View Full Version : Honda Accord (1990 - 2002)
- D4 flashing , car no starting
- 92 Accord won't start
- idles really low
- New To H Accord, need advice on oil and filter change
- drum to disk brake
- Car won't rev past 2k
- Rolling the Fender
- Tran Swap
- how do the f22 in a accord turbo run?
- Honda Stock or Kyoba Struts?
- Interstate Batteries = Trash
- Transmission Question
- Good price for a H22 swap?
- WTB: Accord 94-97 EX passenger side fender (link) ASAP
- 90-93 Body kit question
- SEAT BELT ISSUE
- clutch question?
- wideband o2 sensor
- header question on h22 swap into 92 accord
- Has This Ever Happened to YOU???
- 60,000 mile maintenance service?
- Vigor Leather Steering Wheel Fit?
- Help - Noise at 40mph on 97 Honda Accord
- 6 Speed Swap
- Car making squeaky sounds.
- noise in rear wheel
- 03 Accord Ex Coupe 4Cyl
- JDM of USDM which one do i buy for my accord 6th gen
- ant techs got any ideas for this no start
- exhaust q
- Car is not starting when it is hot outside .. what is wrong?
- 2002 EX-V6 Stock Rims Offset vs 2002 Acura CL type S offset
- 96 Accord ES Security Bypass
- headlight sanding/clearing
- Hybrid tranny question
- Car rumbles when stopped...for 98 Honda Accord
- 95 EX, no spark
- Advice: More power for a 4th gen
- Planning on 17s, wondering about tire sizing
- engine build info.
- Resonably JDM priced engines....
- shocks
- 1980's Honda Accord < 30k miles
- 92 LX Wagon Need Help...
- Tranny Click.......
- Accord Heads..Where to find them?
- Help My 1990 Accord Trunk won't Lock/stay closed
- Toped out my accord tonight
- Removing cd player
- accord timing belt issues
- What size is the rear and front speakers on a 1990 Accord EX 4dr?
- which rods
- Wheel Bolt Size on 2003 Accord
- Turbo Fitment on DSM Turbo Project.....
- Any easy practical mods to do on a 94 wagon?
- Fuse keeps poppin
- Just Curious..............Rust Issue.
- Running sluggish....
- How reliable is an H22 swap?
- 99 accord v6
- tempature problem with my engine
- head questions
- Starting problems
- Need help on what to do with either a 96 v6 or i should turbo a 4 cycl
- Clicking Whirring Noise
- Problem w/ jdm f22 (obd1) motor into 96 accord lx
- NEED HELP BAD, Stopping Distance help...
- Motor swap
- !!!!!!!!!!!!!!!!!!P28 with H22 program!!!!!!!!!!!!!!!!!!!!
- coilsprings
- How to replace starter on a H22a1
- Cruise control Diagram
- 87 SOHC timing belt wants to walk off the cam sprocket
- 91 Accord stuck in park then doesn't shift right after override
- Timing Belt Replacement Balancer Shaft Seal
- Cheapest exhaust for a 90 Accord.
- Handling/Steering Question
- '93 4cyln. not starting when wet...
- ABS warning light reset
- So I was at the drive ins....
- offset and bolt pattern / 17's
- 91-LX-may B prob with electrical wiring?? requsting help...
- Pistons and Rods for F series...
- 92 Accord: Automatic Transmission Problem
- CLUTCH QUESTION
- Replaced Ignition Need Advice
- P/S Pump noise and chirping sound when steering
- Interior/Tail/Corner lights not working on 91
- h22 in 2000 accord
- squeal when fist turn on car and when ac on
- Replaced axles, H22 swap, have vibration underacceration
- Front Stabilizer (sway) bar removal?
- Window Problems, HELP!
- Door wire routing
- h22 head swap on f22a1
- Accord Shifting Problems?
- 1985 honda accord ticking fuel pump
- Rattling Noise upon acceleration... 96 accord EX
- 04 EX V6 nav question
- 1982 Accord in need
- Im about to purchase a f18b engine with h23 tranny?
- CAR X Performance Exhaust
- Price for an 04 Accord EX (purchased for my wife)
- body kit
- Easy to buy
- rims
- Drop in oil pressure
- Best place for relay?
- what type of trany problems do acura tl's have?
- Does anyone have 2000 SE 4DR Rims for sale?
- PUNK FUCKER KEYED MY CAR
- New Power Pulleys, now battery is goind dead...Help!!
- How long will my tranny last with a turbo???
- brake lamp light
- wat's the F22 vtec 5spd tranny code?????
- R134 retofit qestion
- boosted 5-6 gens help me!!!
- How much power can the accord autobox cope with?
- 99 Accord - camber kit?
- Antenna question
- Is the F22 a closed deck???
- What are the steps for replacing radiator in 1993 accord with auto trans.
