PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 [177] 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. Am I crazy, or should I just kill advanced auto (see pictures)
  2. U GOTTA READ THIS!!!
  3. How Much Faster.......
  4. I NEED AN OPINION ABOUT ENGINE SWAP....
  5. Do H&R springs sag?
  6. Any reason for a delayed acceleration?
  7. Blinking Check Engine Light
  8. clutch MC
  9. Bushing Problem
  10. help with HID
  11. distributor o-ring
  12. 92 Accord Ignition problem
  13. 5th gen wheel bearing replactment write up...
  14. Questions On Which Header I need.. HELP!
  15. How do you know which calipers your CB7 has stock: Nissen (sp?) or Abenko (sp?)
  16. LOTS OF HONDA PARTS!!! CHECK IT OUT!!!
  17. how meny cc's do 91 accord injectors have plz help thank you
  18. GAS LIGHT
  19. Having trouble changing brakes on '92 accord
  20. 96 EX - ABS Light ON
  21. Need help quick on transmission year differences.
  22. bumper bule prints
  23. Help on installing AEM intake system
  24. Euro-R Manifold with Skunk2 68mm TB
  25. driver window
  26. h23 head
  27. New Car Decision - 2007 Accord
  28. DIY 92-93 Lip / Air Dam
  29. H22a running reach
  30. Oil Leak around transmission after Oil Change
  31. CD sideskirts on CB
  32. Coolant water Drain too fast...
  33. Radio code for Accord 2001
  34. Looking for a Honda A/C systems expert...
  35. V6 front brake calipers on 4 cylinder accord.
  36. Confusion on WHERE to clean EGR ports
  37. 92' Hona Accord EX-R. Check engine light comes on and then car stalls at low speeds!?
  38. My 92 Accord LX Oil Problem
  39. Help - turn signal problems
  40. Fabrication .. Roof Swap?
  41. OEM shafts vs Not
  42. AC not working...what to fix?
  43. engine swaps
  44. Coolant leak only when fan is on?
  45. A/C help
  46. LED Taillights
  47. I need some serious help!
  48. Cooling fans not coming on...
  49. Just for fun
  50. brakes on the 1995 accord
  51. rpm's goin crazy at 3.5, 4 need help pls!!
  52. Cams for 2006 Accord
  53. replacing 5th gen Accord transmission
  54. Is it possible to put turbo on accord V6 with automatic transmition??????????????
  55. A lady hit me...
  56. VAFC and cam gear
  57. ECU problems!!!!
  58. 1991 Honda Accord EX Auto-Seatbelt Problems
  59. Daytime running/High beams not working
  60. '94 2dr Accord EX Grille "Lock Clips"
  61. Blower / A/C fan noise
  62. Replacing my rack and pinion. help?
  63. Im Confused Help Please.
  64. Newbie Questions 03 accord
  65. ATF questions.
  66. Need advice on accord 94
  67. Idle Surge (H22 swap)
  68. F series throttle body on H22 question
  69. High RPM's
  70. distributor + plug wires connect diagram
  71. 5th gear grinding?
  72. change your cabin air filter
  73. dc sport strut bar question??
  74. Clunking over bumps - Suspension?
  75. New rims, stock tires.
  76. CL type-s 6spd swap into accord
  77. Tire fitment on Rims
  78. odometer is broken
  79. civic key stuck in accord
  80. air conditioner
  81. Lower springs question?
  82. Transmission Fluid Change/Filter??
  83. 83 Accord Engine swap
  84. Need advice on drive train problem.....
  85. automatic 94 accord rpm lag
  86. clock blinking, cannot use 6-disc cd changer also - Accord 2004 EX V6
  87. timing belt and 90000 service
  88. Do rotors have to be cut even though they are brand new?????????
  89. f22 vtec i.D. ?
  90. Spongy brake issue
  91. RSX seats?
  92. Honda parts online in Canada- Help!
  93. Replacing speed sensor on 2000 F23
  94. 93 Accord - sudden no start
  95. Intake for 89 accord
  96. are totalled cars always bad?
  97. Replacing brake light switch for 2000 Accord
  98. Need trunk dimension from a 7th Gen Coupe
  99. whers good place
  100. Timing belt replacement
  101. oil leak
  102. trying to replace my bumper....
  103. automatic p13 ecu problem
  104. stage 1 clutch
  105. Stroking at h22a4
  106. 96 intake the same for a 4cyl or 6cyl?
  107. Source for hub bearings? (not the entire hub assembly)
  108. shifter cables
  109. gen 7 code retreaval
  110. A/c vents leaking a visible fog
  111. 98+ HELP! replacing transmission
  112. RADIATOR FAN
  113. New to tuners
  114. Car won't start when check engine light is on
  115. 05 accord v6 ecu or cams????
  116. Anybody made a good splash shield for their CAI?
  117. fast help
  118. REPLACING HEADLIGHTS---HELP
  119. interchangable h & f series..
  120. Diy ItR lip on Accord
  121. Interior Dash Removal??
  122. bleeding a car
  123. Honda Automatic Transmission Fluid? Do you have to use HONDA GENUINE ATF fluid or?? VETS HELP?!
  124. Ebay Air Intakes on my 92 EX
  125. Transmission rebuild kits?
  126. 03 Accord shift position dash lights
  127. Headers
  128. H series in a CD7 accord coupe problems
  129. h23, f22b dohc,f23vtec or h22???
