View Full Version : Honda Accord (1990 - 2002)
- Got in an accident - What do I need to replace?!
- honda accord motor swap
- PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!
- 94-97 Accord V6
- Front Disc Brake Rotor Replacement - OEM? & Aftermarket?
- NSX brake caliper swap.
- Some EGR disabling questions
- '01 Accord Coupe: My Passenger Window doesn't go up all the way!!!
- rear lower bumper light pics...96 model?
- Signs of a bad motor mount??
- Water pump replacement guide/write for 91 accord DX F22A1
- Hit a curb, replaced LCA and radius rod but somethings still not right
- Manual Transmission Problem............EX
- replaced master/slave...months later no clutch pressure?
- strut tower bar
- 94 accord window problem
- '91 Accord Trouble
- hood problem
- 1999 Honda Accord V6 ?
- ATTENTION: TOURINGACCORD
- '93 Accord has no power above 3-4K rpm's. I'm baffled.
- Whats Good Boys and Girls! I Finaly register to honda-tech!
- Keyless Remote Part # Confusion
- 94 accord questions?
- 91 accord wants to turn off
- 92 Accord distributor dust cover
- 1990 Accord problem
- '97 Accord with H22A Euro R Gurgling noise...WTF!
- My 93 CB7 leaking way too much coolant!
- 88 accord lxi need help.. please
- Alignment shops in Dallas,Tx
- Got in accident - replacing parts - have a few questions!
- A/C gurus! Need your opinion/help!
- anyone running r crew exhaust?
- Accord 97 Problems
- motor mount question
- 91 Accord overheating when Idle
- honda accord ex oil dipstick tube
- 91 accord performance questions
- 90 accord ex is still overheating
- how do i adj valves
- adjusting 1989 Honda Accord Cable Clutch?
- 95 accord alignment question, please help!!
- taillights question
- Post your accord
- HELP!!!!! will a accord 94 lx cluster fit in a accord 97 lx car?hellp!!
- whats the part number for a 1996-1997 automatic EX ecu?
- 1991 Accord wandering/erratic idle
- 94 lx oil pump
- RADIATOR HOSE DIAGRAM?????
- Good buy race civic hello 2000 accord
- P1259 tried some stuff but still no fix
- coil question
- Where can i buy new seats?
- clutch fluid gone
- Factory keyless entry
- k24 swap
- Steering wheel squeak.
- Why?
- Help choosing replacement radiator
- 94 Accord with 2 problems and i need help!!!!
- location of fuel pump relay and eecu
- Having an issue where my car wont start
- Honda Accord LX 1998, P0420 Code
- 94-95 accord short shifter
- 95 honda accord BRAKE LAMP PROBLEM
- is it possible to do a valve adjustment with the head off?
- 98 accord ignintion switch
- help vtec/rpm problems
- new to hondas and ive got a ?
- help!!!!
- H22A OXYGEN SENSOR CODE 43 WON'T GO AWAY
- Lookin at a car. Want advice.
- Roll Cage for Accords
- Need help with replacing master clutch cylinder on 94 EX
- v6 accord mystery oil leak?! help
- gas question
- Best way to seal broken headlight?
- Heater Blowing cold air
- 2000 accord fuse
- 1994 Accord EX auto rough idle - stiff gas pedal... please help!
- Weight of the 94-97 Accords?
- megan muffler
- Door Lock Relay
- automatic to manual conversion questions....v6 98-02
- sohc broken cam - no oil press ?
- 6th generation accord ex 4cyl headers & intake
- headlight question...help!
- Engine Flooded, 92 Accord
- 90 accord wit a 95 accord ex swap check engine light!!!!!!!!!!!!!
- H22A Swap 90% complete but not starting?
- Installed: AP1 S2000 Steering Wheel
- Upper control arm hitting
- Vibration at 1800 rpm and under braking ('95 wagon)
- Sqeaky noise when I start the car
- Timing Belt Repairs
- 94-97 Accords: Original A/C compressor & charge or NOT? Still Cold?
- Wideband / VAFC
- Question about raising the front of my 95 Accord a bit.
- are the ex and lx TCU the same for 96-97?
- Quick h22 knock sensor question
- what conversion harness
- Major Squeak in Left Front 01 Accord
- intake
- Changing Brake pads
- 5th Gen Accord Bilstein Shock Install and How To - Lots of Pics
- Question on Tranny fitment
- question about stock radio
- D4 blinking and car keeps turning off
- Anybody know the diameter of the Accord clutch master cylinder?
- Tranny: Cursed or Not?
- LX to EX sway bars
- Oil light flashing
- Keyless Entry Control Unit for 96 Accord
- headlight prob.
- EVAP system code 1457
- can someone give me the correct part numbers for cap and rotor on a 97 f22b1
- ECU "Reflashing/Chipping" questions....
- honda access trash box .. picture installed in car
- Help on 94 accord radio /head Unit
- Ecu question
- Need help with my 90 accord
- 90 accord wit a 95 accord ex vtec swap need help
- 95 HONDA ACCORD NEEDING INFO HERE!!!
- door sensor
- 98 Accord EX/Sed Stock Alarm Question.......