- 92 DX: CEL then no power
- Whining noise coming from the belts...
- Accord with dyno?
- 94-97 accord CD3-CD9
- Where is the plug for the OBD II scanner on a `97 4 door?
- Relocate 99 Accord ex Head Unit
- what is this????
- need help on cv boot....pppllllleeeasseeeeee (86 acccord lxi)
- f23 turboed need help
- RACING CHIPS FOR ACCORDS
- Prelude LSD automatic > Accord
- Crashed!!!
- Lowering 98 Accord
- Weird Humming coming from unknown place in engine bay.!!!!!!!LOUD!!!!!!!!
- Check Engine light on 2000 accord ex
- f22 idle
- 95 Accord LX power problems.. **HELP**
- RSX Steering wheel???
- Road rules of Florida
- Accord Engine Swap Question: 6th gen accord 4 cylinder manual to 6 cylinder?
- coilovers?
- Get REAL power with UNICHIP
- 02 Accord: Changing Timing Belt
- window won't go up
- A/C Help???
- 94 Honda Accord LX
- Changing Oil?
- 96 tailight
- f23 help
- Getting ready to buy the Helm's manual, got a quick question
- Honda On 19's.
- Dash lights are all on
- 2004 V6 V-AFC question
- Accord Turbo Concerns: SMOG test (california regs) and being street legal.
- Looking for a BODY KIT
- cold water on my driving foot??
- price on f22 manifold
- post your 03+ accord pics
- Need help H22 or H23?!?!?!?!?!?
- Accord forums
- a couple of questions for 5gen owners.
- 2004 accord v6, how do you reset the maintenance required light
- 2004 Accord HIDs?
- is 35 shoot safe?
- gap between headlights and fender
- Apexi World Sport
- JDM or Look Alike
- Age Old Question
- My check engine light is on, where can i get a cheap(free) ODB2 scan for my car. more info inside
- how do i remove the factory stero??
- WTF would make this happen?
- what could hapend if air get in the power stearing pump
- Power Door locks do not work on the rear doors
- where do I get info on turbo charging my car
- Car shakes when I hit brakes
- 2003 Accord v6 6-speed upper front strut bar
- DUMB QUESTION..
- Cruise Control Out
- 98-01 MUGEN front lip doesn't fit 98 DX front bumper
- stock air intake...bolts missing
- Planning on getting a accord coupe (98-00) hesitating between i4 or v6..
- Brake Lines
- 2002 bumper fit onto 2000 accord???
- What is a good drop ...
- Accord EX 2004
- shaft orientation after belt replacement 93 honda accord
- my car engine went off while driving, who knows what the problem is?
- How hard is it to swap in a new auto tranny?
- Which Stock Accord Rims Looks best???HELP
- removing headlight kit
- What Radiator to use with H22 Swap in 5th Gen Accord???????????????
- Turbo on a 75k mile engine
- Steering Wheel vibrates at 40mph
- Can you guys troubleshoot this starting problem?
- FS: Some stuff off 90 Accord EX
- Spring Shock matching
- eibach sportlines question
- automatic transmission
- side moldings....
- Auto Tranny Acting Weird
- 95 Ex Starts fine for weeks then ABSOLUTLY NOTHING
- A/C shakes car and lower RPM
- Magnaflow cat-back reviews
- best places online or in NYC to get wheel/tire combos?
- WTB-- 1998-02 Accord SE wheels
- ::OT:: Anyone have a pic of their magnaflows on a 5th gen?
- Fuel Gauge Stays at Empty. Plz help.
- h22 swap has issues.
- Rotors!
- accord to prelude compatiablity (spelling?)
- H22 not worth it.
- 96 V6
- 1996 Accord EX-V6 Torque Converter
- Ecu Swaps
- Skunk2 Intake manifold doesnt fit.
- New kid on the block.......looking for help w/ my 91 accord(stick)
- Stereo removal - 95 Accord Auto LSi
- Wipers Out Of Control
- FNG w/ a cooling problem
- speaker sizes
- CLUTCH HAS NO PRESSURE
- h22 problems
- Tires
- Bolt up Automatic LSD tranny?
- Need Help.. Car keeps dieing
- 2003 Accord 2.4 Type S Saloon UK Spec.
- LSD tranny
- what aftermarket clutches are you using???
- 2.2L or 2.3L
- 94 accord auto tranny slipping
- jdm type R steering wheel?
- 88 lx Hesitation while accelerating
- needs advice on tires replacement
- h22a swap shop???????
- Having some problems with my clutch
- what is the difference between a h22a tranny vs the f22
- transmission problems?
- Antenna?
- Dust and pollen filter
- radiators, why they suck...
- 5th Gen Accord SiR
- engine swap
- 04 Accord Stock Headlight Assembly AIMING Instructions
- 1993 transmission fill plug
- 5th gen Accord noises :-\
- h22 swap ecu problem
