View Full Version : Honda Accord (1990 - 2002)
- Loss in power, car sputters
- JDM H22A6 Thermostat and Thermostat Gasket?
- Question on mileage at half tank
- car pulling to the right, need help!!
- 49 dx auto downshifting to second gear at highway speeds
- Axle popped out and my differential became powdered metal!!
- JDM H22 pass smog?
- New Cat Conv. Smells??
- Oxygen Sensor question
- Clutch paddle not release all the way
- Transmission Mods
- Jerks slightly when stopping..
- trany probs
- where would be able to find this?
- mileage gauge
- help: installing speakers in 88 accord hatchback
- 90 Accord window problem
- Spongey clutch when cold on a 90 with 460k
- Won't go into gear, clutch is free and limp...
- Changing to a new a/c compressor, how much oil do you add to the compressor?
- 95 wagon ????????
- steering locked...2000 Honda Accord
- Help with 98 Accord after Trany Overhaul
- Headlight issues
- Overfilled ATF?
- honda accord f18b engine mount
- Help 95 Accord EX
- 92 Accord TCM replaced, not the problem, what do I do w/the old one?
- Dad's 91 Accord, help from those with experience
- 2000 accord oil change
- Cigarette lighter dont work
- Driverside Automatic Door Lock
- help with exhaust
- Overheating Radiator fan not coming on with engine on...does when off
- Tyres/ Euro Accord CG6 '01 1,8 VTEC 100KWt
- What brand air intake is good?
- BLINKERS DON'T WORK! HELP!!!!
- spark plug wire diagram!! PLEASE HELP
- Valve lash adjustment questions
- Engine Cuts out Going down the Road Ne IDeas???
- EGR valve cleaning
- vtec conversion
- Surging and engine overheating
- how do you replace the chrome window trim?
- 2003 seats in my 95?
- some help..thanx
- Need help.
- Remote door lock
- Replacing Airbags
- when to replace timing belt?
- 1992 auto trans. help
- ECU wiring
- 1993 Honda Accord Engine Prob..ne IDEAS???
- need help!!!accord running weird
- f22b can i put a f23 crank in it and would i need custom rods
- Water leaking??
- aftermarket hub removal
- 1990 honda accord engine swap
- 1998 v6 transmission
- I was wondering... :) (off topic)
- Need help with 1996 OEM Honda Fog install
- Swapping a obd2 f22 into an obd1 93 accord
- Suggestionf for my 1994 Honda Accord
- power steering fluid instead of brake fluid
- 93 accord transmission replacement
- FINALLY! H23 VTEC IS HERE!!!!!!!!!!!
- Installing Dual Halo Angel Eye Headlights....
- 1990 honda accord cigarette lighter and front door speakers dont work
- which tranny is better f22 manuel or h22 manuel
- 1998 Acura 2.3CL Questions
- 93 Accord Heating Problem
- Two things going crazy in my 1992 Accord EX
- 293,000 miles 99 Accord v6 auto *need opinion*
- hey cb7 need help
- No signal to ecu
- cam? does anybody make a aftermarket cam for f23?
- De-carbing, fuel injection system cleaning, and cleaning IACV
- Trouble starting in freezing temps, 96 Accord
- 94-95 trouble code removal? need help also need throttle body
- Camber kit for a 95 accord
- Aftermarket Lower Control Arms ???
- rear drum brakes locked
- 1998-2002 honda accord
- no heat
- 99 Accord Coupe Heat
- accord engine
- honda seats
- Types of Brakes
- wheels not centered? Suspension problem?
- oil light and engine noise
- 93 accord wagon exhaust HELP!
- i have accord dx
- ecu
- 1999 LX problems... possibly wiring...?
- Getting a new Tach
- f22b2
- 1996 Accord Sedan $3500 worth it?
- 90' ex accord..valve adjustment
- Engine Damper Kit.... worth it?
- 94 accord ex when is v-tec suppose to hit
- Need an exhaust for my 95 accord ex
- 98 F23 Vtec + 94 F22 Vtec = SAME header bolt pattern?
- Door swap from 93 to 94? Or mislabeled?
- Engine Swap Info
- Plz help
- 99 honda has rough idle
- Honda Accord EX power window wont come back up.
- Headlights for 97' Accord
- Look at this Front Mount Intake lol
- Accord Picture Thread - Discussion II
- Broken sway bar end link on 2000 accord (pics)
- suspension, axles question
- 91 accord cooling fans do not kick on
- 1992 accord auto. trans question
- 1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!!
- ngk spark plugs
- My 94 CD5 Project
- speedo problem
- Torque Amount For these Bolts
- 1999 Honda Accord EX - how many miles is too many?
- Looking for Heavy Duty ignition wires for a 1993 Accord...
- Radiator electric fan not working.
