View Full Version : Honda Accord (1990 - 2002)
- Need help with a Honda part number
- air conditioning retrofit
- Removing BAckseats on 92 Accord
- ECU Problem
- will 97 Prelude SH shox & springs fit on my 91 exr accord?
- Question about installing a aftermarket headunit for generation 7 accord
- Time to lower car... camber kit and other suggestions needed
- 95 accord lx, factory audio ??
- HELP! jdm dohc F22b into 94 Accord LX running ROUGH!
- How to remove the tail light off 98-02 coupe v6
- taking apart gauge cluster
- TASauto.com... Reliable?
- Valve adjustment due for a 1991 EX
- Want to Buy
- 98 Accord Vent shut valve replacement help
- 1990-1993 Accord Bodykit
- 91 Accord Lx Starting
- '91 Accord EX, automatic tranny problem
- Pics of my 6th gen sedan.
- Very confusing issue:S:S:S
- cruise control removal
- caliper upgrade
- Torque spec for 98 accord header nuts?
- A/C Question
- check this out
- 4th gen tranny on 5th gen?
- What are your guys thoughts on 93 Honda Accords LX?
- 7th gen wheel size
- Back end lower than front
- high output alternator
- Rear disc brake conversion
- Do i need a camber kit?
- 90 Honda Accord problems
- can any thing from a tsx fit a 92 accord
- sell price? would you buy it?
- Vanity Mirror Light / I suck at electrons
- On my 1993 Honda Civic LX ac not coming on.
- A disgrace to Honda
- 97 Accord turns off during driving
- rotten eggs?
- Debate?
- 1990 Honda accord RIMS
- Mani Swap
- Mixing mineral and synthetic
- 03 Accord factory radio aux adapter
- ...mileage has stoped moving...
- Come to Ride Night every 1st and 3rd Tuesday @ Applebees Bar in Round Rock TX!!
- Bosal Header/ company general quality?
- 1997 Accord LX
- Anyone have Seafoam DESTROY your engine?
- 94 Accord = Clicking noise when turning headlights on.
- Need some help 90 accord
- Door wont open...
- Problem with Pinging (PLEASE READ)
- idle speed control?
- How To Get Codes From 94 Accord EX
- Stereo Wiring Question
- 95 accord - wiring foglights, help?
- Please help!! :( ... misbehaving rpm
- Anyone with access to '97 Acura CL service manual?
- 87 Accord trans problem
- What is the purpose of the flex portion of an exhaust?
- 5th gen fuel filter
- WWOOOOOOOOOOT!!! I jsut bought a JDM H22 w/ LSD and Mods!
- jdm parts for my 90 cb7 coupe
- FOR SALE: 1992 Honda Accord EX
- tapping tranny for 4th gen swap?
- EGR valve cleaning
- H23 throtle body and air manifold onto F22B2
- Drag Down Pipe
- neuspeed strut tower brace dilemma
- tell me what body kit this is please
- installed new headers now have problem
- smog check needed click here
- Bizarre Engine Behaviour...
- 93 honda accord wagon door locks
- Question about a M2B4 transmission
- Does Anyone Have Pictures Apexi WS2 on Rear Stock Accord Lip?
- 90 Accord LX starts for a second, won't idle, and dies.
- torque coverter whine
- removing a/c
- Lights Stay On
- Car shuts off when it comes to a stop light/stop sign/under20mph
- Cigarette Ligheter Harness help
- 1988 accord fan runs constantly
- 5th Gen Accord Stutter Problems
- This the right way to do compression test?
- problem
- Uh-oh
- High Flow OBD-II Cat?
- MSD Blaster 2 Coil Help..
- 90 EX-R manual.. asked for 37820-PT3-A22 ECU received 37820-PT3-A51..will it work?
- Did ANY Accord ('94-'97) have an immobilizer?
- how do i reset the abs light???
- i need opinions on LSD n Clutch
- Where is the firewall on my 1993 Accord?
- engine swap in 3g accord 86-89
- Accord '93 Cooling System
- Trunk/Cargo Tray
- Replacing Factory Fuel Pump...Sizing Questions PLEASE HELP
- 94 Accord Trany Problems
- Accord 98 transmission problem
- unknown fuses
- what are some good and cheap mods for my 90 accord si?
- CB7 wont start after pulling the head!
- 90-93 Accord gas mileage
- ebay black housing with HIDs? will they melt.
- 1992 EX arm rest
- P-ADAMS ???
- 17s on accord
- how do i clean my stainless steal header?
- Accord 90 to 2002 parts F22 F23 parts
- h22a swap with accord evap canister rig
- TRANNY SWAP RECOMMENDATIONS
- J35 in an Accord
- ummm worried
- 94 accord
- tire, wheel, bearing noise?????
- Seat Belt Trouble
- Need tech advice
- 1994 Accord with Aftermarket Radio
- accord chassis
- 1994 Honda accord ex axle..or what?
- difference between poa ecu and p13
- Where is the fuel pump relay on a 90 EX?
