View Full Version : Honda Accord (1990 - 2002)
- How important was the recalls?
- Can wrong type of oil cause leaks or damage?
- Civic half size radiator in accord?
- which engine would be best & cheapest
- Anyone heard of Nakayama wheels?
- Roll Bars/Cages
- OFF TOPIC: im sorry for posting this but i cant post in the members forum?
- Does a 97 accord coil overs fit a 98 accord...
- Installing an aftermarket Cat converter
- Ebay short shifter problem/question..
- 95 honda accord
- 7th-Gen Accord In-Line Four Owners!!!
- A great place for gauges in accords. check it out.
- Where can I get a new door?
- Has anyone here bought a Gude Complete Head Package?
- OT: Need help selling my car...
- Guys w/ experience with Eibach Prokits, need some feedback.
- SRS Light is on...
- 2003accord
- what can be done
- What a drop will get you
- New to the boards
- Need some advice on alarm systems
- I need some Advice........
- Timing belt change problem
- 92 Accord - Radio Code?
- Anyone know a site that will sell just IC piping?
- cheap rear camber fix info... (info/specs I've found)
- coolant flush? done the right way help!!
- jus purchased new springs
- H series transmission compatiblity on F series Motor
- is anyone at all planning on coming ot the ny meet tommorw?
- Crank Pulley info.
- hey help me with this if u can
- port and polish
- i hate eveything.
- Wheels on a 1997
- H22 for sale?
- Anyone in or near PHNX AZ !?!?
- will a f22b motor fit my 90 accord tranny
- 94 accord Tach
- '94 Accord idle problem
- leakage around oil pan, and recall questions for 5th gens...
- level 10 pts kit..?
- Fellow accord owner express your opinion... bomex, ww, or stock paint matched.
- what fuse to pull to disengage ABS?
- billstein shox on a 3.25 drop cut bumpstop?
- Check Engine Light is on....Suspect bad EGR valve...HELP
- frozen locks remedies
- A/C R-134 Conversion Kit
- 97 ex coupe . need help :: headlight / exterior engine cleaning
- c clip
- Instrument Panel
- hey wat do u think i should do?
- 95 Accord engine swap or stay?
- 4th gen lips?
- wtb: 94 up 4dr accord
- can some one tell me the...
- I realize this isn't *exactly* a tech question...
- Which bumper fits 2002
- 01 Accord tranny oil change help
- modded brakes
- MSD ignition and the such
- dyno results... =(
- 95 LX before and after accident pictures + questions
- OT: finally pics of the green machine
- redline tranny oil
- DIY Links
- Need help with rim questions (and yes part technical)
- 94 - 97 Greddy Lip w/ Bullet grill pictures
- Funny noises in Reverse
- Weight Reduction ?s (mainly for 2point6)
- When is hondasociety coming back
- ATTN: ACCORD OWNERS! WHY AN ACCORD? For the Hardcore Accord Owners
- CenterFOrce Clutch >?
- Maintence REquired gauge?
- dallas meet
- Radiator Hose Blew, Need Help
- what motor is better in an accord?
- Maintenance required light
- 6th gen short shifter?
- dohc f22b??
- 99 H22a in a 90 Accord
- Help with tires
- 1990 Accord Idling Problems.....
- How hard is it to install new carpeting?
- Alternator on a 90 accord (tried search)
- 1990 Accord-Cannot Remove Key from Ignition
- wirring diagram
- help
- Auto or 5spd tranny probs in 96+ accords?
- Koni yellows vs Tokico illuminas vs KYB AGX
- paint
- changed belts, now engine has buzzy vibration
- took turbo off ,fuel pump question
- New to the board.
- JDM Conversion ?s
- 98Accord Pwr Windows & Locks Problem
- 5th gen 94-97 accord airbag question??
- Dry port nitrous
- 1986-1989 accord engines
- Accord idle problem
- Clicking in reverse ??
- speed bumps
- 225/50/15 tires
- Lowering
- Accord Exhaust
- Intake Resonator Removal?
- brake lights dont work
- Anybody building an F22a?
- Engine Swap... 89 --> 90 Accord ??
- f22b1 w/ manual tranny How much to sell for? or keep head?
- spoon rear strut bar
- rear quarter panel rust prevention
- 93 honda accord ex- shocks and struts or just shocks
- 92-96 prelude brakes for 6 gen accord 4 cyl??????
- What is a Good racing clutch ??
- good place or site to buy springs
- what do you like best about accord forum.
- ok n00b questions
- How many accord owners from georgia? esp. macon?
- Any of you Accord owners oven non Accord owners live in the UPPER MIDWEST? (SPRING MEET)
- Parking Light Prblm !!!
- which shocks to go with
- Why are Accord headlights so dim?
- Florida installation shops?
- places to shop online
- OBD II : Complete Codes for your OBD II Reader - linked
- How To: Install Eibach Prokit
- f22 turbo , manifold?
