocks and springs?!
- 98 accord rear bumper assembly
- '06 Accord Horn
- where is my ecu??
- ECM upgrades
- difference between front camber arm and ball joint...
- Idle revs
- ABS light.
- Question about plug wires
- Will an H22 swap directly into a 98+ Accord.
- No heat in 1988 Accord - Heater core?
- Car Alarms
- H22 (Need Help)
- Cat replacement: High flow, test, or OEM?
- Fabricating and installing a LATCH system on a '94
- 1993, Accord EX, Auto, 161K
- Need a list of everything to lower my car
- 91 Accord not taking battery charge.
- should I get DTM or Mugen EURO R coilovers???
- Idle control question
- humming possible tranny bearing
- help with h22a swap..
- How the heck do I change my headlight bulbs on my 95 lx?!
- 2000 Accord - Oil Pressure Switch
- what is the 94-97 honda accord 4d chasis code?
- Need Help
- are the solenoids and tranny are supossed to be hot?
- Turbo v.s. Supercharged
- do the JDM accords have a rear windshield wiper
- 94 Accord getting 41 code - Heated Oxygen Sensor
- Front wheel making noise when braking
- 1996 accord megan header (DX)
- 95 accord ps pump problem
- Auto Transmission problem
- How to replace bulb in CC button??
- 2004 ACCORD jumper wire?????
- More problems - bouncing/erratic idle (94 Accord EX)
- 95 accord{F22-B1} has erratic rpm's changes at high speed
- lowering car law
- Why am I losing gas so fast?
- Gas Lifts
- h22 head on f22 dohc engine
- High rpm at 50mph
- what is this????
- separate lens from light housing? help?
- Accord HP??
- So, is it my imagination...
- where can i get the i-vtec doch decal?
- need help with interior door handle-94 EX sedan
- I need an opinion
- trans problem
- Will this fit??
- accord/ blaster
- 05' Honda Accord Upgrades
- Message to "CLEAN" - on the display of the player
- performance exhaust system...pls help
- 1994 F22B1 injectors. Saturation or peak and hold?
- Ignition/Ignitor module control
- 99 LX....whining noise coming from front at highway speeds
- Honda Accord LX 99 Maint. Req.
- Broken thermostat housing on 95 accord EX vtec, HELP!!!
- rotor removal
- Piston #1 dead due to injector??
- '96 accord Temperature needle not working
- Intake manifold setup for F22B1?
- 03 accord flasher prob.
- 97 ACCORD-My speedometer is stuck on 20, can anyone advise?
- Water leak
- Wondering if any1 have any turbochargers install and want to hear ppls reviews on them
- 92 accord ex is on srs light and cause the car to die........
- CAI question during season
- Radiator Fan (Normal?)
- how to use timing light.
- anyone else have window problems?
- Silencer = N/A power?
- How do you remove a 1985 hatchback OEM radio unit?
- F22 engine stutter issues
- 1986 Honda Accord Headlight Q
- idle/jerking problem multiple CELs
- window visors
- question about the PGM-FI
- Radiator top cracked
- Alternator replacement, accord V6 sedan
- EGR
- Service Light - wrench. Oil at 15% life.
- Sunroof Replacement.
- Radio Code for Battery Replacement
- nitrous intake question
- Go Figure....Another Problem??????
- Honda Accord Insurance Census
- If 99-02 TL's do not have projectors how do their HIDs not blind drivers, could these swap into my 2
