code 6 on a 1990 lx need some help
Old Jun 13, 2003 | 10:09 PM
sacredc0w69's Avatar
Default code 6 on a 1990 lx need some help
well i got a code 6 onmy accord
Coolant temperature, so i figured i'd replace my rad fluid and put in some new stuff
so i did
and i only got the code when driving really really long distances 100+km w/o turning the car off, mostly during long long expressway driving
so anyway, i changed the fliud and went to wonderland, and be4 we got there i got the code again, so i dunno whether i should get the entire curcuit and sensor checked or what?
what u guys think it is?
the temp gauge shows everything normally, nothing overheats atall or anything..
what u guys think?
Old Jun 13, 2003 | 10:52 PM
im_the_teacher's Avatar
Default Re: code 6 on a 1990 lx need some help (sacredc0w69)
a wrong and falty voltage reading from ect sensor could set a code.or ur ect is out of wack,u should replace it. is cheap
Old Jun 14, 2003 | 08:55 PM
civicboisi's Avatar
Default Re: code 6 on a 1990 lx need some help (im_the_teacher)
if this is the same code i had...
there's two sensor's on the head...next to the distributor i believe...check them to make sure they're not loose or unconnected.
Old Jun 15, 2003 | 12:44 AM
k i'll give it a check adn c what it turns out2 be
hatch96y7
May 7, 2007 03:39 PM
tjhogg1
Feb 14, 2007 07:32 AM
90da
Nov 6, 2003 10:15 AM
SpoonPL
Sep 27, 2002 07:39 PM
