PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 [341] 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. Need help on a check engine light on a 93 Accord
  2. 94-97 f22b1 weight?
  3. a few questions ???
  4. 90-93 Accord Offset
  5. looking for sites to buy products ???
  6. 6g H22A Accord...
  7. Need help..where to install all these guages?!?!?!(no, I'm not a ricer)
  8. New '03 JDM Accord
  9. Where is ac filter located on my 2000 Accord VTech4? I am supposed to change it.
  10. ecu for h22 swap
  11. Coolant drain bolt on 98 EX?
  12. Help on Lower Control arm bushing
  13. Does 2000 Honda Accord have serviceable transmission and fuel filters?
  14. Light not working on Clock of 2000 Accord. How do I fix it?
  15. 2001 Accord EX Tranny...
  16. 2000 EXV6 Check engine light
  17. my cruise control won't work!
  18. its back!!! MAN IM HAPPY!!
  19. light bulbs
  20. What kind of engine do i have?
  21. Tranny problems
  22. Suggestions needed.
  23. Simple Electricity question
  24. 93 is toast, bought a 90 with troubles
  25. Question on building engine
  26. need advise
  27. changing thermostat
  28. squeaking noise- good or bad
  29. TCM Problem: D4 Flashing / ABS Light On
  30. door panel removal? 2001 accord....
  31. 5th gen azect lip
  32. Is there a fuse for the back-up light?
  33. Fans Not Working, Temp Skyrocketing!!!
  34. can you convert a 94 into a 97?
  35. Need Help quick!!!
  36. Door lock switch not working. Checked all fuses.
  37. Dam i need help
  38. New In here.. Brake question
  39. '94 Accord EX rear brake Question
  40. fuel/choke problem
  41. Help on choosing new car
  42. Need help car problem ????
  43. new here
  44. h22a Accord 5 speed..
  45. ???Crane Cam???
  46. Building an intake for a 4th gen
  47. my car sucks!!
  48. stanky smell
  49. Code 43(fuel supply)...what do do now?!?!?!!?
  50. 1990 Accord Idle troubles when in park and neutral
  51. Need some help
  52. I need motor specs between the F22b1 and F22b2.
  53. Felpro Headgasket.....
  54. f series
  55. screws holding rotor to hub
  56. P-Motor ?
  57. Check Engine Light?
  58. valve cover
  59. DC Sports Headers...Ceramic Versus SS?
  60. stroke on f23a
  61. rims and tires
  62. I need help on my exhaust
  63. Shocks kyb gr2
  64. question for auto tranny gurus
  65. accord=5 spped,,,,damn it
  66. Uk Honda Accord
  67. Which Accord should I go with?
  68. Alignment or Camber Kit
  69. 5th gen. LX Injector Size
  70. Shifting problem after installing cluch
  71. NX jet sizing?
  72. when to get an alignment
  73. my headlights keep goin out
  74. look im a newb, suspension thread...but more technical i suppose
  75. Which kind of pulleys should I get for a 2000 EX 4Cyl.
  76. 2000 Accord 4Cyl. Offset?
  77. question about the "SS" button on 4th gen
  78. Cam lift specs
  79. is your insurance HIGH?
  80. 97 Special Edition Honda Accord For Sale
  81. EX exhaust manifold on LX Accord?
  82. 2.2 Accord Head Gasket
  83. ball joint boot cover reeplacment
  84. ECU FUSE location
  85. testpipe distributors.
  86. idle problem ???
  87. h22 TPS: where can i get one?
  88. Troubleshooting ABS
  89. valve seals
  90. 99 Accord CEL
  91. I need a gauge cluster pinout for a 5th gen......
  92. top speed
  93. Help - 1980 Accord Cuts Out Intermittently
  94. Anyone with JDM folding mirrors? Need help
  95. dyno cost
  96. Block heater
  97. broken lock
  98. Help! Brake pedal sinks to the floor
  99. any recalls or problems with 4th gen accords?
  100. Pics Of Car And H&R\Koni Suspension Install-Review
  101. 5th gen headlights
  102. temp goes down and heat is not hot but warm now. help!
  103. Wagon Chasis vs. Sedan/4dr
  104. revisiting an old topic: why dont we have a forum description!?!?!
  105. oil leak from exhaust manifold gasket
  106. what is the bolt pattern on v-6 4dr accord '03 wheels?
  107. block code?
  108. anyone actually put rota c8's on an accord??
  109. Where is the water pump located?
  110. OBX SS Headers?
  111. OT : oneway tire rotation
  112. power door lock problem INSIDE lock...errr
  113. will an accord trans bolt up........
  114. anyone know how to reset 2002 ACCORD SRS light
  115. Hit a Curb - Wheel Wobbling Side to Side - What's Broke?
  116. What would you do?
  117. Check My Parts List - 91 Accord Timing Belt Change
  118. Problem with back tire
  119. Compression Cause a Problem???
  120. f22 pistons.
  121. Timing Question, Igition vs Cam.
  122. FYI - Mugen Chip for 94-95 Accord EX - on Ebay
  123. 1990 Accord lx Ignition switch question Please help
  124. Check Engine Light
  125. New clutch/flywheel combination and differences
  126. Tire size
  127. Faulty alternator
  128. Driving with a lightened flywheel
  129. Help... 94 Accord speedometer works, but odometer stopped.
  130. Power Steering Belt
  131. suspension problems
  132. how much is motegi rim cost?
