View Full Version : Honda Accord (1990 - 2002)
- 95 accord ex check-engine connector
- f22b motor dropped in my 92 civic, need help with what kind of spark plugs to use
- Trouble Help !!!!!!!!
- 2004 Accord Satellite radio install
- Question on stereo installation - 1998 LX Sedan
- 1990 honda accord won't start
- ***very intresting, f23 internals and h22 head and block, turbo help, RODS
- Ex Exhaust on LX???
- question on a h22 turbo kit for f series
- What tranny can I use?
- h22
- re: h22 -> accord engine mounts
- ignition info
- bad alternator?
- re-upholster price
- Painting an Accord
- Noob question but....
- 93 honda accord turbo setup
- h22 swap problem?
- turbo
- Question about timing belt changing intervals?
- Need Advise. Have an '01 LX with 2.3L VTEC. What are the limitations to my Motor.
- trans trouble
- weird noise, rattle, squeak, and a bit of clicking coming from car, help?
- Need help from some experienced Honda owners.
- clutch pedal stuck up
- Misfire issue...or maybe something else
- AEM EMS 30-1000 for sale
- Spark plug Gap
- do acura tl HID headlamps fit '00 honda accords?
- 93 Accord EX - ABS questions
- Quick ratio steering rack
- this is great news
- 96 accord how often to change plug wires
- questions on clutch life?
- Accord problem
- well the motor is in now & it is sweet
- 98 Accord Instrument Panel
- FS- 18" motegi ff6 rims/tires $625 ASAP
- valve cover
- trans help!
- Has any one swaped TL parts for accords?
- WHEEL INPUT
- battery relocating
- H22 Accord for sale
- Braking Problem 01LX
- 92 accord help
- engine swap
- ac compressor pulley
- help f22a1/oil/cloging problems
- can't get nut off to remove hub
- 5 speed tranny axle seals ....
- wrong ecu? help asap
- OBD?
- JDM H22A '94 LX Accord REDLINE CHANGES and Radio Fuse Blows out
- 3rd Generation Accord 86-89 swap/conversion/mods
- manual 5 speed anyone change seals ??
- Ignition Coil JDM?? how much to replace it?? any ideas?
- I'm new and i had a question about parts for my 00 accord
- guage cluster issues
- 93 honda accord service check connector
- replace foglights on 2003 accord
- CenterForce clutch in my honda ?
- PROBLEM WITH HONDA ACCORD 2.2 VTC ;1997 - automatic
- What yeah of an accord should i get?
- did a tune-up... wierd ass complication that i need help with (ROTOR Issue)
- Question
- 1998 accord timing belt
- Spark plugs are oily??
- Engine RPM hang when throttle is released while accelerating
- Newbie with a Accord problem...
- Torque Steer
- Would a CAI fit..
- Do SI front seats fit in 94 acoord
- Problem with 90 Accord LX???
- Camber kit question?
- OBD1 or 2?
- Recommendations for NGK Wireset?
- 1998 honda accord coupe v4
- P13 ECU Pinout PLEASE, ANYONE!!!!
- 1991 Honda Accord SE QUESTIONS???
- engine swapping
- 2002 Accord 5spd stalls when downshifting
- my stock tires are 195/65/15 i think
- my car sqeaks when i go ova speed bumps, i think it's the shocks n struts
- Can anyone get a code for a stock accord head unit??
- Blown 1997 Accord NON vtec, will this engine work?
- Brake Master Cylinder bore 1in or 1 1/8
- Anyone have one of these shifters?
- F20 engine swap
- tires 4 sale
- 205-65-15
- Alternator Belt
- Problems help asap
- shifting gear from neutral to drive at 50 MPH
- Need some help, in California, want to turbo 2000 f23a4
- Springs?
- Question about a 1990 Honda Accord LX Coupe
- Hard Start Hot
- Creaking suspension??
- question about exhaust
- having problem with a 1993 automatic transmission
- door panel reupholostry?
- DC5 TYPE R CAMS in a 03 K24a?
- What's wrong with my Honda Accord? Very strange behaviour...
- Simple question about pin locations...
- will 04 TL wheels fit an 01 accord coupe?
- Header question....
- Valve cover gasket
- 97 accord se with idle problem
- Accord 01 HID conversion
- Redo clearcoat on factory rims? How and where?
- 94 Accord LX Sedan
- t.a.s. autoparts (the accord store)
- 1997 accord questions..
- Automatic accord troubles
- f22b2 specs
- Braking Issues 1994 Honda Accord
- Coolant hose
- Tranny swap for a 6 gen accord ex coupe
- Serious electrical problems....
