94 sohc vtec in a 93 accord
Old Jun 18, 2003 | 09:20 PM
92gsrhatch's Avatar
Default 94 sohc vtec in a 93 accord
runs out of power about 5000 rpm, cant figure it out. could it be the map sensor, it wont even hit the rev limiter. i have all the vtec wires run and am using the 94 ex ecu, what is wrong?
Old Jun 25, 2003 | 03:52 PM
Baltz's Avatar
Default Re: 94 sohc vtec in a 93 accord (92gsrhatch)
I don't know your answer....but was there like any problems with the swap?
Old Jun 25, 2003 | 04:21 PM
iam7head's Avatar
Default Re: 94 sohc vtec in a 93 accord (4th gen accord)
Um...max torque in most F series is about 5000rpm, it's not a high performance super doper engine and it hates to get rev' up
Old Jun 25, 2003 | 08:55 PM
YeuEmMaiMai's Avatar
Default Re: 94 sohc vtec in a 93 accord (iam7head)
my F22B2 is very happy to rev up to 6300 rpms... sounds like he might have some fuel delivery problems or something is not wired right....
I would double check all of your work and make 100% sure that you did plug in your sensors and everything is as it should be....
Old Jun 27, 2003 | 06:17 AM
GimpyAccord's Avatar
Default Re: 94 sohc vtec in a 93 accord (YeuEmMaiMai)
sounds to me like vtec isnt enguaging... the low cam on the B1 head is totally worthless past like 4000rpm. Have you verified your oil level and that jazz? When I did my head swap I had to remove the solenoid and TOTALLY clean it out... it had gunk in it. It was working enough not to throw a code 21 or 22, but wasnt letting enough oil in to enguage the lifter locks.
n8b6339
Sep 19, 2013 01:28 AM
The(704)kid
Jul 5, 2011 10:19 PM
G91EF
Jan 28, 2010 05:36 AM
rocker_91
Dec 15, 2008 12:33 PM
LudemanDan
May 26, 2002 02:22 PM