  130. Plastic Trim-renew??? Possible?
  131. Looking To Increase Horsepower 7th Gen
  132. goofy idle and low rpm acceleration, tps or egr?
  133. what do you think?
  134. A/C filter change
  135. What's up with this?
  136. suspension help
  137. help
  138. First Post, couple Tech ?'s...
  139. A/C problem
  140. Turbo Website?
  141. Very Bad Rattle - Subs...
  142. CD6 Accord wheels
  143. Yellow/white electrical wire for car stereo dead -- not red one or anything else on fuse
  144. Front Fenders
  145. Vtec not Vtech .
  146. 92 accord moving problems
  147. car smokes when starting
  148. Does anyone know how to retreive ABS codes wothout scantool?
  149. k sport questions
  150. eclipse turbo and trottle body
  151. 272 cam!
  152. vtec head swap
  153. Won't crank
  154. JDM ITR Front Lip on CD Accord
  155. h23 manifold swap question
  156. F22 crate engine vibration
  157. all motor no turbo or supercharger
  158. New 07 Accord owner
  159. ignition coil
  160. can 98up accord do a JDM front end?
  161. Accord 2004 Automatic Transmission Oil
  162. Body Swap
  163. Sensor help for an H22 swap
  164. 07 Coupe Pricing
  165. A20A3 help
  166. why is my steering wheel to the left, when I'm going straight?????
  167. An H22 into Accord 94
  168. Help with 96 Accord!!!
  169. 5th Gen rear disc brakes?
  170. Bouncing Tachometer
  171. Did I somehow overcharge/discharge my AC?
  172. noobie questions about egr valve and the tranny
  173. 96 Accord overtorqued nut
  174. 98 accord 4cyl.5spd. no fuel
  175. whistling noise inside accord 2000 v6 ex coupe please advice =[
  176. new belt size for 91 when removing a/c?
  177. 94 Accourd turns over fast but dont start
  178. whisting noise inside 2000 accord coupe v6 help please!
  179. Supercharger Suggestions
  180. halo headlights on a 6th gen, anybody done?
  181. Stored my car, now diffuculty braking + burning smell... HELP!
  182. Speaker Installation Help
  183. v-6 swap in a 94 accord?
  184. Help with alternator upgrade
  185. how to remove panel
  186. 04 Accord V6 random misfire
  187. '97 Accord 5 Lug
  188. Help Please
  189. Airbag law in virginia
  190. Crankshaft pulley bolt won't come off (with pictures)
  191. Honda Accord Overheats REALLY Fast! HELP
  192. jdm engine swap websites?
  193. New guy here: Accord has rough idle,bad gas milage, and misfires
  194. getting a new ACcord
  195. my car redlines at 3500 rpms......
  196. rolling noise in 96 accord
  197. This a sensor problem?
  198. is there anything good about this engine
  199. F22B vs. F20B
  200. Rims for a honda accord coupe 4cl HELP
  201. Wagons Need more torque so I said to myself.....
  202. How to change springs without a spring compressor
  203. need help plz
  204. Are Honda Oil Caps Universal (5th GEN V6 -> 5th GEN I4)???
  205. Proper Timing Belt tension?
  206. need someone to do swap
  207. 01 H22a Accord - Code 9 - Cylinder Position code will not go away
  208. whats up with the lag
  209. 1990 Accord LX cranking but not starting
  210. Valve noise, HELP!!!
  211. Is 35mpg good for a 93 accord lx?
  212. spec stage 3 clutch in my 2004 accord v-6 just a ?
  213. Timing Belt Condition
  214. anyone bought one of those CAIs from ebay ?
  215. 90 accord ECU help
  216. 92 accord - fuel pump or distributor bad?
  217. Swapping H22A into 96 Accord (Already searched please help)
  218. Accord doesnt start up?
  219. maintanance light flashes 10 times
  220. 1992 Accord ..Clutch diagnois help
  221. 94 accord ex timing belt replacement.
  222. Where are the grounds? -- 91 Accord LX
  223. accord EX 97 problem
  224. Car wont start
  225. Newbie: Wheel offset for 95 Accord
  226. dc2 speedo in a cd5 accord
  227. new here vtec on the k24
  228. Stealership trying to get 1700 out of me - need some advice!!!
  229. new wheels 05 accord
  230. 1994 Accord A/C stays on even if A/C on button pushed off
  231. Cleaned EGR ports- now EGR valve is bad?
  232. Timing belt 2000 accord v6
  233. blocking of egr valve wondering if cel will not allow vtec to engage
  234. 3rd gen looking for swaps
  235. Cooling fans stopped working
  236. Help for oxygen sensor
  237. h23 crank into f22???
  238. Lowering question - Alignment related
  239. Camber Kit necessary?
  240. short ram intake complete DIY installation for '94 accord ex coupe
  241. Lights Issues
  242. !!!!!!!!!!!!!!Horse power and Torque Gains!!!!!!!!!!!!!!!!!!!!!
  243. car stops at 4,000 rpm in 4th gear? is it the goverener.
  244. k24a1 ????
  245. head gasket
  246. Need help!!Honda Accord CD6..Loss of power..
  247. Problems with radiator fans on 89 accord LXI
  248. seat is loose
  249. F22 with H22 LSD Tranny.. Is it possible?
  250. Door Panel
