View Full Version : Honda Accord (1990 - 2002)
- Will they fit?
- 03 Accord Coupe-Stupid Headlight Bulb!!!
- Underdriving?
- 7th Gen Guys! 06 Interior Shot w/ Trim Kit and Hybrid Mirror Question
- How to prove legality of engine?
- 1997 Accord EX Tranny Trouble/Question
- Key question??
- which muffler and manifold to choose
- Car Clock
- Wierd Engine Noise
- IHE questions...
- question about some tires...
- headers well it work
- Camber kit necessary with Tokico shock/spring on a 1990?
- exhaust problem on a turbocharge accord
- weight?
- looking at buying an 87. what to look out for
- Request: Pictures of 2003 6cd Radio/Dual Climate Unit
- Temp gauge problem
- can you do this
- Three main problems with '82 Accord
- installing headers -- should I use gasket sealer?
- '82 Accord - Help/advice requested....
- A few simple questions.
- wings west lip fitment
- awesome i fixed my idle problems
- Too good to be true? And will they fit?
- transmission questions
- OBX turbo manifold??? will it work with AC for 98-02
- 93 accord revvin to 3500 then bogs..Any Solutions or Advice!!!!
- compression on 92 accord?
- Tranny questions please reply
- 87 Accord - gas pedal cable suddenly detached
- 94 Accord, Front Lower Ball Joint Removal.
- EGR valve
- Intermediate lights not working
- 95 Accord Lip Question
- oil pressure sensor removal
- f series Vtec or NOT???
- ball joint install questions???
- 2002 Honda Accord EX Automatic - Feels clunk/rapid downshift when cold
- help with motor swap
- Tranny Conversion / Swap
- maintainence
- Quick Question: Which distributor do i need for 1991 accord LX coupe
- SHOCK RECOMMENDATIONS.
- Best glue for tightest seal?
- 2003 Accord Radio/Climate Control Mod Questions
- Clutch wont REALEASE
- Alternator problem
- strut bars brand
- apex suspension
- h22a4 swap
- Spring fell out when replacing clutch anyone know where it goes
- H22a head on a H23a1 block, How TO???
- Crane HI-6 ignition.
- CEL...
- honda raddling!
- LX Owners/Side molding painters?
- Window wont go all the way up
- 06 Accord Question (Buying)
- halo projectors
- WTB 94 Accord parts--Orlando, FL
- fuel injectors
- Brake questions
- WTB 94 accord tranny
- HELP! steering wheel moves back and forth bad!
- trans strain
- Where in the hell is D.R.L sensor located in accord 92 EX (canada)?
- Cleaning EGR ports '92 Accord
- Rack and Pinion!! what years are compatable????
- 1996 accord lx cel trouble
- Low, rough engine idle
- new accord seats in 94 coupe
- Fuse for stereo
- Oxygen Sensor change?
- Oxygen Sensor
- Water pump replacement
- Need your help for H22A
- 96 Power Mirror part #
- 2001 accord timing belt
- 1998 accord egr ?
- part number for championship white paint, anybody know it?
- Accord Spring install Help!
- swap
- WHY cant i post anything in the market place?!!! HELP
- OEM Caliper Rebuild Kit Grease
- a series?
- distributor question for h22 swap
- Help...
- F23 tranny concerns
- ? on exaust manifold??
- Torque specs for exauhst - 90 accord???
- Power locks broken
- help... auto tranny troubles
- Problems on my 91 accord
- looking for some aftermarket per4mance parts 4 96 accord LX
- 91 accord help
- Possible Accord Purchase... any thoughts?
- 04 Alignment Kit errr
- Window Tinting on 2006 Accord Coupes
- black housed headlights
- Oil Consumption Question
- F series parts
- 4 lug to 5 lug conversion...
- how much should I sell it for?
- Rare JDM header
- '87 Accord LX dashlight/parking light/tail light problem.
- CD7 sidemarker placement
- Quick clutch question
- What color is the Vtec pressure switch on a 95 EX??
- Removal of FIA Controller for intake
- 05 Accord V6 Misfire
- Ground control coilovers on a 5th gen?
- DIY LED's into centre console. . what do you think?? **PIC**
- motor swap question
- Car problems
- Stereo question
- YEAAAA BUDDY!! Nice Score at the U-Pull-It Today! Auto-Manual Swap + SOHC Head!
- Clutch Alignment/pilot Tool
- ACCORD SURGING/JERKING... undriveable :( ...URGENT HELP NEEDED!!!!!!!!!!!!!!!!!!!
- wheels and tires...
- How to remove front bumper 92 accord???
