View Full Version : Honda Accord (1990 - 2002)
- spoon chip?
- Oil Disappearing
- what manual tranny fluid to use?
- Lubegard and Lucas
- 94-97 Accord Sidemarker Templates...anyone?
- 95 Accord question
- '88 Accord LXi
- Newbie w/ Questions and Introduction
- 6th gen CAI install ???
- swapping h22 into 6th gen info
- 1997 Accord Exhaust Tips
- Fitment question... can you get Volk GTU or Work VS XX in 4x114.3 (for a 92 accord)
- '88 Accord LXi: Starting Problem
- 94 honda accord sedan trany
- 94 accord rotors
- Blinker blinking too fast
- Joining the Ranks
- 1993 Accord SE - Whizzing sound from engine?
- The homemade beast
- Is this a piece of crap?
- 95 Accord LX door lock actuator
- ingalls camber kit question
- Need some advice with HIDs
- Why is it nessescary to losen the bolts on the rockers when replacing a head gasket?
- 91 4DR LX driver door is stuck shut.
- i think my clutch is dead
- black housing rear bumper lights
- Anyone heard of this new forum?
- 90 accord lx mystery antifreeze leak
- torque converter lock up
- CHeck engine light.. VTEC code. 99 Accord
- steering rack replacement and problems unfold...
- 1st Gen Accord Website
- Alternator removal question
- AIr Bags!!!!!!!!!!!
- ZOMG... look what I found.
- Possible Suspension Upgrade
- check engine light on my 1998 Honda Accord LX
- Creaking from front end...
- Ignition Switch Replacement
- 1998 Honda Accord wheel clicking
- Rear view Mirror
- jdm ecu pin diagram?
- 94 front and rear lip
- 95 Accord EX BLOWN ENGINE
- What brand of brake pads?
- Accord 98' CF4 SIR
- Slight Shaking.
- White Smoke when freshly started?????
- Sylvania Silverstars in 99 accord
- exhaust manifold flange
- short ram intake install
- Looking for F22B1 ECU pinout.
- How to restart the check engine light in 91 accord
- EGR valve location...
- gauge cluster brake lamp
- question about LSD tranny...
- 99 acoord headlights
- Signal Light Help!
- brake Lamp lights On
- oil sludge + cold weather + high oil pressure HELP
- accord idling problem
- iabs = not good.
- where to run amp power wire? [90-93 accord]
- em or head gasket leak
- cold air intake bypass valve
- solid, quality, cost efficient build on an H
- Coil wires?
- How do I replace a radiator?
- h22a auto tranny install help
- Gas mileage going down - what can it be?
- 2003 Accord LX Radio Upgrade to Climate Control
- Electrical problem!?
- H22=F22
- '91 Accord LX "Equivalents"?
- cliking
- speedo question 94-7 accord
- Prolong Engine Treatment.
- question about different 5th gen brake rotor sizes
- streaking sound from slave cylinder
- Stereo Code Help...???
- i need help!!!!
- bolt pattern 4x100
- Pressed on rotors...
- Removing Alternator in 86-89 Accord
- To boost or not to boost?
- Quick radio code question...
- auto tranny: safe to mess with n-d4-d3?
- Bent the Rear so-called "K-frame"
- car park idle
- Oil Leakage
- Rim Size
- accord problems
- Heater Core Failure (cb7)
- When car is running, suddendly it feels like it's on Neutral, what it can be?
- tick tick tick tick....
- Accord 98 Car maintainence.
- Emissions Test.
- Bolt Pattern
- I can only hear sound out of my left speakers...... any ideas?
- Gas Pedal roughness
- Swaybar noise
- un-plugging battery question(s)
- Starter cranking is slow
- Please Diagnose: Car wont start...
- Faulty gas gauge?
- h22 no rev past 6200rpm, why?
- Two CEL codes - EGR and 02 sensor
- '98 with 3.0 VTEC Timing belt
- HAVING PROBLEMS WITH MY CLIMATE CONTROL... PLEASE HELP!!!
- 98 Honda Accord EX-V6 P401 problem
- What Size Speakers is the Accord 98 EX V6
- start-up thunk...
- 92 accord, starting problems
- I have a transmission problem
- turbo manifold
- Anyone with a F22b DOHC???
- rsx-s head swap on a k24 block
- Transmission? or Idle?
- 1980 Accord Electrical Questions
- BAD body roll
- Thoughts on suspension for a 94 EX... Everyone give your 2 cents please
- boost question, again.