- h22 tranny with h23 motor
- 97 USDM Accord LX w/ 52k: OEM auto transmission 'bursts' on up/down shifts
- 93 accord antenna mast replacement HELP!
- Tire/Rim Sizes
- Check engine light on my 89 LXi.
- h22 question
- CEL code 1, oxygen sensor, do i need a new one or what?
- OT: Honda/Acura San Antonio meet!
- I need the tightening sequence for my exhaust manifold on my 1992 f22
- Guidelines for installing a weak turbo on a f22.
- what bulbs for 90 accord ?
- Flashing battery light on odometer
- Anyone know much about the ELD unit?
- A question for people familiar with the Accord V6 engine.
- WTB / Want to Learn 90-93 accord suspension
- Using my H4 bulbs as both high and low beams?
- Price of a 94 accord
- Are all F seires parts interchangeable? (doing swap)
- Aftermarket Hood HELP!!
- 98+ accord coilover help!!!
- anyone have experience with ball joint camber kits???
- Arizon HT meet! Link to members corner.
- do header give louder exhaust.?
- Rear washer trick don't work.
- Rear brake setup
- 909 people, please help keep an eye out
- Hi new honda girl here!
- Is this the o2 sensor??
- 90 Accord damage
- Been busy
- crazy idleing...help soon!!!!!!!!!!!!!
- Sunroof Installation?????
- spark plug gaps...
- FYI - 2001 prelude H22 engine/trans for sale - Los Angeles/Orange County Area
- Need Help
- For Sale: Complete 94 Accord Interior
- Cam Gears
- Coilover noise... Can someone look at this?
- Where to buy F-max turbo kit
- H&R vs Eibach Springs and camber kits
- Oil leaks/having trouble trying to diagnose
- don't see a lot of turbo'd accords..? well look here..!
- heat shield for 4th gen short ram
- 92 Accord - Timing Belt Change - Need A "How-To" Guide
- possible to change only cylinder #1 on 99 accord v6?
- Test drove a V6 Ex coupe 6 Speed!!!
- Comparing Adjstable Cam Gears
- Finally I got my coil-over system
- ny meet on the 20th
- Rear Camber Trick?
- Another 4th gen AV6 Brake Upgrade ?
- 94/95 Accord EX RIMS with Tires
- Accord/TL rear-sway-bar swap?
- Long Term Effects from Lowering
- Bent front crossmembers
- Tach sticks, then moves
- camshaft or cylinder head replacement
- Camber Kit
- Speedo
- Need some help with a few issues! (92 Accord Wheel bearings, antenna among them)
- Major Oil Leak!!! HELP!!!
- engine codes and generations
- Exospeed.com sponsored Drag accord... prepping for 2003 season
- anybody ever bore out there own TB?
- Apexi Exhaust for Accord online store
- eibach's vs koni's?
- Widest drag radial on a pair of 7 bar 94-95 EX rims?
- 4th gen, throttle body / intake manifold
- CV Boot and Valve Cover gasket replacement
- high idle then surges
- Boosted Accords..
- Can somebody with a 5 gen LX help me?
- FI stuff for sale....MSD BTM, FMU, Missing Link, MF2 Injector controller
- 90 Accord 4 Door H22 Problem......
- upper Control arm hitting inner fender on 92 accord ex
- 91 Lx ecu or 92 Ex ecu ?? NEED HELP !!!!
- JDM H22 Harness
- Tire Size
- 03 accord exhaust
- anyone wants their VIN# checked on CARFAX?
- extra engine block at the house
- Noob Question About the H22a..
- Throttle body bore
- h23a VTEC swap, has it been done yet?
- 5th gen h22a swap question
- Extension of Intake Tube?
- air/fuel guage
- shaking steering wheel
- Springs- which one to go with?
- Power Window
- accord dream dies for now....
- Err-3 on radio of new '97 accord....Please help.
- spoon magnetic drain plug (tranny): fitment issues?
- IAT Sensor??
- Igniting Oil
- 6th gen motor
- Picking the right Tires
- 1192 distributor on 1991?
- intake mani off !!
- V -AFC controllers
- Borrowed pic from the Tokyo Auto Show......
- lowering 4th gen??? need some serious help!!!
- Will my old F-series parts fit the H-series?
- WTB: '96-'97 accord bumper!!!!
- is it true that when you drain and refil your tranny oil, only 30% of the fluid is replaced?
- CrankShaft Bolt Removal
- maintenance thing turning red...
- exhaust
- Honda or aftermarket fluids?
- replacing 93 Accord waterpump - ?'s
- Lowering Woes
- Shipping
- ? '88 Accord LX, rough idle and sudden high oil consumption
- 2003 accord
- stock hp
- are there any online manuals for the 94 accord? like an online Helms or something?
- lowering
- Shock Tower Torquing when installing springs.
- s2000 seats in accord
- Swapping a F20a into a 93 accord
