View Full Version : Honda Accord (1990 - 2002)
- plain curiosity
- how can i pull this off??? D:
- 97 accord 2.7 v6 LOCKUP SOLENOID....HELP!
- 2002 Accord Keeps Stalling
- i have two ecu's but dont know where they belong to, P0F and P0K
- Limited slip LSD ?
- 96 accord with h22a1 no spark
- 94 Accord Half Shaft Problem
- f22b swap into 95 accorrd(f22b2)
- No Clutch Resistance. Please help!
- will oem 4th gen prelude spoiler fit a 97 accord sedan?
- 01-02 accord sedan to 98-00 coupe front end conversion
- will they fit
- Will a 91 honda accord head fit 92
- 92 Accord no start, still...
- auto to 5 speed clutch dampner?
- 91 honda accord need help
- 95 ex no start?
- Power Steering Belt Issue
- looking for general advice for newbie owner of 90 accord 2 dr 5 speed w 153k
- my 93 accord EX
- rewired map sensor now im getting a cel 5
- 96 accord sensor wire diagram?
- OIL smoke after headgasket install on 90 accord?
- low temp, thin density greese??
- F23 Rebuild Question
- 1993 Accord Wagon with a couple of problems
- New 94'' accord owner need help with repairs!!!!! please! og here!!
- Speedometer gear differences between F22 and H22 trans
- TL Type S brake upgrade
- new guy, turbo question
- EGR Question and vacuum questions?? need help
- Honda Accord Transmission Codes & Ratios
- 1995 accord v6 oil pan gasket
- A no start problem that is baffling!!!!
- 2001 honda accord vtec
- How to remove the fuel injector plastic connector?
- New car
- Intermittent gear selector
- Where is this leak? *Pics*
- Car keeps turning off at idle
- EGR valve???????????????
- want to build up my F22B1
- 5th gen No Spark, fuel pump not kicking on.
- Auto > Manual swap
- F22B SOHC V-Tec ID'ing....
- 92 honda
- 96 Honda 2.7 stalls after warm up
- Speedometer Not Working 95 Honda Accord!!!!
- 1995 Accord RPM's violently "Spike"
- 90 accord brake warning light and loud buzzing noise - abs problem or . . . ?
- Roaring noise
- 97 honda accord lx starter just spins
- 88 honda accord
- 2000 Accord Drvr side auto lock problem
- 95 Accord Brake Rotors Replacement
- f22b2 build need help ideas
- Fog Light Install Instructions
- 93 Accord doesn't start
- rad fan
- 2000 Honda Accord VTECH not starting
- still needing ideas
- 92 honda accord D blinking
- tranny swap auto to manny
- Cluch Kit
- Transmission problem?
- A few questions...
- H22 tcu help?! 92 accord
- Botched lower tube seal replacement
- HEADGASKET!!!
- Need help with distributor and iacv wiring for a H22A4 into a 6th gen accord
- 1996 accord drive belts?
- 1991 Accord Code Problems
- h22 accord swap questions, plz help!!!
- Sideskirts
- Two horns on the 97 Honda Accord
- 95 Accord Cruise Control Issue
- Intermittent Keyless Entry Problem
- 1999 Accord CG8 - Steering fluid leak
- 96 Accord LX
- Any Idea where I can find a PDF service manual for a 92 accord?
- f22a4 head studs toruq spec
- weird fan problem
- f20c to h22 trans?
- 16" wheels?
- Fuel Pump gone out?
- no power to diagnostic port 97 accord lx
- Changing the trans fluid.
- 98 accord low compresion
- 1990-2002 Accord FS/WTT/WTB (Jan - Mar 2011)
- h22 swap sensors leftover?
- Dizzy Wiring?
- 93 honda accord trouble codes
- I still have a miss...
- New guy with blinking s code
- Valve Cover
- 96accord h22 brackets?
- Heater Core Replacement
- Burnt once, willing to try again...
- Difference in my Speedometer vs GPS - Help
- f22a1 to h23a1 swap!!
- Shifter Box
- F20B IM/ H22 IM
- Any interest in a power steering pump reseal DIY for a 90-93.
- 91 accord problems need help asap plz
- 2000 Accord- Ignition Switch Problem?
- Map Sensor cb7 h22 swap
- 92 Accord coolant issues
- 92 accord water leak. Not evap drain.
- 92 Accord Auto EX, Shifting Problem
- Broken 4 cyl. Exhaust Manifold Stud
- 97 Honda Accord LX Shifting Issue
- h22 swap question
- 96 accord
- Coilover suggestions
- Loose steering
- CD5 Help
- Jdm h22 penzoil platnium?
- 93 honda accord front end problems
- 98-00 and 01-02 side skirts
- ABS And Cruise Control
- need help starting my car back up
- 91 Accord Motor build
- Start up chirp
- hid headlights are different color
- dire need of help or ideas...