- 93' accord motor swaps?
- Braking Questions
- Flooded motor
- whats worth taking off an EX to put on aan LX?
- Need Help on A/C Replacement
- brake/clutch pedals different distance from firewall?
- Hello, New to site and have a tranny Q
- ABS Light (intermittant illumination)
- Fully Loaded? 96 Accord? What does it mean?
- Spark Plug Tube Seal (pic)
- Front Seat Swapout
- Interior Lights
- just bought a parts car.. want to get it running
- will a 5spd ecu work for an automatic?
- Buying 98 Accord EX - Timing Belt advice needed
- 2000 Accord Auto transmission slipping
- tried looking
- the bolt under the steering knuckle dont come off!!1!!11!2 (6th gen)
- Heater Matrix
- Rust a common problem with older late model Accords?
- 1997 EX door handle
- Just bought a 1994 Honda Accord LX, need some advice !
- '97 Accord with H22A Euro R no idle Need help!
- **n00b alert** will 93 civic coilovers fit on a 95 accord?
- Question about 1992 Honda Accord EX
- Radio Code Problem
- Windshield washer tank
- skunk 2 throttle body question
- Does the 90-97 Accord Hub Removal Tool Work on Other Honda's?
- Tein S-Tech?
- 90 accord swaping in a f22b1 v-tec i got some Qs
- 99 accord o2 sensor
- Brake problem....
- click click click click
- Problems with clutch?
- Window switch Or Window Motor?
- weight reduction
- Mystery Smoke Coming From The Hood.
- Stainless exhaust w/ baffled muffler
- speedometer somtimes doesnt work and stays at 20 mph? help!
- Speedometer and Tachometer, electrical problem?
- Any recalls for a 96 Honda Accord LX
- adding a tranny cooler..
- Intermittent Oil Light Flashing
- Help with 99 accord coupe clutch adjustment, any help?
- cam shaft broke need serious advice
- headlight bulb removel
- 99 3.0 V6 EGR Questions and repair
- Idle issue
- Transmission mount - Help please
- Aftermarket Upper Arms
- Touch up paint, which types do I need?
- 95 Honda Accord Coolant Flow Direction
- what size are the rear brake rotor set screws? 98 4dr Ex
- 94 Accord Suddenly Dies?
- Honda accord 2000 LX wont start
- popping sound from the gas tank.
- digital a/c heater question on 98 accord
- TSX rims on a honda accord ?
- People with Tein Basic on 98-02 accord have a question
- cb7 emission issues
- Very interesting problem.
- will honda still honor the emission recall on 5th gens if the heads are swapped?
- need help car is idle surging...
- Please Help!! Local Mechanic Needed
- Christmas day problem......
- looking for acura cl-s tranny and engine??????????
- ***93 accord f22 transmission problems***
- 94-95 lip on a 91?
- Intake/Exhaust Options for a 1998 Accord V6 4-Door?
- Rev Limit ??
- help with ecu for '95 accord
- 1997 accord-hesitates
- What is leaking oil all over the driveway
- 2000 Accord stock CD Changer malfunctioning
- problem with gauges
- are 90-93 ex rear subframe, hubs, discs, suspension, sway bar ect the same as 94-97?
- intermittent squeal/whine after timing belt/water pump change
- ***Window Visors***
- Turn Signal Problem
- 91 accord timing belt tension question
- Anyone know the torque specs for a power steering pump housing?
- 98 accord problems---need help
- CB7 Speaker size please!
- My aCCORD vTEC... need Info on it..
- Can I slide out distributor to replace o-ring?
- f22block with f23 DOHC head??
- Axle bearing noise
- swapped the f22 back in
- 5 SPEED CONVERSION
- smoke coming from engine and blowing through ac vents as well...aaahhh
- dashlights and rear tailights
- 98-02 accord engine bay and 97-01 prelude engine bay question...
- engine RPM's @ 60mph/does 2600 sound right
- MY IDLE GOES UP AND DOWN AFTER THROTTLE BODY CLEANING
- brakes issue need help
- 92 h22a into 96 ex accord, stuck in safe mode with o2 problem please help.
- RETRACTING SEAT BELTS NOT WORKING
- good clutch for setup?
- ATTN: MUFFINMAN..
- Where's my horn relay or fuse (1990 Honda Accord Lx)
- Window
- Honda Accord ignition problem!!!!
- Good place to buy exhaust
- 2002 Accord EX ULEV - Trasmission
- Question about shock absorber replacement.
- CD5 Headlight wiring screwed?
- thermostat location...mixed results
- Some bigger ideas?
- Sandy grinding noise coming from steering wheel ... what does it mean???
- Headlights out?
- Just got a 94 Accord - HELP ME PLEASE!
- 1990 Accord - wiper fluid motor not working
- 01 Honda Accord vibration during acceleration
- 97 v6- tach is bouncing around and other issues
- Ebay turbo kits??
- '99 Accord 2.3L EGR bench test
- 99' LX Accord E-Brake Handle Cover ....clueless and lost here.[pics inside]
- will an h22 distributer work on an f23?
- Tire size
- Gas Tank problem
- why cant i participate in some of the sub-forums here?
