View Full Version : Honda Accord (1990 - 2002)
- Slow battery drain in a 88 Accord LXi
- LOSS OF ACCELERATION IN MY ACCORD WHEN I HIT THE GAS
- 96 accord ex stick frog type noise?
- oil filter fitment question
- help with paint
- Brake Pads
- Carpet is SOAKED with antifreeze, but i just put a brand new heater core in today..help me please
- Do lightweight flywheels offer much to your car as far as performance?
- Bomz INTAKE from ebay
- ABS problem.
- 98 Accord Starting Problem
- Temp guage
- >>>>NEED An aCCORD BLACK DOOR.<<<....
- 1992 Accord EX: Sputters and stalls (especially when idling)
- Blinkers not working..plz advise
- Three windows is not work
- 98-02 drivers seat question
- not a real problem but annoying
- no friction mod
- O2 Sensor Wire?
- huh??!!
- VALVE BROKE INSIDE ENGINE BLOCK!!!
- 2000 accord trannie!!!
- 5th gear grinding. HEEELP!
- 1993 accord headlights
- 1991 Honda Accord vibration??
- H22 vacuum routing
- dont know what clutch..
- 5th gen antenna
- Eibach springs
- Can someone quickly tell me
- h22 installation???
- F-Series Turbo?
- 7th gen shift knob, 5th gen accord (i did a search i swear)
- quick question on paint
- Suspension setup ?
- quick clutch question
- Washing engine, air intake?
- Instrument Cluster
- TSX headlight to Accord Swap
- Another sway bar ????????
- Parking light wire
- Lugnut split on me, Help!
- 91 Accord EX Sedan Speaker Problems
- Tire Size Concerns
- 96 accord Axle question?
- Battery and Charging
- Need help with ODB
- Question Help Me Out
- can i run 17x8 whees?
- 92 Accord 167K miles- Loss of power & erratic idle
- Attention - Jim Blake
- Brake Calipers
- 89 lx-i coupe adjusting the clutch pedal engagement point?
- small light fuse keeps blowing...
- Looooong Sparco seat review & stock seats
- fuse box diagram
- h22a for sale
- M3 Mirror 411
- honda accord trunk lid swap (1996 lid on a 1994 car)
- Gen5 rear tail lamp upgrade
- rear coilover install problem
- 5th gen map lights ???
- Hood Latch Suxors
- need help with 02 accord
- question face gauge
- 98 Accord (6gen) headlight and front bumper removal
- auto alarm ??????????
- 95 and 91 please help!!!!!!
- jdm black housing
- how do you install sprint springs on 96 lx accord
- lowering springs
- 92 Accord EX - How to change front headlights?
- 96 accord bumper fog lights
- 95 Accord EX ... Starting problem fixed??
- My cooling fan fuse keeps blowing - got questions
- If I were to take the back seats out of my accord would I have to replace them with cross bars?
- Q: 94 Accord fluid levels and Trans flush procedure
- Remote starter problem with 6-cyl '97 Accord
- f22b2 turbo
- HID setup/housing compatability question
- Apex'i WS2 exhaust?
- TURBO
- hey whats the weight on the 91 accord 2door?
- autometer acting strange
- Suspension set up
- idle problem when cold
- 1991 Accord problem....my (back up) radio fuse keeps blowing out..i just installed a new alternator
- OT: Parts for sale in classifieds
- no spark
- Degreased the motor on my 95 LX today
- My tac is jumping, but no problems?
- what is the total fluid capacity of a '94 accord ex tranny?
- Are real JDM blackhousing a lot different from the knockoffs? 5thGen 94-97.
- Big intake or small intake?
- 2000 accord LX need some info.
- turbo f22b2
- 1990 honda accord speed sensor
- Throwing a code 5 someone please help
- newbie question..
- i need to find a 96 accord shell for a buddy. ( so cal )
- auto transmission gear shift light out
- dashboard dims sporadically, voltage 14.2 then 12.88
- '96 Accord EX Coupe Rust Analysis
- question bout remote start?
- 91 Accord Electrical System Probem
- What intakes are good for 02 Accord?
- h22a accord idle troubles
- ? for you accord gurus
- New Exhaust
- Brake pads installation helpp!!!
- Ecu limp mode without CEL possible?
- J30a swap
- HELP!! 88 Accord idle's at 500 rpm then dies!!
- 99 2 dr Accord Factory Alarm
- No start 90 accord
- Accord O2 sensor
- How do u remove the bezel from a 92 accord?
- 96' Accord Turn Signal Problems
- 94-95 & 96-97 Compatibilty
- New engine time?
- Rusted Bolts
- Motor differences?
- 89 accord won't stay going
- What do you all think about this new F22B1 header ?
- 95 lx muffler
- Dashboard Mystery Item
- Erratic speedometer - replace? lube? sensor?
