99 4cyl stalls under braking
Old Jun 12, 2003 | 05:34 AM
GSRMatt's Avatar
25 Year Member
Default 99 4cyl stalls under braking
I have a bone stock 99 4cyl manual daily driver. It has had the ignition switch recall performed.
Problem is when I'm braking down from speed, particularly hard braking, or braking down hill. When I put the clutch in the engine just shuts off. It will start right back up, and its never stranded me, but it seems to be happening more and more often.
It will not stall if I heel/toe into the corner and it is in gear the whole time. Also if I blip the throttle as I'm braking it will not stall.
Best guess is maybe some kind of PCV, vaccuum, or idle bypass problem? I haven't checked to see if it is better or worse with the AC off, but I live in South Florida so the AC is on pretty much all the time.
Any input, or similar experiences?
Matt
Old Jun 12, 2003 | 07:23 PM
Stripped Honda's Avatar
99-0104
Default Re: 99 4cyl stalls under braking (GSRMatt)
my neihbor had this problem and all we did was open the air mixture screw at the top of the throttle body a bit and it solved the problem
Old Jun 13, 2003 | 11:31 AM
GSRMatt's Avatar
25 Year Member
Default Re: 99 4cyl stalls under braking (Stripped Honda)
I'll give it a try, thanks.
billcass
Jan 2, 2011 03:59 PM
diydog
Jan 21, 2009 09:33 AM
nj99civic
Apr 22, 2007 10:00 AM
tonezilla
Jul 30, 2005 04:41 AM
