View Full Version : Honda Accord (1990 - 2002)
- Oil problems on plug wires 2nd and 3rd
- Cheap Performance Mods - Suggestions?
- 95 JDM h22a, how to make it work in my 1996 Accord.
- 92 LX brake job... Pass/Fail
- advance timing
- 89 Accord SEi 145 hp 2.0l option?
- Update on my 91 accord
- Anyone have any more info on the JTCC accord?
- Timing belt broke on my 91 Accord..... Questions
- question about honda-tech.com (i'm a newbie)
- wiper problem
- Modified Eclipse Manifold To Fit F22A6 *Huge Pics*
- Slotted, Drilled, Slotted and Drilled, or Blanks?
- spoon accord
- 92-95 JDM cams .. will they fit ok in a usdm 96 h22
- whos going to get the 2003 accord coupe 6spd mt?
- Pics of ground controls...
- JDM H23a spec? and price?
- Ground contol coilover kit q's
- Alternative to the H22
- MIL CEL scanner recomendations
- tranny wieght
- where can I get a wheel bearing pressed
- Anyone have a cdplayer laying around
- Why are dual pistons better than one? sorry its such a stupid question.
- Window is too slow
- Power Window Problem
- How much should I sell my 97 accord for...
- Where can I find the 02 OEM spoiler cheap?
- ATF drain and refill, now CEL...
- Big Big Big Electrical Problem
- Computer Upgrades
- an upcoming decision on my car...
- another NA accord on scotts a$$
- 91 brake caliper, piston seal leaking
- Quick Fan Switch question!
- 95 accord ex vtec engine fit in 93 accord lx easily?????????????
- Brakes...........
- Wheel Studs For a Drag 4th Gen Accord
- how to instructions for removing Corner lens sucks
- Have to pick between 98 or 01 Accord LX........ What would you do?
- change Auto to 5sp
- H22 Accord owners!! quick question.
- Should i get them?
- Low 5 Door?
- HELP!!'93 Accord idleing too high, wtf!!
- 94 Accord Cigarette Lighter Outlet LOOSE
- Pictures of my car
- Do performance chips help at all?
- Do You think this is bad?
- 1990 Accord LX power...
- Anyone have................................
- Taking out air bag!! (help)
- Lower Arm Bar on 1990 Accords!!!! HELP ME OUT
- Knock Sensor
- the spider gears in my 97 Accord EX????? Help!!??
- Girlfriend just got a 02 SE Accord. Are there any problems?
- First time in this Forum!
- grind in shifting
- 6th gen h22a?
- PGM-FI main fuel relay location
- gc questions??
- crower billet rods for f22 for sale
- WTB: '92+ ACCORD shifter assembly
- Oversized Piston? (friend needs help he's doing all motor H22)
- Little project
- cams
- '99 Accord shuts off when clutch is depressed?!?
- 6th gen h23
- Please help me out...
- someone tell me.......
- Which is better? h22a1 or h22a
- Fresh Meat
- Call me crazy but this doesnt make sense to me.
- 4th gen. fog light
- Bendy
- Accord ?'s...
- 99 Accord Timing Belt
- Where can I buy a h22a1???
- Turbo for cheap
- 91 accord power
- A stupid question for you engine guys...
- best place to purchase h22 swap or accord performance parts?
- how do I get my shift nob off?
- kits and other stuff for 92 4-door accord
- new to the forum
- anyone ever painted their stock rims?
- pics
- Strut or Shock
- 98V6 all auto?
- thinking of getting a 94- 97 accord !
- accord v6'rs
- what the best pulley kit on the market for accords
- testpipe problem
- how do i remove the stock headlights just got some new ones
- I need a 94-95 front bumper cover!
- 24 valve 4 cylinder for 89 accord..?
- Neuspeed Race Springs - Good or Bad?
- my lx 97
- Help with noise
- brake upgrade gone awry
- 99 Honda Accord - Technical Service Bulletins
- Got any pics of open deck vs closed deck?
- Please Help....Oil in plugs
- white smoke out the exhaust...
- Turbo for an H22a
- ne1 know stock spring rates for...
- which springs...front back???
- Maintenance questions for f22 with almost 90k
- 1990 Accord with problems
- Bucking at 2000 RPM
- Rims Websites
- Fresh Water damage totalled car...
- Check Enging & Maintenance Req Lights on (2000 Accord 4 cylinder)
- Replacing bushings
- Rims
- Indiglo's been in for 5days, MPH Tach acting weird now, HELP
- Accord 90 blinkers not working. Help!
- does any1 have an Accord 90 fuse box layout ?
- Does anyone have info on the 2-stage manifolds on the F22A6?
- WONT REV over 3,000 and cant check codes
- best brake pads
- anoyne drive a 92-93 accord....
- help...
