PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 [243] 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. which turbo
  2. omg! need help fast please.
  3. 94 EX compressor has no power....
  4. H and F series trannys interchageabilty?
  5. cf trunk lid
  6. radio wont turn on
  7. diffierence in f22a1 and f22b1??
  8. What would cause one of my front wheels to sit back further? CD5
  9. JDM Black Rear Bumper Lights
  10. ?!Gear/Brake Release Switch!?
  11. How do you know if your Honda is built in Japan or America?
  12. 93 Accord EX... Shattered Spark Plug
  13. 4th gen short shifters
  14. Factory fog lights
  15. Help, 1998 accord EX 4cylinder, less than 20mpg in mix driving
  16. i need info on the bottom gear for timing belt
  17. 03 auto v6 tranny fit 98 v6 accord?
  18. how come my accord shakes when i shift gear????
  19. Trans Problems
  20. 98-02 Accords.. Any in VA?
  21. 1988 honda accord help..
  22. O2 sensor is going I THINK.... CEL comes on after 2minutes of drving... HELP!!
  23. wing light out
  24. groaning brake noise
  25. f22a4 vs f22a1
  26. Anyone ever heard of NEX Coilovers?
  27. ANY1 had any experiences with the XTD prolite flywheel???
  28. F22A1 crank bolt thread pitch and torque?
  29. washer trick question
  30. I hate my life and chewed up timing belts!
  31. clock doesnt work
  32. hey
  33. Windows wont go up
  34. 1988 honda accord problems... many Need help bad...
  35. 99 accord head swap?
  36. H22A VAFC Question
  37. Brake question
  38. help with air breather
  39. Transmission help on 98 accord
  40. I need help to find cigarete lighter fuse in Accord 2005 LX
  41. Busted Transmission -What can I do???
  42. Transmission Question
  43. 96 Accord Hardcore Electrical Problems. Please Help!!!
  44. vtec
  45. Pic request please...
  46. Neuspeed springs
  47. 94 accord cam
  48. Battery=CHECK, Crank=NO?
  49. put car in overdrive to save gas?
  50. 96 Accord LX Problems..May be up for sale.. :P north FL.
  51. What size do you think will fit best?(Wheels)
  52. Windshield
  53. Cracked Mugen Lip
  54. hondata s300 for sale and stage 4
  55. Oil leak -- but I just replaced the valve cover & dizzy o-ring gaskets!!!
  56. 2001 honda accord stud 4lug
  57. 98 Accord head swap options? H22? H23? G23?
  58. 1995 Honda Accord EX V6 "maintenance required" light on
  59. Help with a/v installation
  60. Wiring?
  61. odometer frozen, any ideas?
  62. front and rear control arms didnt fix my suspension issues...
  63. Maintence Required light
  64. swap cost
  65. Is the f23 tranny a direct drop in a f22b1 engine?
  66. What size of rims on a 97 SE
  67. Just Need To Double Check-Imput Please-
  68. CD5 Automatic - Won't Come Out of Park
  69. super air intake? what do u think? check it out kinda crazy
  70. SiR accord headlights
  71. How to adjust idle on OBDII
  72. 1995 Accord V6 Auto shift issues
  73. swap related questions
  74. 92 accord f22a ignition problems
  75. Axle
  76. brakes on a 88 accord (caliper and bracket frozen together)
  77. wtb accord ex vtec engine
  78. 91lx idle problem
  79. resistance specs for CKP/TDC sensor
  80. Is the F20B ECU OBDII A or B
  81. 1993 Accord rear defroster Problem
  82. A/C causing idling problem
  83. H22 Manual transmision and F22 transmission are the same??
  84. 94 Accord, Electrical Problems (Door Locks, Horn, Headlights, Brakelights)
  85. Help
  86. Where can I order a upper ball joint 1994 Accord (help)
  87. 98 Accord Misfiring????????
  88. H22 setup Opinions
  89. accord fog light
  90. door locks all fucked up
  91. defroster 90 accord
  92. pillar gauge pods
  93. black OEM headlights for 92 accord
  94. DIY blacked out headlights
  95. Building F22......
  96. V6 AT tranny fluid
  97. Question on Lambo doors fast
  98. Questions concerning swap into a 1995 Accord
  99. Don't want to sound ignorant, but..... H22 question
  100. 98 jdm h22a4 header 97 accord
  101. ECU fault 15
  102. rpm signal for shift light????
  103. FRT ROTORS REMOVAL TOOL 90-97 ACCORDS
  104. ac compressor repair 1995 honda accord v6
  105. install on an h22a into 1990 accord
  106. PAINTING OPTIONS and stock fenders for sale???
  107. anyone make a home made camber kit for the 90-97?
  108. 2002 Accord COUPE fog light bulb size...
  109. Racing Hart wheels... any experience?
  110. black window trim on 5th gen
  111. Horn Fuse blowing!
  112. 93 Accord 2dr ex
  113. Scraping sound from wheel
  114. VTEC controller
  115. Dash Clock Light Ques!
  116. 1992 Honda Accord Died, Wont Restart
  117. 1991 honda accord window regulator power motor -PLEASE HELP USA and JAPAN built???
  118. Quick 98 accord exhaust question.
  119. Brembo Rotors, for 97 accord
  120. HELP FIND A SHOP IN SD?
  121. Pics of 96 Accord with decent looking wheels: Request
  122. led bumper lights
  123. 1999 accord vtec v6 automatic tranny q's
  124. foglights retrofitted into bumper lights
  125. vtec and v-afc problems please help!!