- Clutch Kit
- short ram intake, causing check engine?
- '02 Transmission Question
- Turn rotor on 91 accord?
- Caliper bolt cross-threaded??
- accord map sensor assbly
- gunk motor flush
- How to Reset Tape Deck "Clean" Message?
- H22 head to F22B1 BLOCK
- How to replace timing belt?
- 99 Accord Maintenance Required light
- Cheapest place for hood for 95 accord?
- 1995 Accord - Rad Support Damaged in Accident - Can I repair?
- Head SWAP?????I have F22B DOHC in me accord 93
- transmission problem?
- h22 resistor pack question
- Please Help with 92 Honda Accord!!! My car won't start
- 2000 Honda Accord SE Cruise Control
- 1994 Accord EX Charging Problem
- 98 accord h22 euro r swap problems...
- how do I know my 96 honda accord tranny is slipping?
- Ignition coil for F22B2.
- 98 F23 Vtec - couple simple questions!
- help retrofitting 6th gen
- whats the lowest offset i can use on my 94 accord??? please help
- ECU help.....
- How do i program the garage door opener in my 00 accord?
- Quick Question about OBD?
- starter spin when i connect the battery
- help me please
- BAD catalytic converter causes engine damage?
- cracked pistons?
- K&N Filter?
- 98-02 accord coupe white with black interior?
- F22B1 Auto Trans work with F23A1 engine mount and all???
- 91 accord shuts down ?!?
- dash help
- 91 Accord timing
- F22 Turbo
- F20A5 Turbo.
- Question on re-wiring corner lights to bottom turn signal 94-97
- my old cb7....i miss her.
- Looking for true *BLUE* headlight bulbs
- replacing flywheel
- aftermarket cat conv on obdII accord? worth the savings?
- 90 accord messed up trans. advice?
- f22b1 cranking problem
- please help.the backup battery for my radio and clock is dead.
- Need a picture diagram of power window switch
- Apexi Fuel Management Computer?
- Issue putting my Accord in Gear.
- 1990 Honda accord ex steering pump question.
- Good Year T-belt special
- idle speed?
- Problem whit battery
- wheel alignment ??
- This thing fell off how safe is it to drive
- 1995 EX brakes shaking the whole car
- 02 accord suspension issue..
- exhaust piping kit?
- grinding noise coming from belt
- Relay Location
- Newbie
- .......Stock oem exhaust questions........
- 01 V6 break problem
- H22 wont start. Ran wrong ecu
- 3rd Brake Light.
- Code 91 on a 1996 honda accord ex
- 1995 LX Auto I4 - Harsh shifts
- Off-topic Forum related
- question???
- Code 16(injectors)?
- EGR Code 80, please help
- Service manual versions
- losing oil in 93 accord lx
- another trans problem '02 accord
- Genuine Honda PS fluid?
- Value of a 91 Ex Coupe
- h22 PS Pump (Searched)
- How to replace entire passenger door (98 Coupe)
- Engine/Transmission Flush?
- '93 Honda Accord LX headers Question!
- making my f22a6 vtec/anybody know about vtec controllers
- 95 Accord Heat Problems
- seatbelt buckle
- need rocker arm assembly torque specs (searched)
- Radiator support replacement
- 93 Accord suspension squeeks question
- 94 accord lx dies after start up or just cranks
- Tow Capacity?
- help with 93 accord engine bay cleaning
- Need help with cable shifter in my accord
- Sun visor install....
- Side Airbag light comes on every now and then
- Accord keeps on dying, and is now dead
- 95 2.2 in 92 ?
- 98 accord sedan
- C-Pillar Bar Install
- Looking for help with timing belt/water pump
- Neuspeed Race Springs Help PLEASE!
- timing advance curve adjustment with hondata, crome, neptune etc
- need part number
- 2000 honda accord problems---need help bad!!!
- h22 timing
- 1994 Honda Accord LX Dies While Driving
- blower motor removel
- Amsoil on a high mileage Accord??SHOULD I?
- OEM oil filter - same as Civics?
- Pulsating gas problem.
- Mugen Front Bumper
- 92 accord engine turns over but wont start.....
- brakes
- 2002 accord lowering question?
- Honda Accord Heating Problems.
- Check these axles, which one should I get?
- IAT Sensor on 95 Accord LX non Vtec
- L reg no fuel flow wont start!Please help me!!!
- accord bogs down after warm up ???????
- F22B jdm prelude DOHC into fifth generation Accord
- Lower control arm bushings
- help
- Noisy AC - '96 Accord EX v6
- ZR Headers w/ O2 Sensor problem
- jr supercharger?
- 1995 accord non vtec
- Check Engine Light
- Re. 93 accord electrical problems: wipers, dashlights, hazards, and passenger window don't work