  133. bouncy RPM's after 4K, car also bucks help
  134. only want to buy rear koni yellow
  135. post pics of your accord
  136. a few questions about AT -> MT conversion
  137. what to get next..?
  138. Need help regarding a friends 2000 Accord
  139. OT: some misc. question about 6th gen coupe
  140. Sizes of OEM Winshield Wipers..?
  141. window motor
  142. need help on finding o2 sensor for 96 4dr
  143. Anyone have advice on cams for the F22a6?
  144. Anyone have the Tanabe Sustec stut bars
  145. What engine will fit an 94-97 Accord?
  146. F22 -> H23 motor/tranny, AT -> MT conversion...
  147. grounding wires on 93 accord
  148. 2001 Coupe EX Manual Tranny Rough
  149. Checked the plugs today, interesting looking...
  150. post about guy messing up fender cuz of control arm
  151. aftermarket key lock lug nuts
  152. Wheel offset and tires - ????
  153. how much torque do i need for 91 accord head bolts?
  154. Hot Cold dial for heater/ac broke. How to replace?
  155. bulbs?
  156. cutting the bumpstop
  157. 91 Accord DOOR
  158. what boost?
  159. 88 Honda Accord fun...
  160. Question about some underhood fuses and my electrical drain problem
  161. Thermostat on 96 Accord?
  162. What mounts to use on a 90 accord H22 swap?
  163. how much would this cost?
  164. 2003 2 door V6 Accord
  165. should my new tires fit alright?
  166. balljoint
  167. Strange Smell
  168. First mods.
  169. how do i replace my bumper turn signal fixtures?
  170. Just got my Timing and H20 changed..few questions
  171. Knocking/Rattling sounds when Braking HARD???
  172. block guard
  173. HEK-1 engine any tech tips?
  174. 91 Accord tach/stall problem
  175. got 2 rust spots on my ex
  176. 00' v6 coupe
  177. NOS Wiring Help Needed..
  178. Parking Brake Light
  179. spec your turboTurbo F22B Info
  180. Accord Custom Parts
  181. Trunk Piece Needed
  182. how to check MIL...
  183. Newbie with Question on Headlight Replacement
  184. 2002 coupe door panel removal
  185. Battery, starter, or just too damn cold?
  186. need help with color id
  187. What to do?
  188. Exhaust tip gets black quickly after cleaned. running rich?or no big deal?
  189. install help
  190. Good idea for accords to remove stock o2 sensor housing for true full exhaust.
  191. Error code 8: Faulty dist. misfire. Any replacement for OEM?
  192. Intake Manifold from H22 to F22?
  193. Pinout for 93 accord harness
  194. Diameter of intake?
  195. Power Window Stuck
  196. Exhaust leaking on fuel tank....
  197. power window bounces on the way up.
  198. my accord is dead
  199. Engine surging 95 accord ex
  200. question about the V6 brake upgrade
  201. Anyone know 88 accord head bolt torque specs?
  202. Custom piping exhaust tech question.
  203. Doing bussiness with digitalracer.com
  204. Trunk Lid Fitment
  205. tranny question 4 turbo?
  206. Anyone interested in a how to: dry nitrous install
  207. How many of you Accord owners have built/n20 fed/boosted f22s and have F22 SOHC PRIDE?
  208. PLZ READ: I NEED BETTER Suspension and brake system
  209. I need a new engine definately!!!!!Read for more plz
  210. HOW TO: trunk brace and 1st post
  211. Accord exhaust from Kteller8
  212. do u think this would go good?
  213. Maintenance schedule?
  214. squeaking from new Koni SP3s... damnit.
  215. Clutch Problems 95 Accord
  216. Accord with H22a Swap and boost
  217. how do i get the smiley off?
  218. Looking for best Honda service in Los Angeles
  219. rods
  220. distributor timing
  221. Free AEM V2 Intake For the Accord
  222. Can anyone help me on this. Intake Manifold for a f22b2??
  223. 96-97 O2 Sensor after CAT
  224. Need Parts Info/List for Rear Disc Swap
  225. camber kits?
  226. rear defroster causes hella radio static
  227. what setting on kyb agx for 93 honda accord ex?
  228. help... my car wont start!!!!!!!
  229. FMAX Turbo kit GB individual kit parts too.
  230. Old PIC of the Accord, Post pics of your Accord here to if you can..
  231. Engine Vibration after T Belt change
  232. will chirping tire at every redlight cause major damage ? (very dum question)
  233. 94 accord wagon lx > PLEASE HELP WITH AN INTAKE
  234. anybody seen CF fenders for a 4g?
  235. HELP my trans is clicking!!!!!!!
  236. Cost of getting a 5th Gen. Bumper replaced?
  237. carsound cat
  238. Dash and tail light not working on a 1990 accord
  239. quSqueaky springs
  240. bad gas smell
  241. hybrid f20b/c?
  242. S/T sway bar install
  243. 98 - 02 EX Coupe, Any Difference?
  244. 95 front speakers
  245. Anyone have a 2003 Honda accord 4dr
  246. How Do You Ship Rims?
  247. 98 v6 into 4th gen... (READ) should i do it if i can get the motor & tranny for really cheap. Why no
  248. flooring it and then let off and it stays revved for a sec
  249. Xenon HID bulbs
  250. what type of exhaust for 91 accord