- ogbusboy thankyou
- trouble install springs/shocks on 98 accord
- ANOTHER problem with the accord..... window related
- Accord '95 Engine Swap
- Turboing a 2001 LX accord
- JDM 90-93 Accord 2.0 SI Fuel injector cc and flow style?
- 2004 Honda Navigation System
- problem with exhaust
- cheapest 250+ hp?
- TWIN TURBO ACCORD
- putting on new shocks
- Injen CAI power gain
- depress broke needle gauge
- OT: Cheapest place for OEM Sumitomo Sparkplug wires?
- Engine Water Damage Question
- dealer installed AC
- weird humming sound on freeway speeds
- Wheel, Tire, and Sensor Questions!
- where to get these parts?
- 97 Honda accord borken can anyone trouble shoot this Problem?
- 96 Accord exr (1/4 mile times?)
- best suspension set up accord
- Location for TCM for 98 accord (already searched)
- H22A accord idling problem.
- 99' parking brake
- fan problem
- how do i clear a ecu code ?
- 93 Accord> D4 always on, wont shift, only stay in 3rd gear
- Front Axel
- Alternator bearings going up?
- HEY, HAVEN'T POSTED IN LONG TIME; some questions on older Accords
- hotwireing a 89 accord
- 98-00 accord coupe leathers with door panels and trim for sale
- 01-02, 4 door accord leather seats door panels trims etc....all the goods for sale
- Suspension Questions
- Air Conditioner filter
- ABS Light
- insight to a 1996 accord v6
- HEAD...cams, springs, retainers, valves?
- CODE P730
- Tranny will not lock up... Please help
- NEED HELP REAL BAD!!!!!!!!!!!!!!!!!!
- Temp gauge going up on long idle times...
- Problem on cold start.
- can someone show me a pic of tein ss coilovers and how low they go?
- F22B sohc vtec swap into CD5 Lx, problem.......
- Picture Thread?
- F22 Automatic to H22 Manual Swap in a 92! Help!
- Accord EX V6 Coupe Exhaust Tips w/ underlip spoiler - HELP
- EX vs. EXR
- Air filter question
- Better performing intake manifold for an F23
- ECU connector? 93 Accord
- only have 1 spark from coil
- Low Beams always on!!!??
- Vtec
- check engine light flashing
- what? nobody knows?
- What bottle to use
- HELP!!! Major car problem...
- how to do a h22/h23 swap into a accord
- 94 accord ecu pin outs
- tranny conversion on 5th gen obd2
- 96 accord suspension advice
- Thinking of getting an accord
- What is the best repair manual for a Honda Accord?
- WOuld it be easier ifi took out healights?
- Lost my 93 EX
- 89 Accord won't start
- 1990 LX all fogged up!! Help!!
- accord 98-2002 cockpit
- 1996 Clutch question
- Accord Coupe Type R
- Need Help Fixing Back light of Clock
- Whistling noise on my new intake.
- Thermostat replacement- 91 accord
- ecu question
- 5th Gen strut bar
- 5th gen antenna
- 91 Accord. Help about Supercharger.
- Attention all Accludes!!!!!!!!!!!
- bulb sizes?
- 94-97 5th Gen ATF
- 91 Accord Supercharger/Turbo
- 89 Accord LXi won't start
- f22a1 or f22b2 head?
- Odd Technical ghetto question ????????????????????...............
- Lowering and Modifications
- fly wheel alignment
- brake pads installation help!!1
- OEM vs Aftermarket O2 sensor
- F22B fit D16 tranny???
- ACCORD FRONT END HELP!!
- Accord Heater Question
- The Bumper lights~! 4th Gen
- just finished swap need some answers
- Oil in my spark plugs holes? Help Please
- JDM 4th Gen.
- timing marks on f22 a1
- Decoding VIN to paint color & Seeking General Advice on Used Accord 'EX Coupes
- Servicing my automatic tranny
- 98 LS tire rubb n wear.
- I'm picking up used (1 season) snow tires. What should be the thread height?
- What kind of metal are the Denso and the Toyota Rads for the 94 Accord EX ?
- wtb cheap f22b2 turbo manifold
- ISO 95' accord auto transmission
- 4th gen camber kit
- Light Bulbs
- What winter tires do you recommend ('95 accord LX)?
- 90-93 Accord Camber?
- How to know if LSD is working correctly.
- ^'th gen A/T
- SOME ONE please help with CLUTCH LINE
- 86 honda accord start problem need a little help
- cam and crank pulley aligment
- AC knob switches
- 94 accord seat swap
- problems with overheating in 1996 accord please help.
- DOHC head on an A20a block?
- block capable of 360hp
- MERRRY CHRISTMAS!
- 97 Accord suspesion?