- Fog lights for 01 accord lx
- 92 CB9 + 97 Lude SH..... can it be done.
- Send Me Your Engine Serial Number
- Rear Bumper
- HONDA ACCORD BRAKING ISSUES
- Help with fuel problems
- 96 Accord P1491 issue.. need help
- Lowering
- Window Regulator with no power
- 92 White honda Rims?
- 2001 Accord V6
- 99 Accord EX V6 transmission compatibility
- 95 honda accord c-pillar question
- F22 motor & H22 Tranny, TCU question?? Please help
- Water Pump requires 9 pounds of torque, torque wrench I own is 10-100 pounds....
- Hey Everyone
- DIY Underbody Kits
- DIY EGR job question...
- Best Replacement Radiator? Where To Get It?
- Best camber kit for 94 accord
- Visual recommendations
- Tint information
- Stock painted rims
- radio is on but no sound
- Lower spk seals changed, valves sticking after 45 sec???
- pls help me find the photo or draw of clutch pedal
- Stereo removal- Acura CL
- Stanley Fog lights?
- Car died on freeway, catastrophic coolant loss... 1993 Accord
- Lightened underdrive crank pulley experiences
- H22 type s pistons?
- Idle Problem
- 93 accord foglights?
- 98-02 Accord Heated Seats problem
- ect switch
- 92 ACCORD I NEED HELP
- Severe Oil Leak
- no injector pulse
- 97 CL Questions
- 94 auto not shifting into 4th
- Very hard to start, then dies. Very intermittent
- Accord Immobiliser Problem ??
- Steam coming from front end!?
- Drivetrain noise after new clutch installation
- 2002 Accord 5 speed manual trans clutch system
- I have to pump the gas to start the car WHY?
- 90 Accord Just Died Last Night... Quick Diagnosis, Please.
- oil leak :(
- 7th gen cluster to 6th gen?
- h23a accord wagon
- Engine is way out of timing, how do I safely fix this situation ?
- Accord 1994 Driver Control Arm Bushings Help
- Bad Luck
- Honda Accord 02.?
- 1990 Honda Accord - Car Won't Start, Press Brake Pedal Click from Shifter
- B18c1??
- Honda Accord Problem - 1999 Auto - Creaking from front offside
- Goals set, ready to build.
- 94 accord ex overheating after oil change
- NEED HELP F22B TURBO SETUP
- where do i buy cv axles??
- code 15
- For those that have added new pins to ecu's...
- Need Help 1990 ef swap
- 1989 accord carb question! Plz help
- 91 accord lx "s" dash light
- 1990 Accord, what version OBD is it?
- Car Starts then immediately dies
- Vacum leaks
- trans repair costs?
- Interesting starting challenges
- accord f22b questions
- 1997 Honda Accord car alarm
- no power to the obd port on 97 accord
- help me out some one
- Missing and dying
- Check Engine Code Help
- Third Brake light is acting funny
- Non drastic weight reduction
- ebay turbo
- 2001 Accord LX 90k miles Service
- Accord 1994 Weird Noises from Driver Side
- o2 Sensor Replacement
- Accord 1999 breaks problem
- 91 accord DX, proportioning valve ports
- Honda Accord 1.8 CF3 parts needed
- 1992 CB7 with problems...... need help..!!
- Removing brake MC
- ecu replacement
- ECU # of 2001 honda accord f18b
- How do you know what octane level to use? N/A
- Car dies after warming up
- f22b1 crankshaft seal
- holy junk!! very high oil consumption
- Door lock help
- Loose Nut rolling around when turning steering wheel (2001 Accord)
- Coolant leaking overnight, not on long drives
- Timing belt swap and what else? 02 accord
- h22a swap into 4th gen 91 accord ex exhaust question
- 01 Accord 4dr to 2Dr Front??
- H23a VTEC blue top ???s
- Are the 6th gen Accords OBD 2?
- Help for Accord 1994 Upper Control Arm/Balljoint/ABS
- Map Sensor Problem cb7 h22 swap
- Gas Tank Overfull?
- 2000 Accord Automatic Transmission Questions
- Help with a hose....can't figure out where it goes.
- Help with 3 issues
- Perfomance Suggestions
- 94 Accord EX PCV Tube... can't find one anywhere.
- how to remove 3 connectors from ecu?
- Green Slime... Seriously!
- What octane gas do you use for your 6th gen V6 Accord?
- Honda 2001 accord power window problem
- New Mod's for my 1996 Accord DX with 87K on the clock.
- Tranny Oil or Motor Oil
- Looking for cool black rims
- 2002 Honda Accord Coupe Lipkit?
- Camber help!
- Crankshaft sprocket removal
- 1996 Lx Wont Start When its Hot Out
- Honda accord 1998 keyless entry remote question
- just got me a 1994 accord need ideas