- Sparco Harness bar
- overheating..thermostat??? help
- Strut Bars
- f22 turbo accord
- Good shop for engine build
- Headlight fading?
- Ground Control Coilovers
- upgrades for 01 accord3.0 v6
- Turbo...h22?
- motor question
- 5Zigen Cat-back exhaust for 95 Accord
- Power windows wont work HELP!
- map sensor wire up- 90 accord
- door panels
- help with head gasket
- Engine Oil Pressure Switch
- Lowering ride cost inlinefour
- CB7 gear ratios
- 97 accord cylinder position sensor
- 93 honda accord pricing?
- 94 Accord cooling fan issue
- Great Mechanic in Los Angeles areaa
- Where to buy H22a?
- This question is for cali people (smog related)
- dumb question but what is 500 mile break in peroid on a clutch ?
- Engine Maintenance Light
- what exhaust should i go with
- 98 Accord 4dr EX - Need New Clutch :D
- Annoying ABS Issues, Dealer can't recreate. Help!
- help tint removal
- steering problem
- OK NEED HELP !
- 94-97 Accord and need some pointers
- idle problems
- lots of parts must go make offers
- Intake help
- F20A dohc auto tranny?
- H22 Running Rich?????
- Brake Bleeding Advice and Help
- What tire size to get with 16" wheels?
- do you think this long drive will be oK? (timing belt related)
- 1989 Accord LX Alternator/Electrical Upgrade questions...
- TOKICO adjustable shocks
- master cylinder fluid
- 92 honda accord wagon
- suspension help asap
- highflow catalytic converter?
- 89 accord LX
- Going Accord Shopping in Ohio...
- ECU Question...
- 91 Accord coupe(need help)
- No heat in my accord!!!
- oil leaks on starter & celleniod on 1990 accord EX
- combination switch on a 89 accord LX
- RPM's
- A bolt and two washers to fix negative rear camber????
- honda accord problem-pls help
- AIT (air intake sensor) on 87 accord Please help
- 97 EX rear motor mount change???
- RPM LIMITS
- Advice on H-tech Tein springs
- 01 Accord Rattles...If any experience with them, please help
- 5th gen. advice on lowering components
- cold start problem!!!!!!!
- "90 Accord fuel problem
- Quick Question about doors! Thanks!
- Door rattle 2000 Accord Coupe V6
- 1st gear problem
- which k24 engine is better stock crv,accord,tsx
- Camber kit Question
- JDM Gen5 sidemarkers
- HELP.. Opinion On H-Tech Tein springs
- 6th gen camshafts
- unorthrodox pulleys for 6th gen questions
- changing the projector to one that holds a bigger better bulb
- 88 accord short shifter
- 94-97 projectors
- Tenzo Type R Lowering springs.
- Wheel Bearing?
- accord turbo kit
- car makes buzzing sound around 2000 rpm
- for the 6spd. V6 people
- Turbine Speed Sensor
- Clicking noise when turning the wheel on the car while moving.
- Side window replacement
- 91 ex coupe rear speaker removal
- got in a accident
- Brake light in cold temps
- 93 Accord reverse gauge from ebay
- Accord Type-R Transmission
- 94-95 Accord Lip
- best guess?
- 2004 Accord - Windshield crack due to cold weather
- Psi Question
- i got a question...about f22
- SRS
- Aim JDM Headlights
- 2004 accord engine problems
- prelude axles
- axel problem
- wheel noise
- Acord Paint Protection
- Knock Sensor??? Anyone Have any idea on a price???
- Injen Air Intake (Will it fit???) Exhaust (Will it fit????)
- Need ACCORD parts 94-97 2 door
- JDM Headlamps (Stanley Black Housing) Some Questions...
- Wiring HIDs, which wire is postive
- 5th gen lude steering wheel
- Engine Code
- Loose Door Handle
- 5th gen accord h22a ecu codes
- 2004 Accord EX-L - Passenger side seat creaks when slid all the way back
- Dash swap
- are all V6 accords automatics?
- 94 accord 2dr, i wana chop the top 2"?
- Max/Min wheel offset
- Cars loud when at highway speeds.....
- Thought it take much more $$ and mods to graze 200hp with a N/A H22a
- 90 accord, with a d15
- Bad sound, power and mileage sucks
- Crankshaft Help ASAP*************
- 98 Accord Need help with Lower Ball joints
- Big question with nitrous
- 1998 Honda Accord 2dr V6
- 1991 Honda Accord 4d SE Help?
- Knocking wheels
- F22b2 turbo upgrades and what not
- WTB: 5th gen prelude cluster
- Engine help on a 95 EX
