View Full Version : Honda Accord (1990 - 2002)
- F20b specs??
- Valve noise F22b
- removin the map light
- Where can I Get Exhausts Done?
- Dash Lights, Cluster Lights, Tail & Fog Lights are gone
- H22A JSPEC Motor From Prelude to 94 Accord DX
- Fuel Gauge Light Duration?
- knock Sensor
- Comptech supercharger in V6
- 2002 accord 4 dr head lamp driver side very low beam.passenger side normal beam
- Need some help fast Accord motor idles really wierd!!
- 98-02 accord tranny (4cyl) should have recall! does it?
- 2006 - 2007 Honda Accord Bumpers
- Tune-Up Question
- turbo help???????!!!!!!!!!!
- Engine Timing Shenanigans
- Question about wheel offset, 17x7 mags (6th gen)
- 07 feels like i'm driving on a bad surface.
- Balljoints
- Automatic Seat Belts
- Idle Problem
- H2B for Accord?
- Getting into a 1995 honda Accord
- Need radio code
- 1995 accord valve specs? f22 need some help
- White Face gauge install on a 94-97 accord Ex
- overheating problem 97 Honda Accord EX V6
- F22b2 Turbo injectors ?
- How hard to remove a steering knuckle?
- Cat Rattle
- 1991 Honda Accord "S" light
- ELECTRICAL PROBLEM
- Accord automatic "Sport" mode in an Odyssey automatic? (F23A7 2.3 VTEC)
- bought f22b
- Engine Noise
- 97 accord LX radio
- First Post/Greetings/Questions
- Help with 91 Accord???
- Clutch coil... What should I do?
- rear seat...how do you remove it?
- damn potholes (with pics)
- 1997 front rotor change
- NEED HELP ASAP!!!!
- Engine cuts off after start? Any ideas?
- cluster change
- Vacumm Gauge Volt Gauge And Air to Fuel Ratio GAuge
- Oil Drain Plug Washer Size for 97 Accord
- What synthetic oil is best for the engine?
- help wit 2003 honda accord
- accord suddenly stalling
- New to h-t.YAY!!!
- Any good shop in Cali....?
- 96 accord h-22 swapped!
- Looking for the Cd squad
- engine
- 92 Accord Raw gas smell at idle
- changing the front rotors on a 2000 accord...
- 96 honda accord wont start
- tranny issues?
- How to rebuild a distributor
- Where do you buy your parts?
- h22 hesitation, sputter.
- good website to buy engines??
- Where Can I Get Fender Lights...???
- 96 accord door locks?
- short hub adapter
- 1991 Accord Noises
- AC issue - blows cool but not cold
- Turbo kits for F22a
- which exhaust pipe is the "B-pipe"?
- Cold air vs. Short Ram
- Lowering
- 92 Accord Hesitation
- JDM front bumper question..
- Rear Seat
- Need engine bay pictures from a sohc vtec accord
- 92 accord TCU
- F20B Swap Drama
- Simple solution, to a very complex problem
- 2004 accord blower realy
- 89 honda accord lx
- 1990 accord will only start with boost...
- 96 CD7 w/H22A hesitaes during 2000rpm and 3000rpm
- Tein s. tech or H&R sport??
- Head bolts
- Torque steer question?
- Attention all 6th generation Accords (98-02)
- 91 accord ex fuel problem
- Engine cooling fan
- transmission fluid, how to clean
- Changing out the engine harness - 6th gen...?
- What to look for?
- gear shifter problem
- Fuel Pump Wire Question!!!
- Taking out the radio...
- Knock Sensor - Here we go again...
- 95 Accord DX speedometer problems
- f20b junk so now what?
- HELP! battery light won't go out no matter what
- ebay spoon and mugen
- Bad igniter or Bad ignition switch
- air filter hole/tear/what ever you wanna call it. re-usable? pics
- Need to be clear about this msd stuff
- vtec pressure wiring help
- bad vibrations during acceleration
- Admins Read This
- Starting problems.
- how to port
- Me + AutoX
- suspension setup for 18"s
- car won't turn on
- Looking for 2000 Accord used catalytic converter
- "courtesy light" for 2007 accord sedan
- how do you put eye lids on accord headlights and do they have to be 1 pice kind?
- spark plug gap question F23
- Alternator / Transmission issue?? please help!
- CD Squad...site is up...check out our pics
- Thin Radiator Crack, what's a solution?
- 92 accord, can't get drivers side half shaft nut off, HELP!!!
- H22 ecu
- civic and accord gauges
- engines???
- good ecu for f22a1
- mugen and spoon
- cruise control
- 94 accord auto transmission question
- Gauge cluster light replacement
- maint. light?
- Best Exterior Style??????????????
- 88 accord motor swap B21a1?
