PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 [216] 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. Auxiliary audio input to stock stereo?
  2. 94 accord main relay?
  3. 96 dashboard removal pics needed!!
  4. swap Q ??????????
  5. skunk 2 h22 intake manifold help
  6. 91' Accord For Sale
  7. Is a cam worth the benifits on a F22 sohc non-vtec?
  8. exhaust sound clip
  9. ECU pinouts
  10. few small problems with accord '91
  11. F22 H22
  12. Please help!!
  13. towing
  14. Springs & Shocks
  15. Tune up parts
  16. 1st time posting here...help with my moms accord (temp gauge related)
  17. need help finding parts
  18. Fuel consumption on 5speed?
  19. Oldschool Accord
  20. Car cutsoff on me once the car is warmed up
  21. Door locks on seventh generation accord
  22. WTB... I know this is the wrong area but...
  23. SIGNS of a BAD DISTRIBUTOR??
  24. 03 accord power gains
  25. Need A lil' Help..... Please!
  26. CEL problem
  27. 05 Accord Forum?
  28. Weird loud noise!
  29. 95 accord timing belt replacement
  30. F22A4 head gasket
  31. 96 accord lowering problem
  32. 2000 accord V6 timing belt replacement
  33. SATIN BLACK PAINT JOB
  34. are these coilovers any good ?
  35. 92' Accord won't start...
  36. Advice, rear suspension went bump!
  37. New Owner
  38. Acceleration
  39. Interiors.......
  40. Newb here...
  41. DTC P0171
  42. Trouble finding wheels
  43. getting vacuum from throttle body map port at idle.
  44. acoord turbo problem
  45. distributor
  46. what HID's do i use
  47. ? About '00 V6 Accord
  48. 2003 Accord LX Idle Trembles
  49. need more low end tourq 95 acc autoLX 2.2
  50. 95 accord lx auto speed sencor?????????????
  51. need help pls... car dies while driving
  52. Foggy head lights...
  53. Suspension question
  54. bore and stroke on a f22b1
  55. do i need chamber?
  56. new, shifting
  57. newbie here with a wheel question.
  58. Noob question (searched) VTEC solenoid
  59. Transmission problems 91LX
  60. What should I go with prelude wheels rub
  61. 93 prelude suspion work on 94 accord?????? asap please
  62. Brake pedal height
  63. 90 Accord Bearing, time to kill honda designers!!!
  64. How much?
  65. VTEC Cuts off 96 cord H22A OBD1 HELP!!!!!!!!!!!!!!!
  66. Question regarding to 7" Dynaudio installation
  67. aftermarket bucket seats Q
  68. Head unit problem
  69. HID in 7th gen
  70. accord body kit
  71. Front End conversion on a 5th gen???
  72. 2002 Accord SE Auto Transmission Problems
  73. 4cyl accord sc build
  74. Accord 2000 wiper control broken?
  75. cruise control works intermittenly
  76. Painting Hubcaps ?
  77. I'm a new guy!
  78. shaving antena off
  79. need help with air cylinders...
  80. Turn Signal Will Not Stop Clicking 91 Accord lxi
  81. New Skunk2 lowering springs
  82. need help on spring noise
  83. WHICH TRANNY IS BETTER F22 OR H22, GOING ON A F22B1 MOTOR?
  84. 98 lx CE light
  85. VAFC or SAFC for 98 accord f23????
  86. Headlight
  87. Receiver Dryer
  88. Broken Timing Belt Question
  89. Radiator choice?
  90. Will these fit?
  91. Alarm issues
  92. Wheel Bearing?
  93. Please provide me a good mech in LA/OC area
  94. 1993 Accord motor mounts.
  95. H22 or F23A1
  96. 98 accord possible fuel problem
  97. HID question
  98. Weird idle problem. Please help.
  99. problem with my CAI
  100. b20b vs f22a1
  101. Some transmission problems with Accord
  102. IMPORTANT!!!! PLEASE HELP
  103. car wont shift to reverse
  104. WANT TO BUY... -F22a1 shortblock for 90 accord
  105. Automatic transmission Fluid
  106. H22 swap
  107. Would You?!?!???
  108. front bumber 6gen.
  109. New engine rebuild h22
  110. Accord 96-97 rear lip
  111. Accord '93 Front wheel noise
  112. HUGE PROBLEM NEED HELP IMMEDIATELY---POSSIBLE GAS LEAKAGE
  113. Stupid mistake
  114. anyone have the link to accord turbo
  115. Short block replacement problem
  116. Two coolant temp sensors??? One green, the other black 1989 Accord lx-i
  117. 95 V6 accord
  118. uberdata tuning in nashville, Tn area???
  119. Power Locks Broken??
  120. Why is my car using so much coolant?
  121. Help Please!!!!
  122. HELLOO newbie here got some questions
  123. Accord coupe w/H22A & Auto Tranny
  124. 91 accord coupe drivers door wire harness
  125. 96 honda accord suspension troubles, need sugestions
  126. Is this a good HID kit?
  127. turning noise up front
  128. auto to 5spd in 96 accord
  129. 00 coupe power suggestions?