  126. Wheel bolt pattern
  127. i have a ploblem with the electrical system...
  128. lowering a 96 accord lx...
  129. tsx suspension fit on accord?
  130. 2000 4cyl 5 speed....tranny fluid?
  131. Heater core
  132. Really dumb Question Manifolds for F22 and H22
  133. 93 Honda Accord SE Eng. light came on,died,could not re-start,had to tow home
  134. h23a1 sohc take h23a dohc head???
  135. 1996 Acoord h22b2 interfearance engine?
  136. bumper vents
  137. When did the Accord get L.A.T.C.H. child seat restraints?
  138. KNOCKING NOISES WITH LEFT TURNS????
  139. Balance shaft seal... oil pouring out..... HELP
  140. 1998 Honda Accord Fuel Pressure Regulator
  141. Car paint
  142. Please help me build my car
  143. 96 accord, what year h22a fits?
  144. driver side window won't go up
  145. Question about "bore and polish"....97 accord EX
  146. Moving Violation Ticket
  147. WTF
  148. Bought The Accord
  149. whats smarter? h22a or turbo f22?
  150. Any one looking for an Accord Type-R....
  151. tHE BIGGER THE BETTER !!!
  152. wtb auto to manual parts
  153. Pulsing Power Locks
  154. Automatic shifter chop
  155. harness question?
  156. got accord parts for sale?
  157. shot gun sound from car
  158. Brakes
  159. what the one thing that you hate the most about your 94-97 accord?
  160. ABS Light
  161. removing hub
  162. interchangable knuckle
  163. turbo manifold
  164. fs f22b2 head
  165. heat problem
  166. best clutch for a mid mod accord
  167. what should i do?
  168. Cost to replace master cylinder and brake pads?
  169. Installing Short Ram, need help ASAP
  170. Engine
  171. where to buy
  172. bumper lights
  173. just replaced VSS and speedometer still not working "HELP"
  174. 5spd 4 door accord 4 SALE 4,200 custom paint and body kit PICS!!
  175. 5spd 4door ex accord 1994 looks nice custom paint with kit $4,200
  176. 5th gen Accord cluster went out
  177. Going to buy an accord with a f22a6... i have some question concerning ECU
  178. is it a dizzy..? HELP FAST!
  179. F/S 94 4door accord
  180. Looking for 17" rims or rims and tires in MN that would fit a 90 accord.
  181. 90 Honda Accord DX redlin 5250????
  182. 6th gen Pioneer head unit installed
  183. ?HT's fastest accord?
  184. Pics of accords from The Grand Cayman..SiR Accord and others we dont have..
  185. changing tranny or rebuilt tranny?
  186. How to turn off Rev limiter and speed governor on 7th Gen accord?
  187. Interior door handle
  188. 93' accord 4 door quarter panels
  189. Little tire help needed
  190. when would a oxygen sensor likley to go out
  191. HEADER CRACKED NEED HELP
  192. starting problem......please help
  193. questions on 93 accord transmission
  194. 03 in-dash changer (lights)
  195. replacing strut
  196. off topic - Has anyone pictures of their car with "legend conversion" brakes?
  197. transmission
  198. 97 Accord Fog Lights Where is a good place to buy em???
  199. speedometer doesn't always work
  200. Radiator Fan
  201. H22 power steering? oh no!
  202. Is Honda paint available in a spray can?
  203. Buying an Accord
  204. h22 swap
  205. Exhaust Question
  206. f22a4 vs f22a6
  207. 9006 HID Conversion Kit 90-04 ACCORD 00
  208. How much to charge?
  209. fitment problem with power steering hose
  210. car dies when im on neutral..rpm tooo low
  211. rear defrost button light goes out but defrost works
  212. need help TT 2001 accord 4cy ex 5speed anyone out there?
  213. Need help with engine swap
  214. OBDII - OBDI Coversion
  215. 2002 Accord - UK spec F18. What other engines will fit??
  216. Parking Brake Light staying on after releasing hand brake
  217. Question about interior
  218. Intake Pipe Size
  219. Hazard Light Not Working - 96' Honda Accord
  220. How to replace clock light in a 2002 Accord
  221. 96 accord w/ 95 jdm h22 conversion harness
  222. ran out of oil
  223. Broken fuel door release handle
  224. Trying to find a Spoiler...
  225. im looking for an auot trans
  226. noise in front right wheel WTF?
  227. rpm does not drop when shifting gears
  228. asking 6th gen (98-02) accord people.
  229. do u kno
  230. 2000 Accord EX automatic bogging in low gears/low speed
  231. fuel injection swap
  232. swap questions
  233. Good Deal?
  234. Steering wheel controls
  235. f22a1 vs vtec engines
  236. 1990 Accord auto shifting question
  237. HELP: Offset on 19" wheels
  238. Quick alternator question?
  239. will a 3.0 V6 yr 98-01 fit 96-97 yr?
  240. power locks.
  241. Give me your thoughts on what i should do next :)
  242. regrind cam for my accord
  243. Preventing further rust damage
  244. Making a 98 (6th gen.) Accord DOHC
  245. 97 accord SOHC... cam shaft....
  246. New Griiiiill or bumper for 97 accord??
  247. Accord 97... legend brakes (conversion)
  248. lost the key to my 1982 accord...any1 know how i can start it and make it run daily
  249. 97 accord SOHC ....crank,PS and AC pulleys... Underdrive or OEM?
  250. shift boot