- AccordexR 97 for sell
- 1991 Civic DX...Power Steering
- Changing battery in 03 V6 Accord
- having a/c recharging issues on a 91 honda accord
- 92 A/C not working?
- 93 H22a Internal Coil Dizzy using a 2000 Civic SI cap n rotor????
- H22a OBDI in a 96 Accord OBDII
- exhaust system
- 1998 Honda accord Ex CV Boot
- distributor going out?? on cb7
- need a picture
- car stalls after 20 minutes
- supercharged
- Car sounds like an airplane underload. (friends car)
- Any tricks to bleeding the clutch?
- Oil in the Distributor
- 98 EX - changing climate control to digital???
- Is it possible to disable the 98 accord demobilization security system??
- 96 accord engine improvments
- oxygen sensor
- how to make my 98 v6 accord faster
- Accord Trouble Code..HELP!!
- 1990 accord brake loss
- H22A Swap error codes 41, 12 cant get rid of it!!! HELP!
- vacuum hoses on 86 accord look horrible
- Sound Deadening
- accord 98 ecu error code 45
- outboard cv joint
- 97 Accord EX not starting
- ABS Bleeding
- Quick Question about cylinder heads
- Tranny Fluid smells like crap
- Help with window garnish on 2003 Accord Coupe
- Changing MTF
- is this chip really working?
- 7th generation people, what chipping or management system do you using?
- tuning questions
- 91 Accord acting strange.
- engine getting to much fuel
- Functionallity......
- Short RAM or Cold Air
- Noob..asking how to convert from Auto to Manual
- DIY on head gasket?
- Perfomance Increase 88 Accord EX.
- Radio/Lighting Wiring Question....HELP
- 1993 Accord Lost Engine Power, ALMOST CRASHED!!
- '92 ex and '88 lxi compatability
- gauge cluster lights dont turn on
- Checking codes--98 Accord OBD2 with OBD1 swap and a P72 computer?
- Need help with my 2001 Accord..
- high mileage cd?
- H22 Questions I'm not dumb haha
- 92 accord drum/shoe brake problem
- mileage resetting
- I need help
- alright guys, i need help pretty bad, 95 accord swapping a 98 prelude motor auto ss
- wheres a good place to get accord jdm rims
- h22 in a 6th gen v6 coupe....
- easy to change fuel filter?
- 86 Accord carberated problems, please any kind of help
- Just replaced O2 sensor - STILL have CEL - P0135
- engine malfunction light
- what something nice i can so to my accord for 40 bucks?
- Stock Ride Height
- AEM V2 on a 07 Accord Coupe 6MT
- TourinAccord - Where purchase to parts for Timing Belt change? Need to cross ref part numbers.
- honda accord light
- car vibrates when in reverse
- BIG TIME PROBLEM
- which would be better? new dizzy cap&rotor or upgraded coil
- F23 turbo - any need for EMS? - 6psi...
- Top Speed
- How can I increase power for my 2002 accord V6, so that I would be able to go a 1/4 mile in 14 sec.
- cluster lighting
- 96 accord ex, one motor is out from the power seat
- 6th gen timing belt/water pump - any need for tensioners, etc?
- transmission 92 lx overdrive light
- going to buy a 250,000 mile accord
- will 92-96 knuckle assemblies fit on a 90-97 accord
- coilover question help
- high-pitched whine at low acceleration
- Gas and Temp gauges problem, and other ...
- misaligned or something worse?
- 93 Accord problems help?
- theres a spirit in my car LOL
- Contacting civicfixer
- 97 accord?
- s2k steering wheel into a 5th gen.
- prelude sh rims fit 97 accord?
- 95 honda accord 2.2 vtech automatic
- cheap and reliable replacement of timing belt package for 99 Accord in Atlanta
- b1 head goin on b2 block
- SUPER GEAR LIGHT STAYS ON
- I nEed Someone to do a VTEC coversion for me PLZ!!!!!!!!
- ANYBODY KNOW HOW TO DO A VTEC CONVERSION!!!!?????
- What will fit in my 1999 honda accord
- Replacing Fuel Filter (can't find service bolt)
- h22 wiring
- 2001 Accord - Reman Transmission and ATF Filter
- lips kit for a 94 4 door accord
- Gauges on 03 Accord
- alt. belt with ac removed
- turbo questions
- 95 accord odometer
- left axle....is it supposed to do this?
- front end problem
- distributor issues
- installing neons and I have a question
- selling and shipping a car....
- 98 accord F23 auto.... main relay??? where is it?
- Another A/C problem
- Complexity/Compatability k20a into 5th Gen.
- New to tuners
- AEM Cam Gears
- Removing rear seat on 92 accord
- Loud Screeching Noise when starting Car?
- manual flywheel weight
- 03 Accord ABS, TCS lights
- EGR
- air intact
