View Full Version : Honda Accord (1990 - 2002)
- Engine Light Blinking, Stuck Boots, Changed Plugs Rotor Wires Distro Cap, Wont Fire
- 90 Accord Motor Mount help
- rust convertor on brake lines?
- Coilovers
- my brother is a dumbass
- 93 Accord, partial brake lights not working?
- 92 Accord coupe front end/clip/nose swap
- Best H22 custom header
- 01 Sedan front end conversion
- f22b1 to f23a1 swap 94 accord ex
- Bought a 91 for cheap, now to troubleshoot. :(
- code 9 cyp sensor problem
- LED LIGHTS....BLINKER QUESTIONS
- 2001 Honda Accord Transmission
- My 01 civic loses power when trying to pus the gas peddle
- Best Spring/Shock combo for DD Accord Wagon
- looking for H22 for 92 accord
- Miles before changing timing belt
- cb7 auto to manual
- NOOB Help!
- transmission replacement
- P0420 99 Accord LX
- help a girl out
- Any kind soul out there able to help with an egr problem?
- girl in need of answers
- 1997 accord shifter cable problem
- 96 Accord Burning Oil - Swap Options?
- 2002 honda accord 4cyl woodruff key
- No heat - 96 civic
- 2001 accord d4 light
- 96 accord brake light for E brake stuck on.
- 90 accord distributer
- 90 Accord no acceleration?
- H22a into 94 coupe injectors wont fire
- JDM automatic transmission compatible with USDM?
- 1990 honda accord CEL
- 1999 2.3 vtec rocker arm diagram
- What size would fit?
- over heat
- 92 honda accord ex 2dr, 94 accord 4dr suspension swap
- 94 accord A/C power issue
- How do I know if my timing belt has been replaced?
- '90 ex stock....what size tires!?
- new owner
- Throttle Body on 2000 Accord Coupe
- Can you guys help?
- 90 CB7 swap H22A4
- 1996 Accord DX P0335 CKP
- Need help with main relay on 2000 Accord
- accord v6 trans swap .. help!!
- 1995 Accord Speedometer not working.
- Car won't start
- 91 Accord EX tranny goes out while driving
- Normal Shift points?
- 95 accord A/C & Heat bad odor
- need help with 68mm auto skunk2 tb
- 2002 Honda Accord Trunk Leak
- I just cant find what I need.....
- Injectors came back with an extra piece...
- need help with these timing belt instructions...
- '90 accord cuts out while driving..wtf!?
- j30a1 head bolt torque?
- 94 f22 into 96 lx
- My accord has got a 20 mile range
- losing power
- Airflow Problem 98' ex
- Transmission explosion
- 1992 Honda Accord electrical problems
- Rear Tire bump wobble
- f22b1 rotation direction?
- 1996 Honda Accord EX engine swap
- 2001 Accord Heated Mirrors
- 1993 Accord: Ground wire locations?
- Honda Accord 2000 EVAP Emission Control System
- Changing the auto shift 'knob?'
- Level of difficulty?
- 92 accord f22 - h22 vtec swap
- 1990 honda accord starting issues.
- japanese cars a/c and heater.
- p0171, p0170, p1297
- Accord doesn't start when cold
- 96 Accord w/ F23A4
- 1994 accord rpm issue... Help
- Oil Pressure Switch Size
- 94 accord gas help
- Free tuneup from honda dealerships 95-97
- Cooper Weather-Master S/T 2
- 1994 Accord EX Runs with Non vtec ECU... Will not with Vtec ecu
- right and third brake light wont work
- Hi. I'm new here. 97 LX wagon noise issue
- thinking about buying a 1998 accord EX 3.0 V6
- 94 accord wagon build
- 99 Accord F22 swap for RSX K20?
- spoiler fitment?
- HELP!! Fixed broken timing belt - now it doesn't run!!
- Rough idle between 700rpm and 2500rpm
- Fseries stockish build beginning - input appreciated!
- f22a PT3 head
- 2000 Accord Vtech P1149 and P1399
- Issue with a fuse
- Honda Accord EX 2001 Radio Code
- does anyone know how to fix the window popout
- 94 accord lx advice
- jdm cb4 oil burn
- Looking to buy a '97 CD7 EX, but what about the tranny?
- 97 Accord
- brake/clutch line fitting sizes?
- question?
- Head H23a Blue Top for H22a vtec Block ??
- 1997 accord lx coupe project
- Paint Car with Rattle Cans?
- searched and searched... f20b swap keep obd 2 legal
- Radio code
- 1990 honda accord ex starting issues PLZ HELP
- Speedometer issues
- faint noise from my 2002 accord
- 94 Honda Accord LX Overheating . . Possibly dying slow painful death
- what the heck is the difference!!!???
- question
- Where is the ECT in CB7?
- 91 accord H22 swap p/s line adaption.
- d16 in 92 accord??
- 90 accord ex steam problem
- setting base timing on a f22b1??
- 04313 rotor right for F23A4?
- SRS trouble code 51... what to do?