  130. accord 2002 seatbelt problems
  131. FAQ: OIL IN SPARK PLUG TUBES (sticky?)
  132. suggestions on my accord...
  133. 95 4cyl. to V6 front brake converison?
  134. quick question on which ecu to use on my f22b1 and h22 tranny swap!!!!
  135. Installing new shift cable-any tips?
  136. so if my ca r wieghs about 3000
  137. 92 ex bumper
  138. Lowering Springs on stock struts?
  139. Is there a quick-fix for oil leak in the spark plug tube?
  140. f22b dohc tuning opinions
  141. srs warning light
  142. 94 Accord ignition cylinder, auto or 5 speed. The same or not?
  143. 7th gen relay box!!!!
  144. Supsension time
  145. Which Path?
  146. Anyone know how to turn off the Seat Belt Reminder on new Accord?
  147. Never seen this happen..
  148. Maint Req light
  149. F23 Piston sizing
  150. F23 header worth it?
  151. noobie - so my first, and last dumb questions
  152. 1993 Honda Accord Check engine light and flashing D4
  153. question about brake pads....
  154. How many amps is a stock 97 accord alt?
  155. Can I use a 92+ h-series clutch kit in my F22?
  156. Please help pass 1989 Accord Carbon Monoxide emissions!
  157. '94 Sputtering worries
  158. just bought an accord need some help
  159. Passenger side air vent
  160. 1/8 mile times or quater
  161. manual conversion on a honda accord 92 lx
  162. Random JDM-ness CB6 pic
  163. i need wiring diagram for a 93 accord wagon
  164. 2.7L RPM at Highway Speed
  165. just baught a cb7 is something missing here???
  166. 1992 accord EX
  167. h22 head on a f22 block?
  168. 99 EX-V6 air conditioning help
  169. '02 Accord dash/radio
  170. getting rid of my 06 dc5 for the new accord
  171. caliper bolt
  172. How can I tell what transmission a transmission control module is for?
  173. 88 DX is it worth it??
  174. New to Honda, help.
  175. Naples, FL Accord for sale! Bump if you read please.
  176. ? on 94 accord tail lights! < they're always on.
  177. Deal or No Deal?
  178. IN NEED OF NEW CATALTYIC CONVERTER
  179. nitrous users
  180. 3.5L swap?
  181. 1992 accord ex coupe tail light leak
  182. 95 accord accelerating problem
  183. intake manifold
  184. H22a4 SH engine in 90 Accord?
  185. jsut a few questions and concerns
  186. Soon to replace stock suspension
  187. 95 Accord Legend 2 Piston Brake Upgrade
  188. TYPE OF GAS FOR 99 V6
  189. --Two accord cd5 chillen on a sunday--
  190. difference between f22b1 head and f23a1 head?
  191. 91 accord ex
  192. EDR's
  193. 94 honda accord OBD?
  194. Suspension Help
  195. Engine removal, 2000 Accord, f23a1
  196. smoked tailights
  197. Car wont start. No spark
  198. 1995 honda accord gear issue
  199. :( H22A JUNK??
  200. Rim Size
  201. Placing tweeters, need help with placement/interior work
  202. rear suspension noise
  203. Yet another suspension question.
  204. Accord won't start
  205. Problem with cold starting
  206. Tire sizeee
  207. Front license plate.
  208. anybody from the harrisburg srea
  209. FUSE OF MOBILASTION
  210. 5th Gen. Spoiler on 4th Gen. Accord.
  211. Oil Cooler for H22... What should I do?
  212. Anyone in Va/MD/DC wanna help me w/ my h22 swap?
  213. shops in PA?
  214. Intake manifold interchangeability: F22A4, F22B1 and H22 Prelude
  215. Alignment
  216. Coolant temp too high?
  217. o2 sensor
  218. suspension noise
  219. Exhaust rubbing
  220. Rear Drum Brake Upper Return Spring
  221. 1998 accord?
  222. the drop
  223. valve noise
  224. distributor question
  225. broken timing belt
  226. 04 Fuel/o2 sensor problems
  227. 90 accord with 228,000 miles wit a couple of problems
  228. Thinking about buying an '89 SE-I Coupe...
  229. Auto 92 accord shudders when i come to a stop..?
  230. some help please
  231. an accord front clip conversion..
  232. Will I have Cruise Control with an JDM H22 w/ euro R Manifold?
  233. jdm f22b dohc runnin iffy
  234. Acccord Lacking power
  235. 92 rear caliper bracket rusted on
  236. Basic suspension setup?
  237. 86-89 Accord Lx models
  238. Air Conditioning "Upgrade"
  239. Help with switches/sensors
  240. Factory Part Number
  241. Accord Power Windows
  242. V-6 front brakes on a '95 4cyl
  243. engine skipping?
  244. 99 ACCORD REMOTE
  245. Springs Vs. Coilovers
  246. prelude wheels
  247. Need to replace fuel pump in accord where teh heck is it?
  248. D4 codes - car won't start - 92 Accord Auto
  249. how do i check codes on a 91 accord ???
  250. valve cover gasket
