View Full Version : Honda Accord (1990 - 2002)
- Accord fuse box
- problem w/rpms's bouncing when in park
- can someone explain engine diffs to me
- intake backwards?
- Question on the exhaust for a 98 accord
- What is need to change the fuel pump a 1994 accord?
- HELP! Installing intake on 96 Accord LX
- Auto and manual radiator
- strut mounts
- 93 Accord LX, overheating, and heater core question?
- Fixed my shaking, poor idle, squealing trouble
- Bye Bye auto trans
- Insurance Repair Question
- 93 Accord code 6
- gude head package
- Problem With Car Temp
- RPM tach needle fluttering....need help!!!
- Factory Wing
- wierd temp guage activity- thermostat?
- Dim Drivers side headlight
- H22/Accord question... Resistor pack.
- Timing Belt
- Hey Rotary Buzz.
- Nankang Tires.
- 1-Piece Headlight Installation on a 92 Accord
- i think i figured out the constant shaking in my car, read on.
- noobie.... laugh at me
- Need Help Unsure
- Tune up?(what do i need)
- h22a swap
- 96 LX Accord Coupe, Improvements?
- Srs
- where is your factory temp needle sitting at during regular driving?
- Rear Drum Disk
- What Size Socket to Remove Axles on 92 Accord?
- Where is the ILDE SWITCH?
- Charleston, SC meet- GA/NC/VA/FL/SC/TN EVERYONE COME!
- Eibach pro-kit to low in rear
- Best place online to find an engine
- Just purchased a 2003 Accord Coupe, best place to buy Honda accessories online?
- PCV Valves, Spark Pulgs, and Brake Pad
- for those who rebuilt thier transmission please help!!
- did search. 88 accord bolt pattern
- f-series h22 vtec head swap
- c-series engine questions
- OT:Finally a lips for 01-02 accord coupe..
- OT: What was "ZeroForum"?
- 92 Accord Stalling (ECU code 15)
- f22b dohc water pump
- Driver Side Interior Panel ( 91 accord )
- Why does TireRack have it like that?
- rpm's are bouncing at idle. what is wrong??
- speedometer out of wack!
- Valve Guides
- NSX Caliper
- Transmission Maybe
- Different Speedometers for 4th gen?
- Is it just me or do all accord motors have that rod knock/ piston slap sound?
- Merry Christmas
- speedometer question
- HELP...i have a question about the AEM cai
- anyone selling their springs?
- WHAT THE HECK?!? (speedometer and indicator light issues...)
- VTEC indicator
- blown motor
- where to get jdm parts for 4th gen
- good shop in NK for h22 swap into accord?
- 5th. gen Power steering problem ???
- Merry Christmas Everyone
- 4th Gen Accord over heat problem
- Big Important Timing Belt Question
- passing smog.
- Accord engine specs...help.
- Still got oil in my spark plugs
- how do i hook up my water temp guage
- Window problem - 94 EX
- Where to get a complete service manual
- How much was your Timing Belt?
- The Euro Accord could be coming into North America.....
- Helical Limited Slip Differential
- Supping up a 2k Accord F23a
- Clutch problem or not?
- size of the tire on a stock 4th gen accord?
- It cuts off while driving
- Aftermarket parts for sale
- Bump stops
- Good pedals for auto-x?
- WINTER temperture and auto trannys (90-93)
- 99accord ex v6 egr fix
- Does anyone have pics of Accord wheels...
- Will a 95 Accord leather interior fit in a 92
- Exactly how LOW is your Accord?
- Nitrous install
- cv boot/axle?
- highest comp. "shelf" piston for f22....?
- Front turn signal lights
- Apexi SAFC question
- Please Read ...... SWAP
- dead pedal
- Bullfrog by Gude
- Would this hurt the tranny?
- F23A4(99)-F23A1(98)
- Header Flange Gasket..
- pcv valve question...
- where can i get an h22 cheap
- tach installation
- 95 v6 accord manual tranny swap (progress)
- Heater turns off by itself
- lights out on my 91 accord
- NY/NJ/CT Tristate H-T Meet
- Routine Matinence ? What should be done
- Awkward "burbling" sound coming from exhaust
- turbo my 6th gen? I have a prelude tranny (shorter gear ratio)
- fuse box location
- what to do if heat it stuck on!!!
- oem wheels
- Noob in the house.
- f22a rods who makes them
- damn indicator is always on
- Timing issues
- OT: HandaAccessories
- SRS Light Always On
- Service light reset switch
- Lazy turn signal.