- 94 Accord CEL question
- 96 Accord EX P1300 code
- '90 Honda Accord LX :sputters slightly then CK eng. light,then runs ok?
- H22 head on f22b block
- new car 95 accord please reply
- WHEEL HUB CONVERTERS
- pan gasket
- 1997 honda accord lx f22b2 to f22b1 head swap
- Timing belt replacement as well as...?
- 1992 LX running issues.
- trouble starting car after replacing timing belt and water pump
- 94 accord , need advice..
- Spring Pad
- Starting problems now with swap
- checking the BS radar
- H22 90 Accord Blue Smoke .. HELP !
- fuel pressure regulator on '93 accord ex
- clutch pedal wont come off the floor
- '92 Accord, TCU problems, D4 light stuck on
- H22A4 Auto into 5th gen/ odyssey I assume
- 98 accord, opinions please
- Fixed longrunning idle issue by cleaning alternator connectors
- Wired wheel squeaking
- 96 accord p0335
- Rear Balance Shaft Seal
- Honda Accord brake disc corroded or defective
- HELP!!! 94 Accord
- Lots of moanin and groanin up front when turning
- f22 motor with a h22 trans ?
- 98 prelude springs on 96 accord
- Front End Squeaks - Only when it rains
- Torque spec - vtec oil switch
- 1995 rear wheel bearing w drum brake
- Caliper install
- Hood replacement 1996 honda accord 2.2L
- final drive gear choices
- Radio isn't working!! Please help! 1991 Honda Accord LX
- 1990-2002 Accord FS/WTT/WTB (Oct - Dec 2012)
- '90 ex (2radio) wires touched, now pwr seat belts dont work!?
- Removing stubbern o-ring seals
- 98 Accord LX issues, not starting
- 92 accord need help ASAP
- f22b1 engine and a f23a1 trans?
- Car overheats when driven
- counterbalance seal
- What mpg's are you getting from f20b swaps?
- Oil leak on f22a1
- Need help bleeding brake line on 94 Accord
- Gas mileage issue, any ideas?
- 94 Accord Interior Lights Fuse Blowing
- transmission
- Lost dash, taillights. blown 15amp fuse
- 90 Honda Accord stalls & shuts off when braking or driving downhill (@ < half tank)
- '92 Accord overheating problems
- Replaced Main Relay now battery is dead
- Tasauto.com ??
- Help converting IAVC 3 to 2 wire
- Somebody help a playa
- Auto to Manual wiring
- New Oil Press. Switch Not Working Right!
- Possible HG issue, need input.
- Replace front seats with a different model
- 96 Accord LX has intermittent split-second power fall-off
- Interior swap question?
- defective knock sensor?
- 97 accord with c27a4??
- 99 honda accord acceleration problem
- How to Replace Oil Pressure Sender
- F20b swap need to know what to buy!!
- 2001 Accord JDM Used Engine
- 00 Accord Problem- Tech help please!
- Ok I know this question gets asked all the time
- Tire wear and new struts... See pix need help
- What could this be?
- electrical issue no brake lights/horn (90 accord) plz help!
- screw in egr vacuum hose
- 4-1 manifold atr
- Driver side wheel bearing repeated failure <1yr. Theory& possible explanation.
- 2002 Honda Accord V6 -- Idles High When Cold
- Moog Front Wheel Bearing
- Speed sensor plug wires
- Need a Lil tech help please
- Trunk security for 94-97 Accords
- $170 denso starter vs $80 duralast
- Build or Swap after 300k?
- New accord owner driversside windows not working
- Stuck Shifter 98 accord
- Failed Emissions 95 Accord -- High CO
- 93 Accord Cutting out while driving
- 99 accord 3.0 v6 vtech drive shaft whine
- 1995 Accord Wiper Malfunction
- 99 accord EX V6 internal oil filter???
- 92' Accord Transmission Issue?
- am i correct?
- My 1990 Honda Accord LX.
- questions about replacing 1999 accord starter
- 1999 v6 accord engine swap
- Seeking Honda Wiring specialist
- ECU compatability
- 98-2002 Accord V6 need to ID motor
- 99 Accord Steering Wheel Control Problem
- Gas gauge not working properly
- 95 Accord EX Idles high and rev's when put in park!
- 1992 ACCORD BRAKE LIGHT AND DOOR AJAR LIGHTS
- 96 accord iacv questions
- F20B question
- trans swap cv axle ?
- F23A1 VTEC oil pressure switch
- Accord 1996 Radiator
- opinions on cv joint replacement
- '01 J30A1 Windshield wiper system malfunction
- Non-adjustable shock with race springs
- Weird mechanical sound/resonation in steering wheel
- 94 Accord LX Dash/Interior Lights Wont Work
- Idle problems with swap and chipped p28
- rsx type s swap in cb7
- 2002 Accord LX burning oil after fresh rebuild
- Recommendations on oil
- Do I have to rekey? AT to Manual, 2000 Accord
- 99 accord tries to stumble when coming to a stop
- 1994 Honda accord lx
- 98-02 front seat question... coupe/sedan the same??
- Cons of adding the removable Cat Back silencer