- Fuel mileage for a 4cyl 6G Accord?
- Can you please tell me why I should buy a 98 Accord LX with 48K miles?
- Whine in trans
- LSD for 5th Gen Vti
- Help !! Accord >>>>>>>>>>>>>!!
- Bolting h22a to a F series tranny.
- quiet exhaust?
- Idle problems in honda accord lxi
- new to this board (pics of my car)
- recaro seat...
- any easy swaps for an 87 LXi hatch
- getting springs off w/out compressor?
- Got a '98 Accord coupe lx manual on the classifieds. Take a look!
- I need airbags!!!!!!!
- 89 sunroof leaks
- Bypass valve or not?
- Would anyone be interested in....
- JDM tail lights
- brake question
- Steering shimmy, shudder and clunk
- CL Type-S rear sway on 98-02 Accord
- Changing rotors...
- about the legend calper swap
- I am NEW and my sister's 92 accord won't start
- Easy accord audio question
- Can I get in the 15's with an F22?
- Suspension Questions (me = n00b)
- Lug Nuts
- most bang 4 the $$$$$
- 88 LXi head same as other 86-89s?
- HELP Car is about to sh!t a brick
- Help code 10, engine missing, rough idle F$@k
- Whens fuel cutoff on an H22a?
- dim blinkers
- i have retarded blinkers
- First Modification to my car will be...dun dun... auto to manual conversion, but i did a search and
- interior trim?
- have you ever done 110...
- My Best Track times
- After_Burners Accord...FINALLY
- RPM's going crazy on my 95
- ABS Code needed!! Please help guys!
- Valve springs
- oil leaking into spark plug wells....any fixes?
- Results from the track today
- Fuel Injector Cleaner
- How to adjust headlight beam on 96 Accord
- What Mods Do I Do?
- swapping a 5speed to a automatic, yes sound wierd, read it please.
- need some help for a non accord owner
- Srs light blinking....
- ECU Chipping
- My 1997 Accord SE is a DOG
- how many 4th genners. . (new to the boards)
- Yeah so i installed one of these... (Apexi turbo timer)
- OT: so i been gone for the last 8 days
- need instruction for custom turbo
- New Accord runs 14.9 1/4 mile...
- Cigarette Lighter Pulled out
- f23 turbo
- oversprung?
- Big Brake Kits
- Tein HA install??
- Swapped transmissions this morning.
- Do iT yourself short shifter mod *done*
- replaced rear motor mound and....
- How much to fix a wheel bareing?
- Turbo on f22 accord
- ECU Pinouts
- Attention Whoring
- 1992 Accord - Gas Mileage
- Long ride, comfortable?
- 1996 Accord Air Filter Installation Question
- 1990 wiring for swap? with OBD2 engine? what can i do?
- a/c wont work after paint job??
- afc/n20/VTEC
- Need to know bout Throttle Cable Tighting?
- Does anyone have pic of their 94-97 Accord w/ a 1.5" drop.
- Accord emergency..........won't start.....Dizzzy?
- Upgrade to external ignition coil???
- 03 accord pics @ TOV
- anyone got their pos stock radio laying around?
- Accord V6 performance....
- idling problem
- 97 se rims on 4th gen?
- Tech Articles
- engine running warm on a 90 accord ex
- Video from the RSX forum
- f22b1 swap into 4th gen
- Anyone know or have a picture of what the JDM 1992-1993 Accord bumper lens assembly look like?
- H23 vs F23
- crazy swap: H22 into 89 Ackerd
- ACCORD BUDDIES: Help me out.
- Looking for a muffler w/ 2.5" or 2.25"exhaust tips...
- 99+black accord search!!
- Max boost levels on f22b2 stock sleeves
- Is this normal?
- Do I have to change the exhaust wit h22a1?
- apexi AFC
- Fuel Pump Question?
- quick q: what's the size of the rear license plate screws?
- A/C hot & cold and idle dropps?
- DO I have to buy it again??
- motor trend has somce pix if the new accord and a short review
- Stree legal?
- JDM EK9 or EG6 Side Markers for 1994 ACCORD ?
- ecu codes plz help
- 91 Accord needs swap help
- Which is a better 4-1 Header design? Kamikaze or DC?
- Anyone here from Minnesota?
- Clutch/Tranny Issue.... I think
- prelude type s motor
- Is it worth the change of header...
- Short Ram vs. CAI
- Vibration
- 90 accord ex difficult warm starts
- h22 tranny question
- How to make an accord super fast
- anyone see that accord...
- the helm publications service manuals
- JDM (knock off's) Headlight Bulb change trouble
- Tailights
- Jumpy transmission
- Fuel Delivery Problem?
- Pics of the Soy Bomb
- I need Amber side markers, Mugen or Grill piece, and Eye lids... WHere ??