- Need Info On Accord Euro R
- Electrical system failure
- H22a head on F22a block
- Installing power window motor
- Does the 06 have different size gears? Than 03,4,5
- 96-97 grille fit on a 94-95?
- 2.7 AT's > 3.0AT's
- 2006 Accord 6-6 Gets 30 MPG
- 92 Accord Ex.....REAR wheel bearing, Disk Brakes,ABS, Need help
- HONDA TECH GUYS!! NEED UR HELP!!!
- 06 accord hybrid v6
- help with the engine
- Automatic Shift Knobs?
- Gauges
- Accord - Won't go into reverse
- PLEASE HELP ME ON MY NEW INTAKE SYSTEM
- h22 arp main studs in a f22a1
- i need help turboing my 92 accord
- Header issue 5th Gen
- Help on whining noise
- So me and my friend test drove a 94 accord...
- Windshield wipers move in reverse direction
- 95 accord Trany or 1/2 axle problem?
- 96 Accord LX to power windows?
- 91 Accord...parts that break over 140K
- Clutch Problems
- Please help -Honda Accord 1993 - Automatic - EX
- Info please engine specs F22B8
- Accord stock weights?
- tacometer fluctuates after 3000 rpm
- wiring diagram-headlights
- auto transmission question
- 92 accord hood needed pref.....black but any color will do.....thanks
- 94 accord intake filter only
- h22 accord swap
- Fan Relay
- 90 Accord w/ no brake lights
- Shaking wheels
- Whats Best Old Transmission Treatment?
- 93 Accord Questions
- Vlave Cover Compatability Question
- need some info about 97 accord
- High flow cat or Omni test pipe?
- HELP ABS LIGHT ON HELP
- 92 accord fuel line. needed
- Need a Honda Expert in San Diego
- Decoding interior colors?
- A/C Question
- Continuous Alarm - help! I'm going insane!
- 92 accord ex stumbles, loses power, then goes back to normal when cruising?
- headers f20b
- How to fix ecu error codes 20 and 22?
- 93 accord
- Best place to get crank lightened?
- 98 accord lights
- car is running rough
- 5th gen rear engine mount?
- 2004 accord ex radio wont work
- LOOK!!
- cheap way to gain power on 92 accord????
- burning smell??
- HELP!! H22 wont idle...
- Is it possible to bypass the limiter
- Sports light and TCU
- F Series Blocks - Iron or Aluminum? I know i know it's a dumb question
- 97 ACCORD F22B1 VTEC/ HOW MUCH PSI CAN I BOOST?
- tranny swap 6 gen
- PROBLEM WITH MY ACCORD STANCE !
- Stock Speakers
- TCU part numbers
- Jdm H22a head on a H23 Block???
- Civic Si Rims
- 3 Trans ?'s
- Brakes
- Every time I turn right, my car stumbles...
- INJECTORS!!
- Transmission fluid???
- Need spec for 1984 Accord valve guide height
- 1988 Honda accord Transmission problem!!
- How to make 97 accord a little faster
- whitch one????
- 2000 accord coupe suspension
- Hooking up Autometer Guages
- anybody tried this spoiler out for a 5th gen accord?
- code 30, transmission signal??
- 90 accord overheating problem(already searched)
- Horn blows when brake pedal applied 93 accord
- Green "S" Light Blinking or Steady On Solution.
- did the 94-97 accords ever came in a type r version
- 91 Accord Break Light Problem
- H22 94 accord for sale 3,200 bo minnesota
- Front brakes on 95 Accord ... pressed on rotors, slide hammers ... empty wallet?
- $500 to spend on a 7th gen accord. Your suggestions?
- ipod without a radio?
- 04 Aftermarket Header rattling
- Valve Cover Leak?
- Rear spoiler 2006
- motor mounts
- head gasket help!!
- TCU
- 95 Accord - Speedometer/Odometer Issue
- I stand corrected
- Shaking/Low Idling
- Anyway to take off the seatbelt alarm on 04 accord????
- good tranny shop in SF area?
- I need help with a 1993 accord lx automatic to manual transmission conversion
- 90 Honda Accord problems
- Front Driver Side Door Won't Open
- Electronic Control Module and Check Engine Light
- fuel problem on a 99 honda accord
- Xenon Headlights Installation Help
- Gauge Cluster Cover
- CHECK THIS OUT
- CODE ISSUES
- 2005 Accord Coupe 4cyl; panel removal?
- How to make my 2002 Accors faster withough spending too much $$$$
- lsdtranny question
- 6gen Accord 5gen Prelude Short Throw Shifter!!!
- 02 accord swaps
- Injector lag time
- HELP!!!!...lol
- Keyless Entry
- 92 accord ex frame question
- EGR valve
- 6th Gen Climate Control Swap?
- blinging d4 light