- Puzzling Brake Issue.
- how to install short throw shifter adapater
- oil on spark plugs
- ok
- 2001 EX V6 timing belt and water pump
- Finding a turbo manifold
- H22 tranny
- Anyone with a ball joint camber kit installed? Problems?
- opinion on header
- window stutter
- Accord Cam Gear ?
- Must See: Turbo Mani for H22 Accords (a/c and p/s compatible)
- iac ???????
- '93 Accord: Heating-A/C dial broken
- Lock-Tight (Thread locker) on the engine mount
- question on engine selection.
- A cheap mod..
- Won't Start when hot, searched, not main relay, PLEASE HELP H22 SWAPPED WAGON
- F/S: APEXi World Sports N1 Damper Coilovers for 98-02 accord
- f23 head with f22b1 dizzy
- Strange Noise from Passenger Side
- How to remove water spots on glass?
- Check engine likght comes on at 50-60 mph or high revving
- ABS Light ON..insight...
- h22a tranny rebuild ????????
- Oil Pressure Gauge Hook Up .. F22
- header gasket question
- How many oxygen sensors needed for 2000 v6 Accord? Help!
- Header Bolt Smokin
- How to Remove Door Panels
- k series accord
- Driver-side window only goes up when it wants to....
- Ball Joints wearing out....
- 1995-1997 Accord V6 ECU - POG
- help - sticking high revs on 92 Accord
- Parking Lights?
- Raced the swap h22 today
- Interior color codes???
- f23a1 swap into a 95 civic ex
- Axle back exhaust opinions
- How do I change the headlight bulbs on my 2002 accord v6 sedan?
- Oil where the spark plugs go?
- 1991 honda accord/rear ended
- 94-97 accord jdm lights for under $200??
- In the process of...
- pics please...of 2003 2door ex
- 94 accord suspension?
- Rebuilding Trans 1992 Honda Accord LX ?s
- Radiator fan dead...
- 94 Accord LX Brake job... Pad help
- 1993 Accord LX
- exhaust
- fluid changes- all of them 96
- 1992 accord FITV / IACV query
- 95 Accord Timing belt...
- 01 Accord... running wires!! HELP!!
- sponsorship advice needed
- removing the back seat
- transmission problem?? NEED HELP
- Catch Can Question *searched*
- Will 94-95 rear mudguards fit 96-97's?
- 95 accord, in-car ground?
- Can anyone run a carfax for me?
- Is my engine ruined? Timing belt slipped due to manual tensioner failure. new poster
- rev limit at 3500
- Speaker Sizes for 06 accord
- 2002 Accord LX
- 96 wheel offset
- What wire to tap into at ecu for air/fuel gauge?
- 99 accord transmission help!!!!
- Help! Auto-Manual 4th Gen.
- What exhaust is compatible for my 97 ex?
- zoom zoom zoom honda zoom
- 90-97 Accord Gear Questions
- HID Issues
- H22 swap
- Cooling issues... help with diagnossing the problem
- heavy load on car these past days
- Front tire wear - causes?
- What Doors Fit 93 Accord EX
- f22s motor, want to add h23 throttle body/ air manifold
- 2005 Honda Accord Forced Induction, RWD Swap, and SMT Swap
- Best oil for high mileage car?
- Car Idles Rpm Up and Down
- offset +25 wheels ??
- Need pics of the back of a f22 block
- Problem with my radiator fan, goes off and on after the key is out of ignition
- No start problem on 95 EX
- Short shifter for 92 Accord
- will replacing cat with straight pipe cause engine malfunction?
- Wiring Help - Tail Lights...
- shifting problem...on and off.
- Accord Type R or H22?
- Valve Tap/ Valve Cover gasket Replacment f22...
- EXHAUST RATTLE ---- SORRY FOR REPOST
- f22b jdm dohc with some probs need help
- JDM CD6 GAUGES
- help with a no spark condition
- need a vtec head for f series
- Fan Problem!! Help Please!!!!
- Brake pads for 98 accord V6 sedan
- Carbon buildup - DIY?
- Oxygen sensor
- Need info on a h22a swap
- what's availabe to lower my 06 accord v6?
- 04 4-DOOR ACCORD (4-CYL) EXHAUST. HAS ANYONE DONE IT?
- AZ Emissions testing
- 1991 Accord windshield wiper problem? HELP !!!!
- B1 head on B2 block or A1 on B2 block
- 97 Honda Accord EX V6 transmission problems
- Is there a twin cam head that bolts on to a 91 engine?
- Can a Type R Motor go in a 91 Accord?
- Car pulls in different directions at different spds
- 97 Accord Rear Struts / Bushings
- Grand Am Series 7th gen
- Axles
- What size intercooler fits the best V gen Accord?
- 90 Accord rear disc conversion
- mounts for an h22a in a 90 accord dx
- F23 head..
- Manual Rack Swap for 94 EX?
- White badges
- Will a new O2 sensor cure my problem?
- new comer here
- 97 Accord engine swap..... h22 or k20???