- 84 Accord leaks when it rains
- New Lights for Accord
- Car wont start.. No CEL
- convert a auto to 6 speed in a 98 v6 4 door
- oil leak+exhaust manifold=smoke, lots of smoke
- rpm raises fast then drops fast sometimes in idle
- Turboing my 96
- engine won't turn over
- p/s problem .. please help!!!!!
- Annoying buzz noise coming from below the Glove Compartment
- i just bought a 96 V6 accord, i want to JDM it out
- Have 1988 honda accord, problems: high revs at idle(3000-3500) choke-out at same rpm
- Fan Noise? Help
- 90-97 Accord antennas info post
- do it yourself tints
- Code 41 on 92 honda accord
- Frustating Fogging on the Glass - Please Suggest
- Rust, Rear Quarter F'n Rust!
- 94 accord oil in the sparkplugs
- Need some opinions for engine swap ideas.
- NEED HELP!
- maintenance need....
- Accord heater smell....
- 97 Accord Shifts/Jerks Hard @ 3-4000 RPMs? HELP PLEASE!
- 2006 accord questions
- 89 accord conversion FAQ
- weird sound
- hmmm... a few questions about a 4gen accord...
- CL-s in a 6th gen
- turn signals / hazards... help needed please
- **SRV Knuckles on 4th Gen Accord**
- Fuel gauge problems...
- 97 accord alarm problem
- 1999 Accord Shudders --- 4,000 RPM --- Check engine light
- vacuum line diagram
- Can't explain fuel mileage loss?
- 99 coupe factory alarm problems...searched no help.
- Original belts and alternator?
- h22 swap?
- talk about bad news...
- O2 sensor on aftermarket HF cat
- Installing rear bumper cover on Honda Accord 2005
- very slow windows
- spark plug gapping
- sunroof
- v tec vs vw
- hey
- 1994 accord Passide Cracking Clanking bouncing noise??
- Looking for salvage car sites, any help please?
- dent removal
- Question about Car Painting
- 95 accord LX Check engine light
- h22 swap into 91 accord....? about tranmission mount
- Oil in exhaust manifold
- Damaged front end
- Why the car get hot whith out the thermostat??
- Possible wheels for the accord ?
- h22 block
- Extra Power with out a swap
- F23a1 internals question
- 91 Accord EX Shift Solenoids Problem
- scrunching sound over bumps.
- Help! Bunched window cable!
- 95 accord door change
- Out the thieves
- 94 Accord LX hood
- 94 Accord Question
- Mirrors?
- Replacing Valve cover gasket and spark plug seals..
- WTB Spoiler for 99 Accord V6 VTEC
- accord vs scion
- Exhaust
- pulleys and such
- The new guy is having some difficulties.
- Needs help with wiring Halo Ring headlights (NOT ONE PIECE)
- Cat back...
- 96 Honda Accord Front Corner Lamp
- Replacing oil pan gasket..
- engine oil all over my spark plug
- 2008 Honda Accord? Anyone got pics or sketches or info?
- I cant find the manufacturer information for depo headlights...
- Brakes
- installation of oem navigation 2005 accord
- Anybody else have poor radio signal in there 5th gen??
- 98 Accord transmission
- 99 Accord Coupe
- God dammit!
- 5 spd swap
- Need a bit of help with a DTC
- 2006 Accord 4cyl - what motor?
- recommend a remote start for a 2001 accord ex v6 coupe at
- Water leak
- Hallow out cat versus performance straight throug cat.
- 1995 Honda Accord EX V6 - Antenna Problem
- should i upgrade my Brakes??
- Head swap?
- electrical problem??
- 04 honda accord 4 door - exhaust
- is my suspension bad
- j30a4 swaps into 98-02 accords?
- trans converter lockup
- JDM Accord Euro-R gauge cluster fit on 2001 Accord?
- hesitation
- Can you guys post your Apex-i WS exhaust pics?
- Boost question
- JDM Stanleys with Depot corners?
- 00 Accord coupe EX...Vibrates a lot...
- Idle Status on Transmission
- Radio Code for 1995 Honda Accord
- Vibration at idle during cold temperatures
- Engine cleanout
- No longer need tune-up
- WTF is the "service engine" light about?
- OEM Shocks/Springs
- do the greddy evo2 and sp2 exhaust for 97 up prelude will fit my 96 accord ex
- Emissions Test.
- Removing Old Rotors and replacing new one need instructions
- F20C Theory....
- Accord history article
- rattling under car at 2g rpm
- engine hesitation
- Testing 1990 Accord For TCU Code 6
- F20B Question
- 2001 Accord F234A4 5-Speed coupe problem
- 1990 accord engine/tranny swap
- eBay intake
- 92 torque converter lock up