- accord race car
- Codes please help!
- Oil pressure sensor
- 95 honda accord engine code
- Right front end pops.Help ASAP
- 97 Accord Trunk Question
- 1987 Accord, Are there any things I should know about it?
- help - 1997 accord lx - why isn't the car moving?
- ECU help. info needed for future H-C accord
- which tranny to use? f22 or h22 tranny for boost....
- A6 and A11 Pin Locations
- Best place to find oem 98-02 4 lug accord wheels?
- Pulling Codes
- 95 Accord EX Vent ques???
- Ran into the CURB!!!!!
- need sites
- Sway Bar Links and Bushings
- Stripped Screws
- Framed O2 Sensor!
- 91ex automatic tranny problem, shifts hard
- 1989 Accord LXi blown auto tranny - anything special?
- Help - V-AFC Tuning Issues For 94 EX Coupe, 4 Cel's Deep And Counting...
- New to the forum
- battery questions
- Camber Kit
- Throttle Body Spacer.... Pt. 2
- need some tips on nitrous?
- upper grill for 92
- sylvania silverstars for accords?
- Fender install
- Looking for a Fuel Pressure Regulator
- Windows...HELP...ASAP
- Accord hesitates from a rolling start
- My accord squeals!
- Tranny went out today
- Speaker Wiring, need help ASAP!!
- Chassis Codes
- h22 with bump shift conversion/swap???
- removing anti-lock brakes
- Car shakes on the freeway...help!
- plannin on gettin new motor or somethin like that?
- Installing Brake Rotors
- Looking for Genuine Honda Accord Hubcaps ('90-'93)
- Ignition Problem...
- OT: any 6th gen accordian got a lower tie bar?
- 2000 v6 check engine light?
- Blower Motor Switch
- I'm back. Post your tires and tire pressures
- Camber kit question for 5th gen wagon.
- Engine rebuild suggestions
- late 80's Accord, what size are the bolt patterns?
- Bracket for headlights
- Where to find used OEM Parts
- Driving around W/O VTEC?????is it bad??
- Over heating honda accord =(
- h22 accord
- just installed intake, and have a question
- Can you help me ?
- where to buy pre-painted bumpers?
- Headers vs Stock manifold, '96 LX
- Tech question, 1998 Accord LX, how do i get the maint req'd light to go away?
- '96 EX Exhaust manifold vs headers for my '96 LX
- Suspension Done!!! (for the most part...easy stuff left)
- Ok, HOW do you install Tie bar?
- Let's talk longblocks.. H22 specific.
- f22 ecu number?
- Pullin 2 the right
- high compression ???
- newbie here
- cheating
- damn another prob
- N/A Accords
- Opinions on Aerospeed Mufflers
- whats a good generic CAI/SR
- just got an 03 ex v6
- F22 DOHC in my moms accord..
- need help, broken stud on valve cover
- OT: Some Requests
- fuel starvation with stock F22a injectors and worked H22a?
- 94 Accord shaking at idle...where is the idle screw???
- Accord Newb
- Engine shaking at the normal rpm
- What causes the brakes to push back when you apply them on snow?
- FYI: OEM F22B2 Rod vs Eagle H-Beam H22A1 Rod
- Replacing studs
- CrankPulley bolt on a F22B1
- Air Conditioner Filter
- oil pan
- Please help with some part #s
- 93 Accord radiator? questions
- Hello! New to this board...
- h22 pistons in f22?
- h22 motor swap
- engine swap?
- 03 Accord Headlights
- HID conversion
- 6th gen koni yellow perch setting question
- Grr Water in Lights! Not rice either Help
- question
- Sold the Accord
- anyone know...
- Steering problem
- electrical dilemna... need help ASAP
- shaking steering wheel, and no its not the rotors!
- Would this give me any extra power?
- what is this part? and how important is it?
- V-AFC hi Throtle with Nitrous
- wiper washers not working
- CAI for 4th Gen Accord Question
- 95 accord manual tranny swap questions
- NO VTEC. Help
- Tranny Swap
- Sorta OT.. this is for anyone with a 98 up Honda Accord Coupe
- should i sell my accord?
- VTEC kicking in???
- problem installing CAI on 4g accord...
- Stock Engine With Boost
- thing to hold throttle cable against the throttle body the metal tube?
- motor code for 94 accord
- JDM Accord SiR
- Torque pistons
- Limited Slip Differential
- Hayden Tranny Cooler
- Momo Steering Wheel
- cat-back exhaust
- How-to on installing springs/shocks?
